View Full Version : Shovelhead
- frame
- Possessed 75 Shovel Fxe
- Best dual exhaust for a 74 FLH
- 81 FLH Hasn't been started in 7 years
- 82 FXS Starter won't turn over motor
- Breather
- plugs fouling
- I want to change my stock carb
- 1983 FLHT front cylinder lifter clatter
- J&P Cycles,,,Dash kit
- spit and sputter
- SPEEDOMETER RESET CABLE #67210-73,.. what size is that NUT!?!
- Belt drive ??
- Quick questions about idle and such
- Derby cover
- tapping with a little smoke
- Enclosed Chain Drive to Belt Drive
- Wadda ya think it's worth?
- real crappy at low revs
- keihin to cv
- 1983 flht
- Extended cables and lines
- Bike cuts out.
- I'm just sayin'... (rant)
- Rear tyre
- engine runs zero comp. rear clyinder
- Favorite online parts source?
- 1975 FXR Shovel low miles
- motorcycle carfax
- Keihin Float Bowl O Ring
- Axle size of 83 FXR?
- smoke coming from vented primary
- Finally got her running!
- Runs for 2 mins then quits
- Shifting
- Are shovelheads dinosaurs now?
- looking for torques for 66 shovel
- oil leak Rocker box
- Hi, Im new and need some help
- Has anyone else got a "rat"?...
- check ball
- Keihin Carb Rebuild
- differences in primary covers
- '82 fxr
- intake leak
- slider seat for shovel
- 67shovelhead tranny oil change
- belt
- oil pump rebuild kit: lock ring question
- FXE Front Brake Options & ignition question
- Riding,,Finally!!!!
- Pushrod tube wont stop leaking on my shovel
- Old '73
- 1980FX Starting Problem
- kicker stuck
- shovelhead starting problem
- instructions
- whats bent
- New Clutch and belt drive
- Ignition coil
- is something bent?
- both tail light filiments on?
- inner primary
- S&S B carb adjustments
- Oil Stabilizer?
- Aftermarket gas tanks
- Starting problem
- tranny plate
- 19" Front Wheel on an FLH
- oil problems with 78 shovelhead
- Swing arm pivot shaft
- 1977 FXE Fork tube question
- Wiring
- 2 place seat for '70 FLH
- Bearing Housing Retaining Plate screws
- bent valve rear head
- 77 fxe front end
- Need help with brakes!
- 1966 FL: Frame Year Code Die Size
- Looking for information for sidecar
- charging system ?
- Rear Disc
- Swap meet in Portland, Or
- need a 21" wheel for my 73 flh
- reproduction tank 67 FL
- stroker plates
- Oil Overboard
- 1966 fl
- '81 FLH Conversion- remake- thoughts? Pitfalls?
- throttle cables
- 38mm mikuni vm
- flt came to life
- Binding clutch cable?
- Sealing crossover pipe on 72 FLH
- voes
- 82 shovelhead lowrider
- Running hot
- belt drive and clutch
- lukas synthetic 50wt yes or no ?
- Help
- high idel
- Help
- Sprockets - Tech Tip - Determing Final Gear Ratio
- 81 flh
- sprockets
- value of a '66 FLH?
- WHY IS CLUTCH BASKEt LOOSE
- tank size on 67 flh
- solenoid and ?
- Sprockets !
- carbs
- camshaft identification
- My 79 FLH
- Inner primary
- 79 vin. #
- Clutch Problems 74 74ci
- S&S E carb on 1340 shovelhead ?
- Help with identification (VIN)
- 1967 flh clutch problem
- trans sprocket
- new, & getting back, diehard old school man
- Cant figure out what my model is? Can anyone help
- 1980 Shovel
- Sold 81 sturgis !!!
- Might be joining the Diggers club.
- 81 FLT Classic
- Anybody out there?
- Speaking of compensating nuts...
- Rear Frame Section
- 1980 shovelhead points setting
- 1980 fxs shovelhead won't start
- Shovel compensating nut size
- 69 Paint Schemes
- 4 speed problems
- 4 speed tranny rebuild problems
- Spin On Oil Filter Conversion
- "Please allow me to introduce myself..."
- '69 flh
- Noisy Brakes
- 77 fxe
- Turn Signals 1984FLHS
- bad clutch or Tranny?
- Speedometer History question....
- 1980 fxs low rider oil pump problems
- make it simple
- crane Hi4 single fire ignition
- '69 FLH #'s
- New paint before and after
- 1983 speedometer rubber mounts
- Question on 67 FLH
- 1984 FLH -- starter does not turn
- 75 FXE voltage regulator question
- 77 shovel normal oil pressure
- 1978 shovel cant get to run
- clutch Fingers
- 81 FLT Chain cover issue.
- '81 Sturgis clutch
- 1983 FLT seat question
- Carb?
- Shovelhead Road Kit
- 72 FLH Trans
- starting problem
- 82 sturgis
- Looking to buy a shovel
- Crane Hi-4E in a Shovelhead?
- Polished rotors
- 76 Shovel clutch hub removal - how?
- light problems?
- primary belt drive
- 77 fxe shocks
- 82 FXE Mainshaft seal
- Cam ID
- Polish & chrome
- 1983 FLH starter problems
- New bars
- Inner primary bearing
- 74'' with .60 over pistons?
- 1977 tour pak, do these have any value?
- new bars
- Used triple Tree issue
- Switching gas tanks...Maybe...
- Need help/lever action start
- the correct muffller
- neutral switch threads in tranny cover stripped
- Carbon
- cam
- 77 fxe motor
- Sturgis rear wheel fitment help needed
- Compensating Sprocket Nut
- been looking at a 1974 electra glide
- width of triple trees
- Cam for 1980 80" FLT
- Spark plug question
- Need advice on cases/oil pump
- Batwing Repo's??
- Trying To Start A Nine Year Sitter.
- Original Grips
- '74 FLH needs new battery. Which one?
- Spark plugs for 82 FXR
- Shovel starter, major PITA
- displacement?
- 79 Electra Glide Windshield
- Dual disc forks...??
- 1984 hd fsb
- Would an evo engine bolt right in to a 82 fxr frame?
- Old shovelhead?
- Frount Break Switch
- 1979 derby cover
- And we're off again .....
- finned tranny case
- 75 flh update to belt drive
- Kick starting
- Need help with model ?
- new pic
- Shovelhead rebuild, let the fun begin.....
- New member with a burning question!
- Quick Release Ball Lock Pins?
- CV
- Considering buying a shovel with a mystery frame
- CV Carb Adapters
- CV carb adapter
- TwiZted Biker...
- 103" Shovelhead video
- Which forum would you use?...
- Any reason why...
- how long can you ride a shovel
- Oil Temp/Pressure trouble
- best guess on hp/tq without dyno
- No juice to starter when i push button
- Oil question
- No oil pressure
- Need a place to start
- tach wiring
- Starter "kicking back?"
- How far to go
- Rhetorical question
- Back of primary leaking
- Shovelhead Identification
- if buying a complete motor - which one?
- Oil blowing out breather hose
- Oil cooler nessary?
- Oil hoses tank to pump
- kickstart
- Axtell 3.812" bore cylinders
- Carb adjustment/blue flame out of exhaust
- How do you identify an Andrews cam?
- 82 FXB Sturgis.....deal or moneypit?
- Oil leak. Please help me out!
- frame?
- Front cylinder ticking
