PDA
View Full Version : Shovelhead
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32
  1. New style Forks in an 80 FLT's trees???
  2. Oil on spark plugs
  3. Help with tranny oil capacity.
  4. question
  5. Timing problem
  6. What are????
  7. 74" with 80" jugs
  8. 78 FLH won't stay running.
  9. suicide shift
  10. 82 Superglide!
  11. front sprocket, recess in or out?
  12. 1976 shovel 4 speed
  13. '79 1/2 Lowrider
  14. Excitment
  15. starter problems
  16. 76 super glide
  17. Temp diff between front and rear Cyl
  18. 86 shovel S7S super B?
  19. Just bought my first shovel - 1983 FXDG
  20. Wrecked 82 shovelhead
  21. Why do shovels always need a top end?
  22. sprocket
  23. 78 fxe inner primary
  24. 1978 1/2 FLH Parts manual or CD
  25. Runaway Starter
  26. clutch rattle
  27. wanted: exploded view of lifter
  28. Just Got 'er Done
  29. FXE Shovel Head Shakes?
  30. carb tunning help!please!!!
  31. cv carb float adjustment
  32. FL to FX battery switch...
  33. Controls and floorboards
  34. Oil Breather tube
  35. 1975 Super Glide HELP!!!!
  36. My '75 shovel
  37. circuit breaker
  38. I'm getting a shovelhead!
  39. 76 FLH questions
  40. FLHT fuse box
  41. 69 shovel ignition point eliminator
  42. 79 Shovel Help
  43. Electric start problem
  44. Low fuel in filter
  45. 73 shovel somebody please help me
  46. tach jumping
  47. trans oil
  48. 1977 fx i need a wiring digram
  49. The Bride of FrankenBike Returns...
  50. 1980 mfxs swing arm
  51. 1983 fxr transmission top cover oil leak
  52. fork oil capacity
  53. Clutch noise
  54. New front end old front wheel
  55. need some advise please
  56. newbie-what to check when buying
  57. Quagmire...kinda long
  58. changing fork seals on a 1974 fxe
  59. What model is it?
  60. FLT Tour Glide cruising speed
  61. Primary Chain length ?s
  62. rod bushings
  63. How the heck do I get my trans out of my 72 FLH?
  64. Wiring harness
  65. 79 fxe ignition timming module blown
  66. Best under $100 modification for me yet!
  67. Shovelheads, high maintance???
  68. Shovelhead clutch
  69. 1984 Shovelution....
  70. Front end question
  71. Advice needed Please.
  72. 1980 flh 80
  73. Police special
  74. 1975 Paint Formula Needed - Help the new guy...!
  75. cowpie or rachet top
  76. How much oil, and what weight
  77. 73 shovel droppinf front cylinder
  78. Lifting gas tank
  79. Salvage Nightmare...
  80. 80 flt blow buy
  81. 80 flt blow buy
  82. FXS 78 - Highway Pegs
  83. s&s carb on shovelhead
  84. exhaust studs or bolts
  85. Red Saddle Bags....
  86. To Buy or To Repair...that is the Question!
  87. carb issues
  88. Thanks to everyone who recommended Monster Ovals!
  89. 81 fxwg info needed
  90. recognize this oil filter/cooler?
  91. What should I look for?
  92. 78 fxe compensating sprocket nut
  93. oil puking thru crankcase breather?
  94. Harley Davidson Exhaust. (SLIP ON)
  95. 78 fxs
  96. ?what carb is this
  97. carry over / wet sump ??
  98. '82 flh backfiring
  99. Cylinder 1 Popping out of carb under idle...suggestions?
  100. engine oil temp...'80 FLH
  101. Compression 125 Front, 0 Rear. Just Rebuilt. Please Help.
  102. Rocker shaft end cap bolts, and various other oil leaks.
  103. 73 spotster generator problems... help!!!
  104. Last 1984>First 1985 Shovelheads
  105. Will 91-up hypercharger fit on my shovelhead?
  106. Showa 35mm fork seals leaking
  107. 73 shovel kicker only dont want to start
  108. How to price a 1969 shovel
  109. 78 Shovelhead Trans leaks
  110. Recommendations please!!
  111. Tire size
  112. Please help me fix my shovel
  113. 77 Super Glide Won't Run When Hot
  114. FLHT seat
  115. Saving Money
  116. Wanted !!!
  117. starting issues
  118. intake manifold
  119. I cant sell my shovel
  120. engine clunk, front cylinder
  121. Info apprciated
  122. Running, Rode It, Not Running, Issues...
  123. s&s 80 shovel carb info
  124. transmission oil level
  125. big twin timing trick
  126. 1978 shovel 1340
  127. 6 pole ingnition switch.
  128. not on my OLD scoot!
  129. what the F@#k!!! S&S super E
  130. Shovelhead cone left case
  131. Newbie buying a Old 80 Shovel FXE
  132. 85 sportster rear wheel
  133. lost oil pressure
  134. back brake light switch mount???
  135. HD Shovel crankcase part numbers, anyone?
  136. 73 shovelhead hard starting
  137. Question about an old FLH shovelhead
  138. need more light
  139. 1973 Shovel Electronic Ignitian Conversion
  140. 82 fx neutral light
  141. 28 FXWG starter
  142. 80" flywheels/74" pistons
  143. Gas in oil
  144. 1980 Shovel misfire.
  145. 79 Shovel Electical Bug
  146. shovelhead starter drive
  147. need transmission
  148. question on 2 into 1 pipe.
  149. primary chaincase vacuum
  150. Oil cap broken?
  151. Keihin float bowl gasket issues
  152. shovel head mileage
  153. More Shovelhead
  154. Questions for pococj
  155. ok this may be a dumb question....
  156. 82 fxr, and I have a few questions...
  157. Help...Questions about my 1983 FLHT
  158. trani
  159. need special tap
  160. Oil/Filter questions
  161. new shovelhead-- acutally first ever harely
  162. 81 FLH clutch handle
  163. First rebuild
  164. Oil pressure gauge
  165. 67 FL info
  166. Picked up a flyscreen...
  167. Speedometer drive for rear wheel??
  168. 1980 shovelhead misses at idle
  169. Keihin rebuild kit - who makes a good one?
  170. what kind of carb do i have
  171. '82 FXE for sale
  172. some bikes and a Liberty build.
  173. 79 Shovel Electrical Problem
  174. 79 Shovel Crankcase breather pugged off???
  175. clutch pressure plate angle
  176. poping thru carb
  177. carb bracket
  178. Help with Dyna 200i-p install
  179. wont start...throttle dont work...crap
  180. rocker box chrome line kit V-Twin 40-0180
  181. Need advice please
  182. Exhaust Bolts
  183. Exhaust gasket
  184. shovelhead rubbermount question
  185. Same old shovelhead primary question
  186. what kind of gaskets?
  187. Police air seat on my Shovel.
  188. 4 Speed Trans question
  189. 84 FXSB neck angle
  190. Found a small weld on crankcase????
  191. new build
  192. Only one cylinder working???
  193. Transmission Whining
  194. Kicker Issues
  195. shovelhead carb question
  196. where is everyone?
  197. shovel head starter problem or solanoid
  198. shovelhead exhaust issues
  199. Looking to buy shovelhead
  200. Exhaust power cones
  201. 79 fxe front end question
  202. Will a Corbin Solo Seat for FL fit an FLH
  203. Crane Cams...Out of business :{
  204. Solid lifters
  205. Hard Starting 82FXR
  206. 1973 Shovelhead
  207. rewiring a 73 FLH
  208. Kick starter is not engaging - what to do?
  209. Lean Angle?
  210. Swap Meet, Humble TX
  211. sneezing shovel
  212. Encased final drive chain
  213. Carb suggestions for a '66 shovel?
  214. NO Compresion in cylinders...
  215. shovelhead pushrod cover leak
  216. 83 FLHT front springs and rear shocks question
  217. Shovel identification help
  218. manual to hydraulic clutch- 4speed
  219. Later model wheels on an '81 FLT
  220. chain primary
  221. Customizing my 83 FLHT
  222. Want it lower...
  223. need help...my first top end rebuild
  224. need help...my first top end rebuild
  225. Power
  226. 1980 fxwg
  227. a problem with shocks/studs fitting
  228. 1980 5 speed
  229. 1966 FLH Restoration Project
  230. 80 FXS grinding problem.
  231. 1980 Wide Glide
  232. Front fender... yes or no
  233. Frame tab...
  234. Pix of your shovels....
  235. Looking for original '82 FXE exhaust.
  236. shifter problems
  237. to too many shovelhead threads i see
  238. Lifter block won't come off!!
  239. Anyone running LePera Bare Bones seat...
  240. Tips on Shovel Intake Manifolds
  241. How Much Oil Does a Shovel Use?
  242. '78 shovel electrical fault - a weird one...
  243. Length of exhaust pipe
  244. anybody running syn. oil
  245. 75 1000CC Shovelhead
  246. Old tank medallions
  247. fxe wheel interchange
  248. cure for adjusting timing problems
  249. MAINSHAFT SPROCKET -22T or 23 T.
  250. MAINSHAFT SPROCKET -22T or 23 T.
