- Looking for original '82 FXE exhaust.
- shifter problems
- to too many shovelhead threads i see
- Lifter block won't come off!!
- Anyone running LePera Bare Bones seat...
- Tips on Shovel Intake Manifolds
- How Much Oil Does a Shovel Use?
- '78 shovel electrical fault - a weird one...
- Length of exhaust pipe
- anybody running syn. oil
- 75 1000CC Shovelhead
- Old tank medallions
- fxe wheel interchange
- cure for adjusting timing problems
- MAINSHAFT SPROCKET -22T or 23 T.
- Who Needs ForceWinder Air Cleaner
- Anybody running these pipes... FilthyLucre would love your opinion
- balanced shovelhead
- 500-16 firestone deluxe champion blackwall tire
- How to tell if oil outlet is lubing primary?
- Keihin Carbs
- I want to change gaskes covers cylinders
- Help on a top end question
- Bike missing
- pushrod tubes
- Quick question re: my FXRS
- Brakes
- early or late '79
- New here...Old pics 1974 SuperGlide from Iron Horse 105
- Getting rid of the belt final drive
- 1980 fxe kicker shaft replacement
- Need parts number
- forward Controls
- Top end rebuild
- Need some parts 75 shovel fxewg
- handlebar advice
- 79 shovel with adjustable lifters
- Researching shovels. Seeking advice
- fatbob tank mounts
- Just Curious
- Electric starter not working
- Converting kick only to electric start with 3" open primary question..
- Burnt bike
- 64 generator
- 1980 fxb
- Can anyone help me identify?
- clutch woes
- 5 gallon VS 3 1/2 gallon tanks
- 83 FLHT rocker box removal
- 78 1/2 FL Drivetrain vibration
- Shovel won't start
- stator question
- Shock question
- 1983 Shovel Head 80 in Remanufactor
- new tank mod?
- 71 clutch removal problem.
- 71 FLH starter relay
- Intake question?
- Kickstart/Tranny question
- tranny issue
- FYI new shovelheads
- Primary chain noise
- Exhaust popping
- Question about lifters!
- nedd help changing 82 fxe front end to fl
- seating rings
- got a leak (oil)
- Pressure testing gas tanks
- more newby shovel advice
- shovel problems
- What type of mods can be done to a 80" shovel?
- Need advice on exhaust bolt
- 1977 flh
- Stem Neck Bearing Removal
- would you shed some light on this subject for me!
- How much $$ for a 4 speed transmission
- 77 fxe super glide (74 c.i. Shovel)
- Runaway Starter!
- Lowering a scoot...
- Bastard FXEF
- Confused with my FLH
- Super Sport FLH
- 72 FLH electraglide trans. sprocket seal - special tool required?
- belt drive inner primary...oem pt #?
- Bike not mantaining electrical charge
- What upgrades/updates to a 78' lowrider?
- help
- crank case breather
- Front wheel and straight tracking
- Sifton lifter blocks Warning for generator engine!!
- re wire
- Engine Guard/Crash Bar Question?
- Spedo cable
- The Chopper Roars again!!
- 1978 or 1978 1/2?
- Front wheel hub cover question?
- Finally a picture of the chopper!!!
- crankcase breather location
- inner primary cover
- S&S Carb
- generator removal ?
- where can I buy pre-painted tin parts?
- Copper oil lines
- Stock Solenoid Starter Switch
- need help checking clutch adjustment
- quick question about 73 shovel
- sealing off primary, and need help
- Anybody running Gimp Hangers...
- Help!
- Supergilde Tires
- Avon Gangster MT90H16 71H
- 4 speed kicker
- Points settings and Keihin carb
- Help picking a carb
- Tons of Shovel pics...
- Where are all the posts?
- Shovelhead Gurus
- Loss of power
- 79 fxe bagger
- Dual Exhaust Change
- Passenger Board Mount for '81 FLT
- 73 FL clutch trouble
- jockey shift
- 79 Shoveldead
- saddlebag rail question
- 1981 fxsb
- Popping while accelerating
- single fire
- '72 shovelhead ignition problems
- sportster shovelhead
- HD Forum Newbie
- 83 flh need oil line routing diagram
- Starter Issues
- Photo of My 69 FLH
- 1982 FXR Superglide II
- whats this bike?
- Electric start conversion...
- 1979 FLH bendix problem
- Question about my 83' Shovel!
- ultima thunderfire starter
- Belt Primary on a 1981 FLT 5-speed
- 68 flh
- Need pics of unmolested 81 Fxb
- Gas cap help....
- shovelhead exhaust gasket alternative?
- upgrade to 6 speed
- Welding Shovelheads
- CV on a Shovel!
- Am I back?
- Shovel/Pan friction discs: half disc
- evo valves,guides,and seats in shovel cyl heads
- Crane Electronic ignition
- Forum looks great!!!
- need help with new problem on '71 shovel
- psi big air carbs on Shovel
- 83 Primary belt problems. HELP!
- throttle question
- 1980 Sturgis stickers & owners manual
- voltage reg.!!!
- rear wheel alignment
- Shovel Trouble
- Riddle for the Wrenchers
- Stock or Not
- 02 Duece Oil Lines
- new to forum
- 1983 FLT
- electrical boggle
- long haul Panhead advice.
- HELP with service
- Way to fix a oil leak on the crankcase
- mixture screw on CV CARBIE not working
- Saddlebag Gaskets
- carb tips for 53 pan shovel?
- Won't start
- Shovelhead exhaust?
- Small size battery
- Adding a oil cooler to a 1979FLH
- Starter relay question
- Oil cap leaking
- horseshoe tank & electric start
- Seats for 78 shovelhead flh
- Primary oiling newbie questions
- 79 FLH kicker cover
- 72 Shovelhead
- fork oil capacity
- Good Chrome Shop?
- clutch wet dry
- Kick Start problem
- Need OEM Part# for FXDG
- 84 FXEF Fat Bob w/35k, $5000.00 good buy? Need Info.
- Normal oil consumption??
- solid lifters
- Cant find VIN on 82 engine
- Best 3" belt drive 1972 Shovelhead
- my 1984 custom shovel for sale
- My 69 FLH
- Help with a 71 fx restoration
- 1982 comemerative issue Low Rider
- clutch problems
- revised plee for help
- timing a 1967 electraglide
- Freaky Electrical Stuff
- A friend needs help
- good aftermarket FLH shop manual?
- Just Inherited the ole mans
- regulator?
- Super B questions
- carb or something else?
- So the restoration of a '71fx shovelhead begins!
- 1981 FLH
- Flathead Engine to Shovelhead Frame
- SOLO SEAT.....
- Cleaning
- dry clutch oil?
- What tools are needed for refurb
- Towing the Hog
- Chain oiler guard replacement???
- push rod tubes
- Stock vs. S & S Super B
- shovelhead running
- Installing rivets
- Where do I find part numbers?
- going thru coils
- 4 speed tranny oil
- swaping wheels
- collector plates
- Want a 1971 FX service manual
- Carb and starter housing.
- 78 FL, Fork chatter-vibration.
- shifter linkage
- I'm sorry, I just can't deal with this tank anymore....
- carb info.
- Whats this worth?
- Burning hole in points
- help!!!! no brakes 3 days to laconia
- 1973 super glide not run for 5 years or more
- 1979 fxs jumping at low speed
- engine torque plate
- New Shovel
- thunderheader tuning problems
- old gasket
- 1984 FLH-P
- maytag 4 speed vent
- Head gasket leak
- Squish pipe exaust?
- vapour lock on 78 FLH?
- starter part number
- BAFFLES OR TORQUE CONES?????????
