PDA
View Full Version : Shovelhead
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33
  1. 1979 FXS Clutch ?????
  2. 73 ratcht top %#@!
  3. 1978 1/2 fxe value
  4. 73 Shovel Head..
  5. winter/summer/fall project
  6. 1972 FLH shovel
  7. Shovel top end noise
  8. 1972 FLH shovel
  9. Fx transmission
  10. finally, 66 shovel motot
  11. updates on my generator shovel
  12. 1984 FXEF Russian Roulette
  13. Shovelhead 8mm or 11mm Primary Belt Drive Recommendations
  14. Sifton 102
  15. '78 belt drive on
  16. alt replacement
  17. Need Help Trying to static time 70 FLH
  18. 78 shovel timing
  19. Opinions on What to do
  20. 78 Shovel questions?
  21. 9 hole primary on 78
  22. Transmission
  23. 1982 shovel
  24. Leaking oil thru Breather-HELP !!!!!:icon_toast:
  25. How can I like my shovel?
  26. BAND STYLE INTAKE MANIFOLD SEALS 1983 FXWG / Super E
  27. 84 shovelhead solenoid plunger shaft
  28. Starting troubles
  29. 84 shovel solenoid plunger shaft roll pins
  30. Shifting
  31. designer shovel outer primary or scrap?
  32. Five speed in a four speed case with kicker .
  33. Shovelhead burning oil.....
  34. 1972 shovel problem
  35. Can I get a stock exhaust header for a kickstart FLH?
  36. obsolete manuals
  37. Buying a Shovelhead - what should I look out for?
  38. Passenger peg brackets
  39. 4-Speed Kick & Electric Shift/Release Lever Shaft Freeplay
  40. Shovelhead Chain Final Drive Sprocket Advice
  41. Hey twizted
  42. Shovel hardtail frame brand?
  43. Hard Shifting
  44. dead battery
  45. 71 FLH replacement Hand Controls
  46. Harley 1976 model ID?
  47. custom shovel
  48. 82 FXR Shovelhead questions
  49. easy pull clutch..
  50. Tamer ? And number of clutch plates
  51. Clutch retainer
  52. PITA trying to remove Shovelhead Inner Primary...
  53. losing sleep need advice
  54. Verify which wheel I need to be working with....
  55. Locking the engine
  56. looking for fxb starter housing
  57. Pushrod adjustment and advice needed!
  58. Shovelhead rigid frame? FL,FLH,FX, Electra glide etc etc
  59. Shovelhead build
  60. hard start and low idle problem
  61. 81' and ratchet top
  62. 1983 FXRS Shop manual
  63. oil level ?
  64. 82 shovel belt drive conversion
  65. 1979 Lowrider Shovelhead Full Re-Build
  66. fuel reserve capacity ?
  67. S&S super E: 74" setup
  68. Modern Controls and taller drags?
  69. what cam cover # for 72 Shovelhead
  70. 4 speed tranny speedo
  71. Sidecar value?
  72. What will these fit on...
  73. 76 FLH Brake Light doesn't work with front brake
  74. 74" starter solenoid
  75. 74" starting problems
  76. No spark ,77 fxe,compu-fire
  77. Time to dump some money into the shovel...
  78. This carb for my 1976 shovelhead?
  79. Fatboy Wheels
  80. transmission stuck in 4th gear
  81. Shovelhead differences to look for a bobber project
  82. 1980 FLH Shovelhead questions, what to look out for?
  83. Idle back fire??
  84. Shovelhead has me and my dad stumped
  85. shaving heads to raise comp
  86. 4 speed blues
  87. 1985 Shovelhead
  88. brake line fitting on cailper to banjo conversion
  89. 1980 FX Low Rider
  90. Shovelhead Lifter Coversion
  91. Front end
  92. Dual Plug Shovelheads any advantage
  93. Generator light stays on!
  94. how to change the cam in a 1977 shovelhead
  95. What causes "Starter Gear" to go bad ?
  96. Need Assistance
  97. Full of Fuel
  98. 1984 FXSB Build
  99. 83 willy g
  100. Rear Engine Mounting Bolt Removal
  101. Front End for Shovelhead
  102. 1972 FL Front end one that will fit!
  103. No power past 60 mph?
  104. Pushrod adjustment question
  105. Clutch Hub Finger Broken Off
  106. On the fence...
  107. oil pressure switch: automotive alternative?
  108. Places in Tampa Clearwater area to work on Shovelheads
  109. mY sHOVEL
  110. 1980 Rubbermount motor in a rigid frame
  111. Early '78 Electra Glide
  112. Stubborn Shovelhead Cylinder Base Nut Removal
  113. 82 Sturgis
  114. What to do? Rigid, or fix up my swingarm bike?
  115. Me first Harley
  116. Rachet Top Jockey Shift
  117. leaking push rod tube
  118. Long Rides
  119. New Bars and Wrapped pipes on the Ol' Shovelhead
  120. help! no oil pressure
  121. Any way to repair a leaky gas tank mounting tab?
  122. The mistery on true duals
  123. 81 sturgis starter removal
  124. Clutch pulling and shifting problems....help
  125. Need FXR mid control advice
  126. Paint 1979 FXS Low Rider
  127. Oil leak
  128. Handlebar wiring
  129. Rear drum brake builds up pressure and won't release
  130. 74-74 flh
  131. Squeek !
  132. 4 speed works on bench not in bike
  133. Wide Glide forks noise problem
  134. Looking at shovel, need advice
  135. 4 speed tranny: 3rd gear issue
  136. Shovel head- Heads
  137. Helicoil Exhaust Port 5/16-13
  138. Factory service manual?
  139. rear head removal 1979 shovel
  140. Hylomar Advanced Formulation
  141. Kill switch - '76 FLH
  142. No Start
  143. 76 FLH 1200 shovel: reasonable offer?
  144. Need help with sheet metal for 1982 FXRS
  145. Need to sit farther back on FLH
  146. Ignition ptoblems
  147. gone with the wind
  148. Question concerning clthch retaining nut/shaft threads
  149. hard shifting
  150. clutch pushrod will not remove on a 79' FXE
  151. help
  152. Points or electric
  153. 1983 FLHT shovelhead
  154. toast 101
  155. 1977 FX dash install
  156. New To This
  157. Oil Burning on a rebuild
  158. 1980 FXEF Stock Parts?
  159. '72 FLH firing problems
  160. WTB white police solo seat 4 shovel
  161. High Back Seat
  162. 81 FXS Lowrider - dragging start
  163. For you guys with big motors
  164. Shovel questions
  165. Carb question
  166. all about spark plugs
  167. remember these???
  168. front brakes
  169. 82 FXWG rear rim question
  170. Shovelhead starter
  171. Lowering a 77 FLH?
  172. Pipes and Carb Help
  173. rocker cover bolts o-rings: replace
  174. 1983 Keihin: jetting issue?
  175. 78 FXE Carb questions
  176. cylinders fire unevenly cold
  177. Bolt Kit That Holds On Rear Sprocket To Drum Brakes On 72 FX...
  178. She won't down shift to first
  179. 78 fxs 1200
  180. speedo question
  181. Gonna have a busy winter!!
  182. 75 fx
  183. Easy Rider Tech Tips
  184. Where do I start?
  185. Hello
  186. speedometer_odometer
  187. Rocker switch headlight hi/low going bad often
  188. speedo drive
  189. holiday cheer
  190. Oil pressure gauge lost a - ?
  191. 79 fx clutch
  192. check out this shovelhead painting
  193. Headlight failing to light
  194. Shift lever
  195. Compensating nut 1979 FLH-80
  196. 103"
  197. back in the day
  198. Smokin Shovel
  199. 1983 FLHTC possible purchase
  200. Whatcha runnin in your cow pie?
  201. 74 Shovel Battery? Who makes a good one?
  202. Brand New Here 74 FLH 1340
  203. newb with a shovel
  204. warm motor no start
  205. warm motor no start
  206. Front forks
  207. Shovel Oil pump retaining ring
  208. Shovelhead starting problems
  209. Replacing sparkplug inserts
  210. Just found & bought my dream bike!
  211. Electronic Ignition
  212. no fire in rear cylinder
  213. Newb w/ a cable question
  214. Exhaust with a Baker 6-4
  215. 72 shovelhead motor ....hole in case
  216. clutch problem
  217. low compression, oil coming from vent line
  218. handlebars,,, narrow with pullback...
  219. 78 fxr rim swap with fatboy - ?
  220. 79' FXE stock front master cylinder size?
  221. Clutch Slipping
  222. 2 front heads
  223. can anyone tell me how much clearance is needed between the pistons and cyclinder
  224. son's tang
  225. wifes sporty
  226. 100" shovel
  227. rear chain
  228. pic
  229. 76' Shovelhead Super Glide needs lots of work..
  230. kicker help
  231. blowing smoke
  232. primary oil change 67
  233. Dual Point Test Light
  234. Unpleasant rumblings !
  235. Looking for Old school shop Indy area
  236. 79 shovelhead clutch
  237. frame
  238. Possessed 75 Shovel Fxe
  239. Best dual exhaust for a 74 FLH
  240. 81 FLH Hasn't been started in 7 years
  241. 82 FXS Starter won't turn over motor
  242. Breather
  243. plugs fouling
  244. I want to change my stock carb
  245. 1983 FLHT front cylinder lifter clatter
  246. J&P Cycles,,,Dash kit
  247. spit and sputter
  248. SPEEDOMETER RESET CABLE #67210-73,.. what size is that NUT!?!
  249. Belt drive ??
  250. Quick questions about idle and such
