View Full Version : Shovelhead
- 81 FXE Shovel
- Potentially Stupid Question on Cam Lift
- no spark
- Is this 78 shovelhead FLH worth the price? Quick responce needed!
- starting problem
- S&S diagram
- oil leak!!
- shovelhead noise!!
- 1976 Superglide..what to look for?
- Sealed Wheel Bearing Removal Help
- Restoring 69 FLH
- 72 FL exhaust
- front cylinder
- S&S help
- S&S Reed-type Breather Valve
- tranny problems
- Roller rocker's
- Speedo Drive Re-Location???
- Cough, power loss, dies @ highway speeds
- Fresh Build.. How Much Oil In Crankcase?
- Front Brake control
- '69 Shovelhead Custom
- will not start
- Trans-swingarm removal?
- Did I get ripped off on repairs?
- dies on deceleration <fixed>
- 82 FXRS build
- Buddy Seat Comfort
- lifters
- 78 Early / 78 Late ??
- another BDL question
- '74 shovel Super B & exhaust questions
- Banana Brakes
- Shovel front end
- Smoking shovel
- BDL BELT PROBLMES
- New Brakes...
- Historical Plates!!!
- Wooo Hooo!!!! She's home!!!!
- Shovel Cranking problem
- 77 4spd jumps out of first
- 1968 Shovelhead
- discovered new Sun-K11 belt drive here
- ignition gremlin
- trying to identify an old elecra-glide frame
- '66 FLH Tranny
- Relocating Passenger Footpeg
- introducing
- got a miss
- crank case vent
- Rocker arm shimming
- Timing, bolts, and other questions
- 4 SPD Cutch issues.
- 73 shovel kachunk/cough thru carb eng die
- baffles
- Clutch replacement 1979 FXEF
- My new bike! Late 78 FXEF (exhaust???)
- 77 FXE rebuild
- new FXWG 1982 rebuild
- throttle
- 1978 FXE UPGRADE
- Hand shift
- decoding 66 electra glide vin
- Need some opinions....
- leaking sprocket shaft bearing insert???
- 77 glide
- I finally got my Shovel !
- Always wanted a shovel.....
- 1968 Hydra Glide
- did i fry my electronic ignition?????
- Another leaking shovel
- WHAT SHIFT PAWLS GO IN RATCHET TOP??
- Gears?
- leaking motor sprocket shaft seal
- Front End Question
- '77 clutch shudder
- Shovel for a first HD?
- 1977 FLH
- NOS 1968 Rear Bumper
- Instrument bulbs change out
- NEED HELP !!
- [Deleted]
- Dead speedometer
- Hey all, dumb question for you.
- Shovel noise
- valve seals
- Pic's of dresser's with a kickstart?
- Oil Pressure ?
- whiney noise on 72 shovel after rebuild
- lifter noise after intial warmup 81FX
- Old AMF Brochure
- Great website for shovelheads
- 2007
- Clutch and Frame questions
- Merry Christmas
- 2-1 exhaust
- Is this hole suppose to be there?
- Factory photo
- S&S engines
- clutch hub removal
- FXE CHAIN ADJUSTMENT
- 1980 fxs shovel
- s&s carb. setup
- primary housing take off 78 flh
- What's the difference between a 72 and 73 front wheel?
- Value of 1970 Shovel electraglide with "ASM" Title
- top end
- New Guy
- electra glide trouble
- HEAD TORQUE
- 78 shovel blues
- original pictures
- Solid Vs. Hydraulic Lifters
- decal
- adding Slipons and no sert?
- clutch/wiring
- air cover
- carburator
- lowering kit
- JETS?
- Fishtails
- S&S Heads?
- disc conversion, early shovel
- ragman
- Parts Manual
- Cross over pipe
- Just Checking
- PICS?
- Upsweep pipes for Shovel?
- What year is my Shovel motor?
- hard to start!!!
- New member also with pipe ????
- Shovel Pipes
- 17X4 on a Shovel
- solenoid?
- 79 shovel hard to turnover
- Horrible primary rattle!
- Early or late model???
- what to with my 68
- front primary sprocket
- FXEF Stock tank decal
- 76 shovel - idle hangs high and slowly comes down
- shvelhead won't start
- Lifter Question
- Individual rocker box oiling
- 77 FXE Breather Gear O.D.
- FXE Shifter
- Open Primary Suggestions
- Top end help
- shovelhead spyke starter for sale
- top end help
- Whats the deal with these spark plugs?
- Won't Start
- disregard
- cleaning house shovel parts
- rubber mount tanks
- Help Re-installing my kicker cover
- Oil pump leaks...
- compensating sproket nut
- problem with speed
- Buying a Shovel??
- It dies!!
- Front banana caliper rattle question
- Help... 79' Superglide
- Points
- 75 FXE Superglide
- Lower Hinged Rear Fender
- Parts Info
- Wiring the front brake to the rear brake light
- 79' Shovel dual plugged, coil question
- Started or wire problem?
- Fairing Installation
- Gennie Shovels and Alt Shovels
- What's my rpm?
- Picture of the frame
- Connecting Rod Info Needed
- 71 Boattail
- To Bladder or Not to Bladder..dat is da Question.
- Pressure in crankcase.
- Overheated Coil
- Strokin' My Honey - Need Stroker Pistons
- Needed: 1:1 Ratio Front 16" Speedo Drive Unit
- What do you suggest for electronic ignition for `77 FLH?
- Evo Style Oiling for Shovel
- Do they make/sell Shotgun style exhaust for`77 FLH`s?
- Wiring my turn signals
- Compression & Clay & Stuff????
- Chronic Rear plug fouling
- oil pump pinion shaft gear question
- transmission speedo cable
- clutch adjustment issue
- `77 FLH Need help with mystery problem
- Shovlehead valve guides-HELP!!
- looking for a cam
- "Stumble" on acceleration
- Clutch hub removal
- 1984 FLHS SPORTGLIDE
- Inherited 74 FLH 1200, need help
- 81' Shovel Oil Pump
- How DRY can DRY actually be?
- What parts fit?
- Original '77 Lowrider
- cutting out
- Amsoil Synthetic & Shovel Question
- Rev Tech Transmission
- swingarm bushings
- What to buy?
- 76 BiCentenial ElectraGlide
- Mount FXST tanks on 81 FXWG????
- Valve guides
- Trike Modifications
- Synthetic oil in Shovelheads
- Correct transmission mounting & Spacing
- help.... major oil leak
- cams
- S&S super e on 79 fxe
- Single Vs. Dual Disk brakes
- 6 speed for 80 shovel
- Clutch Replacement Question
- 78 Style Gas Tanks
- change back to points
- Is More Venting on 74" Shovel Possible?
- single fire ign and tacho
- Pipes, Forward Controls, etc. for 81 FXWG Wide Glide
- Pics of my project
- 4 Speed Kicker Install (Part 2)
- Compu-fire ignition
- 79 FXE stock pipes bracket
- good find tour glide
- Shovel hand grips?
- New to Me 82
- New Member - 83 starter problem
- 4 Speed Kicker Install ??
- Any Thought on Pushrod Cover Gaskets
- heads
- '04 41mm Front End + '77 AMF Turbine Wheels
- frenching
- HELP, 79 shovel problem with wiring
- no spark to my 79 shovel. why?
- Anti-vibration foot pegs?
- Steering lock
- single fire ignition
- wiring problem
- fair price for '73 Shovelhead?
- Leinwebber Cams
- tranny fluid
- Idle problem
- MONTH AND YEAR OF MANUFACTURE
- Help!!!Carb problems
- 1978 shovelhead
