View Full Version : Shovelhead
- addin to the stable
- Battery not charging
- 46 Indian Clutch..
- Oil Pump on a 83'
- Shovelhead Tour Pak
- curcuit breaker 83 fxsb
- Motor oil
- Top end rebuild?
- 1980 shovel project bike
- Dry or wet clutch?
- 1978 1/2 Lower rider shovel
- Disk and Brakes
- Another clutch post
- Oil Temp
- Drive gear replacement
- 79 fxe le para seat
- proper way to change oil on a shovelhead
- 1979 shovel kickstart only, kick it and is almost starts but then farts out??
- That ONE thing....
- 81 FXS Lowrider Price suggestions
- shovelhead Compensating Sprocket Shaft Extension Removal
- oil leak
- Dies when open throttle?
- help no spark.
- Primary belt drive, now what to do with all these oil lines?
- 1980 wide glide fork tubes HELP!!!
- need help 1971 FLH vent hose clip
- Fxe to flh shifter conversion
- lever instead of solenoid
- electrical 67flh stock
- Another fuel question.
- 74 Shovelhead Shifter
- trans ????
- 79 shovel rigid frame
- FXE speedo drive
- oil leak question
- Inner primary cover
- oil pressue
- 81 FXB, looking for Gas Tanks
- Big Shovel $$$$ Score! Now What?
- FLT pieces needed
- picture of voltage regulator on gen/svl
- Oil question???
- Oil leak on 81 FLT Tour Classic
- 82 fxrs
- Shovel Bobber Project
- Shovel Flat Rate Book on Ebay
- 81 FLT Frame Swap
- Front brake master cylinder ?
- Spinning Starter
- help me get in the club?
- FatBob front axle spacers on 21"
- 83 fxrsb stock pics ?
- 4 speed: starter clutch gear key, kickstart side
- Shovelhead runs on one cylinder when cold
- Trying to ID this part???
- Can you rubber mount a shovelhead that isn't rubber mounted from the factory?
- Sprocket Size on Trans for 93"??
- Any Shovelheaders in the Portland OR area?
- 71 Shovel stalling after starting
- shovelhead carb ID challenge
- shovelhead noob here
- More clutch questions
- Condenser
- 67 flh
- FLHS Tank Panel
- FLH instrument panel question
- Tire questions
- Shovelhead Rocker Arm Nuts
- New Shovelheader...Wanted to introduce myself
- 1971 fl fx xl
- 80 FLH unable to build front brake pressure
- Keihin carb choke linkage
- ShovelHead Exhaust Head Studs or Bolts
- Extended kickstand +4"
- 69 shovel kickstart electrical
- Carb
- bendix carb fouling plugs
- More timing questions for 78 Shovel
- Installing Swingarm Cleve Blocks Question
- shovel chain oiler
- Carb support
- Advice on buying a shovelhead.
- Header Rap is finished
- 71 shovel wont start
- 1959 pan for sale in Az.
- Oil !
- New Shovelheader
- 1984 FXWG Exhaust Header
- Turn signals and wiring ?
- 1979 FLH purchase
- Starter issues
- '67 Shovelhead
- battery question
- Heat shield or header wrap ?
- Turn signals on 72
- 82FXWG Electronic module.Help.
- Newbie shovel stroker question.
- 1983 FLH fork question
- batwing on 81?
- orig colors?
- super E carb
- Hitachi starter and solenoid
- Need some help on FLH specifications......
- Can't start my Newly Restored HotRod Shovelhead?????
- Hydraulic lifter insert frozen? WTF?
- New dash for 82 FXWG
- 1975 Shovelhead Battery?
- Bobber Build: Rebuild Older HD Shovelhead? Or use new S&S?
- 72 FLH Gear Cover Removal
- To rebuild or sell '82 FXRS?
- dual plug coils ??
- Kick Start Install Question
- Throttle cable try downs
- Will these floorboards fit?
- 1980 FXS what year front wheels can I use?
- Crankcase oil breather adapted for 82 FXWG.
- Looking to give it new life
- Help finding parts for my dads bike
- 1972 flh
- 75 FLH - Just bought need some advice.
- Decoding my VIN
- shovel head
- thread lock...
- Crankcase breather?
- Issues with 82 FLTC
- bad coil on 72 FLH
- lollipops for some better performance
- Puzzler
- removing the oil tank...
- Oil cooler
- Can this be done? Replace stock rim with fatboy rim
- 76 flh
- starter won't stay engauged
- Can you guys help me identify this bike?
- Opinion On A 1978...Santee Frame
- Timing a shovel
- fxsb lowrider
- Stock fender & wheel?
- Jackshaft Blues
- custom made exhaust
- Wheels Options for FLH?
- What am I looking at (potential buy)
- 1 1/8 " rear pulley
- Project Shovelhead Street Glide
- Old FL/EL Frames
- Clutch hub Nut
- UN-crate instructions 78 FXE
- Converting my 1980 FXWG to mids?
- Shovel been sitting for 4 years
- 84 FLTC questions
- No signals or horn?
- Hose connection on inner primary
- Shovelhead bagger project update
- '72 FX, no headlights, horn, or starter
- gma brake pads
- Looking at a 78 FLH
- Exhaust options on 78 FLH
- gear play
- '76 Shovel vent question
- Chain tensioner
- Looking for Oil Pressure Kit for '79 FLH
- 79 lowrider clutch problems
- Torque cones
- Sprocket advice
- Trans set-up 72 FLH Four Speed
- Shovel lit like a Christmas tree..
- 72 FLH Trans
- Double Trouble Shovel Porn
- Looking for exhaust head pipe
- 82 FXR top end kits
- Some shovel porn, dual mags, jugs, eng :D
- 4 speed transmission rebuild Help
- Newbie with lifter question, 1980 FXWG
- 79 shovel Trans
- Exhaust measurement
- locked up motor
- Rear Rotor and Sprocket Question 75 Shovel
- Talk to me, how many aluminum jugs, dual mag shovels have you seen?
- Sputhe Hydraulic 5 in 4
- cold start proceedure
- CV carb conversion- cable issue
- Fun day
- Oil in ignition- 72 shovel
- sprocket shaft oil seal
- 71 72 Electroglide
- 1979 OEM Hinged Rear Fender
- Kick & Electric 4-Speed Shovel Tranny Rebuild (Stock H-D 79 Trans)
- Will it fit?
- Cast pistons
- High Torque starter trouble
- Yep, another clutch question
- sealed speedometer housing
- Paint in Baltimore
- Throttle cable
- Push rod adjustment
- Electronic Ignition Options for '79 FXE
- Electrical problem
- Potential buy, need help!
- Custom wheel and hub: what bearings & internals?
- Super Glide Puking Oil
- Raked Triple Tree's
- 1980 lowrider coil/ignition issue
- Trade opportunity
- Fluctuating Idle, S & S Carb
- Internal Fork Stops for Harley Springer?
- 81 FLT clutch?
- 78 FXS Lowrider
- Dyna ignition?
- Speedometer ratio question
- forks from 77 FLH-on a 08 FXD?
- Bringing a bike back to life - where to start?
- Gear set
- Wheels for a shovel bagger
- Just bought a '77 Super Glide
- need gear set
- 4 speed on a softail drain plug problem
- Trans
- Questions
- Making a Shovelhead Bagger
- 1972 shovel FLH
- cam plate
- New Shovelhead Owner
- 72 / 73 Flh
- shovelhead exhaust
- 1979 FXEF Electrical Issue
- shovelhead starter relay
- Passing Light Issue
- neither starter nor kick starts the engine
- Vulcan lifter/block/pushrod update
- New owner of a 1982 FLH
- any insalled pics of lever solenoid replacement?
- Weak aft cylinder
- Possible future shovelhead owner, questions
- 1979 FXS Clutch ?????
- 73 ratcht top %#@!
- 1978 1/2 fxe value
- 73 Shovel Head..
- winter/summer/fall project
- 1972 FLH shovel
- Shovel top end noise
- 1972 FLH shovel
- Fx transmission
- finally, 66 shovel motot
- updates on my generator shovel
- 1984 FXEF Russian Roulette
- Shovelhead 8mm or 11mm Primary Belt Drive Recommendations
- Sifton 102
- '78 belt drive on
- alt replacement
