- Chain oiler went crazy
- internal throttle
- Oil temp. question
- Drive Problem - Transmission Sprocket (maybe?)
- Whats it wourth?
- Pics of my build
- Oil Pressure 50 lbs at idle..not right..then dies
- 1980 4 speed information
- Wide Glide front end
- Belt alignment trouble 83 fx
- Idles high then drops to normal when I stop
- Painted the shovel today.
- Rocker box tick
- Electrical issue??
- electric start installation
- blown gasket
- 81 vibration
- 79' flh shovel outer primary
- Starter relay wiring
- cases leaking
- Superglide extended headlight visor
- toms river beer hopper lookin for buds
- reassembly.....paint pics
- ok so...head gasket fixed..............
- Crankcase vent line dripping oil
- power to coil problem
- blinker on the blink?
- 74 Shovelhead
- New Member with FLH 1969
- parts for 81 fxe?
- need help from all you pros
- transmission and primary issues
- oil help
- back fire
- blowing oil out carb plate vent hole
- Baffle or Rejet???
- Clutch adjustment 83 FXSB belt,belt
- Need Help
- Leaky Carb
- Exhaust guide O.D. size for an '80 "80"
- How yall doin from North Carolina
- starting problems
- Oil Cooler
- 76 shovelhead
- one or more problems?
- alternator plug retainer OEM 29954-71
- Tourpack adhesive
- rubber mounted shovelhead
- Red loc tite for compensating nut & trans??
- 82 shovel swingarm
- HELP ON S&S CARB
- Gears don't engage
- Starter drive
- 76 Shovel reborn
- Spark plug preference.
- Hey Rodney
- trying to tune a cv
- Anybody here fabricate their own stuff or...
- starter relay mapping
- 77 fxe start relay mounting
- Rebuilding an FXWG engine and transmission
- Web Page Dedicated to the S&S carburetor
- brakes dont work
- Barnett Scorpion clutch
- Shvlhd Motor Starts but Dies out Immediately
- And now for something completely different
- thunderheader install on a shovel
- rocker box covers..
- bike pulling to the right
- 4 speed trans
- 1981 Sturgis stock
- S&S Carb Help!
- s&s jet
- HELP!!! BREATHER OIL LEAK!!
- WANTED....69 or older shovel
- Changing out a FLHT gas tank?
- Wheel help for the new guy!
- lowering and the kickstand.....
- 75 FLH repaint. pics pics pcis!!!!
- 5 speed kickstart???
- need clutch help..please?
- '84 FLH value?
- primary guard??
- REBUILD 60' SHOVEL
- Tappet oil screen
- Best Cruising Speed
- Lepera seats
- Top safe RPM ?
- A couple quick questions
- 71 shovel tranny
- My new 83 FLHT
- s&s carb never mind found it
- s&s superB carb. one or two jets ?
- trans fluid
- Mustang seat wont fit right.
- wining VS whining
- I got a winer
- dyna coil hook up
- might help (wiring)
- real head turner
- Update on exhaust
- Lean rear cylinder question ?
- will a dual fire coil run a single fire ignition
- dont want to cut.
- Front wheel spacing
- s&s carb adjustment
- Running out of gas...
- Rodney, experience needed !
- what clutch part two
- Need a little help.
- Help to Decode Vin and Any Info
- 1980 Custom Rigid Shovel 1340
- Engine won't start (no spark)
- Newbie
- what clutch?
- My winter project
- Test
- Attention "powdercoater"
- Tried to buy exhaust systems lately?
- Nice old ride for sale
- Help with my FLH
- Banana Calipers
- which type of atf
- mechanical brake switch
- 1983 rear head
- crane hi-4 single fire
- Hard to start
- shovel 4 speed
- 1981 FXB Sturgis Decals/Emblems
- opinions on shovel head?
- Lowers for Shovel FLH
- triple tree installation
- loud pipes
- Either the hair has to go,..or the Electra Glide
- SU carb adjustment!!
- 81 FXWG Ignition Question
- NEW Primo belt drive for Shovelheads!
- oil leak
- 1975 cle-80 info
- Hdraulic lifter adjustments
- Update on 83 FXE Starter
- Turn Signal Won't Flash
- 77 fxe reference books
- New Gas Tank
- Kicker cover problems
- Tachometer on 1979 fxs lowrider
- Getting Started, Need Help.
- alot of smoke
- Tranny Woes
- shovel max size
- Top End on 74"
- parts links for resto
- stock clutch
- Ft and rear cylinders?
- Mag Wheels
- Shovelhead front end update
- original manual 1970
- '71 super glide starter conversion qustion
- service manual
- oil for trans
- Rodney
- Project shovels?
- Rodney
- Fender Hardware
- Super E and clutch?
- FL hinged fender question
- Getting an '83 FLH EG - Opinions?
- Stripped Exhaust Threads
- 71 Superglide
- 3/8 5/16 treaded stud
- 80" plugs
- clutch cable adjustment
- Post Wreck Rebuild COMPLETE!
- hard bags
- Looking for some help
- pistons, forged vs cast
- Rigid Frame ID
- 1970 FLH Restore project
- 1983flht primary
- 77 FXE parts needed
- best tire, price/ quality
- 73 shovelhead
- freshening up my 74 ,pistons?
- oil out of the breather
- question about 1971 FX super glide
- New clutch
- Oil pump ball bearing residue??
- 80 Shovel hard kick start update
- voltage regulator clip
- 79 Low Rider
- First ride on the shovel this year
- geyser
- 1979 fxr
- 74 Shovelhead
- Wiring for 5 pole switch
- High Torque-starter install for the ShovelHead
- Need opinions on tanks
- trans
- 1981 FXB Sturgis Tank Decals
- Got Floorboards?
- After Market parts that don't fit Shovelheads
- '81 Keihin carb question
- Shovel rear cyl blowin oil smoke.
- Barnett Scorpion and Primo/Rivera Pro clutches for shovelheads
- A bit of patina
- My Gothic sledge!
- ATF in primary
- 1968 FLH restoration almost completed!
- oil presher
- My 83' Won't Start
- Help! What kind of bike is this?
- wont start
- 1983 FXDG Disc Glide Refurbish Thread
- Exhaust for 93 cu in SHovel
- Top end oiling questions 1968 Shovelhead
- 1981 FXS- Opinions
- 78 1/2 Tranny Leak
- 2 into 1 for an FXR
- 82 fork seal replacement
- Starter engagement problems
- EBOC anyone using???
- Rubber Mount Shovel??
- Narrow dual disc to wide glide dual disc
- Hydraulic Brake
- 71 Shovel Will not start
- zenith carb adjustment
- Points vs Electronic
- Shovelhead Head Reinstallation
- 80/80 exhaust question
- Primary Gasket Questions
- Double Shovel
- Do I need a more powerful batery for my new hot set up
- What is HDForum worth???????
- shovelhead piston arrangement
- Friend Passes On
- 80/80 Restore 2
- 80/80 Restore
- 1982 bagger questions
- WON'T START
- Shovelhead Base Gasket
- primary chain question??
- ITS ALIVE !!!!!!!!!
- custom pipes?
- Paughco True Dual ?'s
- valve replacement
- 1977 low rider question
- 80" battery
- When does a shovelhead bottomend need rebuilt?
- 1966 FLH Restoration
- pan/shovel motor for sale
