PDA
View Full Version : Shovelhead
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33
  1. lost pieces
  2. Seat
  3. Lost frame
  4. Octane
  5. Looking at possibly buying a 1980 FLH Shovelhead any advice?
  6. generator output
  7. 1975 FLH Rear Brake Switch
  8. need photo of stock 1984 genuine HD speedometer
  9. modify front end of "75" Shovelhead
  10. New Heads
  11. Bent Pushrod
  12. Bigger front wheel for a 78 FLH?
  13. FX with FL forks?
  14. Compensating sprocket
  15. Questionable?
  16. 79 fxe chopper finally done
  17. Identify a stroker or not.
  18. '63 PanShovel Oil Light
  19. Need help, primary allllmost off
  20. 1975 FLH Speedometer Not Working
  21. 1977 Harley Davidson Confederate Edition tribute bike almost done
  22. Primary chain
  23. Intake Manifold Leak/Alignment ('76 FXE)
  24. Preventive Maintenance Checklist
  25. 1981 FXWG questions
  26. Barn find
  27. Shovelhead with EVO heads?
  28. more FXE questions - rear fender spacing
  29. Adjusting Shock
  30. shovel starts with ignition in off position
  31. Confused on engine size
  32. Crane Cams- Hydraulic Lifters Kit # 3-1003 Anyone?
  33. New (old) 1979 FLH
  34. FX - FL Frame Difference
  35. 1969 transmission swap...what fits
  36. Kicker return, NOT
  37. stinkin superglide tank mount - fail
  38. timing plug
  39. Cleaning up a 78 FLH Electra Glide
  40. 79 Shovel Starter Relay Question
  41. This true when switching to struts?
  42. I ferget
  43. White Paint for old Fiberglass?
  44. Need help bike won't start
  45. '83 FLHS belts
  46. Big Crank battery question
  47. Need help tearing down
  48. Purchase - 1983 FXDG or 1983 FXRS ??
  49. bendix question
  50. 82 FLH rider backrest
  51. Carb problem?
  52. someone check me on this please
  53. CV float needle problems
  54. general vibration and rear wiggle
  55. DOT 5 and leaking front caliper
  56. 1978 1/2 80cui
  57. '69 FLH finished
  58. Belt drive primary compensating sprocket - got one?
  59. 4 spd clutch release shaft retainer pic
  60. jetting
  61. superglide tank mount help
  62. tranny plate and spacer
  63. fork seal question
  64. Heavy duty seat post springs
  65. adding a brake light switch to the front brake.
  66. First shovel....
  67. 1966 FLH color chart
  68. o.k. I got one for ya.......
  69. Starter problems.
  70. 1980 4 speed problems :( video inside
  71. Ironhead Saddlebags
  72. Oil problems
  73. KeepN a Shovel OG.
  74. fat boob tank mounts
  75. Weird clutch wear - would appreciate your advice
  76. Couple oddball questions i guess
  77. one shock or another
  78. Shovelhead oil puking problem
  79. FXWG Question!
  80. Handlebar
  81. Motor Tranny alignment ??
  82. Footpeg rubber adhesive
  83. security lockdown
  84. more 4 speed questions - locking key spacer
  85. pull trans plate to install 4 speed???
  86. Springtime Tune up!
  87. Crankcase Breather
  88. Springer on my 77
  89. Vetter Fairings
  90. oil pump woes
  91. 4 speed fork spacing
  92. Mystery of the vanishing clutch....
  93. 74 flh >4k miles . sitting 4ever
  94. Looking for spokes
  95. electrics
  96. Which oil cooler
  97. so why is my gen light on?
  98. Shovelhead Missing
  99. Poor braking
  100. What manual to get for my 1982 shovel
  101. Another vin # question
  102. Oil Pressure gauge
  103. Can anyone identify these tins
  104. Shovelhead Flywheel Numbers
  105. cam bearing question
  106. got the old un out
  107. rear highway bars
  108. 1967 electraglide front wheel
  109. 4-Speed Rotary Top Shovelhead Won't Go Through All Gears
  110. Converting an 81 FLT to a Road King, picture heavy
  111. Reflectors
  112. HELP PLEASE! Rear brake, solo seat install and unknown dual spark plug heads
  113. 67 flh
  114. A 78 FLH question or two.
  115. 82 flh shovelhead wheel fitment question.
  116. 2 months and stumped
  117. FLT left header support bracket
  118. What do you think bastard shovel
  119. 1984 low rider tach 7 trip repair
  120. 1982 Duo Glide Starting Issueses
  121. 1971 Electra Glide FL seat
  122. Invader brakes
  123. 80 CI belt drive Shovelhead
  124. 1971 Electra Glide
  125. Noisy Heads
  126. Solid lifters, oil lines, etc: 82 FXRS
  127. Shovel lifters
  128. Fxb
  129. Length of a 78 FLH
  130. Cateye Dash Wiring On A Alternator Shovelhead
  131. Open Primary help
  132. '77 FXE Cam Cover and Outer Primary torque specs
  133. oil line route
  134. Seeking Advice
  135. Some input please '81 FXS
  136. Need help on removal of fuel tank on 79 FLH
  137. Couple shovel questions
  138. Couple shovel questions
  139. trouble finding clutch cable of custom shovel build
  140. Not new but first post.
  141. Will these brakes easily fit on an '83 FLHS?
  142. newbie here looking to get into the world
  143. CR ratio guesstimate
  144. stupid question
  145. 1977 FLH nacelle headlamp w/s bracket needed
  146. 5 speed frame: rear swingarm rubber bushings
  147. Speedo drive problem
  148. FLT coil position puzzle
  149. FLT rear master cylinder bore
  150. 80 Shovel, bad fuel?
  151. Rigid frame shovel project
  152. smoke ..exhaust guide or ring??
  153. Rebirth of a family Superglide
  154. what is it??
  155. new to forum with a question
  156. Sparkplug blew out of the head
  157. VIN missing .....or location
  158. Neat Pogo Seat Idea for FX frames
  159. Shovelhead starter shaft to short
  160. Exhaust opinions
  161. sorry its edgewood NM on the jetting
  162. jetting denver area question
  163. Best carb for shovelhead?
  164. FLHP vs. FLH
  165. Air cleaner cover mod
  166. Service Manual page missing
  167. Badlands Turn Signal Module Install
  168. Eliminate Speedometer Cable From Transmission
  169. Hardtail frame identification????
  170. American Made 6-Pole Ignition Switch For Fat Bobs
  171. HD Carb -
  172. tips for squaring up trans
  173. rare shovel
  174. Compression test readings
  175. Delkron Cases
  176. shovel indentification
  177. My 1980 FXB Barn find
  178. Shovelhead pick of the day...What did U pick recently?
  179. air shocks for FLT
  180. Can I add baffles to this exhaust system?
  181. case number identification help
  182. 72 Flh Basket case
  183. CV Carb help
  184. need help identifying this bike
  185. Nacelle Installation
  186. transmittion
  187. Differences between shovel and evo brake cylinders?
  188. How can I tell someone what to look for if it's a true 82 FXR?
  189. 73 flh
  190. Oil pump replacement
  191. 1973 FX Superglide Shovelhead restoration
  192. Shock Angle Too Much??
  193. late model shovels
  194. 21 inch wheel
  195. Compression test question
  196. Paughco s127a 2 up 35 rake any opinions?
  197. S&S SH103 vs SH93H?
  198. 79 fxs 80 binding and noisy trying to crank
  199. solenoid plunger
  200. 4-Speed Kicker Issue
  201. Comfort flex seat
  202. Rear Brake Fitment on 80's Rubbermount Swingarm
  203. '82 shovelhead: external oil lines
  204. Extended brake pedal for 1969 FLH
  205. 2 into 1 exhaust ?
  206. Looking at a 77 FL w/ 93" - Need Advice
  207. For facebookers
  208. Alphabet air cleaner filter
  209. cases?
  210. Trouble with Starter circuit
  211. S&S E on a 76 FXE
  212. ultima cylinders
  213. Exhaust on the fl's
  214. Shovel length (dumb question)
  215. Working on a 1977 FXE-1200 Superglide
  216. cost of '82 shovel?
  217. banana caliper
  218. Isolated Primary
  219. V-Twin Fiberglass Bags
  220. another use for a shovel motor
  221. belt slap
  222. I found this FXE Super Glide Shovelhead Limited Edition Series III
  223. 76 FXE Startup
  224. FLH 1979 footboards problem
  225. Exhaust leak
  226. Scratched cylinder wall. Cylinder boring or new heads.
  227. Four Speed False Neutral
  228. Replacing fork lowers to use the new Brembo Brakes
  229. Question - 82fxb limited
  230. front rod slop
  231. sissy bar insert
  232. Gear matching for 1975 FLH
  233. re-assembling a 74-flh
  234. Found A 82 Electraglide Opinions Wanted?!?!?
  235. rigid frame software
  236. '69 Shovel questions
  237. sprocket choices for 72 FX
  238. Shovelhead Exhaust Pipes 69 Back & 70 up
  239. Original solo seat
  240. Electronic ignition 76 shovelhead
  241. 69 with very hard clutch pull
  242. 69 turn signal controllers out there?
  243. 69 shock settings
  244. Cats Eye Dash Fitment
  245. Mysterious oil consumption
  246. Comprehensive list and of shovelhead reliability issues and solutions
  247. 3" open belt to 1.5"
  248. Sifton 101
  249. best way to plug primary oil lines ?
  250. CV carb support Bracket
