View Full Version : Shovelhead
- 76 shovel fuel problems
- 1972 flh shovel condensers...........
- Split rocker boxes
- xr1200r shocks on flh?
- Raking a panhead rigid frame
- Battery eliminator?
- Cam recomendations
- Front master cylinder fitting
- Turn signals mandatory?
- Hydraglide fork harsh rebound
- Just picked up this 84 lowider
- Just showing it off
- 1967-1972 front wheel hub diagram
- Axle question
- Bonhams or Mecum's for my '66 FLH?
- rebuild recomondations
- Static time electronic Ignition
- Preferred Drive Ratios on 93"?
- 93" Cam Choice?
- 1967 Electra glide
- 1968 Stock exhaust removal
- Cold start
- Starter keeps turning FXEF-80
- Front brake fades
- High Cranking AGM Battery for Shovelhead Stroker
- Bike wants to stall not sure if its the carb or clutch
- Rocker oil gauge
- Wheel on old FLH
- antique "dell orto" (keihin?) carb
- 82 FXR needs help
- Here's where I am in my 93" Build
- Best ignition for kicker
- 1971 FL restoration
- 1968 FLH kickstart
- Oil Pump for '69
- stupid question - but can;t google it up
- 19x250 rim
- Winterizing
- Breaker cycling? And an intro…
- rebuild time
- front rotors I.D question
- Starting
- 74 vs 80 Cylinders
- pan/shovel hybrid????
- How to: Update your FLT to late model tins and bags
- Static Timing Dyna S
- cam seal
- Taller Pushrod Cover Seals???
- Shovelhead rocker box stud removal
- Speedometer Help Needed
- Exhaust flange is always welded on?
- Crankcase pressure? Venting issue?
- question about valve adjustments
- backfire, no exhast leak
- Is there an adapter ?
- WTF with the starter now?
- '83 FXRS: New to Shovels!
- early 1984 FLT tour glide bottom end question?
- Looking for a pic of a saddleman explorer on flh
- 72 fx 1200
- Shovelhead smokin'
- Started tear-down on 1975 FX-1200
- 1972 HD Shovelhead
- Inner Primary to Case O-Ring
- 1984 FLT EVO sprocket shaft question?
- 1979 Value ?
- oil light
- Whats wrong with my head??? Shovel Head that is
- Ignition Switch
- Cylinder heat
- How to Wire an Inner Primary Bolt?
- wont stay running
- 76 FLH Fork Seals
- Custom Shovelhead Primary fluid question
- connecting rods on a 1984 FLT
- Just picked up my first shovelhead
- Keeping my 1957 XL, but wanting shovel
- Starter working on a good day
- Crapping out after a few miles
- Here's mine
- My 74-74
- I was Offered this Shovelhead, should I get it????
- Starter Clutch, Starter Drive, Bendix..whatever it's called, how do you replace it?
- Just bought a Shovel
- Oil Leak
- Stator issue
- 76 FLH Squeals Bad Starting
- Recommendations on a carb conversion.
- Need help finding fender struts for 79 Low Rider.
- Best way to find good shovel head
- Trying to ID this Build
- Spark Plugs
- Need to replace speedo cable...what ratio?
- Evo in shovelhead frame
- My first Shovelhead
- Help please>>>>
- new starter
- CV carb conversion - How to?
- Push rods for solids
- Kicking a Shovel
- smoking at start up
- engine and transmission oil change....
- Front Chain Baffle
- gas tanks mounting
- Timing?
- Now it is really finished......
- Operating temp
- Best brand solenoid?
- Rocker Oil Fittings size
- Crossover dual mods
- Runaway Starter
- slight knocking sound in pushrod
- Update: Leaky rear chain case on FLT
- '82 FLT speedometer bounce
- Pastor Jim
- check ball cap plug
- Kicker installation
- 77 Puking oil and missing line?
- Pics
- audio read switch
- Busted oil vent fitting 1980 FXEF
- Idle is bad. Ideas?
- 74 Superglide Won't Start
- hey john
- 81 FXWG kicker clutch spring
- Soft Front Brake
- 82 FLT starter operating correctly
- Tranny dope
- Eating crank bearings
- Help
- Help
- Doesnt run right. (video)
- What carb do you run on your shovel??
- 82+ front master rebuild
- 74 superglide charging issues
- Rear muffler turned yellow...
- cone engine cam shaft question or 2
- No compression
- 1993 FLHTCU Low Accessory Voltage
- How to set up a 4 speed totary top trans for a foot clutch?
- '80 FXEF 80" wiring woes
- 80 FXW noise
- Primary Belt
- Speedometer jumps over 50mph: repair?
- Paint schemes for 1975
- Scored rear cylinder ... please advise
- 76 FLH Stripped Swingarm Pivot
- oil leaking out of my breather hose
- Vibration near top speed
- options for pipes
- wide glide front end
- Battery reccomendation
- '80 FLT done
- another oil question: automotive oil
- New true duels on
- puked some gas at last fill, is this normal?
- Question about Tappets and adjustment
- Front dual disc
- Wtf is wrong with my clutch?
- Clutch plates
- Questions for electric ignition install
- New shovel for me
- Drum Brakes Humming
- Replace rigid rear brake line with a braided one
- Clutch bearings
- Front Brakes
- Dual Caliper Single Rotor Rear
- Rear footpeg mount
- Synthetic Oil ?
- Any issues with taking a shovel from sealevel to mountains in one trip?
- Front tire Reccomendation
- saddlebag lid
- BUying my first shovel next week
- rocking nut/leak on rocker box shaft;
- Progressive Drop Ins on 75 FLH?
- Flh hinge fender
- How much transmission oil? 1974 flh
- mirror glue
- Paint codes for older bikes?
- Headlight
- Front brake issue pump up lever holds, let go lever drops
- What Happened to all The FLs?
- Starter turns but motor doesn't
- Bag Guards For ‘77 FLH
- Rocker arm screw oil leak
- 82 FLTC issues
- Fork seals 'n oil...time to fix
- removing a batwing faring
- tranny oil
- 7" Headlight on 1980 Wide Glide
- 74 exhaust true duels over priced
- Need guidance with air cleaner and carb rebuild
- lifter block MOD worth doing?
- Starting to look @ shovels
- anyone still run the stock primary chain oiler?
- Starter question
- Oil pump pinion
- 76 FX Superglide
- 77 shovelhead - Rebuilt silenoid, but now won't engage
- clutch issue
- from the ground up
- Left rear crash bar for 1979 FLH
- Fairing question??
- Shovel chop don't like water
- wheel cylinder 63 through 72
- Oil mist
- Noisey Valvetrain.
- Need Speedo Suggestions
- What internals?
- New Guy
- Need ideas for coil
- Dead battery help
- lifter Base bolt thread size?
- Backfiring through carb and exhaust??
- 82 fxr breather issue
- Ignition timing cover riveted on?
- 72 FLH Project
- rods
- 4 speed tranny fill level argument...
- Project '72
- Looking for a kick-start.
- Original Rims
- 1982 Lowrider FXS Build
- Old School
- 82' FXB Sturgis - starter issue
- looking for true duals
- 2000 two cable carb on a 76 Shovel???
- Regulator
- 72' head
- Popping through carb
- Oil consumption
- brass(?) parts in transmission
- fluid capacities
- What other front ends will fit and ild FLH
- Primary chain oiler
- Just bought a new Project - Not sure where to start
- extended forks
- Corbin seat question
- Finally ... bought my 1st Shovelhead
- Is it just me or does everyone have problems with the handlebar buttons?
- Tail light/ Headlight upgrade
- Anyone have a simple wiring diagram using the 72-81 style handlebar controls ?
- Primary assistance
- Respoking
- Died while idling, now won't start.
- 78 shovelhead cylinder base nut leak
- Rebuilding a 1974 electraglide
- How did this happen?
- 74 74
- Need tranny help with my new custom build...
