- Series III gas tank and fenders
- Shovelhead 75 FLH crank case drain plug stripped
- Getting 74' FL w/ S&S 93" and Baker trans ready for long tour
- Fuel Wash/Cylinder Wash Fix?
- 5 GALLON SPLIT TANKS ONTO A 1981 FLT ?
- Help with custom lights needed
- 76 FLH with 79 tranny. Gear ratio for the hiway
- Chip in brk pad?
- Any suggestions?
- O-ring for main drive gear - 11166
- Found a 71 FX I couldn't say no to
- 90's 5 speed mainshaft seal in a 4 speed ratchet top
- 84 Shovelhead
- ULTIMA 96” shovel motor regulator connector
- Primary Belt Trouble 1983 FXSB Low Rider Shovelhead
- Which lifters?
- pressure checking '82 intake manifold
- Rotary Trans Leak/Issues
- 4 Speed Question
- VIN decipher
- I wanted o-rings on my 82 shovel
- New shovelhead owner
- 1972 FLH
- 65-78 79-84 closed BDL pulley question
- fxe 1978 rear wheel
- fx 1978 rear rotor center in galiper
- Mystery air fitting
- The Runout you can't neglect
- Wheel hub disc flange to spoke ring distance variations
- Head bolts
- Changing oil weights
- Headlight recommendations 76 FLH
- Compression Problems? Too much?
- 44007-80 and rubber brake hose collapsing inside questions
- Best diaphragm clutch conversion kit 1972
- Shovel is beating me down...
- Looking for a D gas carb?
- Newer controls for shovelhead
- 4th gear spacer
- Petcock left to "ON" for 5 days.
- In need of assistance
- Neutral safety switch
- Kickstart jammed causing elec. start to not work
- Ruthie Rebuild (1977 FLH)
- Shovelhead FLH Project
- 1977 FLH "Ruthie" Rebuild.
- S&S B Air Filter
- Tips for bleeding front brakes
- Tire removal?
- Rear Chain Adjustment
- SnS Super E
- belt
- Riding a Classic Flh with the Banana Calipers Early and Late
- Stripped stud
- 2-Part Road Trip Posts
- Cheap easy turn signals, 76 flh with 72 tins
- FLH bobber
- First start in 15 years. How to pre-lube?
- 4 speed counter shaft bushings
- Shovelhead, super E carb jets
- 1972 Harley Davidson
- Secondary resistance (Ohms) 31609-80 Spare Coil for Flh
- I'm on the road
- Delkron timing plug???
- VIN number
- Valve lapping
- 1984 flhs shovel head anniversary edition.
- valve stem protrusion
- bike rider movie
- Is there a terminal plate behind the headlight?
- Section of Heater Hose to insulate gas line between cylinders
- Exhaust pipe recommendation that will fit FLH with floor boards
- Single Fire or Dual Fire
- Bending tranny clutch lever
- No start. No click. No Nothing!
- Tail trunks
- Shovel VIN info before purchase
- S&S E carb drain hose
- '80 FXS Electric Start Conversion
- FXE 1978 rear wheel interchange
- Clunk from headlight area over bumps
- Cylinder flange finish
- Tank Emblems
- 67 FLH Starter Button Dead
- New exhaust options
- fxe chasis
- Fx model after market seats? They done fit?
- Shovelhead left hand trans noise - stops when you pull in the clutch.
- stock
- FXE repop tank
- Gas tank venting
- S&S Air Cleaner On CV Carb
- 1982 FLH gas tank hissing
- I think I need forward controls
- 1981 FXEF Nylon Clutch Spring Retainer
- 1971 FX Super Glide parts guide
- 1976 fxe project
- Do I have a wet clutch or dry?
- spark plug half oil
- 1982 FLH front brake
- Shovelhead maintenance
- Simple diagram for 5 light dash?
- Shovelhead with Super E Cranky Cold Starts
- BDL Primary Belt to tight on 1973 Shovelhead
- 1982 FLHP Journey
- 1968 FLH front brake issues
- Pushrod help pls
- Alloy Transmission Pulley, does one exist?
- Just bought a 76 FLH disassembled
- Cometic gaskets and strange hole
- Question on zirc.
- 80" Shovelhead Backfiring
- Transmission Shaft Oil Seal Hack
- FLH grab rail
- New valve train noise
- New member
- Oil light / oil return circuit 81 Sturgis
- Is this an issue?
- Made some progress
- OEM shovel to S&S
- Shinko tires
- parts
- Mirror glass
- Oil pressure light on 1975 fxe Superglide
- 1982 fxr shovel exhaust options?
- '76 FLH wheel upgrade question(s)
- fuel cap
- Rear cylinder not firing
- Motor Shaft Oil Seal
- 80 80 project - need your help!
- torque plates
- 1971 Electra Glide Police Special
- Any input on this magneto?
- Fireball tank
- Tourpack parts 1975 flh
- Tourpack parts
- Help Identifying FX Super Glide Model Year!!
- base gaskets to lower compression
- 74" shovelhead rings and cylinder questions
- Twin Fire or single fire
- Cannot get timing right.
- ..haven't pulled it out since July 2020
- Pushrod Question
- 84 flh rear rims fitting
- Fork installation kit
- AMF parts made in USA?
- 1979 Fat Bob or Low Rider?
- Original HD Alarm “system”
- Posting pictures
- Stators
- Fried
- Piston ring size for 74" to 80" converted shovel?
- comfort flex 52518-80
- four day ride
- supercyle magazines vs easy rider magazines
- 81 FXWG Runs for 5 sec then cuts off.
- 1980 FLHS Progress and Questions...
- My Shovel turned 40 today
- Kicker Conversion. 1980 FLHS. Grrrrr!
- Question about Grandpas Shovel 1982 Low Rider FXS
- Early Shovelhead Stock Dyno Charts
- Vented Derby Cover Show and Tell
- engine
- Stock stroke
- Little Help
- Rear Drive Chain Adjustment
- Valve Stem Sleeves
- Draining Transmission Oil Q.
- Not another oil thread!! 25/60
- Shovelhead FXWG VS FXE OR FXEF
- 4 speed trans roller bearings
- Shovelhead installation
- Clutch for belt drive basket Q.
- 1976 Shovel Superglide FXE Forward Control Mounting Bolt Size and Pitch
- 82 Shovel Oil Pump
- '76 HD FLH Shovel project...
- Damaged O-ring lip on engine case (Fix) ?
- Import Bendix carb kits
- 82 Sturgis seat
- 76 FLH Slider to tube clearance
- best source for new parts??
- Fork tube length on a 1983 FLHS sport
- Is this off a motorcycle?
- Starter not engaging
- all kick starts and no push buttons.
- Coils for Points
- drain plug troubles.
- Seeking advice
- Starter Question
- i.D. these widgets ?
- Attention knowledgable Shovelheaders !
- Stupid question
- Clutch issue?, advice wanted.
- Push Rod Cover Seal Choices
- Seat post question
- whats up with the oil lines in the 82 shovel ?
- Have a drag racing question for you guys in the mid-west states
- Gap between piston wrist pin and spiral clip?
- Can you help identify this bike?
- 73/47 circuit breakers.
- 40908-81
- 1st bike 76 FXE basket case
- Need tips on removing stubborn Rocker Box Studs
- 71
- 1969 FLH basket case restoration
- 1979 FLH saddlebag guards
- need pics.
- Rear fender welded fasteners
- FOAM air filter oil
- power on both sides Sparkcoil
- lowrider
- Got my birth year HD 1976
- Tour pac template
- Clicking noise when turning wheel to the left.
- S&S
- Anybody know where to find this?
- Batteries
- 1967 flh
- Clunking noise from front
- Foward controls
- FX double disc front brake lines
- Converting from Accel to Dyna2000i
- Primary Concerns 82 FXWG
- Tank Woes
- Shovelhead FXE 1200 problem oil motor
- Starting a shovel
- Recommendation needed for 1984 fxe muffler
- Gap Trans Shaft
- 1969FLH numbers
- Wiring harness
- accel spark plug wires.
- New 76 Shovel FLH project
- Rocker Shaft Caps
- 82 FXWG Terminal block issue
- Clutch hub lining
- What bike is this?
- Need help IDing cylinders
- Fxwg front fork 80-83 vs 84-99
- Outer Crank bearing oiling
- Getting first Harley
- Straight Cut Drag Pipes
- What year 1/4" NPT Petcock Tanks
- Hello from New Zealand !
- Swingarm king and queen seat
- 1979 FXS shift lever
- Truing info need
- Clutch hun will not come off
- Starter relay confusion
- 1978 Shovelhead
- turn on ignition and bang
