View Full Version : Softail Models
- D&D fatcat on... cam in and dyno'd....
- Before/After C&C
- 2009 Crossbones price check?
- It just died :(
- should i or do i change out ignition.
- It's here, with the RH Crossbacks!
- Will got my Cam Converstion Kit From Herko(John Wadsworth) now to get it installed.
- 98 custom - thunderstar wheel
- New Tach and Speedo combo....!
- New Deluxe price..?
- Cholo's on V&H true dual headers...
- 1 year later and I miss my Dyna.....
- Did I do good?
- Finally able to ride the re-born Train!
- HD LED 5-3/4 headlight Fit Rocker?
- Moco get a grips?
- Primary chain ajustment
- Heritage passenger seat
- Lowest Deluxe
- not feeling the saddlemen solo
- Rocker aluminum tank insert??
- 2002 FI Fatboy won't start
- Heritage rear wheel question
- whats the difference
- Hard Bags on FXST pics
- New Softail?
- Rocker tank on a Deuce question
- Softail Security System light
- Spring seat with a Heartland
- Headlight nacelle on the deluxe
- Robert at Garage Leathers...
- Did U do a Dyno? Did U post it,? Whats Ur numbers.?
- LePera "sorrento" Seat???
- Batwing needs lower blinker bar
- Riding Gear Questions
- 107 Headquarters Build
- Rear shock adjustment ?
- One and only winter mod done
- anyone know if these pipes will fit with hard bags
- Lo Profile Console backorder = WTF????
- 2008 FXSTB/Turn signal question
- New LED or the old HID head lamp???
- Anybody have the Air Wing Luggage Rack w/t light??
- I think I'm going to sell my LO
- How much are my 2010 Fat Boy Lo tins worth?
- Deuce Seat 2000-2007
- Harley Super tuner and dyno
- 07 softail custom?s help
- 1996 Fatboy Fluid Change
- Remove frame down tube stickers???
- Remove spring when replacing lowers?
- Is $1400 too much for 14" Gangtsa Apes, Bra Riser, diamond back cables and labor?
- Power Commander and Rear Cylinder Heat
- Winter mods are done.
- Ape Hanger Mirrors
- Clutch Problem
- seats
- Cool Custom Softails
- Deluxe Passenger Seat
- FLSTC floorboard swap to forward control
- Oil pressure guage#s wtf?
- Grumpy's Customs pics?
- hello
- Success with canned maps?
- Budget Stage 1 for $225
- I want cruise control on my Cross Bones
- Where do you suppose this cam cover insert comes from?
- flush mount gas cap, not flush
- boom volume control
- 1st Ride of the season and 1st on my NT
- Will 2008-10 Fat Boy tins fit the Fat Boy Lo?
- Flat or gloss
- So...what exactly is this called
- Warranty on used bike
- anyone installing bigcity thunder baffles 6 in from rear of pipe
- KC Fail
- Will newer model softail wheels fit an older bike?
- Wild 1 Chubbys on a FLST
- Primary case paint
- Headlight question.
- 2010 Rocker pipes on a 2004 standard?
- Break switch screw fix???
- Cable lengths for 16" hangers on 02 Fatboy
- Losing the tank's center console?
- 2006 Heritage Ignition/ACC question
- After sitting on the blackline
- Another fender question
- LePera's Hardware Sucks
- Problem with fron turn signals
- My bike is on Ride Wrights first page...
- Anyone put Burly Slammers on a Deluxe? Got pics?
- HELP.....Rocker Sprint Seat
- 240 tire Luggage rack or rear seat/wbackrest
- Motherwell rack is on!
- milwaukee twins parts
- Wattage output on 07 Softail
- Lowered Softail Questions
- HD of Seaford, DE
- New Bike and A Question
- Could have spent $250, but would rather spend $500
- Heritage Decor Questions - How Tos
- Finally a day to ride and see...
- 73273-11 LED Headlamp
- Night Train question
- C&C Seat Covering Opinions?
- Big radius owners??
- Some Mod Input, Please
- Carlini Slickbacks on a Rocker?
- Sundowner Seat Owners - Protecting Fender?
- Factory riser height on a Heritage?
- Holy Crap! The led headlight
- 2002 Deuce Rear Pulley Question
- Heritage Tail Light
- Need some help Please
- New Deluxe pricing ?
- 08 FXSTC not starting
- More than just Switches?
- Cyclevision Floorboard Extenders.......HELP!!!!
- the deuce and I joined the rest of you monkeys out there
- 2009 Harley Softail Deluxe/Heritage 100th Anv. Leather Bags w/Hardware & other parts
- Customized speedo?
- Tax Return = Which Mods?
- anyone using either bct baffles in v&h bs longs
- Rear axle and pivot bolt covers
- Looking For Speakers
- SE Stage III or Stage IV for FLSTN??
- solo seat with springs question
- who's running a 21 x 3.5 on a fxstc
- Exhaust Question
- 70 Degrees and a awesome ride
- Are there any other brilliant silver crossbones here?
- Help! Softail Deluxe or Road King Classic?
- I'm thinking extended hard bags now...
- hooray for tinkering!!
- Used Night Train
- Advise /Opinions
- Closeup of Vee Rubber 21" tire...PIC
- Installed LEDs/blinking problem?
- Need Help
- Cam Advice
- RSD Tracker Fender
- Where can I get?
- Visual Quiz - what's missing from this bike?
- Progressive Suspension 422 diameter
- 08 Deluxe brake pad pin
- '06 Night Train
- Le Pera Bare Bones on my Crossbones Pics
- SE Race tuner older version???
- Advice for Aftermarket Hand controls/switches
- wierd wear on my front tire please help???
- Round 1 of mods complete
- Touring HardBags on '05 Fatboy
- 2000 Duece Air Cleaner Cover
- Hard to put on Saddle Bag Guards?
- 2010 softail fxst
- Can't reach the ground!
- Are 2 1/2 inch Pythons slip on exhaust too loud on Deluxe?
- Mustache Engine Guards on Fatboy ?
- Custom rear fenders on a Softail Pics?
- What's wrong with my bike?!
- 2010 Softail front axle size?
- Fat Boy Lo with Passing lamps?
- Anyone running a swingarm bag with true duals?
- Mod of the day (lowered rear end)
- SE pipes and stage1 ac do you think this bike has a fuel management system
- will spedo from 2005 work on my 1998 ?
- swing arm bags
- I Give Up
- New Fat Boy Lo front fender
- new 2011 blackline
- Power Commander PCIII USB
- bags from bikerbags.com
- Backrest for stock Heritage rider seat
- best pipes for a fat boy
- Cooling Fan for Fatboy
- 103B hp/tq
- need to be hurd
- Harley Finished!!!
- 2006 Deluxe Question
- Do many Softail riders toss the belt guards?
- 2-1 Bassani
- New HD L E D headlight
- Fatboy Lo ~ A Bike To Remember?
- 21" rim under a Heritage Classic fender
- stupid seat question
- Show me your CUSTOM Bare Bones
- Outlaw DOT Carbon Helmet and Xelement Jacket
- Nacelle or Delixlight Kit
- Fork Removal on 07 Train??
- got pics of whitewalls on chrome rims?
- Wifes Heritage back today from winter mods at Dealer
- Wow....what a difference
- Knocked out some mods today! Pic
- 08 Fat boy ape hangers?
- V&H fuel pak vs Cobra FI 2000
- Fork Boots ya or nay with pic
- C&C seat question - Replacing rock hard badlander
- adjusting stock shocks
- Handlebar Fitment Question
- HELP! Clutch problems
- Chrome Lowers & Fork Sliders,,, Help
- 2011 CVO Softail Apes
- Ready to start some MODS - Advise needed
- Internal wires lengths to fit 09 Fatboy with 18" Carlini gangster apes?
- First Mods
- could use a little help with pc3 install ,
- Traded Nightster for the LO
- sumax big ass bags
- Saddle Bags
- 2011 Softail Body Control Module (BCM) Safety Recall 0144
- High Flow Air cleaners
- springer question
- I need help!!
- timing cover help...
- Springer Handlebars - new owner
- How many hours to install Boom speakers on a Deluxe?
- Anyone Sturgis Softail, know anything about it?
- Flush mounts, tach, headlight
- Best Solo Seat for Softail
- Spun Alum Speedo-How long from HD
- Internal gas and brake line Carlini Gangsterapes
- LED Strip on my Heartland Fender
- Fatboy to Heritage Front Fender
- A\Fuel Pak or Race Tuner
- heritage springer seat rail
- Putting a Delux seat on an 1990 Hertage Classic
- Another thanks to Dr V Twin !
- Disc Pad Replacement / Suggestions
- Handlebar mounted Speedo?
- need advice on vance and hines
- Odometer Chaff
- SE chrome back plate ?
- Has anyone found a wider white wall rear tire..
- 2 Part Question
- C&C Solo vs Mustang Sport Vintage Solo
- DNA Wheel Paranoia
- (Video) Ooops no again, Yamaha Star Stryker vs. Harley Davidson Rocker C
- Best cam choice for softail deluxe?
- Help with tank/bars/speedo mod?
- Lower legs.
- Fork Springs
- Harley oil cooler
- Air cleaner emblem question ?
- Chromed Deluxe...check it out
- Rear axle question
- parts ordered... now to wait..
- Rush Stands behind product!!
- Tuner and factory warranty
- Help - Heritage windshields - LRS
- Nightrain
