View Full Version : Softail Models
- 88" Twin Cam, cam tensioner reminder..
- Evo crankshaft pinion bush
- shocks on a harley fatboy
- Fork oil amount issue
- Fishtails and Tune?
- late model Fatboy leather saddlebags
- Console
- inner primary removal
- Ignition Module issue?
- 2008 rocker C hub spacer
- Crank Position Sensor
- Newish rider, need some help from the experienced please.
- 2006 night train vent line
- Automatic Primary Chain Tensioner Issues
- harley timer cover screws
- 2003 heritage Softail Windshield Question - Memphis Shades
- Broken piston rings??
- PowerSport Batteries
- 2020 breakout rear brake problem
- Fork Tube Plug
- Push rod / lifter question
- Build a Fat Boy out of a Deuce?
- Oil amount in cam chest?
- Make Soft tail Hold an A motor
- 2002 Fatboy, things to look out for when buying
- Upper front brake line extension- non abs
- Starting
- Blackline and Apes Question
- 2010 harley fatboy lol
- Fishtails for Heritage
- What Oil
- 08 flstc front fork oil
- De Facto Immortality!
- Price and Sanity Check - 1985 Kicker
- Cranks but no start
- Buying used 103" B motor
- dealership charge for cam removal?
- ISO leather pro leather lowers
- 2012 Softail with upgraded rear shocks as good as new Softail with stock monoshock??
- GMCSierra
- What are these?
- 2015 Heritage -- Legends Revo A ST Softail shocks?
- Front brake light not working
- 1984 Softail clutch and primary
- HD ST Bob 2021. Looking for an ABS Bleeding brake fluid Scan Tool
- 2005 softail torx bit size?
- Mounting a 96" in a 103" frame
- 2003 Fatboy turn signals
- Where to find front fork deflectors for 2015 FSTLN?
- M8 engine cooling
- New Forks for 2005 Heritage Classic
- Jet Size
- FXSTBI Fender Question - Has this Fender Been Altered?
- Sport Glide Front Fender mods, anyone ??
- size of oil hose on 2005 fxst?
- 2018 heritage handlebar swap no power
- groups opinion on whether to change tensioners?
- '21 Heritage Classic buffeting issues driving me crazy
- Handle bar question for Fatboy
- It's gotta go
- 2008 Softail Saddlebags without relocating turn signals
- True Duals
- inch/lb torque wrench opinions?
- Winter transport of my Deluxe
- steering head bearings
- Springer front tire diagram (Cross Bones)
- 2011 Softail Deluxe FLSTN front fork upgrade 21" front wheel
- 2022 Service manual needed? Have a 2018 manual.
- S&S 124" Hot Set Up Question
- Fun towing the Softail
- tighten diaphram clutch from scratch
- primary oil for 2005 fxst???
- Softail or Road King?
- clutch damper spring???
- What cam
- Big bore kit or new engine
- Bobber rear fender help
- Emergency help ya'll!!
- My Bike is not Starting
- question
- Softail not so standard
- Front Heat Shield 03 Heritage needed,
- Screamin eagle hydraulic tension system
- Ran out of Gas (5-gallon tank?)
- Passenger Footboards For Hearitage Softail
- Softail drag pipes wanted
- Cruise control on older softail?
- question about s&s gear driven cams
- I have a strange question
- 2016 Softtail Slim S whinning noise
- Bannasi sweeper exhaust on Euro 5
- Vance & Hines Big shot slash tip replacement
- Front fender riser for FLSL (Slim)?
- 2000 Fat Boy (carbureted) lost spark while riding
- 1990 Grey Ghost Registry
- Need ideas for a bag and phone mount
- Two, Two Pin Plugs On Right Side Of My 03 Anniversary Heartige.
- groups opinion on rear wheel
- FXLRST Saddlebags on '22 FXLRS?
- 2002 Fat Boy FLSTFI fuel pump assembly help
- Need some quick help with under seat wiring on a 2004 FXSTS
- opinions on swapping out strater
- 2009 FXSTC no start
- Speedometer and odometer issues
- What color should I paint my 07 deluxe ?
- Out with the old. In with the new Heritage
- FXBB Chicano/Vicla
- Why So Many Sport Glides for sale?????
- Sundowner Seat on Deluxe
- 08 heritage softail classic
- Transmission Side Door Bearing Replacement
- Has anyone ran a 150 rear tire on their '07 softail?
- Screamin' Eagle Compensator Sprocket Upgrade
- Which 05 Softail deluxe?
- 1999 Softail Standard - Deal?
- 2005 fxst trans chain sprocket trade new belt
- Handling with Rim size change?
- Softail Heritage front fender
- Jackshaft issue
- DTC - "d01CL" ?
- FLSTC exhaust
- is it possible the get replacement key?
- 05 fxst clutch damper spring and damper spring seat
- 2003 fatty Rusty tank
- Build List Decipher
- 200 tire on 2005 softail standard fxst
- problems/2006 heritage
- Trading in 2018 FLHCS, getting new 2022
- Cover recommendation - 03 Heritage
- Low Rider ST bag vibrates
- Neutral
- Old Owner, New 2005 Softail
- new project tire size
- FXBBS with Memphis Shade
- BB Reproduction Bubble Bags
- 03 vs 05 Heritage Classic (differences)
- Fatboy won’t shift down
- 2008 fatboy seat
- Softail slim S 110"
- Custom bike. Would you lose your ass?
- Never Owned a 2000 Fat Boy - Opinion?
- Sport Glide Return???
- Does anyone know who makes these bars?
- 2022 Softail Cast wheels
- CompensatorSproket Replace
- '07 Springer Classic QuestionHI everyone,
- Still Considering Fat Boy - Which of These?
- 17 Softail Deluxe rear tire 150/80 B16 will it fit?
- Clunk from primary case
- Successful Swingarm Bag Install on 2016 FLSS with Passenger Pegs?
- Stock Oil Dipstick Measurement
- Catch Can location
- Screaming Eagle Exuast Contract 2004 Fatboy
- Bullet fairing
- Regulator wired directly to starter.
- Fat boy tin swap
- Thank you Shop Manual
- Stretched Rear Fender
- So what color seat?
- Springer Conversion
- 1998 Softail Custom Brake Light always on, electrical issue?
- ROV Hose in tank
- '05 Springer Softail front wheel question
- Rocker c fuel filter change out
- New and Need Advice
- 2016 Slim- Why Front Brake Lever Soft?
- Does anybody know what size the bolts are on forks 2012 Fatboy Fatboy low
- Sometimes you just get some joy replacing a turn signal
- question
- 1998 Softail Custom Fuel Guage?
- Tired of being short!
- 2006 Heritage Softail Classic offset passenger footpegs
- Wrecked 2003 Heritage Softail
- Tall guys. What kind of seats are you running?
- Heritage starting issues
- battery care at long term storage without power
- 2007 Fatboy header bolts
- Is it possible to convert a carburetor FLSTF tank to use on a fuel injected FLSTFI?
- NEED HELP!! EFI cuts in and out on my 2003 FLSTCI
- 2000 Softail Duece Rear Brake Piston Size
- Front end damage
- Odometer Not Functioning
- Engine options for 06 efi softail.
- Screaming Eagle II exhaust slipons on a 2013 fatbot 103 twin cam
- Saddle bag brackets or braces for an 01 Softail Deuce
- Oil Temp Dipstick Is Waaay Off
- 2000 owners Manuel
- Softail frame replacement
- Pogo Seat On A Softail
- Rear engine guards for my 2011 FLSTN
- Seat
- can wheel be balanced without rotor and sprocket on?
- Clutch cable
- ISO Front fender skirt
- Oil Cooler
- Tc 88 cam plate question??
- Road assistance needed (or a bike swap)
- 97 Fatboy Choke Question
- Primary Drain Plug.
- How to Get Maintenance History
- Possible to run 150/70R17 on FLSTF?
- Trip reset button
- 2003 Fatboy - intermittent start issue -
- Street Bob Digital Gauge
- Springer Bouncing - Fork crooked?
- Saddleman Renegade passenger seat?
- Fatboy charging/starting issues
- Tail light blinking
- Problem with eaglelights load equalizer / run brake turn module
- What Brand A/C is This?
- First Softail Post Touring Bikes
- How to adjust unknown adjustable push rods!?
- Broken primary mounting bolt
- Question: re Slip-Ons for a Softail Deuce
- Front end wobble
- Metal shaving on my speed sensor
- Stock Tc 88 cam upgrade( 2001 fxstd)
- HD 1.25 Battery Charger 12V - Flashing
- Big brake upgrade for 17" Fat Boy?
- 2000 FLSTC Tank replacement options?
- Pullback Risers
- To lower or not to lower, is the question
- Neets Foot Oil
- Turn signal
- My 124" Build
- P0134 & P0154 codes-in a 2006 Deuce?
- Thoughts on this ape hanger kit?
- Condition of used se203 cams?
- Haley night train
- Who is running fishtails?
- Performance machine rear brake master cylinder rebuild
- Forum Members Helped Me Think
- O8 heritage soft class stalling issue
- AN Big Sucker vs. Naked Monster…
- Fuel sending unit failure.
- changes
- Speedo, T-sig and Idle issue.
- Help with Headlight and Fog/Running lights
- Amp draws 08 FLSTC
- Backfire Cold Start
- Windshield for stretched nacelle
- Crossbones rear wheel question
- Mirror Flip??
- Fat-Boy 04 rear cylinder not running on idle
- Change Tire Size... Brand for a Deuce ???
- Need help with my 05 Deuce
- Manual/Checking oil 1995 Heritage
- 2003 FXSTI Gas Tank on a 2006 FLSTCI
- Winter Storage
- 06 Heritage Front cylinder clatter.
