View Full Version : Softail Models
- what is the best synthetic oil and what do you use??
- I am finally going to it...
- PIC CRAZY!! Before and After
- SLAMMED and FATCATTED!!! Winter Mods are Done!
- Touch-up on the head
- HELP !!!! Headlight Trouble
- went for the 95" upgrade.
- pics of fatcat ehaust
- Started cutting the fender but need some input please
- Need Leather Bags for '03 Fatboy Struts
- exhaust pipe free to 2-1 difference?
- Changed clutch cable - will not roll in gear with clutch pulled
- Just put on fatcat...wow.....
- Sunday ride in sunny socal
- Super Reduced Reach® Solo Seat for Softail?
- cool seat for xbones????
- Looking for
- Forks hit Lindby Unibar engine guard on Crossbones?
- Question about bags for Fatboy Lo
- Cycle Vision Saddlebag Hardware
- Best online tire store
- what i thought of the blackline after my first ride
- Softail Custom to Springer conversion
- Tank lift for 11 Rocker
- 2004 Fatboy iMovie Experiment
- need new front fender for 2007 Springer..
- 80 spoke on the front and 40 on the rear- look wierd?
- Anyone Fabricate a iPhone Charger Cable?
- Can you simply swap out stock bulbs for LED
- 04 Fatboy FI Low Idle and Almost Stalling-FYI
- A few Mods to Night Train Complete
- 07 softail cable routing
- Twin Cam 88.....Octane....?
- Will a FLSTC fit through my front door?
- Lowering a springer?
- Is it hard to replace a clutch cable without removing my exhaust?
- Alright cant wait,can i..
- starting hard since stage 0ne install
- Progressive 422s with lowering bolts?
- Wiring harness issue
- Spring Mods - Fatboy Passenger footboard and Saddlebags
- spike air cleaner
- fatboy exhausts
- My Winter Mods
- Rocker C - Hard starting lately, now clutch won't catch
- dyno
- Lowering rear
- 1st Ride of the Season !
- K&N air filter number for RSD 7 spoke air cleaner??
- Thinking about a Night Train.....
- 03 swingarm on 07
- Arlen Ness 3" extension kit problem!
- Exhaust wrap on Fatboy Lo
- Chrome Trim Rear Fender
- still got fitment issues with pcv
- Need opinions and ideas on a direction for my Train...
- Crossbones - Painting the frame cover - ??
- 2 into 1 exhaust question
- FXSTS - Front wheel change to lower/wider
- Need some thoughts/opinions on Deluxe
- Trouble Mounting License Plate to Rear Axle (Rocker)
- My new C & C solo seat
- Springer Risers
- Cafe Racer style fairing for Rocker
- rocker box
- rear fender swap
- constant brake light
- lower legs swap
- reinstalling speedo issue...
- new programmer
- security system
- Fatcat exhaust here......
- Wtf??
- Headlight replacement
- Radio Shack Siren Install
- Centre stand
- Fatboy Won't Start - Please help
- Risers......the long and short of it.
- Was thinking of putting drag bars on my Rocker C, anyone have advice or pics?
- Softail Deluxe rider backrest
- Gangsters or flying?
- inverted fork mount, rims and night rod
- will a crossbones fender fit my 2003 flstsc?
- Evo Softail Primary/Tranny Oil Change Question
- Slip-on muffler help....Fat Boy
- Alloy art rear turn signals question
- Who makes this Exhaust ?
- Quick Detach Backrest
- Labor Cost to change a Rocker's rear tire?
- Little RUSTY...
- 2011 Rocker warning light ... anyone have
- Stripped torx screw
- Help with installing BCT Baffles!
- torque spec for 09 softail night train for front and rear axle.
- Question socal style
- Anyone used CycleVisions cover up for Nacelle
- HD oil cooler kit and changing the oil filter
- AEE Lowering Shocks???
- Flush-Mount Fuel Cap and Gauge Kit
- My 2011 Crossbones
- Best LED's on the market?
- Night Train fender and seat question
- Cleaning question
- Fender Bib attachment???
- Deluxe Question
- V&H and extended brake pedal
- Rear brake pad replace 09 Crossbones
- Turn signals
- Bought JS Jack and bike it lowered. Cannot get Lift Under the Bike
- Cable options (brands) for my ape set up.....
- advice needed?
- lowering stock shocks
- V & H 2 in 1 with floorboards
- Bel Ray Big Twin Transmission Oil
- led headlamp
- Warning! If you have the Glymer manual for you evo softail
- Arizona Bike week
- Need Some Help!! Starter Related
- Convertible Apes, Who makes similar?
- Transmission Drain Plug
- there goes my plan...
- Stalling at stop lights and such...
- pcv install help
- Removing Vance and Hines baffles???
- Got my new C&C seat and fender bib
- 2005 Deluxe back pillion
- Speedometer/Tach Won't Change Background Color
- New (used) Fat Cat Muffler
- EVO 80in and Ultima pipes?
- Front AND rear fender rails
- Tire Fundamentals
- Heritage backrest studs removal
- My hat goes off to u guys that ride withou a windshield
- Looking for risers to fit on 09 Fatboy with headlight nacelle & 1.5" Carlini gangster
- Pc-v troubles...need input
- 2011 Fatboy lo
- Another "Lowering Bolts" Question
- Chrome Allen Nuts for our exhaust manifold studs??
- Fender bib question
- XBones Riser Helicoil size
- V-Factor Oil Cooler on a FLSTC
- blackline handlebars i need new ideas
- Took the Rocker out for a quick ride today.
- Heritage/Fatboy Rear Fender Questions
- Clutch cable needed
- Fat Boy Lo Wheel mod complete
- Backfiring question
- Auxiliary lighting
- Low profile dot helmet?
- Heritage Style Handlebars (internal wiring)
- Charging System Replacement (tech/ tricks) (pics) plain and simple
- PCIII Baffles Question...
- Cholos exhaust with a Bobtail fender...
- softail standard ape hangers and hardbags
- Got my new 2011 Deluxe:)
- HD Front Lowering Kit
- 2011 Deluxe w/ V&H Big Shots Staggered Black?
- PCV plus Stage II flash
- I am really dumb, tired, or just had a brain fart. (help needed, please)
- Does your Heritage burn oil?
- SERT needed ?
- Engine Guards that Match Carlini Evil Apes?
- Goin apesh!t - progress! (pics)
- rocker box gasket
- Softbrake Mod
- Is it better to measure for cables for an ape install or just go +6?
- KC International Do Not Order Your Mammoths From These Guys!
- nacelle with 1.5 carlinni risers and bars ?????
- What's the difference: Rinehart and Bub7?
- Anyone with 120R yet?
- Speedomoter playing up
- new front wheel
- Bell & Ross NightTrain
- Softail VS. Softail
- 11 deluxe has arrived
- Belt tension
- Cholo's in Hawaii
- What u get for your $
- Headlight adjustment WTF!!!!!!!!!!!
- New HD owner...need advice
- Replacing Fatcat Muffler
- Fatboy Lo Plate Location
- Programming Key Fob on an 07 Fatboy
- diamondback tail section
- Springer front fender mounting thingy
- Deluxe Solo Seat Suggestions
- I'm Done
- exhaust help
- Ultra cool oil cooler
- brake help
- Where Are All The ROCKER C Owners At?
- Fuel tank "pick up tube?" problem
- Fender Rails
- Moving signals off of strut,what to fill holes?
- Crossbones Springer Lowering Kit
- Mechanic says Power Commanders are nothing but trouble!!
- Shock or Transmission Leak?
- Another stupid noob question
- Jockey Shift - Which Way?
- Shift linkage suggestions
- Whats the best spark plug???Does it really matter??
- stage one questions
- Fatboy Lo Tank Badges
- Fatboy Lo Monkey Bars
- Bag guards for Road King bags on Deluxe?
- What software will work with a SERT?
- Which mod? Best bang for 300 bucks?
- Need help with ape install on 02' stamdard.
- Replacing Grips,clutch and brake levers
- Fender bib plus luggage rack on Heritage?
- Stage 1 stuff finally orderd.....
- dbi 2" under fork tubes
- Concidering a 2006 Deluxe
- Mods Completed with rating - Easy to Not so Much
- what would you have done
- Round oil tank install
- Quick Release Solo Seat-Deluxe
- Night Train - Gangster apes, Ride Wrights, Shotgun Shock
- Mommy, what's for dinner? Floorbaord surprise!
- Heritage Classic Taillight Bar on Lo???
- There goes a nice chunk of my tax return!
- 08 Heritage Drivers Backrest for OEM seat
- 2010 Fatboy Engine Shutting Off
- Which connector is the ECM?
- kickstand options
- Why does HD make their engines like this?
- Robin@USKoolines
- front fender trim (softail deluxe)
- Advice on purchaing Heritage Softail Classic
- reflector on rear fender
- Dr. V-Twin strikes again
- Motherwell rack
- Does this sound a like a good performance/sound package
- Can't remove instrument panel!!
- Fork Oil...How Much?
- Help finding a 1-piece stretched gas tank
- evil apes
- Weekend Mods
- tuning work cross bones from taiwan
- wondering if some one can help
- Passenger floor board help
- Stripped Bolts
- LED tail light ?
- fatboy tank decal
- How to Adjust the Springer on My Xbones?
- jetting out the carb
- New 2011 softail deluxe owner
- Help...2011 Fat Boy Lo, Supertrapp X Pipes, missing bracket...
- Cross Bones?
- V&H Duals Install Questions
