View Full Version : Softail Models
- Is a fatboy considered a….
- Aftermarket seats for Softail Slim
- Skid pan
- 3inch 21 Front wheel on a Heritage
- Replace quick connect oil line to engine fitting
- engine oil change interval
- 05 Heritage seat onto a 05 Deluxe?
- 2021 heritage clutch cable aftermarket adjustment
- clutch adjustment
- Turn signals on a 99 FXST
- Load Bearing Index for tyres
- Reduced Reach Brake Lever
- Need help
- Heat Shields and Seat
- 1988 Softail Custom
- Ignition system
- Vance and Hines baffles
- Help with a head scratcher
- 1993 Softail custom
- Need help with rear floorboards 07 heritage
- 2003 Night Train fork oil change
- Tranny question
- More Comfortable Pillion Seat
- Security Light
- Running problems on a 2006 soft-tail heritage
- speedometer/tachometer for 2002 FXST
- Motor swap question
- Custom seat options 23 Fatboy
- Rear tail lights
- S&S Motor?? Umm not sure
- V&H Short Shot Exhaust & Saddlebags
- Another Softail Question...... EVO vs TC
- Learned Something New Today
- Maximus tuning help
- Early Twin Cam Fuel Injector kit.. needed or not?
- Primary noise after starter clutch replacement
- 2022 Lowrider S With a Difference
- Pro street tuner
- Convertable parts.
- 2008 Rocker rear wheel bearing replacement
- Softail Slim lowering question
- Satnav cable fitting to Sportglide
- Best Brake Pads For The Money.
- Drivers Backrest
- Will stock 97 exhaust clear an 84 kicker??
- Low Rider ST seat?
- 2020 lowrider s Cable needs?
- 2017 Fatboy S starter WON'T shut off!
- Frame change?
- Rookie Question
- American Custom Exhaust Systems?
- Exhaust question
- 50,000 mile service
- Best spark plugs 96 Fatboy 80cubic in. 51,000 miles
- 2014 Breakout Rear Turn Signal
- Fuel management systems.
- OTD price for Softail Standard?
- I Made the Mistake…
- BCM absolutely unbelievable situation
- HD Bags fitment need help
- Advanblack Softail Chin Spoiler. Painted to match your bike color preference
- Low rider s issues
- 96 Fatboy info needed
- Frankinstein Build
- 2013 fat boy riser help
- Slim Swingarm on '12 Fatboy?
- softail standard stage 2 / Carburetor upgrade ?
- 2008 Harley Fatboy rear axle nut size
- Springer wheels
- M8 torque
- Drivetrain interchange options
- 2003 Custom Paint set
- Just ordered a '23 Softail Standard (Wire Wheel options etc)
- Trying to change neck bearings
- Cooling fan for the rear jug
- Fitment information for a 1997 Softail springer fxsts
- Shipment of Samson Exhaust
- 2002 FLSTC Tire
- Bad Miles
- Can anyone ID these handlebars?
- can anyone ID this seat 18 Deluxe
- Please help! Softail slim 2013 seat ?
- Dash cam
- Shifter Lever Bushings 07 heritage
- Softail tank panel
- Blinker Eliminator for 2004 Softail standard
- 2005 Softail Hard Candy Purple. Factory custom color?
- 2010 fatboy lo
- Fork spring spacers preload
- Yet another security fob post
- Inconsistency power issue with TC88 engine
- Fatboy wheels on a Heritage
- Freedom windshields
- Paint question
- Solo seat mount, 1 bolt or 2?
- 2002 Fatboy Starts Then Dies Story and Solution
- Do I need a new starter ? 2015 fat boy lo
- High Flow Air Cleaner for 2009 Softail Deluxe
- 2006 Heritage Classic Starter issue
- Softail mini seatrest for fender luggage rack?
- Heritage softail lower fork covers
- Oil in crankcase
- Slim S new look
- late model Fatboy with 4 in Pullback riser
- 2005 Heritage Classic Transmission Housing Replaement Cost/Hours
- 2013 Fatboy-Speedo doesn't come on sometimes but still starts and runs
- Relocation Kit For Rear Bag Guard 03 Anniversary Heritage
- Tire just a little too wide
- Hoping for some help in identifying the modifications to my 1998 Softail
- 2010 heritage softail turn signals
- Saddleman for Lowrider S
- 95 softail Vibrating pulling off
- 2012 Fatboy Low Starter Motor Replacement
- Year 2000 carb. Fxst data link
- Fender questions
- No start lol no manual 05 flstfi
- Cafe fairing usefulness
- 2005 fat boy rear turn signals
- swapable?
- 2017 slim s heated grip interconnect location
- Mini apes
- Great guy, helpful and honest
- Fatboy fuel vent tube leaking
- Fat Boy Dash
- Engine light
- Fatboy won't start
- Before and afterpics
- Larger Gas Tank on 22 Street Bob
- Considering an older Heritage (2000 - 05)...Still viable?
- 96 Fatboy won't start
- First 3-hole
- Back running lights and blinkers issues
- Heritage Tire Pressures
- Changing exhaust on Night Train 08 (Oxygen sensors)
- 2004 Softail drivetrain swap?
- brake/runnuing/turn signal light conversion
- Rider backrest options for 2014 FLS?
- Fog lights not working
- 2018 Deluxe turn signals
- Runaway throttle
- Brake pad 12 point bolt size?
- Help finding upper motor mount
- Maximum handle bar upgrade
- 2” thick ape hangers
- Hydraulic Clutch Conversion…..anyone done one?
- 2016 Fat boy 103 insanely hot exhaust pipe blazing hot
- 2002 harley fatboy
- No start, bcm?
- 2001 88 to 107
- Tab Slip-Ons Breakout
- 07 fat boy twin cam motor
- 2005 Heritage softail
- Manhattan wheel
- Front turn signals
- Front cylinder intermittently dies
- Footpeg feelers
- New front caliper or rebuild?
- jump the starter solenoid
- Blue Collar Blackline Update!
- swingarm
- Street Bob turn signal switch relocation.
- 2003 softail flooding
- 2003 Heritage Softail - Rear Wheel Removal Questions
- Need clutch recommendations
- New 103 cams
- New Member
- 21x3.5 wheel on a Deuce
- 2022 Fatboy - Round Headlight Housing
- Rear wheel size
- 99 Solftail Custom Indicator Lamps
- I need a chrome swingarm, where are they?
- Screaming Eagle Air Cleaner element rusting
- Tsm
- 2022 Fatboy Replacement Headlight or Front fairing that fits the Nacelle
- 02 Deuce Backrest
- Security system 2011 heritage
- 2013 Fatboy Lo: High beam toggles to low beam
- Service Manual
- Rough idle in 1st gear
- Never touched a harley in my life, until today... Cam timing question
- Ride on wheel balancer and sealant
- Engine idle
- Road King Leather bags on a Heritage??
- Trans plug debacle
- Starter issues
- Lowering kit
- New Rider, New Member... 2007 Deluxe.
- I made a DIY Catch Can to keep the oil out of my air intake
- 09 CVO Springer 100 mA Electrical Draw
- 2010 Fatboy conversion to wider tire, short fender
- S&S 2-1 superstreet "Race Only" exhaust??
- New to me Heritage
- 2012 Softail slim footboards to pegs
- Help needed with Thrashin bars and risers
- Softtail Slim 2015 Breakout box
- 21" front wheel question
- 07 Softy
- 2008 softail rocker fxcw led fuel gauge
- 2003 anniversary with low miles - what to do to future proof
- Questions regarding a 1998 fatboy
- 2000 fat boy questions.
- 2023 FLXRST Won't Start
- Rear fender strut question
- Back in the wind
- FLSTN seat on FLS
- Don't Like Farings
- Stage one unfinished breather bolt covers
- Notchy steering
- Saddlebag Recommendations For 03 Anniversary FLSTC
- Night Train won't start.... start engine done?
- White seat?
- CVO CENTERLINE 16x3 Rear wheel fitment
- 2012 Fatboy stalling issue
- New tires for a 2000 Softail Heritage Classic
- 22 fatboy seat
- Exhaust
- 08 Heritage. Help!I wanna throw some money at it
- Fxlr rhotos
- spark plug color
- 2008 CVO springer lean angles 28°left\32°right..WHY?
- Very high pitched noise Softail 2003
- Stainless Steel Exhaust Clamp nuts, bolts?
- 22 street bob stock suspension brutality
- 2007 Heritage rear brake locking up
- Bolt/ screw size
- 2003 fat boy strut bolts
- Front wheel spacer
- Heritage 114-Saddlebag mounting bolt torque spec
- 2017 FLSTN new wheels, chrome forks, progressive lowering springs?
- Issue with horn, turn signals, and brake light 2012 Heritage
- TSSM question
- Which hardbag rear fender set up for a Heritage?
- 2008 Heritage Do you need to remove stud plate to install 2up seat
- Are wheel hubs from different manufacturer interchangeable?
- Have the itch to ride again, breakout?
- Wheel Balancing
- 2000 Softail Deuce Tank Fuel sensor gasket
- axle size / wheel
- Clamp
- Front Ax;e cap pinch bolt socket size
- 2019 Heritage Rawhide and Black Pinstripe question.
- Saddle Bags for my Fatboy
- help me understand Softail vs Slim vs Slim S please
- 2013 ultra seat fit a 2010 heritage?
- Early softail suspension
- Model of This Harley
- Options on motorcycle shops (not dealers) around South Florida
