View Full Version : Softail Models
- Question re: coil & horn relocation using DK Customs kits
- Making 2020 street bob louder?
- 03 Fatboy new to me issues?
- Ultra fairing lowers on '08 Deluxe
- Flstf 1999 fatboy evo
- 2011 Blackline wont start (sitting for 6 months)
- First HD - In Love
- Carlini bar install
- the non-baggers
- '01 TC-88 - possible oil sumping?
- Your Dream Front End?
- Picked up a 2012 Deluxe
- Solo bag
- 2009 Heritage Tank Trim
- Swing arm stop bumper for Ultima Softail
- My 87 softails different builds
- 2017 footboard to peg conversion?
- FSTF Speedo light and Odo not working, no signals
- Grips not fitting new bars
- What can I do to fix this eyesore
- security issues
- 2004 FLSTCi Solo Luggage Rack
- Hayden M6
- What air suspension is this?
- Nice set of Bluetooth speakers for my bars?
- paradise lights
- Tires
- Coil Testing question
- Removing heat shields off D&D lowcat
- Clymer service manual?
- Modifying passenger pillion on Mustang Wide touring seat
- Looking for a new set of slip ons (black finish)
- Does anyone have a video of Harley Breakout with 120R motor installed?
- 2012 FLSTC Fuel Lines "HELP"
- My 1st harley
- ByeBye Cow Bell
- Need Info - 2003 Heritage Springer & Heritage Softail Classic Rear Fenders...
- 04 Deuce engine noises (Help)
- Floorboards
- 2010 Wide Glide Peg
- Seat Nuts
- Extension cables for Ape Hanger upgrade
- Fat Boy front wheel spacers
- Heritage Wheeze
- Looking for Fairing
- from Ol' Reliable to "oh god what is IT!"
- Fuel line replacement 2012 FLSTC
- 2013 heritage softtail classic rear brake caliper
- Primary Drain Plug
- What do you think of the 1999 Fat Boy
- 2020 Softail Standard mods
- Whiskers Adjustable Highway Bar | Gloss Black - 50865-09
- Rear shock travel
- Upsweep Pipes
- oil drain hose?
- Dem Buttcracks, tho
- Rear brakes noise. (Not squealing)
- 1999 evo fatboy seat HELP
- 19” sportster/fxr front wheel on a softail?
- Extended brake cables.
- Vance & Hines Big radius 2-2
- Need help custom exhaust shop in L.A. area
- 130/90B16 on front of 2011 Heritage Softail Classic (load rating)
- Horn Relocation
- Sticking shifter - up and down
- Cylinder shut down when hot
- 2017 Softail FLS Primary Quantiy wet vs dry
- Alarm Speaker for 20 LFXLRS
- 2007 FLSTN wheel change
- Good aftermarket fenders
- Thunk in the front end
- 2018 Heritage springer
- Solo seat on 03 softail mounting
- Help Me Solve The Headlight Equation!
- Biltwell Kestone Bars
- '17 Softail Slim Passenger Footpeg Bolt
- FLSTC seat change question...
- Harley fork mounted wind deflectors
- My adventure at trying to buy a Night Train
- Newer rear caliper for '85 Softail
- Help with windshield spacers
- 1994 Fatboy Specs
- Spark plugs
- Folks with 21” wheels, steering adjustments?
- Swingarm bag
- Anyone with a 2016-2017 Heritage
- Cylinder Fans
- FXSTD Deuce - Not Starting - Pls Help
- Pinging heritage
- Check enigin light
- 2017 BO narrower rear tire
- question for the taller riders here??
- Oil capacity???
- 06 FLSTCI Exhaust
- Softail seat Q
- New machine
- Switch cover replacement without cutting signal light wires
- 21" front wheel.
- Visual Difference between 96ci and 103ci
- 2009 Harley Rocker C
- Harley primary chain case oil level
- Harley OEM Texture Black Air Cleaner kit questions
- What seat is this
- FXSTS rear suspension height
- 2005 Exhaust question
- Tire problema ?
- Vibration in front at high speeds.
- Windshield ideas for 2001 softail std.
- Mag wheels for Slim
- Softail Slim Owners HELP!
- Extended forward control kits
- Removable saddlebag options for older Softails? FLSTC
- 2009 Night Train rear running light keeps blowing fuse?
- Faultcode P0662
- 06' Softail Deuce EFI w/ 04' Carb Tank
- 2001
- Anyone have issues with counterbalancers on earlier TC's?
- Horn not constant and front brake flashes
- Front Brake Issue?
- 1998 Fatboy fog light fix
- Help for a new Softail Owner
- Harley Back rest
- HD Softail Seat Question
- Safe to ride to dyno tuner
- Show me your seats!
- Fat Boy Low electrical issues
- Help with startup noise diagnosis
- Slim S LED Gill lights installed. PIC LOADED
- 2011 103 RK vs 2009 96 ST cams
- 2017 Softail Slim S Pullback Risers
- Limited Edition 30th Anniversary Fat Boy Celebrates Model's Iconic Status
- 2004 Heritage Softail Classic seat installation
- FXCWC brake light
- Softail Deuce Twin Cam
- Bars and lowering!
- Softail Slim Accessory Bags Falling Off
- 2008 fhstc teflon tape on transmission drain plug
- Vance & hines slipon's
- Tube for DNA Mammoth's
- 2011 FXS Blackline Handlebar
- True Duals for Deluxe
- Crossbones Headlight
- The Softail Standard or the Softail Slim
- Commander 3
- What to Look Out for When Buying 1991 Heritage
- Need advice
- Crossover fuel line
- 240 wide tire conversion kit
- rear lights
- front braking problem
- Neutral HELP for 2018 Fatboy
- S&S 100 kit or 95 hot kit?
- 2000 heritage with sudden vibration
- Pics of a Blacked Out SLIM with 19" Front Wheel and 17x4.5 Rear Wheel with 160 Tire
- Kick stand
- 2016 heritage internal wiring
- Deluxe Rear Seat
- CVO muffler mods
- New guy from Alabama
- 2007 softail deluxe no start question
- Dyno Tuner in Northern VA?
- slim rinehart help
- Just put 21 wheel on fatboy
- Rocker axle bolt
- Breakout part query
- New to me efi heritage springer
- Looking for help on extended forward controls for 2017 FLS
- Any reason why this wouldn't fit an earlier model softail?
- Fork tubes
- 98 fxstc ticking noise
- Rocker c tail lights
- Spark plug info
- 07 Fatboy handlebar options
- Engine Guard Fitment
- Hard cranking 2001
- Fatboy owner with mustang tripper photo
- Leaking primary?
- 2017 Breakout Fuel Gauge reading “LORNG”
- Rear fender Rocker C
- No fuel pump sound
- 1990 Softail custom strang question need some input
- Chrome Turbines
- Rear foot peg swap
- Rocker battery tender
- 7" CREE Head Light question about halo
- Hogworkz LED Halomaker installation
- Cover
- Softail Heritage FLSTC Spark Plug Removal
- 2000 flsts passenger seat
- Headlight Upgrade
- 2006 Night Train
- Help with 1998 Fatboy Carburetor
- Oil fat boy
- Deuce Luggage Rack???
- Brake/directional light US to UK spec
- Is the Heritage Classic 114 Crap?
- Pic Request: Chrome or Stainless Cables
- 2008 rocker c rear tire
- Interchangeable wheels
- Bike troubles
- Starter opinión work out?
- need a tach for my Deuce
- Dunlop or Metzeler White Walls
- Ordering a new bike from the factory
- 2000 soft, cam tensior upgrade
- Wild1 WO508 + 1" Riser Kit (HD PN46809-09)
- Larger front wheel for sport glide
- If you had $10k and wanted a fatboy...
- Engine swap question
- Any helpful pointers on exhaust swap?
- Softail Primary clunk
- no brake lights.
- New mufflers for my 17 flstc
- Thoughts on a high mileage engine
- Question about Michelin Scorcher 240
- Lost signal to left throttle handlebar controls
- Do bigger wheels/tires and lowering cancel each other out?
- Oil Bud Oil Cooler
- harley one piece sissy-bar
- LED in the tailight is facing up only covering half the lens
- Blackline, how's the ride?
- Need help for cable kit
- KST Kustoms apes
- Advice on Arlen Ness 3' control extension
- Night train
- 2004 tins on a 2007 (Heritage)
- FXST Tire advice, same size with different widths.
- Newer softail tail light mounting
- Anyone with a Tuner in a big urban/metro/city like NYC or similar?
- Heat Shields - Something a Bit Different
- What is a fair price for a DD6 install?
- 12 deluxe w ultima king spoke fitment issue
- Fxstc risers
- 1988 FXSTC Troubleshoot
- Small shield options for heritage. Can a sport glide fairing be retro fit?
- injector, plugs, coil,
- 06 softail deluxe
- 06 softail deluxe auxiliary lights
- Softail deuce value?
- Deluxe turns Evil
- Low oil but no warning light
- Rocker C, flush fit front axle
- Rifle scabbard?
- 1998 fatboy speedometer
- New ride :-)
- Will a dyna saddlemen seat fit the new softail model.
- Rocker fenders
- New exhaust on my Heritage
- 2000 FXST Tire and Tube advice.
- Saddlebag lid removal
