View Full Version : Softail Models
- 05 HD softail Deuce FXSTD power lose
- '04 Handlebars on a throttle by wire bike, what to expect?
- softail flsts 98
- Anyone Using Legend Revo-A ST Shocks On Their Softail?
- high flow air filter that looks "old school"
- Neutral light will stay on even when bike is off
- quick question about cam plate removal 2003 softail
- Vance and hines exaust with the exta quiet inserts still too loud
- Anyone switch to a 5 Gal tank on their 18+ Breakout?
- 2:1 Exhaust opinions - HELP
- Cross Bones Windshield..?
- Thoughts on buying a Fat Boy?
- Back on a Train
- Bad Leak - No Oil
- Fork Oil Change
- Deciding between an '09 96 and a newer 103...
- 2008 crossbones
- 2000 FXSTB speedo not working
- Passenger Floorboard Kit FLSTF
- Why do I have 2 stop switches?
- A tiny battery to put the Ecu under the seat next to it? But 113ci?
- oil dipstick
- Oil spray on left side 23 heritage classic 114
- BCM code 62156c
- Blackline issues
- Blackline issues
- Guess I can slum over here too now
- Carb jetting advi ce 05 fxst
- Inverted forks for FXBB
- 2004 88" Deuce
- 1988 softail custom
- 02 Deuce Twin Disc Upgrade Questions
- shocks for my 2017 Heritage
- 2002 fatboy vs 2006 fatboy
- 1983 Low Rider has both a kickstarter and a Start button
- No rear running lights
- Arlen Ness 15" Jagged Big Brake Rotors, Hub Mount
- Use port
- 96’+ Grip Conversion on a Pre ‘96 Bikes?
- Can saddlebag hardware be changed?
- Bleeding Brakes
- Ultimate
- 04 Deuce
- Paint codes for 84 fxst
- What year tanks are these?
- Speedometer mount compatibility
- 2011 harley-davidson softail deluxe turns on but no power p&a 15a
- 2023 standard muffler mod
- 2015 Breakout Arlen Ness big monster problems.
- Key fob 2023 standard
- 2015 softail slim rear fender change
- Bike won't start - turns over but won't idle and backfires
- 2003 EFI Softail stutter when cold
- 08 Rocker C Starting
- Carb / Air filter issues
- Chrome cap on the forks
- Quiet python pipes down?
- risers of low rider
- 02 Deuce Starting Issue
- What's the value of a NOS Fat Boy front wheel?
- Ultima 6 Speed - Correct Alignment of Transmission
- Heritage Springer lighting issue
- 2017 FLSS Torque Specs.
- Don't buy a Heritage Classic until you read this!
- Air Filter upgrade retune?
- help
- 05 fxst need help load stabilizer
- GIVEAWAY - ThunderMax EFI ECM module for 2011 Cable Operated Throttle!!
- 2019 Heritage Classic 114 Digital Display Brightness
- New bike 1000 miles service
- 103 top end on a 96 inch ???
- 2020 Heritage Black Seat Studs
- H-D Chrome Windshield Trim for 2009 FLSTC
- Use Trans fluid extractor on 5 speed?
- V&H short Shots 2013 exhaust to 1988 Softails
- Speedometer Accuracy
- Problems with 23" wheel on softail slim
- 2004 Fatboy wont start, speed and odometer doesn't work
- Recommendations for selling a harley.
- 1997 Heritage Windshield
- Arlen Ness 3" Forward control extension
- 2024 Fatboy Passenger backrest
- 03 FXSTB rear wheel/tire options
- Ignition problems?
- Softail Springer owners. What tires do you run? Dunlop Shinko, Avon?,
- Front brake light switch replacement FXBB
- Tssm
- 03 Softail saddlebags question
- Oil tank removal
- Primary Cover Hole Plug
- 2017 Heritage Saddle Bags on a 2006 Heritage
- 2002 Softail Springer, Can't remove sissy bar rear bolts..
- 2000 FXST - Gas Range
- 2002 Fatboy turn signals not working
- harley one piece sissybar
- Seat recommendations for 2012 Fat Boy Lo
- Fat Bob 114 rear wheel problem
- 03 deuce looking for compatible windshield help
- 107 to 129 build advice
- M8 Fatboy thread?
- 09 Fatboy belt problems
- 6 gallons for street bob
- Slip-on exhaust options for FatBoy114
- 117 lean bog after tune and cam
- Anyone in Pittsburgh possibly help please??
- Harley Passing light (frenched) trim rings.
- Anyone have a harley manual for fxsti?
- Lowrider St Ape Hanger question
- 21inch front fat spoke, caliper rubbing on the spokes
- Short, Fat, and need a new seat!
- What you do to you are Softail today
- 1994 springer softail
- Harley is Dissing Softails
- 2001 FXSTBI TSSM/ECU/FOB headache
- 2019 FXBB w/ 107 sage 2 using oil
- FXFBS Speedometer fogging
- Speedo not workin
- Vin number stamp
- eBay forward controls
- Aggressive sounding cams
- Can you please tell me what this is?
- Windshield advice please
- Stripped Rear Brake Pad Pin Bolt Stuck on Caliper
- Horn upgrade
- Engine Size - Conflicting Answers when searched
- 04 Fatboy Bogging on hard trottle
- Grey wet grafite looking stuff caked to my clutch pack
- Oil pressure I tank issue. Blowing cap to the roof. Yes I’ve tried some things
- brake light sensor removal
- oil cooler line repair advice
- 2007 FXST build in Japan
- Softail 2007 won't start
- Help totally confused about Seat with Driver backrest
- 2004 Fxsti turn signal issue
- I need some options on what I found.
- Shouldn’t the Lowrider ST come with forward controls and floorboards
- Fat Bob Replacement Saddle
- Kickstand help
- FXSTI rear shocks
- ACR on Fatboy 103
- Touring legs on an FXST
- 110 Upgrade Help
- Will this work? I’d really appreciate help!!
- Long Road...but no miles yet!
- 06 springer high pitch screaming sound
- 2008 Rocker C 96"
- Electrical short is killing me...... and my batteries. ('93 FLSTC)
- 2007 night train issues
- Where to buy 2004 Flstci SoftTail Light Mods?
- Suspension?
- Lifters on 2008
- dumbest question in 24 so far.Dumbest question in 24 so far.
- Help please, instructions needed
- ECM Codes and Loss of Acceleration
- Engine swap
- My new to me 02 fat boy
- Anybody put chrome LAF pipes on a Fat Boy?
- Trade street bob spoke wheels for later street bob mag wheels
- '07 Fatboy With Melted Battery Negative Post and Transmission Issues
- Could Have Been Worse
- Headlight bulb replacement for Heritage.
- My Rear D401 ...
- Got a 2002 softtail bobber
- Speedometer not working
- Aftermarket speedometers
- Back in the day when Harley cared about you..
- Will this work on a 93
- identify this part on my new 2003 FLSTC
- Another cam thread
- ACR Valve
- 2016 Fatboy S front hcu problem leading to empty battery
- 05deluxe: Options for clutch cable that’s too long
- Am I the only one?
- Trailer Length Question
- Corbin seat for Fatboy
- 21 Heritage 107 or 23 Heritage 114
- Slim 103 vs 107 heat
- Low Rider ST question for current owners
- Springer Front Wheel Alignment - FXSTS and FXSTSB
- Is the 2023 OEM STOCK HEAVY BREATHER GOOD?
- 2017 FLSS Transmission fluid transfer
- Jackshaft bolt
- Fat rear tire treadlife
- Anyone use black wrinkle paint for the motor?
- New front brake reservoir
- Rear brake master cylinder repair
- Low Rider ST - rattle in mid-range RPM
- What mirrors with 16" apes.
- Softail Slim S vs. Heritage - 2 UP
- Any good Indy shops......
- Front fender trim for 2009 FLSTC Heritage Classic
- Springer softail
- help!
- Tire options
- Seat Upholster
- 09 FLSTC dies when coming to a stop
- B2206c won't clear after popping loose connector back in
- 2016 Breakout Ignition Pain in The Ass. How to Upgrade? Upgrade
- Floorboard rubber insert help
- Delete M8 oil coolant lines
- Happy 28th anniversary with my Springer!
- Passenger pegs mounting
- Taillight stuck on.
- Captain America
- 1997 Heritage springer floorboard advice ?
- Need some help, I hope I’m right. Ugh
- Measurements on 2006 Fatboy Cvo Highway bar
- Oil dip stick blew out!
- Riser dampers and cable extensions
- Throttle cables
- Pink goo in transmission
- New to me 2016 Heritage classic
- 08 Heritage rear turn swap
- 2000 Harley night train motor issues
- Advice for Swingarm Pivot Bolt Cover usable with Passenger Floorboards
- Heritage bags on a 2007 FXST
- 2012 Fat Boy Lo - rear tire question
- Will this work?
- 07' night train
- 2013 Breakout FXSB Tank Console
- 6 gallon split tank photos (EVO)
- 1997 heritage springer or 2009 Heritage Softail
- 2007 Deluxe rear wheel bearings, which one first?
- Heritage Springer handlebar grips
- 2003 fat boy efi. No power with ign ON
- 2007 Heritage fuel pump issues
- 15 Fatboy lo
- How to Connect 5 Wires To Hook Up Battery
- Heritage Classic/Springer Exhaust
- Rear passenger seat screw hole plug for Fatboy
- Urgent help needed- pushrod oil
- Whats the fix for the heritage rear fender mis-alignment???
- Windshield Frame for 18+ Heritage Softail
- Breakout Tire Wear / Leaning Issue
- 2003 Heritage Loud Rattle at Idle, esp When Hot
- 2013 Heritage Softail classic Exhaust question
- Harley Tuner and Cats
- Weekend Plans for my Heritage
- Portable battery tender
- Red oil light turned on then disappeared after turning the engine off and on again
- 06 heritage efi
- Exhaust options for 2018 FLFBS
- 3 ignition wires the red wire in middle the other 2??
- Help with oil leak
- Pucker Moments...
- 08 Night Train ''boiling'' on warm start-up?
- Anyone using the new Rekluse Apex Clutch?
- Need a windscreen for my 2009 Crossbones, please help.
- Seat information
- Help….Softail Hard Touring Bag Conversion
