PDA
View Full Version : Softail Models
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 [93] 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343
  1. Do I need new tires.
  2. First Ride after winter Not Good, replies please
  3. Ride wright wheel falls apart? Scary
  4. Coil relocation
  5. Andrews 48H Cam
  6. can someone clear up all the miscommunication... what size grips?
  7. 2008 FXCWC service manual
  8. Used Night Trains worth more than other softails?
  9. Buying a New Softail - Deluxe vs Heritage
  10. Sharing this
  11. 2011 Heritage Classic Fender Trim, can it be swapped with for the Deluxe fender trim?
  12. arlen ness 07-611 +3 forward controls on a Rocker
  13. noob with mod questions
  14. Which LEDs for 01 ST Speedo?
  15. What kickstand for crossbones ?
  16. 2009 Rocker rear brake anti rattle spring
  17. 1990 Heritage misfires sometimes
  18. Engine Oil, Trans, & Primary/Fluid capacities...PLEASE CONTRIBUTE!
  19. Another " oh no, I hope this isn't bad !!! " Thread ... by Yours Truly
  20. How soon is too soon...
  21. Pulled the trigger...Shotgun shock on the way.
  22. website for HD models: oil trans, & pri capacities
  23. 422 vs shotgun at STOCK HEIGHT
  24. Winter mods to slim
  25. Quick Detachable Bags
  26. Good brands of 1" spiked grips and pegs
  27. 21" front on evo heritage
  28. Need Heritage Springer Ape Recommendations Please
  29. 98 Fatboy with neutral light issues
  30. how do i remove fuel rail to get to injectors?
  31. What is the best way to extract oil out of trans?
  32. Went ahead and installed
  33. 2014 Breakout or Softail Slim?
  34. need help... quick release windshield mounts 96 heritage
  35. Akrapovic Exhaust
  36. I'm lost...tune question. To tune or not
  37. Picked Up The Bike Today
  38. Loctite in the Breakout ignition switch now!
  39. The Breakout side stand is better than it looks . . .
  40. Labor charge to change front drive belt pulley?
  41. Dimensions of swingarm bag? And better mount? Better bag?
  42. Apes for my 2012 Slim
  43. Is removed speedometer "married" to VIN of bike it came from?
  44. Heritage Classic True Duals?
  45. 97 softail springer head light not working
  46. Shotgun Shock install on Breakout
  47. Arlen Ness 8in modular drag bars
  48. Price for an 2007 Heritage Classic
  49. outer primary cover part number
  50. Help ...need pic of Apes on Softail Deluxe with ABS
  51. New Breakout owner...
  52. removing adjustable pushrods?
  53. Breakout forward control extension?
  54. building a 2 into 1 exhaust for a 2011 heritage
  55. Memphis Shades Batwing
  56. Changing tins
  57. FXSTBi 2006 Front Stoplight Switch ?
  58. Samson shift rod
  59. Slim sissy bar options
  60. Harley Speedo/tach Help
  61. New Rear Fender, DIY Heartland look on the Cheap
  62. To see what Yall think
  63. Anyone running LA Chopper Tree Hugger apes?
  64. Fat Spoke stock tire question
  65. Starter issue
  66. * The Stretched Fender Thread*
  67. Se heads-vs-stock heads and headwork.
  68. breakout blackline dash - NEED HELP!
  69. Going from 18" apes to 12" Heritage bars
  70. RSD 49mm fork caps and headlight bezel
  71. New fender installed
  72. Batwing Fairing on Softail Slim?
  73. Whats my bike worth....
  74. Engine management light
  75. 2013 FLS (slim) Cant find luggage rack that will work with sissybar???
  76. Chrome bolt cover question...
  77. Fuel Gauge
  78. 08 Fatboy stock seat question
  79. FXSTD Winter Updates
  80. Ape hangers on a 96 heritage softail
  81. Heartland's passenger seat
  82. Breakout LED Fender Brake/Turning/Running Light Installation
  83. 21" Whitewall
  84. Carlini Gangster Ape Hanger question
  85. Shotgun shock tranny oil plug clearance issue
  86. eBay Headlights
  87. My new 2014 Breakout
  88. Did Vance and Hines just blow away all tuners on the market?
  89. Digital dipstick accuracy
  90. Battery indicator does not light
  91. Shovel Head Softtail
  92. Rear fender question for you guys?
  93. 97 harley softail wiring diagram
  94. Dumb question- proper place to run additional power to handlebars
  95. Breakout exhaust question fr newbie
  96. Opinion on mirrors
  97. Lowering
  98. ...2014 Softail Slip On...
  99. Night Train or Standard polished rear wheel care.......What product?
  100. Question about lowering the front and wheel size
  101. retro deluxe with sprung seat and almost rigid rear
  102. Want a change
  103. alarm - aftermarket vs harley
  104. clutch bearing gone bad....?
  105. 160 tyre on a Softail Slim?
  106. RSD 12" Vintage Vs Wild 1 Outlawz
  107. ape hangers
  108. Opinions please
  109. Hard Start..Can you make it better?
  110. Breakout "out the door" price...
  111. Bo wheel
  112. Bike Top End Problem
  113. Front end wobble!
  114. NIGHT TRAIN SCOOTS! Which Front/Rear Tire are your rollin' on?
  115. Picked up my Breakout with Stage 4 Racing kit plus D&D Low Cat exhaust!
  116. Axle Sizing - Hard to find
  117. Flush Mount Caps On BOTH Sides???
  118. 97 Heritage Springer Motor Build question
  119. Anybody own a Pitbull Motorcycle lift??
  120. First Softail Deluxe
  121. Breakout mirrors and seeing around my arms
  122. Removing FLSTC bags
  123. Today i noticed
  124. Question
  125. Fender bib for Breakout?
  126. Detachable side plate vibration
  127. Another Wheel Bearing Question
  128. Rubber covered switches for Shotgun Shock
  129. 2002 FXSTD - So Long Stock Bars
  130. rider backrest options for a deluxe
  131. Looking for a new windshield
  132. Question on Wheel Fitment
  133. 07 floorboards
  134. 07 FXSTC Backfires through exhaust, won't start
  135. Spotlight Mod
  136. 19" www, what height to fit 2012 deluxe?
  137. Let's see your grips
  138. Pinion shaft question...
  139. Can a softail look like a rigid bobber and still be cool?
  140. oil Temps
  141. Troubled Softail
  142. what is differance in power commander autotuner for heritage and other softails
  143. Drag Bars on a Slim
  144. 2004 springer
  145. Relocating Rear Turn Signals 04 Fat Boy
  146. Fuel
  147. Oval Floorboards
  148. Blackline wider front tire
  149. New member lookin for some help
  150. FLS Slim and Right Side Tool Box
  151. Anyone purchased from these guys?
  152. Need Deuce help
  153. Cross Bones front brakes
  154. Finally Rode Today
  155. Paint Ideas
  156. Why did I wait so long?
  157. my new 12 Heritage
  158. Engine paint anyone?
  159. hd light bar #68669-05a
  160. dip stick leaking oil
  161. changing 2013 heads for heads without acr
  162. Chrome lowers for my deluxe. Please help
  163. How to put the HD digital speedo into setup mode??
  164. New 2014 black FLS
  165. white walls for 200mm rear tire impossible to find?
  166. LSR 2-1 Pro Stock Pipe Question
  167. Wheel bearings
  168. Breakout,, help with wiring Accessory power for handlebar mounted player
  169. power commander v question
  170. 12" Ness Modular Drag Bars
  171. Swingarm Bag Mounting Kit
  172. quick question
  173. Heritage Classic Exhaust
  174. Lowered Softails.........how do you like yours and how is the ride overall
  175. Adjustable highway bars
  176. my first deluxe!!
  177. Question about ABS and short brake line
  178. Which one? Private or Dealer?
  179. Bagger joining the Softail Community
  180. Shotguned in Oklahoma City.
  181. Samson mini cholos 36" on a 2012 Softail Deluxe?
  182. 19" wide whitewalls
  183. Buying a Heritage
  184. 21" Wheel w/sealed Bearings to 16" Wheel w/ non-sealed Bearings
  185. bigger headlight and turn signal combo for my fxstc???
  186. Samson Fishtails for 2014 Deluxe
  187. Hard Bag Latches
  188. How do I get the pins out of my turn signal connector?
  189. How to Tell if ECM Calibration has been Done
  190. Any companies make a bike cover that works with apes?
  191. screaming eagle 211 cams question
  192. Russ Wernimont Designs Low-Profile Dash
  193. solenoid push button end cap for 89' softtail
  194. suggestions for swingarm bag. Viking?
  195. My Breakout After A Little More Black
  196. 2013 FLSTC Handle Bars
  197. Alarm siren installation on a Breakout?
  198. Best place to buy for UK Buyer
  199. Flush Mounted Fuel Gauge and Gas Cap Questions (fitment question)
  200. Softail lovers - see Jim G's posting under "engine mechanical"
  201. Powder coating Deuce rear signals - how to take apart?
  202. Help/Advice 21'' front wheel
  203. Rocker C passenger options
  204. Thoughts on Pirelli Night Dragon tires?
  205. Vance and hines big shots front head shield for softail
  206. FuelPak Rocks!!!
  207. Softtail vs. Fat Bob
  208. What oil do you use?
  209. rear tire change question
  210. Harley color shop tanks full if bondo WTF?
  211. floorboards on an fxst???????
  212. "No RSP" error code on Engine Diagnostic
  213. 2000 twin cam, mikuni pilot&main
  214. fxstc fork tins???
  215. HD Night Train - Black wrinkle finish.........
  216. Softail Slim passenger pillion
  217. Heritage Rear Crash Bars On A Deluxe
  218. Just checkin in....
  219. Anyone Ever Heard of These Guys?
  220. Softail slim fender conversion - 2up problem
  221. 6 speed
  222. What's underneath my timer cover?
  223. auxillary light adjusting
  224. Brake Pads
  225. Mammoth Gold Spokes on 08 Anniversary Coppertop
  226. Mustang Seat Fitment issue
  227. breakout storage... is there any?
  228. Sissy bar modification for Breakout
  229. Touring to Softail?
  230. Canadian Breakout Recall for Tail Lights
  231. Anyone do Chrome Pulley exchange?
  232. Wireing Diagram for 08 night train
  233. Bars
  234. 2013 Fatboy Lo
  235. Road Rage exhaust on a Heritage - does it scrape?
  236. Powdercoating Heartland Struts
  237. Difference between 2007 or so fxstb & fxstc
  238. Too early to ask about Sturgis?
  239. Is There A La Choppers Nice Curves Knock Off?
  240. advice on 19" front wheel
  241. Long Boy front fender, need advice
  242. Manuals
  243. Starter Issues (again)
  244. Deluxe seat height
  245. 1988 FXSTC Problems
  246. Elevation Question
  247. Kudos to Custom Dynamics www.customdynamics.com
  248. Good price for 110th Fatboy Lo?
  249. New front wheel woble on jack?
  250. Adding Fiberglass bags to my Softail...... NEED HELP!!!
