View Full Version : Softail Models
- Voltage problem
- Newbie: What year sissy bar will fit 2014 FB Lo
- December 15, 2015 --- 65* and Sunny
- Picked up a 07 Softail last Friday
- Bars and Risers
- 21'' breakout wheel on fatboy/softail/slim
- 98 Heritage long haul touring seat?
- TC88 Upgrade Question
- FLS Frame Width
- Need wheel info please
- 98 fxstc
- Primary/Transmission noises??
- Edge-Cut setup Likes/Dislikes?
- Any 100 or 110 aspect ratio tires for 21" wheels?
- Hydraulic tensioner wear check
- Wrecked the BO
- Questions on wheels.
- A few updates to the Fatboy
- How are people liking the D&D Bobcat?
- Chrome front end question
- Cables - Is There A Difference?
- Those with the flush mount gas cap. I have a dumb question.
- Suspension now or later
- Winter project 2015
- Vance and Hines Hi-Output Grenades
- >>>Gloss Black Saddlebag Guards for a FLSTC<<<
- My 2016 Slim with some mods
- Harley SiriusXM Radio question
- Swing Arm Bolt
- Brake light Advice--Springer Classic bags
- The Softail Slim Santa Arrives!!
- Slim (FLS) springer conversion need handlebar help
- Fat Boy S has arrived and found something interesting!
- 2011 Fatboy Exhaust
- Fatboy and HD Touring Bags Winter Project
- Calling all Vicla owners!
- Convert a hydraulic J&S jack to air/hydraulic...
- new member with heritage. castleton ny
- Off idle Spit and Sputter, Help.......
- 2010 harley fatboy rear strut
- Cam cover installation
- My new exhaust
- FLS reduced reach Solo
- any rocker c fans?
- Coil cover compatibility?
- Ride Wrights VS Sinister Wheels
- 06 Night Train Fork Removal
- HOW TO: Modify tail light buckets to use newer super bright 1157 LED bulbs - EZ Mod!
- Questions for Freight Train Nacelle owners
- Front fork extension
- Rsd tracker rear fender
- Driver back rest for Heritage
- Le pera maverick daddy long legs
- Need mod ideas and help
- Power Commander V,,,,YES
- Cam Ideas
- Fork disassembly question
- First Winter with my Heritage Softail Classic
- Slim S New Exhaust Sneak Peek
- 2016 heritage sound
- Dot 4
- Chrome Dash
- What is the best softail and why is it the Night Train?
- Where to look?
- 99 fatboy clutch questions
- Slim with factory looking 21/23 inch front wheel
- Fatboy Lo headlight on Breakout
- V&H or ThunderHeaders
- Christmas came a little early!
- I want a FLSS - Softail
- Tires for 2011 flstc
- New Fatboy Lo exhaust?
- My New Pipes
- Updated Front Rotor and Caliper on a 2009 Night Train...
- True Dual Exhaust for 2008 Fatboy
- Need help with apes/riser combo
- Magnaflow Gen X (Breakout Specific)
- Help!!! Rocker c softail 2011 wont start after i changed the derby cover
- New-ish 2015 Deluxe CVO Do it or Don't
- Turbo/supercharged kit??
- rear turn signals as all 3 lights
- Wild One WO560 (low profile drag bars)??
- 2014 Deluxe - Stock Appearing Floating Rotor
- Rear axle size
- Replaced inner primary; rear wheel doesn't want to spin??
- Front Fender Trim
- Slim's front end
- Axle mount plate holder. Axle size?
- Need Help!
- HD Badlander or Lepera Daytona seat??
- Chrome Right Side Teardrop Toolbox
- 23" spoke wheel on a stock 03 Heritage? Will it fit?
- Traded in the Sporty...
- Sundowner opinions
- Different bulbs for headlight and aux lamps
- 2015 flstc
- La rosa spring seat questions
- 2009 Fat Boy
- Front Fender search...
- break out
- Ready for Apes on Springer
- Looking For Advice
- New project: Springer Classic
- Very strange alarm issue
- Petrol tap help
- Black Inner Shift Lever
- Handlebar Bags
- Fatboy Lo - Cleaning the Rims
- Went To A HD Performance Workshop
- Black bike with chrome exhaust
- Softail on the lift question.
- gas cap
- 21 inch front wheel for slim
- Hit and Run
- Big City baffles
- Modding sportster slipon to fit fatboy ?
- Tank Dash carriage bolt
- Lights and Signals working but ........
- HELP!!! New Breakout, What Tuner? Ugh!!!!
- Show them Slim"s with custom fenders on'em here...
- Frame changes!
- Replacing frame struts.
- License relocation kit bulb replacement help needed!
- in the begining...
- Crossbones fueler napping system what gave you used
- My 2015 Deluxe vicla build
- 2012 Fatboy Pinging
- New Breakout
- Smoked indicator lenses on Breakout
- Converting to Mikuni choke cable. Which plunger?
- Second bike?
- Lower dash ideas.....Joker machined?
- clutch noise when engaged
- Rear Fender Help
- Are you ever tempted?
- Softail buyer looking for milage guidance
- Aux + High Beam lights on 2014 Deluxe
- Deuce bagger
- Softail: Bike check.
- Removeable backrest on 05 standard
- Breakout with Bassani Pro Street Turn Outs
- Saw this high miler!!!
- Anyone ever use true duals with a BDL open belt drive?
- Ape or not to ape...anymore
- 120ST - 120R and gearing
- Newb question about changing the battery
- How did you and your Softail Celebrate Halloween!
- Oil line tool, o-ring tools needed
- Do I need to download new SERT software
- Any Harley Davidson Fat Chizeled Bars out there?
- looking for risers
- HD branded Bobber seat with La Rosa Spring Seat Mount?
- 2010 Fat Boy Lo: Help needed on Burst Air filter kit install..
- What bars are these??
- Clutch Cable Boot
- Soft lowers
- Any Heritage Classics with SaddlebagGuards Out There?
- Milage window
- Pro Tuner settings
- fuel & air management
- Breakout Apes
- 05 night train, 200mm ?
- Metzler front tire size question
- 2007 Night Train - John Deer ‘Blitz Black’ paint match project
- Mufflers or Full system
- Softail Slim 140mm Bobber?
- gas cap question
- 2007 6 speed gear cluster
- Breakout seats
- 2006 Fatboy Sprocket bolts
- Tried Electrical section with no luck
- Voltage Regulator Problem
- Nightrain with wind deflector?
- Rear Wheel Movement While In Neutral
- Deluxe driver seat fixing
- Big city thunder baffles re-tuning
- Hard Candy Paint. All colors. Who has it?
- Whats fair: A friends first harley dilemma. Please help.
- Fat Boy Lo pics
- Saddlebag options for Fatboy Lo
- '08 FXSTC Pivot Shaft Replacement
- Air breather
- Hard Saddle bags guards
- Rear LED light for stock reflector.
- Mod for 96 inchers (air cleaner)
- Breakout Handlebars
- 23" Front Wheel For FXSTB
- Confused....need help
- security system siren
- Silicon Spray
- Extended Rear Fender
- 1" axle swap on 2002 FLSTC
- Softail Deluxe & Carlini Pist Apes
- Decided on S&S 509c instead of the S&S 583C
- Rocker FXCW with floorboard
- True dual fishtail exhaust
- 2014 Deluxe part interchangability
- Pics Bike, Lake, DSLR and Warm'ish November :)
- 2004 Heritage models
- Cobra fi2000 ?????
- P1351,p0261,p0263,p1256,p1357 codes!!
- Primary cover fitment and part#'s question
- Weird Sucker
- Winter projects have began
- Shor'tee Belt Guard 60610-07 fit a breakout?
- Slim-S - Almost Where I want it
- Need some advice ---help
- bike won't start
- Right brake does not work
- light bar ?
- Softail Slim S bag measurement question
- What exactly are the "S Series" softails?
- 2011 Fatboy Lo Load Equalizer
- 01' Fatboy major oil system issues
- Fork chirp
- Custom seat
- Cold weather night train
- What Battery do you use in your Softail?
- Question for the Experts
- ?convert 04 heritage to new style keyless fob?
- New member & need help
- LOL... Turned my Slim into a Christmas tree
- Softail Deluxe Nacelle Headlight Part Numbers?
- FLSS is FINALLY done, I think.....
- Apehangers Installed - BRS Custom sweeping beaters
- Deluxe with Heritage handlebars
- options for solo spring seat on 94 softail also round oil tank
- Looking at se nod bike-softail -help?
- '08 Deluxe stock cable lengths
- Lets see pics of painted or powdered carburetors!
- freakin risers
- Deluxe - SlipOns (Street Cannon vs Shotgun)
- Can someone tell me what exhaust this is
- The dreaded head gasket leak.
- Need help wiring breakout ignition and coil
- Rocker Rear Axle Covers fit Breakout?
- For those looking for a smaller fender
- 2001 Softail Alarm Install Code Problems
- Tranny fluid change
- Burly cable kit question.
- loving my 18" apes on 92' softail classic
- Finally changed my exhaust
- LED headlamp
- 2002 Fatboy EFI
- Breakout and small people friendly handlebar?
- ECM Fitment Question
- Dealing with Sikpipes
- Hard Bags on Softail
