View Full Version : Audio Systems
- Uneven output voltage from amp...
- Speaker choices over biketronics 7.1
- FYI - The BT 7.1 speakers are back in stock!!!
- Speaker fabric installation
- I think I have it dialed in
- Audio Classified is up and running.
- 6.5 Speakers with good bass?
- Audio Choices and Dilemma Please Advise.
- Do I need Dealer Digital Technician again?
- Troubleshooting a bad Speaker
- Lowers: 2180 in parallel or 4180
- Soundstream PN4.1000D Amp
- audios system
- The sound in my lowers (speakers) are screwed up
- Source for molex connectors
- ASWC-1 not working
- Aswc-1 source button
- SMD DD-1 came in the mail today
- Sound quality
- Lowers with heavy breather?
- Kicker ?
- Cleaning your bike with aftermarket stereo
- 6.5" spacer rings
- Cerwin Vega B54
- speaker question
- 2015 Road Glide Audio Upgrade Issue
- For those of you with touring bike and Zumo
- Help with Pandora
- AMP Power wire 2016 FLTRXS
- Hertz HCX 165 vs BT Titan 2's speakers
- Rushmore Amp /Elec. Limits
- Hpd4 in a fairing!!
- Loose speaker grills on '93 Glide...
- Installation advice. Thanks in adavance.
- Stereo vids..bring the hate
- help factory HK head unit.
- BT Brackets
- Aftermarket stereo and amp install in CVO - Remove old wiring to amp etc?
- Problem: Microphones send no signal to the H-K radio (no 8 volts bias on the socket)?
- Speaker adapters, grill?
- Biketronics RetroRadio in 14+ Rushmore Bikes
- Arc Moto 602 in fairing PODs, cutting holes
- Changing Arc 602's to BP 7.1's connectors different
- Exterior speakers and helmets
- Best Non Amp Road Glide Speakers?
- Bt4180 & polk mm651
- Focal Speakers 2015 Limited
- Looking to upgrade Boom system with R/F tm400x4ad
- Jl audio xd400 amp channel issue
- Audio section in Classifieds? Working on it.
- Ipod interface Cord Options?
- Thoughts on PBR 300/4 amp
- stock speaker adapters
- 2016 FLTRU Amp Mounting Bracket
- Kenwood KMR-D765BT Head Unit...
- Arc Audio Promo code
- Audio Friendly Battery
- Mutazu color matched speaker lids?
- Biketronics issue solved
- Speaker lids?
- Sena SMH10 question
- happy dance
- aftermarket HU
- Kenwood 898 install questions
- BT Line levelers compared to other line levlers
- Help, Low voltage at amp connection
- Fm Signal on Rushmores
- Help with Lowers and Speakers
- Audio speakers and Amps
- Latest Boom Audio Software issue
- Biketronics BT355 + SS PN41000D + infinity Kappa 62 11i HELP
- radio problem
- Audio Problems Every Year - Help?
- How do I add pins to the 35 pin radio connector?
- Bluetooth I-phone 5 issues
- looking for a Micro4 dealer
- Questions about adding music to my ride.
- Weird audio problem on a Rushmore
- Amp mount with Alloy Art
- Pioneer avh-x6800dvd flip up screen on 13' RG, how to make the video work?
- 2 blown Arc Moto 602's
- Questioning this pic...
- Videos of my new setup
- Amp question
- Blue tooth amp
- harmon radio stays on
- Replace Jensen HDBT1 with Aquatic AV AQ-MP-5UBT-H?
- fairing factory lower pods-kappa infinity
- FM ability is possible
- B2 or pbr300x2
- Biketronics Install Completed
- 15 RGS with Kappas. Grilles not fitting
- Must have something amiss with my BT setup...
- RF amp help needed.
- Washing the bike and not damaging anything?
- Polarity and Phasse Phone App
- Feedback please, video
- Hawg Wired 6.5 & Amp or Rockford Fosgate
- Stereo check
- Linking a mov file
- 15 Shark stereo done...almost
- Thanks and a quick couple questions
- SS PN4.1000D Weather Proof
- 6.5 adpaters to hertz mpx 165.3 pro
- Rockford 6.5 P1650???
- Audio system
- XM module or XM app on phone?
- 2011 SG budget system
- From wreck to rebuild, it's stereo time
- Help me get the right system! ('16 Street Glide)
- Anyone running 2 amps on a 15+ RG
- Need some help setting up SS pn4.1000 with kappas and bt 355
- Wiring lower pods
- Biketronics 7.1 speaker brackets
- amp & speaker upgrade 1 side cutting out now?
- Rear Speaker Wiring
- Garmin GPS vs smartphone iMAP
- SS PN4.100D in 2013 RG Fairing
- 14 Wide Glide Handle Bar Speakers
- '14 Ultra, arc audio amp, new problem: Help!?
- Audio distortion when under throttle only
- Soundstream amp install/weird issue
- anyone tried the kicker 41KSS654?
- 2011 CVO Road Glide stereo upgrade help
- Now for the Waiting
- Comments, advice on installing Pioneer AVH-X770BT flip up stereo on road glide
- Speaers don't fit in lower pods - what to do?
- Would like a new HU questions.
- It rocks
- To Drill or Not To Drill - Arc Moto's in lowers
- communication headset
- BT4180 location on 13' ultra with CB
- checking for a flash
- Trying to decide on the CV B54 or PA RZ4-3000D
- BT4180 issue/troubleshooting
- Simple amp wire question
- 1994 flhtcu radio & intercom
- Hertz hdp4 amplifier
- wire and connectors help
- 97 EGLIDE retro radio question
- Audio Quality in-Helmet with HD Headset any Better?
- Fix FM reception issues with class "D" amp?
- Line levelers and Arc System
- Starting Install tonight!
- 2014 Roadglide amp grounding help
- New stereo/headunit. Suggestions?
- Still working it
- Hertz Milli Pro Sound system
- AVC (auto volume control) & Blown Speakers
- Confirmed Speakers for Rushmore
- Whoa!
- another flash question
- Amp/Speaker Wiring Diagram
- Blown speaker?
- xm through bluetooth?
- Cd player advice/help
- Lower fairing speaker question?
- Power Aqoustik RZ4-2000D Hiss noise
- HIGHLY Dissapointed. (BOOM II) Should've Listened
- Custom Stereo Shop Schaumburg IL ??
- 2013 Street Glide radio removal
- Can someone with Kappa's in their 14+ SG answer
- Head unit question(s)
- Aquatic AV upgrade in 2016?
- 21" Wheel or digital audio upgrade?
- Grills
- What's your go to songs when your dialing in your systems ?
- ASWC-1 Install Need Help!!
- Audio install, HELP! What is this? (Pic inside)
- Cheap Bluetooth Mod for HDPD users
- Hertz ECX or Infinity Kappa's?
- fnally upgraded, why did i wait so long.
- ASWC-1 Install
- Kenwood kac 3002 or kac 3004?
- Audio installed on Road King
- Upgraded my system
- Power Acoustik RZ4-2000D high level wiring
- RCA on the BT Line Levelers,,
- Important information for '14-'16 lower speaker install
- Amp in 15 SGS do I need an amp platform
- Speaker Pods
- B54 is working correctly now.
- Hitting so hard I'm watching the voltage drop
- Focal KRC 165 Mounted in Pods
- Need More Bass
- New Upgrade Already!!
- How Can I Make Boom Stage II Better?
- Look what arrived today!
- Adding new files to thumb drive Kenwood users
- polyfilm
- Boom Stage 1 Speaker Without Amp
- Aquatic AV USB issue
- Wanting more....
- Horns in a Rushmore Fairing?
- audio newb
- CVO lower pods for Rushmore vented lowers
- System Flash
- Best setup yet!
- Problem with Biketronics amp
- Audio for Dummies...
- 4 speakers amp / 2 speaker radio??
- Removing hogtune tweeter pod
- Boom audio saddlebag lid speakers
- PA4 3000d vs moto600.4 vs hertz hdp4
- advice wanted
- Am I missing something about the BT 4180
- Hertz mpx165.3 or proaudio
- Just FYI Biketronics BT1005x in multi fit parts classified section
- Pics of a Rushmore with 2 PBR's in batwing.
- Porting 2014 and newer batwing speaker enclosures.
- speaker choice between kappas or mm651
- Lid 6x9 Speaker Recommendation
- Looking for a little speaker trim assistance...
- Amp cutting out
- Stock HK no AUX function
- My first shot at a video.
- Need help with boom stage 2 stuff
- Problems with Hogtunes REV 200SG KIT-RM
- amp choice w/polk audio MM651's
- Rca cables
- A couple new videos
- BT2180/BT4180 & Titan II 6.5"/7.1" Questions
- Anyone make a tweeter bridge/mount
- Speaker Advice
- Project Legend of ZED
- Jensen head unit
- Moto 602 + -
- NEED Help! BOOM amp kit install with afterket amp kit as well
- Lower fairing speakers
- Amp advice? Thinking BIKETRONICS...
- 2015 Ultra speaker wire color
- Fix for loose RCA cable on BT 355 line leveler??
- Stripped Speaker Mounting Holes 2104 SGS
- 15 FLTRXS install
- new head unit install
- 6.5 HU went wacky - right side dead
- CVO lower pods/ BT Titan 2 question need help!
- New Kenwood Head Unit/PAC Audio contol interface
- Need help
- mp3s to USB Thumb Drive
- upgrading 2002 ulta sound system to 2012 radio
- Playing Lossless files on USB on Rusmore systems?
- Polyfil in lowers?
- Rear Speaker Harness
- 14 SGS gets a new system
- After Market Headunit Install using The BT Kit
- 6.5 Speaker Adapters For Polk Speakers
- Hsk165xl
- Whats next? Lowers or rear lids? I got the bug
- Soundstream PN4.1000D in a Rushmore Batwing
