View Full Version : Audio Systems
- Audio system no head unit ?
- 8" lowers
- 2015 Street Glide Special Audio
- 07 HK Radio Upgrade
- Do Rushmore head units mute without a load
- Audison Bit 10, Hurtz H8, or JL FIX DSP.
- Hertz MPX 165 or SV165/ST25 with SD800.4
- Digital Media HU
- Boom Box Info System 6.5GT Going Blank?
- Gain setting on new system
- Cheap RCA’s
- 2014 street glide special wiring help
- Blown infinity kappa 6.5 with PBR 300x2
- Rear pod speaker install help please
- Question about the boom audio and sena 20s / 30k units
- Many thanks to Tailwind!!
- Noob looking for advice
- Polk DB652 speaker install on 2015 Street Glide Special
- How many times has this been done?
- Removing Pods
- Trimming the PRV 6MR500-NDY for lower fairing
- Hertz Mille Pro
- Ok Let’s Hear It
- Help Identifying USB Adapter
- 2017 Road Glide stereo sounds different when running
- Got some tunes for my Softail (FXST)
- Road Glide System Upgrade
- Amp and speakers install
- DSPs, any problems?
- SD800/4V2 install
- Speaker issue Infinity Kappa 62.11
- SoundStream Piccaso
- BOOM stage II blown speakers
- For sure its been done before, can't find it
- Diamond 4v2 1 channel dead
- Speakers for the lowers?
- Pre wired?
- Loss of signal or other issue with Deutsch Connectors?
- 5x7 to 6x9 adapters
- 2 channels only off 4 channel amp
- Amp install kit
- Speaker Grills / Tweeters
- Will JL XD400/4v2 fit in pre-'13 RG fairing
- Couple of fitment questions
- Compression nuts on TP Speaker pods
- 2016 Ultra Limited (FLHTK) - upgrading speakers and adding amp
- 2015 FLHTK Speaker Pod Removal
- 6 speaker with Arc 600.4 HOW TO HOOK IT UP?
- Best 2 speaker/ amp combo under 450
- Fairing Only Setup
- DD VO 6x9
- Help wiring Diamond Micro 4v2
- Tour pack off, relocate the Antenna
- Batwing Audio
- input gains different on channels
- Looking for some HU advice
- 2018 Boom Box Switching to Weather Band
- My 🦄
- Sony MEX output question
- Mother's Day!!!!!
- Helping nephew with audio, 2015 RGS
- Iphone annoying issue boom box
- Guidance for rear speaker install
- amp question
- Hogtunes amp on a after market HU
- 2006 electra glide classic radio problem
- Think I figured out the warm and fuzzy secert.
- Changed Setup Again
- DD and Soundigital
- Rushmore RG Pod Mods
- fairing bracket
- Stinger SPX700X4
- Wireless music/intercom options - 2007
- At what step to flash radio on stage 1 amp install
- Eureka, and you guys said I could never get bass at 80mph.
- Road King Sound System Advice / Help
- 2018 RGS have some pieces, need advice to finish out parts for install
- SONY XAV-AX5000, SONY XAV-AX100, and the SONY XAV-AX200
- 2010 FLHTC Suggestions
- Installing Infinity Kappa 62.11I 6.5" speakers in fairing
- Moving speakers, some advice please.
- 2 channel Amp speaker?
- Infinity Kappa Speakers for 2017 RGS
- Audio questions
- Amp
- Beyma 8G40
- Weatherproofing under fairing
- Need reflash if replacing Boom Audio amp & Stage 2 speakers?
- headset electrical interference
- If you could only run an amp and 1 set of fairing speakers what would it be?
- Speaker ?
- Need help with audio for 2015 road glide
- Adding lowers to my set up +questions/advice?
- Dd at 28 eta
- Lower Fairing Speakers
- Rear song advance button not working
- testing filter/cap pack that comes with DD horns
- Newbie audio question. Be gentle. 😀
- setting gains
- DD Speaker recommendation
- Aftermarket radio install
- Hidden Antenna
- Help me spend my money
- Arc Audio
- Time for another WTF moment
- Almost There....Sony XAV AX100 Custome EQ Settings Help
- Speaker placement help , system sounds too bright
- DSR1 questions
- 2012 SG speaker upgrade - MM652?
- JL MX500/4 clipping
- 2015 4 speaker system Demo
- Infinity Speaker broken!
- Pioneer 6902 6x9
- Stumped: HDK001X Blue/Yellow wire hookup
- One Amp or two?
- What will i lose with a boom pre-cal reset?
- Installing New Stereo - chassis ground question
- Looking to upgrade 2012 flhx speakers
- June's Pods tour pack speaker pods
- Left speaker cutting out
- Radio
- Ok I think I narrowed it down
- Pairing Fairing, Lowers and/or Tour Pak
- DD AW6.5 + VO-B3? = what amp?
- aquatic with sound stream channel problems
- 2017 RGS, I have about $1500 to spend on audio
- help with my setup please
- One source channel to a four channel amp question
- Top Choices For HEad Units
- Boom Audio Newb Question
- AVC with amp?
- Power for sound stream
- HI, Not been here for a while!
- Parallel Connections on BT-2180.14
- Boom Audio Amp & Speaker Sound Quality
- 2018 SGS audio upgrade
- Sony XAV-AX100 REVIEWS
- Help with wiring confusion
- WDX6MOTO speakers & RFosgate TM400XAD
- Stereo louder when iginition is switched to Acc.
- hogtune amp
- Frustrated
- Arc 602 v2...Better sound..Pods or Brackets?
- kit for '16 road glide?
- WDX6Moto vs. AA602
- New ride new audio suggestions
- Needin Speaker Help
- Strange problem/time for upgrade
- Audio Newbie Needs Guidance
- Wanting something new
- Focal sport amp
- Amplifier suggestions?
- Need to remove old audio harness
- Rookie wiring question
- Do I need to make adjustments to Kenwood 998 , after adding second amp?
- Power Acoustik RZ4-2000D install 2016 UC
- Parts list to do lower fairing speakers on 2015 road glide
- Mahalo!
- Db drive moto in prerushmore RG
- Any thoughts or reviews on Jensen HD1BT650? Vs any other plug and play option?
- Amp Install ?
- Newly installed JL 400/4 wont power on. What did I do wrong?
- Strange intermittant distortion
- Where I'm at
- Wtb mmat 601.4 and dd vo b3 horns
- Aquatic AV AQ-MP-5BT-H can't pick up radio signal
- Upgrade Recommendations for More Good/Best Quality Power
- Speaker switch as a remote wire toggle?
- Stereo upgrade options
- Street glide radio won’t turn on
- Stevie Nicks
- Wdx69moto
- EQ ver 2.2.1
- Under the hood
- Amp recommendations
- Only amplifying front speakers on Ultra Classic
- Wiring 4 ohm speakers stock HU & SSPN4.1000D
- More research questions
- Reset boombox
- WDX6MOTO - What Are These?
- Boom Audio 6.5 cold
- WIRED headset recommendations
- BT 7.1 Pro blows out after 2 years. Next?
- 2018 RGS 6 Speaker - EPC6K vs MPX 165.3 and DD VO 6x9 vs MPX 690
- Metra speaker adapter help 2011 rg
- Street Glide hand controls on Road King to control iPod and Zumo?
- Amp comparison
- How did I do this gains or filter?
- 2013 street glide needs audio upgrade.
- Setting Clock 94 FLHTCU
- Is 12 Gauge good enough
- Integrating CB into after market radio?
- RMS watts per channel of pyle pla2678?
- Antenna, mounting hardware and cable
- Polk mm652 Questions
- Looking for a little more SQ
- I need ideas for quick disconnect for Amp in bags
- Sony Remote App for Iphone
- Overwhelmed audio
- Amp warmth?
- Speaker Advise
- Which DSP do you like best?
- Own channel or in parallel
- PRV 6MR500-NDY and DD B3 17 RGS Install
- Jensen tweeter grill
- 6.5 boom screen
- striker plate glue
- Cheep-o way out
- 2nd amp for lowers
- Post pics of your Rushmore tp setup.
- Speaker lids worth the effort?
- Biketronics 4180 for sale
- Which 8s in bags
- Problem after updating 6.5GT with 1.22.0.1 software
- Road King Sound System Options
- 6x9 lower fairing Pods from Ebay
- 2 speaker only
- How would this compare to 6x9 lids, or 8's in bags??
- This sound reasonable?
- Riddle me this Gurus
- Love the new system, thanks guys
- I Love my PSM!!!!!
- Prv 10 mb 400 crossover
- Mmats PA601.4 in Pre Rushmore rear pods, spacer size?
- 4 hertz hcx 165/Pn4.1000d settings help
- D4 amp
- Helmet headset recommendations?
- Amp Accessories
- Cutting in and out
- Laughlin river run?
- Do I need new speaker pods in fairing?
- Throwing something together for 2014 flhtk
- Sharing secrets
- Other PA Speakers
- Ready for More. Advice needed
- Amp choice..
- PBR300X4 Wiring Diagram
- Windshield makes a difference
- Just bought the RF HD14-TKIT and TMS65 '14 FLHTK
- Just need some wiring help.
- Voice activated 2 way helmet intercom.
- Mille Pro 165.3 in Road Glide fairing- do they need to breath?
- 2017 flhxse lowers
- Unable to pair to Sony MEX-M70BT
- Aquatic stereo installation
- Speaker grill / install help 2014 SG
- MTX Soundbar question
