View Full Version : Audio Systems
- Suggestions for 2015 Road Glide
- Help with boom audio
- What makes one head unit better than the next?
- Advice on a new Amp.
- Thoughts or suggestions on system
- RF TM400X4ad?
- Audio Help
- Diamond Audio
- Factory HU Volume
- 2006 HK Volume/Decibel Issue
- DB Neo 4 amp
- Need help on my EIGHT or TEN speaker set up!
- System upgrade
- 14 and newer Boom FM cutting out
- 2016 flhxs speaker upgrade
- 2015 Ultra Classic Limited CVO audio
- Bluetooth earbuds?
- Compare
- 1997 Ultra Classic Stereo upgrade Suggestions
- Fosgate Harley Kit
- audio pops
- Refurbished 6.5 GT Head Unit
- Looking for ideas for adjustability
- first time amp install
- Cut passenger 7 DIN plug
- My Sony died already, what's a good replacement?
- B52 Amp setting question
- Bridged or not
- Hertz HCX 165 or Polk MM652 for lowers?
- Wiring?????
- Help:15 FLHX $1k speaker/amp budget.
- How many speakers can be run off a Arc 600.4?
- Help/suggestions
- washing bike with audio setup?
- Challenging audio system.
- 2017 tour pak speaker pod options
- Comparing dual 6x9 lids to 8” lids with horn.
- Sony vax-ax100 no dsp 1 amp 4 speakers
- Looking for oem replacement
- Mic only headset
- Blanket Roll Speakers
- One amp for entire set up
- Is or has anyone tried running the JL Audio MHD600/4 amp?
- Sound Quality and Clarity
- speaker popping
- New Amp Recommendations?
- Best Amp/Amps for 6 Speakers- 4 Front and 2 back
- Current Set-up
- Boom stage 2 tour pack install
- 2 ohm components, 4 ohm components on same 4 channel amp?
- Need help with 2012 RG sound system
- Diamond amp issue
- Boom Audio Auxiliary Input Kit not working.
- Amp set up
- Boom 6.5 rainbow screen
- Forum Meet n Greet
- hog tunes amp
- 2018 SGS Best Speaker/Amp Bang For buck
- Need to repair Rockford Fosgate T400X4AD
- 2018 RG upgrade
- Opitions -- HD Boom 6.5 vs Sony AX100
- What Amp & Speakers to buy for 2017 Limited
- My Road King audio & nav solution
- The Man Doing What He Does
- Thanks to Gannicus and Sbates08
- Newbie looking to upgrade 16 RGS audio and future upgrades
- Getting more with what I have
- Sound System Not Working?
- 2012 Street glide audio upgrade
- 14 FLHTK Boom Addio question
- Need advice for 1997 FLHTCU
- Bluetooth Boo-Boo
- 2016 RGU CVO upgrade
- Best Amp for a 2 speaker fairing set up
- Boom audio echo
- New Head Unit
- Speaker out 2015 RGU CVO
- 2016 Ultra Classic - Radio power plug diagram
- iHeart Radio
- Speaker questions
- Beyma 8 CX300Nd/N
- Which speakers to add to my system?
- Biketronics line levelers
- Best radio unit
- Wiring question ...2 pair amped / 1 non amped how?
- Help With B52 tealth Bomber amp
- 2013 RG CVO Setup Questions
- Boom volume control stuck in rear?
- Looking for lower fairing speaker pods
- Radio sound cutting out on Factory radio.
- 2009 Streetglide and JL Audio JX400/4D Amp
- Xm sat for 17 limited
- Rockford DSR1 tune
- Sound cuts out When I use throttle
- did something wrong...
- Getting an amp to fit with a double din radio?
- Stereo Guys, How's This For A Setup?
- Prv
- Polk warranty
- Wire routing for lower fairings?
- Ground attachment
- Quick question on BOOM audio software updates…
- Static and cheap head unit
- Ohio area meet and greet?
- Rushmore Road Glide & PN4.1000D
- Rain cover for 2014+ aftermarket radios?
- What will most likely be 2 stupid questions...
- Upgrade 2012 SG audio system
- Ultra Wiring Question
- Pioneer pro 8
- 2017 sgs install help
- Help selecting radio with ipod connection for 2012 ultra
- There is a New Coax Contender...Sony XS-GS 1621
- speaker size
- Rain cover fitment
- Suggestion for replacement head unit.
- Quick question
- park brake override
- 2017 Fairing speakers - Bat Wing
- Is the BT355 killing my fidelity?
- Hidden/clean speakers fhlrxs
- Anyone used the pac audio or scoche radio interface??
- Biketronics 2250 road glide
- Stereo problems
- 2014 and up 6.5 RADIO replacement
- DD VO 6x9s
- first bike with factory audio, upgrade questions
- Arc audio 600.4 with moto 602’s
- 2009 Ultra Classic - Recommendations?
- Super happy setup!
- No I Pod
- Hoppe Quadzilla speaker upgrade without an amp?
- Arc
- 2017 Ultra Classic upgrade advice
- 1AMP 4 speakers 4 horns
- amp choice
- Weather proofing question
- Kenwood Radio
- Cerwin-Vega B54
- Sena 10U Universal communication feature
- 2015 touring with intermittent squak when playing thumb drive
- Audio Sound Off in Pinehurst, NC - June 9th
- Soundstream SM4.1000D
- Water proof materiel for grills
- Help with one speaker not working
- Soundigital amplifiers
- sound deadening material
- Looking for advice...
- Install / tuning questions
- BT4180 Warranty
- Components to pair with Sony XAV AX5000
- Audio/Comms dead after rainy ride
- install nightmare
- 2017 Street Glide
- 2018 cvo street glide sound system
- Setting gains front to back
- Street Glide Special - New system thoughts?
- Follow up question: Picasso amp
- road planner??
- Stumped on amp not powering up
- 4.3 Infotainment 3 beep code
- 2008 Road Glide
- Replacement Radio 17 Road Glide Ultra
- PRV's in Upper Fairing Speaker Pods
- Sena 10s and WHIM
- Speaker Adapter Help Needed
- Boom audio interference.
- Battery/Voltage Regulator Affect Audio?
- Shovelhead 1976 stereo speakers batwing
- Mille 1800s with Focal tweeters out, Steg RE 65Cs in!
- Need to restore FM on a 2008 Street Glide
- 2014 Electra Ultra BoomBox 6.5 Issue
- Question for the audio gurus
- 2011 SG Audio
- Help with tuning new system.
- Install Help...Pics/Diagrams
- Hertz Mille Legend 1800.3s in Rushmore batwing
- Need help upgrading AMP
- CB Transmit Problem
- Speaker lid kits
- Audio system no head unit ?
- 8" lowers
- 2015 Street Glide Special Audio
- 07 HK Radio Upgrade
- Do Rushmore head units mute without a load
- Audison Bit 10, Hurtz H8, or JL FIX DSP.
- Hertz MPX 165 or SV165/ST25 with SD800.4
- Digital Media HU
- Boom Box Info System 6.5GT Going Blank?
- Gain setting on new system
- Cheap RCA’s
- 2014 street glide special wiring help
- Blown infinity kappa 6.5 with PBR 300x2
- Rear pod speaker install help please
- Question about the boom audio and sena 20s / 30k units
- Many thanks to Tailwind!!
- Noob looking for advice
- Polk DB652 speaker install on 2015 Street Glide Special
- How many times has this been done?
- Removing Pods
- Trimming the PRV 6MR500-NDY for lower fairing
- Hertz Mille Pro
- Ok Let’s Hear It
- Help Identifying USB Adapter
- 2017 Road Glide stereo sounds different when running
- Got some tunes for my Softail (FXST)
- Road Glide System Upgrade
- Amp and speakers install
- DSPs, any problems?
- SD800/4V2 install
- Speaker issue Infinity Kappa 62.11
- SoundStream Piccaso
- BOOM stage II blown speakers
- For sure its been done before, can't find it
- Diamond 4v2 1 channel dead
- Speakers for the lowers?
- Pre wired?
- Loss of signal or other issue with Deutsch Connectors?
- 5x7 to 6x9 adapters
- 2 channels only off 4 channel amp
- Amp install kit
- Speaker Grills / Tweeters
- Will JL XD400/4v2 fit in pre-'13 RG fairing
- Couple of fitment questions
- Compression nuts on TP Speaker pods
- 2016 Ultra Limited (FLHTK) - upgrading speakers and adding amp
- 2015 FLHTK Speaker Pod Removal
- 6 speaker with Arc 600.4 HOW TO HOOK IT UP?
- Best 2 speaker/ amp combo under 450
- Fairing Only Setup
- DD VO 6x9
- Help wiring Diamond Micro 4v2
- Tour pack off, relocate the Antenna
- Batwing Audio
- input gains different on channels
- Looking for some HU advice
- 2018 Boom Box Switching to Weather Band
- My 🦄
- Sony MEX output question
- Mother's Day!!!!!
- Helping nephew with audio, 2015 RGS
- Iphone annoying issue boom box
- Guidance for rear speaker install
- amp question
- Hogtunes amp on a after market HU
- 2006 electra glide classic radio problem
- Think I figured out the warm and fuzzy secert.
- Changed Setup Again
- DD and Soundigital
