View Full Version : Audio Systems
- Moto 602 + -
- NEED Help! BOOM amp kit install with afterket amp kit as well
- Lower fairing speakers
- Amp advice? Thinking BIKETRONICS...
- 2015 Ultra speaker wire color
- Fix for loose RCA cable on BT 355 line leveler??
- Stripped Speaker Mounting Holes 2104 SGS
- 15 FLTRXS install
- new head unit install
- 6.5 HU went wacky - right side dead
- CVO lower pods/ BT Titan 2 question need help!
- New Kenwood Head Unit/PAC Audio contol interface
- Need help
- mp3s to USB Thumb Drive
- upgrading 2002 ulta sound system to 2012 radio
- Playing Lossless files on USB on Rusmore systems?
- Polyfil in lowers?
- Rear Speaker Harness
- 14 SGS gets a new system
- After Market Headunit Install using The BT Kit
- 6.5 Speaker Adapters For Polk Speakers
- Hsk165xl
- Whats next? Lowers or rear lids? I got the bug
- Soundstream PN4.1000D in a Rushmore Batwing
- J&M Extreme Speakers - Mushy Bass or Reverb Type of Noise?
- Painted grills, yah or nay?
- Music for my 2006 FLHRS
- Bluetooth amp
- Boom Stage 2, front & rear on my Ultra
- Music download source
- roadglide, where to mount pn4.1000d?
- HD Boom Audio partially working
- Best bang for my $
- Aftermarket Head Unit?
- Good 4 ohm speaker?
- Speaker grills with built in tweeter pod
- Why isnt the aftermarket making double din units for Rushmore HD?
- soundstream pn4.1000d question
- Any of you audio guys going to the laughlin river run?????
- Amp & Speaker Relationship
- Stock HK flash ??
- arc moto 602 grills won't fit lwr fairing
- 8 gauge wire/ inline Fuse
- high level ground ?
- Want tunes!!!!!
- iPhone 6 after radio reset
- EQ on Rushmore
- 2ohm vs 4ohm ...pros and cons
- Broken Wire Connector
- Will HK head unit and speakers fit?
- Soundstream PN4.520D Amp
- Pioneer DEH X9600BHS
- 2013 RG Radio Clock going off while riding
- BT4180 radio reception
- Weird radio power issue, kinda stumped.
- Main wiring radio plug
- new upgrade questions
- Speaker options between Hertz or focal
- Rushmore ultra lower speaker pods. Info needed
- Completely satisfied now.
- Delayed engine noise in speakers
- Discussion: Speaker Specs, what do you look for?
- Radio service menu EQ and Reset question
- Speaker questions
- The next step...
- My findings/impressions of BT 4180 & 7.1 Pro Kit
- handlebar audio
- Install uestion 2013 EG
- Infotainment Sun Shade Hood
- Replace stock head unit?
- Head unit blues
- Rain cover for Sony HU 2005 Batwing?
- Headset/Intercom/External Speakers on Rushmores
- Help mounting Bt 355 line leveler in 16 RG
- BT4180 & (4) 602's 14 Ultra..?
- Kenwood KDC-BT558U
- CD Cuts out only when riding
- Tweaking Line Levelers
- Frustrated w/ Hogtunes
- Speaker/Amp choice-Looking for input....
- mounting crossover question - in the pods ok?
- Rushmore's bikes and high level inputs?
- BT Break Out Harness For 2014+ Ultra's Fitment
- Amp upgrade
- 2016 SGS 4 speaker system
- MPX 690.3 Pro
- Setting gains on ss 350.2
- High/level input
- settings stock HU?
- 16 RG amp and speakers chepo upgrade
- Looking for a wiring diagram for shovelhead CB
- Two '14s and options
- it's an addiction
- Speaker and amp combo sugestions
- Just how good is the Biketronics BT791Pro speakers and BT2180.14 amp?
- install help
- New Speakers Old Bike
- Couple of Boom Questions
- Bag Lid Speakers / Leaks
- speaker/amp compatibility
- 1.19.2 boom update radio does not sound the same
- anyone heard of or tried massive audio
- My 1998 classic install of SS pn4.1000d amp and infinity kappa 62.11i speakers
- Grounding the triple tree
- BT 7.1 Mod
- Let's Spend Jim's $600 Bucks
- Question on setting GAIN on my Amp
- Lower Fairing Speaker Videos
- Speaker question
- Need a new amp to replace mine
- Lowers speaker/pod/amp recommendations
- Hi-Lo Inputs Upgrading On A Budget
- Arc Audio M.P.A.K. 12
- What I learned today that's related to audio
- Speakers in series??
- 2016 Street Glide Audio Upgrade Questions & Concerns
- Biketronics BT2180 and radio reception
- hogtunes
- Infinity kappa clearance for 15-16 road glide issue
- Stock left rear spkr blown
- Why is there such a dislike for J&M on this forum?
- HogTunes Replacement Speakers for Lowers on 14+ Water Cooled Sleds
- Sounds System HELP Amp & Speaker Combo
- Sound vid after some upgrades have been installed and dialed in.
- 6 speakers and line converter
- What did I do wrong
- J&M Rokker XX 2 Pin crossover connector
- volume control not working
- Pioneer 6.5 TS-D1602R
- BT 7.1 Lower Fairing
- Only Iphones charge and play through USB?
- Aftermarket stereo problem.
- 2 speaker to 4 speaker flash
- best 6.5 speakers to use?
- Stereo issues
- 15-16 road glide amp location?
- Amp and speakers for my 2010 road glide???
- 2 x 2180 vs 1 x 4180
- 2 ohm kappas with pbr300x2?
- Hertz, Moto or BT
- BT 4180 Review(not by me)
- King Tour pak pod install 2015 Road Glide
- Joystick removal?
- Another Biketronics Install...2015 Ultra
- Best amp under 200.00 for my stock 2012 HK unit and BT 7.1
- Hardware for kappas in the speaker pods
- 2014 Speaker Lids
- crewin vega B54 amp
- Infinity kappa's an BT2180
- Could use advice
- JL HX280/4 Amp Setup?
- BT2180 & BT 7.1 Speakers. What next?
- System Install
- New speaker pod
- Inner Fairing Brace
- Merging stereo into mono
- Best song to test system capabilities
- Pyle plmca30 on 2010 883l sportster.
- Upgrading from boom
- help new to stereo install
- thinking of a new amp
- BT7P1 vs. BT7P1 Pro - worth the extra cost?
- J&M Rokker vs Biketronics for 2014-2016 ultra
- BT4180 Install Made Easy
- Current remedies for fm reception issues
- M103AB amp, any info on these??
- 2013 Lid Speaker ??
- Road king audio
- 08 cvo speaker options
- is this something anyone has seen
- Biketronics question
- Premium infotainment CB problem
- Best install kit with water cover that will fit pioneer flip face 13 road glide
- Speakers making "shhhhh" sound
- Pre-Rushmore upgrades and Stock HU
- Upgrade 2016 Road Glide
- My setup on SG
- 2 amp for 6 speakers?
- Helmet speakers
- Handlebar audio systems
- Help. Amp install, speaker shuts off with volume increase
- Speaker lid qd's
- Kenwood KDC BT558U
- amp install ?
- Boom Audio Amp Installation Help Wanted
- System set up
- New to the audio world
- Problems
- "Mode" switch malfunction
- 2016 street glide speaker and amp upgrade
- Kdc-x500
- bag lids ... best ??
- BT4180 install questions
- 2016 road glide speaker and amp question
- Front speaker wires
- what's a good head unit these days?
- Stereo issues
- Best 6.5 speakers to buy
- Why do we use the brands we use
- Speaker Question
- My awesome system choice is clear as mud...
- 2014 Hogworkz speaker lids and extended bags
- Stereo advice..
- Auxiliary jack on a 2011 ultra harman kardon
- 2003 Electra Glide Radio into a 2002?
- Boom 6.5 Head Unit
- I'm Done Settling for Boom Handlebar Speakers on a Road King...
- Sony MEX M70BT set up vs. remote app?
- Selective Listening on Boom 6.5
- PPI 600.2 - 2 Channel Amp
- BT Package from 2010 to 2016 ?
- Hogtunes Tweeter Dash Pod Question
- 14 street glide head unit issue.
- Arc audio Moto 600.4 and XDI600.4
- Installed BT 7.1 pods.
- radio from 08 fit an 05
- what speakers to use
- Questions about Rushmore speaker pods
- BT 7.1 road test
- arc 692 wiring
- 2016 Road Glide, New Arc Moto System and Aux Light Install
- Rushmore head unit radio connector removal video
- Biketronics BT355 installed video
- New head unit....help!
- Bunker's Beats - slight delay, also need help
- Rushmore speaker pod question
- What head unit do you have and what would you like to try
- New Setup and First Impressions
- Arc moto pics
- How to keep speakers dry???
- One more BT speaker bracket question
- Discussion: Watts, Amp Draw, Power, Charging System; Efficiency
- 6.5 component speaker system
- Amp suggestions.
- Earbuds to a aftermarket radio
- Speaker Choice ?
- Bunker's Beats - Titan II's, Millie Pro's, PC 165's
- pods for chopped TP
- up and running!
- Need Help...PN4.1000D Install 03 Ultra..I'm lost..
- strippped wire question
- BT LL 355 install
- 04 Road glide need audio
- pioneer
- Portable Drives
- Rushmore Audio issue..bt355/pbr300x4
- Fairing Tweeter Specs
- Bunker's Beats - Teaser video
- BT 2180 in parallel?
