View Full Version : Audio Systems
- Need some pro advice again on gains/clipping
- Metra LOC
- Modifying HD speaker cover to accommodate 1/2 spacer tour pak
- Help from audio gurus
- Is this a fair setup for my 2017 SGS
- automatic turns on
- Getting a JL Audio JX400/4D to fit in 14+
- 6.5 speaker's
- 3 part question, Diamond amps, Db speakers, best money can buy?
- Thinking of adding second amp
- Alpine steering wheel control help
- Saving lid graphics when adding speakers.
- How Much Amp Cable Needed?
- CB Sidetone through fairing speakers
- Parallel vs Separate
- Which speaker lids and speakers to go with
- Screws for CVO Speaker Grill Covers
- Amp Challenge.
- KW 998 vs Sont MEX M70 BT HU's
- 2015 road glide need help adding rear speakers to bt 4180amp
- A Big Thanks to the Gurus Here
- Sound deadening pre rushmore
- Screws for speaker spacers?
- low budget bluetooth audio for helmet
- Wiring rear speakers. Which wiring harness?
- 2018 CVO boom system
- SHOUT OUT TO Mike and the folks at biketronics
- 2017 SG boom audio Buzz
- Comments regarding Alpine SR-65 Speakers
- Speakers cutting out on acceleration
- removing headset plug from console.?
- Need some fronts!
- Are DSP's Lord Voldemort?
- DD AW6.5/AT28 In Stock Anywhere?
- Decent stereo upgrade 2018 ultra limited
- Hertz HCX165's and Rockford Fosgate TM400x4AD
- What HU are you all rockin?
- Upgrading My Upgrade
- Focal fdp sport setup
- Building a system for 2017 RGU Lower Fairing
- Need some help here.
- Hissing coming from after market speakers when ignition is not on
- Lower fairing adapters
- Massive BLX4 amplifier
- Audio friendly 2 into 1 exhaust?
- Thanks gannicus !!!
- Biketronics System for '14 Ultra Limited
- Left front Focal 165 KRC is Dead Dead Dead
- Dsp Reviews
- Anyone using adapter from 6x9 to 6.5 and horn ?
- sound competition myrtle beach
- Amp install
- Lids/speakers
- 2012 Street Glide Set Up
- Need help designing a 6 speaker system 2018 RGS
- Has anyone tried the new JL amps with the internal DSP?
- Which speakers for pods with my set up?
- Sound going on and off thumb drive only
- Just bridged my PBR 300X4 to my J&Ms and BOOM 1s!!! AWESOME
- HK Radio Repair DIY
- Little help setting up new system
- speaker size
- Is anyone using the HogTunes lower fairing kit for wet heads?
- What fairing/tour pak/lowers speakers pair well with BT 4180
- Bluetooth Sound Quality??
- Softail deluxe sound system
- American Hardbag DSR-1 Harnesses
- Not Sandbaggin'. Really Need Some Help
- fairing speaker help please!
- Spring audio install
- 2011 streetglide audio help please
- Lids and Weather?
- Newbie question
- 18 SGS 4 Speaker w/amp Setup Help
- BT 7.1 Pros Parallel with what?
- lids to fit hogtunes speakers
- Question on DD Audio
- RF400x4AD, am I setting it right?
- Who should I order my stereo equipment from
- Boom audio scare tactics?
- 09 FLHX Harmon Cardon audio issue
- Need Help Troubleshooting.
- Getting rid of "tinny" sound from Beymas in lowers
- Metric or Standard?
- Fairing is being a beatch going back on with bt brackets
- Favorite song to tune with is?
- What would be my best bang for buck audio set up for a $500 to $700 dollar budget
- Saddlebag speakers
- Speaker Input
- 2012 Ultra Classic pre amp EQ add?
- Stereo upgrade from pbr300x4 to......???
- Upgrade sound system 2012 Street Glide
- Buying amp. Biketronics or Rockford
- Custom POI's and Boom Box 6.5 GT?
- faceplate case for aquatic av AQ-MP-5UBT-HS?
- Speakers in lids
- 2017 SGS - looking for recommendations
- Installing Kuryakyn Thundermax Speaker Pods
- Which Iron Cross Bluetooth module?
- Rockford Fosgate pbr300x2 installation help.
- Try to build a little soundmachine using an Adafruit MAX9744 Amp
- Sirius XM Module Install?
- Hawg Wired or ?
- Upgrade auto system Chicagoland area
- Power Plug
- B52 crossover settings for mm692
- 2015 SGS tunes
- 2000 Electra Glide (stock) speaker upgrade
- Opinions On Foam Speaker Baffles
- MP3 player
- Need help choosing an amplifier
- Need OEM Radio & CB Whip Antennas
- Need some ideas guys.
- Need Some Audio Help
- Can I, should I?
- 2018 Midwest M&G #1 June 8-10 Black River Falls WI
- Fairing Only Setup
- Lid speakers question
- 2012 Street glide amp & speaker upgrade
- Little help with pro audio set up
- Newbie simple system help
- Simple system
- New Speaker and amp install on 15 SG
- ds 18
- Audio help with 17RGS
- Amp turn on switch
- I’m clueless
- looking at this system for my 2018 Heritage
- To Port or not to Port
- SounDigital and DSR1 going in
- Ready to install
- Set up for 17 Limited
- Sound Cut Out
- Filter frequency. And tinny sound
- rockford fosgate?
- Lower speakers with SS1000d
- Upgrading my amps? Speakers?
- Need help deciding on speakers!
- 2010 Ultra classic speakers
- Choosing an amp. How do I know which one.
- FLASH.... things that make you go hmmmmm....
- Bluetooth Direct to amp
- Music cutting out, now what?
- Thanks!
- JL Audio amp
- Amp question
- Rushmore audio
- Need input on current setup
- CV B54 amp & Infinity 62.11i help
- Anyone tried Soundqubed speakers
- No sound
- CV B52 and Hertz MPX 165.3 amp settings advice needed
- SS amp mount ?
- Voodoo 8.8 lowers and other questions
- Amp goes where?
- Rockford DSR1 Install Help
- DB Drive wdx6moto
- Pre-Rushmore amp mount
- Rockford Fosgate perfect tune
- need help from the pros
- Amp Repair
- Biketronics BT355 new
- DD AT28 in BT Pro Tweeter Pod?
- 2015 Street Glide audio
- 1/4" speaker spacers that fit the new AD Cx621x
- Help with ideas for audio upgrade
- Help on system setup
- stock audio, sound cuts out ?
- Rushmore Road Glide Audio
- Horn wiring
- Audio upgrade for novice RG owner
- Kicker 43KM654LCW 6.5 in
- Atlanta Area Audio Tuner
- Frequency response at 2ohm vs 4ohm, dual amps, tweeter horns
- Sony HU MEX70 BT custom EQ settings
- New system installed and tuned
- Amp in saddlebag wiring
- 4.3 Radio in a FLHTP
- Which speakers in saddlebag lids
- Arc PSM help needed
- Are lower speaker pod grills universal?
- What gauge?
- hertz hxc 690 6x9 speakers to my 2016 roadglide
- Friendly PSA for new visitors
- Boom 4.3 USB cable
- Saw thís awesome build the other d
- Handlebar mounted system for 1 1/2 bars
- Antenna location. Do I have a shot with these spots?
- Stinger rca cables
- Installed lower speakers, only get white noise - HELP!
- Noise coming from speakers
- Headsets for 2017 Electra Glide Ultra
- Tweaking the completed system
- Lower speakers are in the pods - final tweaks?
- Budget system for an oldie
- audio system
- Audio upgrade install help and recommendations
- Power Supply?
- Frequency analysis on 6.5 boom head unit?
- Upgraded deck and speakers only
- Rockford Fosgate Hard bag 6x9 kit
- Converter required ??
- So much information, help clearing it up.
- Almost There, Just Need a Little Help
- Is anyone running the Infinity Kappa 62IX speakers?
- Little help on upgrading
- Chinese CVO copy grills fit Chinese lowers (Fairing Factory) perfectly
- Rockville woofer
- Mounting Beyma pro6wnd in lowers
- Big thank you!!
- Arc Moto 600.4 or Biketronics BT4250.14?
- Looking for more... speaker lids, pods, or speakers in the bags
- RTA app and other tuning tools?
- 16 RG fairing install questions
- ARC PSM,,Band Pass crossover?
- HD Boom Audio 20s
- 2002 Ultra Classic
- Question for you DSR1 users
- Road Glide - Horizontal Mounting of Arc 600.4 when using horns in fairing
- Budget amp & Speakers
- PN1000 wiring question Help please!
- Boom! 6.5 Screen Resolution
- Amp installation recommendations in Oklahoma
- 17 Tri Glide Ultra upgrade stereo
- Pushing Mmats 801.4
- infinity KAPPA 62.11I 6.5's in my upper fairing
- Iron Cross Bluetooth Mod Disconnecting and going to AM
- HD Corporate Thinking? Rant...
- PN1000 amp mount
- Amp inline fuse
- Anyone remember details about the old RadioSounds head units??
- Looking for More..
- stereo crackling. Now no sound. Code U1016 pops up???
- AD Designs speakers in Fairing Factory lowers question
- Dd b3 holes size
- 14 SG $1800 budget to upgrade
- Cadence 6x9 vs pioneer ts 6x9
- Neat little device from PAC eliminates amp pop when turning on/off
- Amp Help Please
- 2017 CVO want to add Lowers at a low cost...
- Need some music please
- Audio tuner in NE Ohio
- Active or passive
- SS pn4.1000d and Kappa 62.11i installed
- RF amp and Hogtunes Gen 3 6.5s installed
- ground
- Sony HU and AMP HPF settings
- Refurb CV B52s for $99.
- 2017 Ultra Limited Upgrade $2K Budget
