- moving right side shift
- Randy, haven't seen an update lately...
- winter project: rebuilding the ironhead with questions
- Leaking Tappet Guides
- Where to purchase gaskets?
- Primary Inserts
- brake bleeder leaking
- cc size and carb jetting
- correct point gap on 81
- 73 XLCH rebuild
- Will 99 sporty highway pegs fit...
- Kickstart only engages halfway down the kick?
- Correct way to remove and install right-side engine cover?
- Trouble starting...
- oil leak
- fuel line
- total rebuild
- Stock Shovelhead carb on my Ironhead
- Removing Swingarm on 79 Ironhead
- Chain goes loose then tight?? HELP!!
- ironhead replacement cylinders
- 1974 Ironhead eating starters.
- Primary filling 75 ironhead
- Late Model starter on an Ironhead ?
- $1800.00 rolling Ironhead for sale
- 75 IH 1st gear issue
- It's a done deal
- Top end Rebuild advise
- Front Brake caliper help!
- backwards breaker cam?
- I think I smoked my new starter seloniod !!!!
- stupity at its finist
- no oil pressure
- OK, So Shovelhead Sportsters Don't Exist
- Thin Skin? You tell me.
- Taking motor out
- Hardtail conversion HELP!!!
- Countershaft Sprocket & New Chain 70 xlch
- need spark no wiring
- Carbs??
- wat is this?
- starter wires? removing starter?
- Ironhead value?
- starting engine
- What kind of oil?
- Ironhead - Shovelhead Which is it
- Tear Down and Rebuild of the IH
- Speedo problem
- timing on 81
- Oil cap gasket
- Fluid types and specs.
- BAD oil leak!
- Starter seloniod part number
- 23Tooth Sprocket
- Moonwolf's Ironhead Lounge
- Got my Ironhead back
- sounds from the motor
- oil pump questions
- not starting when hot
- turn front brake disc?
- 84 bobber
- types of speedo/oil pressure etc guages
- how important is the engine brace
- pistons markings
- timing oil pump
- Adding a starter to a '71 xlch
- 1970 XLCH Tach drive
- 1976 Compensating Sprocket
- '72 to '76 front end conversion question.
- hi and low idle
- Single or Dual front brakes
- Battery Life
- Picture!!!! Finally!!!!!
- No Spark
- Help oil coming out of Exhaust
- Chatter?
- Thoughts on performance mods for a 1970 XLCH
- how much rod movement?
- 1970 ironhead battery Problem
- '83 XLH1000, overheating?
- First ride
- What could cause backfire?
- Timing Case Leak
- 1970 XLCH Rear Wheel
- I need some advice on a project
- Need Clutch Help
- fitting of piston pins/ bushings
- cam timing
- grinding inside crank case
- engine casing 77 sportster1000
- Think my clutch is fried, does this sound right?
- Which oil tank might work?
- Wierd noise
- 1978 ironhed
- 79 Ironhead Weld on Hardtail
- 78 ironhead coil wiring
- Sportster to Bagger
- anyone know of a starter
- My aching neck and back!
- Top end rebuild
- Project- is this worth it?
- engine boring
- Ironhead Cases
- where are the posts
- clunking going into first ger
- How hot
- Ironhead rebuild
- First Bike
- Newbie to this forum but not to Ironheads
- Shocks differences
- can i reuse copper head gaskets?
- 76 sporty
- Broken Tappet Guide
- Bike Sold, Thanks everyone
- Trouble at home
- generator problems
- Rear shock stud/bushing size change?
- pulling heads off--any suggestions
- Chain keeps going loose
- Disk brake caliper
- Trans trouble
- blowing up voltage regulators
- need a clutch cable for my 83 xlh
- 61 Magneto timing help!!
- Selling my 75 ironhead
- wide glide trouble
- looking for ironhead motor
- control module
- Best Performance Mods for an Ironhead?
- washed bike don't start
- Oil spasher washer ??????
- any ironhead complants?
- Bike Values and 71 XLCH
- Trans noise
- Newbie needs help
- lifters
- the best lights for ironheads
- basketcase problems
- trans sprocket
- new pics
- evos switch
- pinch bolt torque on 81
- Piniongear is outta here.....
- Can someone fix this forum site?
- Any have a
- '73 xlh engine removal-any tips?
- no oil to rocker
- S&S -hows your bike jetted?
- 1970 Ironhead, have to sell it
- generator leaking oil
- Front brake upgrade
- brake lines
- New Pipes
- Oil Questions for a newbie
- Question about clutch adjustment on 68 xlch
- siezed motor
- 1976 Ironhead Great Deal
- what's it worth
- solenoid problems 75 sporty
- 2 sets of vin #'s
- timing question
- oil lines/cooler
- Oil coming from breather tube
- Posting Trouble
- Charging system and ignition trouble
- Good Buy?
- Best ign coil for 72 ironhead
- Time to upgrade a little
- Intresting front end story
- 1970 XLCH Sportster Ironhead
- Sportster Flat track tires
- did the 81 have a hub speedometer?
- 1975 xlch color options
- starter relay?
- Red powder all over back of bike
- oil tank connections........
- 1979 Speed Question
- forward controls
- 1983 XLS Charging Issues??
- Drag Pipes
- oil line routing
- question about trans oil for a 73
- went down today
- kicker only
- Supergwit's oil tank question.....
- wide glide front end
- Engine rear mounting bolt
- battery not getting charged
- S&S Super ??
- fuel trouble
- Tire Size
- front end wobble
- 77 XLCH Starter Trouble
- Primary conversion
- 1975 xlch cam issue
- SELONOID PROBLEM
- carb troubles
- Oil leaking from primary
- able to shift without holding clutch in
- oil pressure-do i have it?
- Oil Light
- Gas leaking out of carb
- Generator Leak!!
- Glowing Pipes and Bad timing
- Turn Signals
- Charging
- First Ride
- bobber blues
- exhuast valve gets tight after 300+ miles
- 75 XLCH kickstarter
- 75 sporty kick starter bushing
- 76y bobber
- Homemade Tools
- does anyone know where to get carb intake boots?
- Cam timing - running rough
- neutral lite
- 76 bobber
- Cam end play
- replace clutch plates
- Charging system still
- Bike worth?
- primary chain
- Removing the Advance Assembly?
- more bobber wiring
- need help with tranny interchange
- Your Projects
- ironhead bobber wiring
- Front wheel clearance 74 XHL
- 80 ironhead problem
- mystery primary washers
- 1975 xlch rear brake
- Rear lowering shocks?
- negative wire
- How do I install front brake pads?
- Mystery shocks
- Converting to a 2007 front end
- Front Caliper...
- Its Alive Again!
- observation made regarding the double back slash business....
- 1959 clutch getting wet...
- Volatge Regulator
- 24 tooth sprocket
- feakin leakin primaries
- Price too high, or just right?
- valve stem seals???
- 74 ironhead
- Hey PinionGear and other XLH gurus?????
- '65/'72 chopper oil tank help
- Anyone interested?
