- fitting question on cam side of motor
- Highway pegs ?'s
- 1975 ironhead question, for a newbe
- putting mufflers on pipes
- need help with a 77 ironhead
- forks ?
- Drag pipes with baffles
- wiring help. 73 XLH turn signals
- Valve springs
- killed sporty
- what size engine in an 81
- 81 sportster clutch
- Major Oil Leak
- question about crankcase vent
- Eating up Starters
- fork tube and slider?????
- XLH-1000 Kick Start Wiring Diagram
- SOURCE FOR IH PARTS
- Gearcase Gasket Replacement
- 81 pics
- 81 for sale
- Modification question
- 74 xlh 1000 motor-1982 frame
- Clutch basket
- adding blinkers to a sportster bobber
- Building up...
- 1973 XLCH restoration/breakin
- sporty carb/combustion/exhaust ????
- gas mileage on 84 ironhead sporty.
- Identity Crisis
- Fixed flat spot on 85 Ironhead
- Fuel supply issues
- driving lites on a early 84 sporster
- 79 sporty ???
- 75 ironhead reving up on its own
- 76 Carb jets
- thanx guys re engine sizes
- 74 IRONHEAD
- sprotor
- Help...'76 XLH L/H engine case cracked
- master cylinder
- 69/70 Sportie... what to look for?
- Hard saddlebags for 85 Sporty??
- somebody please tell me their getting good ridin time
- Wireing Question?
- Rear tire removal
- Transmission history
- cam question
- lights running the bike down
- Core Charge on 1200 Conversion ?????
- one more problem for the pros please
- Paint Code
- remote oil filter kit
- piniongear
- Brighter headlight bulb?
- kickstart might be old skool but it kinda sucks
- headlight
- A little help for a "new" 1973 Sporster XLCH
- Forward Gear Shift - Help please
- RevTech Electronic Ignition
- S&S Shorty
- mirrors for a 73
- what itermidiate jet?
- speedo drive problem- recurring issue!
- CV carb jetting and atomining?
- Biker's Creed
- Need Help from Mikuni Experts!
- transmission bearing or upgrades
- Proper oil change procedure
- Head Gasket
- Thank God for THIS forum
- 1976 ironhead jetting?
- cams wanted
- cam question
- Problem Starting
- two questions
- crank breather
- carb and oil question
- CAMS
- case crack...
- Vapor lock
- Valve Springs
- 74 clutch question
- carb question
- need a conversion electric start
- 1980 Iron Head Valve Adjustments
- Oil & such
- new ironhead owner
- Ironhead drain? vent?
- Tank crud
- SPORTSTER FATBOB TANK ADDITION
- Swingarm & thirty years of crud
- Tire size
- Daniel Boones on '75 or 76 with cable brake?
- Rear Wheel Alignment IN FRAME
- 74 shifter shaft seal
- fender strut support bar
- '73 ironhead engine sizes
- wanted sportster hardtail frame
- Value of a 1973 XL & XLCH 1000 Owners Manual?
- Another question
- Cam Cover
- up sweep exhaust
- compression question
- sportster motor
- So I just got my head off...
- Automatic primary chain adjuster
- 1979 sportster project
- couple of questions about my 77 rebuild
- 79 XLS exhaust.
- Major oil leak
- My First Motorcycle (and is a Sporty......)
- Hey Ironheads need help
- Stock Piston Size
- Need Rebuildable Flywheels for my 79IH
- xlch wiring diagram
- Rocker box leak
- finnally got starting issues fixed
- So, how fast is FAST?
- Fork seals
- xls top end rebuild
- Oil Leak
- Need help with ID 1984 Ironhead
- does this estimate sound about right?
- 1983 xls
- bike is smoking out of breather tube
- Nostalgia Nitro Harley's
- My '76 XLH Face Lift (Lots of pics)
- Jockey Shift
- What fits my Ironhead?
- Rocker arm shaft screw.....broken?
- What engine do I have?
- Wiring with Bob Ross
- curious
- 71 ironhead sporty
- SOLD - 1000cc Jugs
- Oil tank position HELP!
- Need carb help
- Oil Breather puking
- any cool looking exhaust out there
- exhaust noises
- Muffler Pipes
- compression for 1976 xlch iron head
- Forward controls on a 1975 XLCH
- Evel Replica
- Leaky forks
- This is my 81 xls after a little chop job
- early xlch: impossible design or fixable?
- Boosting the output from a generator
- pGear centerStand
- HNY
- Throttle Spiral Question
- Gasket Sealant
- Heavy duty kick starter shaft and gears??
- What sportster engine is this
- Top End Rebuild
- Screamin Eagle Carburetor
- 74 XLH PIPES
- clutch adjusting
- thought someof ya might want to check this out
- 70 XLH Front end
- 77 Ironhead Rebuild
- 1977 1000XLH Ironhead
- TRAN OIL FILL
- 72 ironhead question?
- Hey, Pinioin--I love my Tillotson
- primary oil ?
- it's been a while
- changing exhaust pipes
- need help with starting a 1971 xlch please?
- 1973 MIKUNI CARB PROBLEM
- Leaks oil!
- I'm stumped - won't start
- breather bleeding but bike runs like a raped ape
- Here it is needs bath but it getting there
- newest problem putting pushrod cover back together
- Progress!!!!
- Stripped lifter bolt 77 XLH
- wheres my drain plug
- Daredevil Evel Knievel dies after long illness
- charging driving me nut is this the right choice
- Picked up my (new) sporty
- Saddlebag supports
- OIl question and breather
- battery ?
- Any truimph collector or enthusiast
- Almost done just got to fix carb
- Sporty starter problem
- BRake light question
- 83 iron exhaust
- 74 XL
- Happy Holidays
- oil migration question
- Standard Frame?
- smokes at start up
- 1979 IH
- Fine tuning, for cold weather
- swap to a wraparound oil tank in a 67 XLCH
- How much oil? primary?
- Cam gear setup
- 1958 xlh question here
- clicking regulator
- rear tire crooked
- Carb jets
- saddle bags
- Bike lifts
- 81 clutch shell
- 76 Starter motor
- How this all started.....48 years ago
- 73 Sporty Carb
- Sporty tank question
- Wanted:Photo of orange/black 60s XLCH
- oil fill amount and trans oil 77
- 1967 XLCH Carb Choices
- 71 iron head sportster
- 73 Sportster Oil puke
- Getting a passenger on my bike.
- clutch slippin
- Greetings to all
- 73 Sportster
- 72' ~ The New "61" Road Test ~~ Way Cool ~~
- Stock Teeth
- Leaking around the tappet guide
- Handlebar Bushings 72'
- 1972 Seat Issues
- oil leak from top of push rod tube
- points and condenser
- 72' PRIMARY QUESTION ~~ Please Help~~
- red hot pipes
- Right hand shift ?? (year ended)
- whats the difference between xlh and xlch
- Ironhead questions Please
- S&S Carbs
- which headlight is better?
- 1970 XLCH Carb upgrade
- Carb adjustments
- how can u tell xls roadster
- Question about baffles and popping back through carb
- Blueing on pipes
- Tranny problem
- Spits back through carb and dies! Arrgh!
- 1972 just purchased from "1" owner with 35 years worth of receipts!!!! A few Questions~~
- Electronic ignition
- How much should I offer for this Ironhead?
- overheating issuses
- need sugestions backing firing in pipes
- 1982 Sportster Anniv ED
- How to build a Sportster (from a pile of junk)
- Oil tank
- Breather Tube?
