PDA
View Full Version : Flathead
Pages : 1 [2] 3
  1. 45 lower end rebuild - Dare I attempt it myself?
  2. Removing WL piston 'circlips'??
  3. Navy WLA?
  4. Another serial number problem
  5. Another serial number problem
  6. looking for parts for a 1931 d 45 cu bike
  7. How to align the rear wheel ona WLA
  8. Just bought a ‘45 flathead. Have many questions
  9. 1942 wla ??
  10. 1942 wla ??
  11. wla primary cover
  12. WL vs WGE motors
  13. WL Engine in Shovelhead Frame?
  14. Flathead shops
  15. Oil light won't go out
  16. WLA generator
  17. 1933rl
  18. How to check engine No?
  19. Can't Start Flathead...Need Help
  20. Identify please
  21. Vl frame unmodified
  22. Looking for leads on flathead parts
  23. flathead
  24. Wla
  25. Frame stamp
  26. Servicar brakes.
  27. 45flathead power
  28. 1966 Harley-Davidson FLH Project
  29. 1966 Police trike
  30. '44 Flathead - Need help?
  31. is this right ?
  32. Servi-car Frame
  33. WL 45 v-tronic auto advance
  34. HD WLA Saddlebag Mounting Stud
  35. 45 Owners Near Huntsville AL?
  36. '56 khk
  37. Looking to Pick some brains
  38. where to find information about harley shovelhead wire routing?
  39. WLA Frame numbers
  40. servi-car front end
  41. 39 parts manual or list?
  42. 1926 jd
  43. In need of some advice WLA / WLC
  44. 1948 Flathead Project
  45. Flathead Advice
  46. one year earlier than the D model flathead
  47. one year earlier than the D model flathead
  48. a year older than the first flat head
  49. 1946 wl
  50. Harley WLA
  51. Flathead motors
  52. The 38 Potato Head
  53. 1955 "G" Servi Car
  54. 1961 Service Car
  55. WLA sidecar setup
  56. Indian Identity
  57. 1946 WL Solo
  58. Going to look at a 1939 barn find
  59. Looking for opinion of value 1942 WLA
  60. Help me I.D. Grandpa's Harley
  61. Ebay 1942 Flathead and Vintage Racing
  62. 53g wl
  63. Pistons for 1943 WLC flathead
  64. handlebars
  65. bought a 42 WLD today anyone have info
  66. wl 45 1st.gear question
  67. Correct WLC muffler?
  68. Hd 33cb
  69. Considering a 42 WL
  70. 47 UL clutch pushrod help !
  71. Shifting wrong
  72. WLG engine in a WL solo frame
  73. 42 WLA marking question
  74. Inherited 1956 HD KH
  75. Flathead serial number
  76. ***ISO: 1946 Flathead***
  77. Cam cover
  78. WL idler shaft
  79. AMCA event jefferson PA
  80. carb rebuild kit for a 1940 wla
  81. 64 servicar advise
  82. triglide caliper failure
  83. Just got a 1942 WLA. No key! Now what?
  84. Identity of this Bike?
  85. New Flatheads
  86. WLC 1942 or D type 1931
  87. Help from here (VIN help needed)? Plz, see link
  88. I found a 42 WLA for sale
  89. 1966 Servi battery
  90. Flathead VL Frontend
  91. my 1946 Model U 74 SV (1214cc) "Rat Rod"
  92. 47 ul
  93. 1949 "45" Ignition Switch
  94. 1926 JD kind of bobber
  95. 1942 WLA 596 original miles selling it
  96. What I am working on GE
  97. 1937 WL Motor
  98. Stolen 42 WLA!
  99. 45 solo frame
  100. WL45 year 1942 or 1950
  101. harley 45 flathead engine no Vin nbrs
  102. VL VLD UL UL ULH & Other Old Flathead Parts Interchangeability
  103. 1946 wl
  104. Leather work..Captain Itch
  105. clevis pin and spring for seat t-bracket
  106. Model WL Tranny Sprocket Leak
  107. WLA engine in a Big Twin frame
  108. Generator and circuit breaker for wl 1947
  109. WLA Carby Qustion
  110. colors for 1945 "U" flatty
  111. UL engin every day ride
  112. 42 WLA Question
  113. "New" WLA
  114. Restoration Book Wanted
  115. 1942 wla ?
  116. New Old Flathead
  117. Found a basket case
  118. The last servicar?
  119. Barn-Fresh WL
  120. Leaks, leaks, leaks - tech questions for Harley WLA WLC WL experts
  121. My Flathead needs a battery.any recommendations ?
  122. Question on flathead designations
  123. '29 JD Need Help
  124. Inlet Manifold Change
  125. vl rev limit ?
  126. Servicar
  127. high"er" compression flathead heads.
  128. 45 Cam Cover Removal help
  129. Flathead VIN verification
  130. 1942 flathead siren with foot mechanism
  131. Needing help to identify a 1933 Flathead
  132. Can't Start Flathead, Need Help!
  133. I'm probably wrong but suicide shifter? Really
  134. Is this the right place for KH info?
  135. Generator Info
  136. Classic panhead ok for novice rider?
  137. Old harleys for sale?
  138. 1936 vld
  139. WLA numbers
  140. chain of fools
  141. Original Service Manual
  142. Grinding noise
  143. old soul in a young body
  144. a little info please on '26 JD Forks
  145. Change 45 flathead to overhead valve engine
  146. British 4 speed gearbox
  147. Flathead wanna be and no threads... Dayum!
  148. OK guys i need your help!!!
  149. Completed 45
  150. alarm deactivation
  151. 1939 wldr
  152. Need some input , wide glide lower tree 3/4" stem ?
  153. 45 up & running at last !!
  154. !965 HD Flathead
  155. need 45 rebuild - N.E. Ohio
  156. 32e generator for 58
  157. Not pumping much oil
  158. Servi-car frontends
  159. Looking for 45 Flathead parts....
  160. Found 34vld motor, in great shape!!
  161. Flathead transmission
  162. WR rear fender
  163. Morris or Joe Hunt Magneto?
  164. Removal of heads and jugs
  165. flathead serial number
  166. Flathead exhaust
  167. Servicar speed
  168. Looking for solo frame!!
  169. Got the Flathead out today...
  170. found this in a scrap yard has not moved in many years it is inside
  171. neck bearings
  172. WLA Engine cases and bike restoration
  173. Right hand case bearing modification
  174. Starts on second kick......I Wish
  175. pinion gear question HELP!!!!!
  176. Spark control 42WLA
  177. Looking!!!
  178. 45 service manual
  179. 1949 WL Questions
  180. 68 chicago real police servi car
  181. 67 flat on servicar need a carb any suggestions
  182. 1941 wl
  183. 1948 Flatty
  184. SAE60 Non-Detergent Oil: Where to get it?
  185. any one still see this 45 around
  186. Shovelhead cone left case
  187. 46 FLATHEAD wr left case
  188. 45 flathead cylinders?
  189. 45
  190. 38 UL Motor - What year transmission?
  191. Grandpa's 1938
  192. Ongoing H-D Flathead 45 project.....
  193. wiring harness routing
  194. Help and Flathead parts needed :)
  195. Carb for 1938 UL
  196. 1941 WL battery question
  197. Great class
  198. which post is which on a flathead generator
  199. Supercharging a VL engine
  200. dash
  201. help
  202. Flathead Engine to Shovelhead Frame
  203. WLA Project
  204. WLA service manual
  205. just finished 1945 UL
  206. Help - Timing on 1963 Flat head
  207. WLA UK registration issue
  208. Unusual WLA serial number
  209. WLA Build
  210. WLA versus WL
  211. Battery ground wire
  212. So many WLA parts!
  213. Swedish aphanger with monkey!
  214. ANOTHER 1950 WL ?
  215. wiring diagram
  216. Flathead numbers
  217. wires
  218. for sale 1941 servi car frame and rear end excellent condition .1000.00
  219. '47 Flathead
  220. have a 47
  221. Diagram of 1930 hub needed
  222. supercharger for a 1941 u
  223. wla friction damper
  224. wlc hand clutch
  225. 1944 U Model, 74 Flathead
  226. 1950 HARLEY WL ?
  227. 1931 VL Toolbax and Delco Remy horn
  228. Does a 1944 Flathead 74 cubic inch exist?
  229. my 38w
  230. bike value
  231. servicar parts wanted
  232. 56 KHK Starting Point
  233. 1928 JD Buck Saw
  234. 1950 HARLEY WL ?
  235. small oil leak
  236. Flathad Voltage Regulator
  237. Roller bearing tolerances
  238. servi car rear wheel ???
  239. Relief Pipe Oil Leak!
  240. New to Forums! 29 D Model Arrives Monday!
  241. flathead transmission
  242. 1930 triple clamp needed
  243. WLA motor worth?
  244. Here is my starting point
  245. 1930 V pics needed
  246. Flathead oil lines
  247. Flathead Fact Wanted!
  248. RG or Flathead?
  249. 1942 Harley-Davidson WLA
  250. 1942 45
