View Full Version : Softail Models
- Stretched Fender
- need some ape hanger help on a breakout...
- Passing light, light bulbs
- 92 heritage wants dual exhaust
- 2015 new softtail modles
- Ape hanger install : brake question
- New clutch question...
- Rim size??
- softail 1999 rear wheel 180-60 16 to 18 conversion
- Hey Texas.
- best cam to cool off a 103ci Softail Slim?
- Part # for 2008 Deluxe Turn Signal Module??
- O2 Sensor Connections, WTH are they
- cams
- Deuce rear fender to bobbed rear fender
- 2011 Fatboy Lo
- Exhaust baffle question for V&H BSS
- Heritage vs. DeLuxe
- 2007 softail deluxe frame search
- LA Choppers nice curves 16"
- High beams and passing lights
- Rear O2 codes, bad sensor?
- Wife wanted to be a Harley Chick...
- Inverted front forks with Klock Werks fender
- Trucklite Phase 7 LED Headlight
- Can't reach rear brake pedal due to air cleaner
- very torn... Breakout or custom?
- Fender & Bag Rails...Yay or Nay?
- Windshield lowers
- Load equalizer location for LED upgrade
- Let's see some springer pics!!!!! ( not jerry, either) :0)
- Shotgun shock height
- Decel pop and Powervision
- New heritage
- Used Slim shocks to lower Breakout
- 2014 deluxe
- I need a scissor type jack to use with my table lift
- Show me some orange
- Muffler turning blue
- Stock passenger peg mounts?
- replace new speedometer 74777-11A
- A usable "formula" for determining correct tire psi - maybe?
- Front end swap - springer to Slim/Heritage?
- Adjustable Rider Driver Stud Backrest(2007-2014)
- back home....fat boy question
- Primary Noise Fxsts 96
- This can't fit right??
- Is The 2014 Softail Tranny Plug Offset??
- Softail Slim Transmission Fill Plug
- Fairly new to the forum, figured I should post my bike! '05 Deluxe
- Top end oil leak on rear cylinder - advice request
- 2011 Fat Boy Lo Turn Signal Re-Lo Issues
- Lost my Hog Deluxe bag today
- Softail Springer question
- Mikuni Question
- Losing Interest
- 2009 **** Swoosh
- Simple shifter rod change with unexpected benefit
- Thunderheader question
- 1st twin cam
- Breakout Fenders
- Is it my Voltage Regulator going out?
- High beam is out!
- Leather pros 3200 bags on a softail slim
- 2001 softail springer...whats it worth?
- My First Harley
- Exhaust Help
- Dyna owner considering a new softail..
- torque specs
- 2007 Deluxe
- Deluxe with a 587 Dkcustoms
- who makes a shorter rear fender for the Breakout?
- PSA - Make sure your bags are closed!
- PLEASE HELP A GIRL OUT: bike starting issue
- 2011 FXS Blackline wheels on 2003 FXST
- Just wanted to thank everyone here for helping make my pink bike what it is today
- Saddlebag guard and Guard rails.
- Successful tire experiment – 2014 Breakout – but need tire expert psi advice
- Dyno Tune or PV-1
- Rear brake rotor much hotter than front - why?
- Electrical Gremlin
- Light Bar on Fatboy
- new seat for the RSD 200mm fender
- Internally wiring aux accy switch
- Question about Rush baffle size
- My heritage (with pics)
- stranded...
- Easy solution to buffeting
- Breakout rear tyre sizes
- Fatboy fender question
- New Slim Apes
- New wheels and Rotors, Now Pulsation????
- Replacing the carb...1992 Softail Heritage
- Question about truck phase 7 passing lamps on 05 deluxe
- Horn quit working
- Securiyty / Alarm Question - How far Back for Softails?
- Chrome struts for 2011 Fat Boy
- Am I nutz
- Road Trip/Gear/Rain review, what worked what did not and lessons learnt.
- Distance 2up rides on Softail Deluxe
- 2002 Fatboy exhaust.........
- Securing Windshield on 2014 Deluxe
- New battery question
- anyone regret their purchase?
- Who sells super bright bulbs for the passing / aux lamps on heritage and deluxe?
- Wiring question for a handlebar swap
- New deals to be had?
- Lowering a Breakout
- A positive Indy Mech experience
- Anyone have an fx softail with a 7 inch headlight
- Is the upgrade from 88 to 95 worth it?
- Samson exhaust
- Question for Breakout Owners
- need help to find a handle bar .
- Pics of solo seats on 200mm Softails
- I have seen the light...Auxiliary light...
- Ordering OEM replacement tires online for my deluxe ?
- 2015 Harley Models Launch date Anyone?
- Insight please
- Tire Time !
- Samson 28.5 true duels crooked
- DTC Code Help 2012 Deluxe
- saddlebag guards
- Fxstc alarm
- Anyone know of some hard bags for a Heritage Softail?
- run turn brake controller help!!
- Moving on Rocker fam
- Bags and fairing on 07 Deluxe
- My Speedo Stopped working and giving "no CAL"
- Blackline apes
- Getting a new exhaust, just wanted last minute input
- Question For ThunderMax Users
- turbo kits?
- Softail CVO Deluxe saddlebags
- Percentage of failure ... Cam Chain Tensioner at 25,000 miles
- Stage II - Powdercoat Cylinder Question Crossbones
- heritage chrome front hub cover removal
- Traded in the Fatboy for a Heritage
- Freedom vs VH questions
- Electric starter problems
- 99 Softail Baker 5 speed w/ Reverse
- usb
- Black Chrome wheels on Breakout
- Transmission overfilled
- '13 flstn
- Question about the CVO Breakout foot controls
- Heritage Back Rest
- softail fairing on ebay
- new-to-me heritage owner has questions
- 40 spoke laced wheels for 05 Deuce
- Floor Board Mounted "highway pegs?"
- Breakout -- Solo and 2 up
- I need a shorter passenger footpeg bolt
- who's got a Corbin classic solo on their Heritage?
- Front wheel hard to spin after new bearings
- will these wheels fit without any mods?
- Back from paint. Vicla deluxe bagger
- LePera seat - where to buy?
- Cam suggestions for 2014 Breakout
- Deluxe rear end vibration
- Tank lift help 05 night train
- Accessory Hook-up for 2014 Heritage Classic
- Progressive monotubes VS Racetech springs and gold valve emulators?
- ID Breakout Exhaust
- new softail purchase? thoughts
- Softail slim seat
- Nacelle and Ness retro fork covers
- Pros Cons 88 to 96.
- RSD Tracker REar and stock brackets
- Naval Airstation Whidbey Island
- Breaout Handlebar Question
- Performance Machine Brakes on a Springer TC88 (2001)
- does '06 outer primary cover fit '07
- 2009 Heritage
- Removed passing light bar heritage help
- 250 rear on a 2008 FLSTC softail heritage anni
- 2014 Breakout Ignition Switch
- Softail Slim: Pics without the headlight tin??
- Gas Tanks
- CV carb leaks from excellerator pump
- Softail Slim Windshield (Pics)
- Bike died on Dyno...
- Head Buffeting Gone--for only $99
- L E D head light switch
- Supertrapp and deluxe??
- 08 Night Train into a 50's Bobber DONE
- Leather tour pack installation
- Blackline Sissy Bar & Passenger Seat Question
- Hardbag options on HST
- My bike didn't come with passenger pegs
- HD
- Breakout Tank Emblem Option -- Need Opinions
- Fall away non existant
- Passenger mounting bracket. Slim
- Air cleaner upgrade questions
- Potential problem
- Operation FATBOY: 2014
- From Cool to "Tour" in 15 minutes.
- 23" front fender
- Deluxe decel popping, bone stock bike ?
- Black Smoke off Idle
- Difference between '00 to '07 and '08 up Softails
- Oil Seeping Out Of Dipstick
- Removing Rear Wheel - 08 night train
- two wire hook up for a brak light??
- Peg wants to see night shots of your LED accent lights
- Relocation kits for 2010 Fatboy Lo
- 99 fatboy - petcock leaking... replace/rebuild?
- Doing a cam in 103 deluxe
- 2014 Breakout Bulb
- progressive 422s - do they have better damping/rebound qualities compared to stock?
- Brake Pads for PM
- Blackline 200 mm rear and 23" front
- ultima king spokes
- Battery Light While Running
- 07 deluxe axle sizes
- Security sytem for my new Slim, thinking HD... any other suggestions?
- Fatboy makin weird sound from belt
- True duals missing heat shield
- my still new to me 2000 flstc
- Truck light phase 7
- question on 95 fatboy gas tank
- Anyone install engine guard on their CrossBones?
- Why I Love My Linby Multibars on my 2013 Breakout
- Softail Delux CVO 2014, has no power.
- Just joined the softail family
- It's a miracle! Avon 120/70/21 "wide" white wall has arrived!
- vance and hines true duals on a deluxe
- Heavy Breather intake Alternative
- New Bike
- Samson long tails
- What's in my softail.
- 88" to 95" conversion on my Fatboy
- Hot Shot 580 cams
- Avon 120/70 21
- speaker system
- FOB/Security messed up
- Fairings and wind noise
- Slim - removing scratches on air cleaner cover
- preload for shocks
- Changing the dreaded Cam Shoes: '03 Deuce
- What color is my bike?
- Ohio Slim owners?
- Review of my new Cleartastic King Size windshield with 'Recurve' at the top
- Ultima King spoke wheel install on my 07 FXSTC??
- Sissy bar mounting, no outer struts?
- first thread! first softtail too!
- 09 Nighttrain Sputters/cuts out upon 1/2 - 3/4 throttle
- 09 Rocker C bagger "Rock Bottom" build finished pics
- First Softail inbound! Tips and tricks appreciated:
