View Full Version : Softail Models
- What's my Deluxe worth?
- Night Train To Deluxe 21" Fit...
- Longboy fender clearance?
- Can it be done?
- Front end value?
- Breakout Air Cleaner
- 13 Softail Slim Mini Apes
- shotgun shocked solved it
- Help with decision - tank badge or bare?
- basani radial sweepers on a breakout
- The Shotgun Shock Installation Thread
- Vance & Hines Short Shots
- How much?
- Rear Fender Wiring question...
- Just picked up my rocker c
- 2013 Harley Davidson Blackline FXS
- custom Frames
- happy st paddys fellow softails
- Deluxe pin
- New Oz on the block
- 5-3/4 Daymaker "Teddy Bear Design" Question
- RSD Tracker exhaust peg Re-location
- Which pads to use on DNA rotors
- axle alignment ?
- Do I need new tires.
- First Ride after winter Not Good, replies please
- Ride wright wheel falls apart? Scary
- Coil relocation
- Andrews 48H Cam
- can someone clear up all the miscommunication... what size grips?
- 2008 FXCWC service manual
- Used Night Trains worth more than other softails?
- Buying a New Softail - Deluxe vs Heritage
- Sharing this
- 2011 Heritage Classic Fender Trim, can it be swapped with for the Deluxe fender trim?
- arlen ness 07-611 +3 forward controls on a Rocker
- noob with mod questions
- Which LEDs for 01 ST Speedo?
- What kickstand for crossbones ?
- 2009 Rocker rear brake anti rattle spring
- 1990 Heritage misfires sometimes
- Engine Oil, Trans, & Primary/Fluid capacities...PLEASE CONTRIBUTE!
- Another " oh no, I hope this isn't bad !!! " Thread ... by Yours Truly
- How soon is too soon...
- Pulled the trigger...Shotgun shock on the way.
- website for HD models: oil trans, & pri capacities
- 422 vs shotgun at STOCK HEIGHT
- Winter mods to slim
- Quick Detachable Bags
- Good brands of 1" spiked grips and pegs
- 21" front on evo heritage
- Need Heritage Springer Ape Recommendations Please
- 98 Fatboy with neutral light issues
- how do i remove fuel rail to get to injectors?
- What is the best way to extract oil out of trans?
- Went ahead and installed
- 2014 Breakout or Softail Slim?
- need help... quick release windshield mounts 96 heritage
- Akrapovic Exhaust
- I'm lost...tune question. To tune or not
- Picked Up The Bike Today
- Loctite in the Breakout ignition switch now!
- The Breakout side stand is better than it looks . . .
- Labor charge to change front drive belt pulley?
- Dimensions of swingarm bag? And better mount? Better bag?
- Apes for my 2012 Slim
- Is removed speedometer "married" to VIN of bike it came from?
- Heritage Classic True Duals?
- 97 softail springer head light not working
- Shotgun Shock install on Breakout
- Arlen Ness 8in modular drag bars
- Price for an 2007 Heritage Classic
- outer primary cover part number
- Help ...need pic of Apes on Softail Deluxe with ABS
- New Breakout owner...
- removing adjustable pushrods?
- Breakout forward control extension?
- building a 2 into 1 exhaust for a 2011 heritage
- Memphis Shades Batwing
- Changing tins
- FXSTBi 2006 Front Stoplight Switch ?
- Samson shift rod
- Slim sissy bar options
- Harley Speedo/tach Help
- New Rear Fender, DIY Heartland look on the Cheap
- To see what Yall think
- Anyone running LA Chopper Tree Hugger apes?
- Fat Spoke stock tire question
- Starter issue
- * The Stretched Fender Thread*
- Se heads-vs-stock heads and headwork.
- breakout blackline dash - NEED HELP!
- Going from 18" apes to 12" Heritage bars
- RSD 49mm fork caps and headlight bezel
- New fender installed
- Batwing Fairing on Softail Slim?
- Whats my bike worth....
- Engine management light
- 2013 FLS (slim) Cant find luggage rack that will work with sissybar???
- Chrome bolt cover question...
- Fuel Gauge
- 08 Fatboy stock seat question
- FXSTD Winter Updates
- Ape hangers on a 96 heritage softail
- Heartland's passenger seat
- Breakout LED Fender Brake/Turning/Running Light Installation
- 21" Whitewall
- Carlini Gangster Ape Hanger question
- Shotgun shock tranny oil plug clearance issue
- eBay Headlights
- My new 2014 Breakout
- Did Vance and Hines just blow away all tuners on the market?
- Digital dipstick accuracy
- Battery indicator does not light
- Shovel Head Softtail
- Rear fender question for you guys?
- 97 harley softail wiring diagram
- Dumb question- proper place to run additional power to handlebars
- Breakout exhaust question fr newbie
- Opinion on mirrors
- Lowering
- ...2014 Softail Slip On...
- Night Train or Standard polished rear wheel care.......What product?
- Question about lowering the front and wheel size
- retro deluxe with sprung seat and almost rigid rear
- Want a change
- alarm - aftermarket vs harley
- clutch bearing gone bad....?
- 160 tyre on a Softail Slim?
- RSD 12" Vintage Vs Wild 1 Outlawz
- ape hangers
- Opinions please
- Hard Start..Can you make it better?
- Breakout "out the door" price...
- Bo wheel
- Bike Top End Problem
- Front end wobble!
- NIGHT TRAIN SCOOTS! Which Front/Rear Tire are your rollin' on?
- Picked up my Breakout with Stage 4 Racing kit plus D&D Low Cat exhaust!
- Axle Sizing - Hard to find
- Flush Mount Caps On BOTH Sides???
- 97 Heritage Springer Motor Build question
- Anybody own a Pitbull Motorcycle lift??
- First Softail Deluxe
- Breakout mirrors and seeing around my arms
- Removing FLSTC bags
- Today i noticed
- Question
- Fender bib for Breakout?
- Detachable side plate vibration
- Another Wheel Bearing Question
- Rubber covered switches for Shotgun Shock
- 2002 FXSTD - So Long Stock Bars
- rider backrest options for a deluxe
- Looking for a new windshield
- Question on Wheel Fitment
- 07 floorboards
- 07 FXSTC Backfires through exhaust, won't start
- Spotlight Mod
- 19" www, what height to fit 2012 deluxe?
- Let's see your grips
- Pinion shaft question...
- Can a softail look like a rigid bobber and still be cool?
- oil Temps
- Troubled Softail
- what is differance in power commander autotuner for heritage and other softails
- Drag Bars on a Slim
- 2004 springer
- Relocating Rear Turn Signals 04 Fat Boy
- Fuel
- Oval Floorboards
- Blackline wider front tire
- New member lookin for some help
- FLS Slim and Right Side Tool Box
- Anyone purchased from these guys?
- Need Deuce help
- Cross Bones front brakes
- Finally Rode Today
- Paint Ideas
- Why did I wait so long?
- my new 12 Heritage
- Engine paint anyone?
- hd light bar #68669-05a
- dip stick leaking oil
- changing 2013 heads for heads without acr
- Chrome lowers for my deluxe. Please help
- How to put the HD digital speedo into setup mode??
- New 2014 black FLS
- white walls for 200mm rear tire impossible to find?
- LSR 2-1 Pro Stock Pipe Question
- Wheel bearings
- Breakout,, help with wiring Accessory power for handlebar mounted player
- power commander v question
- 12" Ness Modular Drag Bars
- Swingarm Bag Mounting Kit
- quick question
- Heritage Classic Exhaust
- Lowered Softails.........how do you like yours and how is the ride overall
- Adjustable highway bars
- my first deluxe!!
- Question about ABS and short brake line
- Which one? Private or Dealer?
- Bagger joining the Softail Community
- Shotguned in Oklahoma City.
- Samson mini cholos 36" on a 2012 Softail Deluxe?
- 19" wide whitewalls
- Buying a Heritage
- 21" Wheel w/sealed Bearings to 16" Wheel w/ non-sealed Bearings
- bigger headlight and turn signal combo for my fxstc???
- Samson Fishtails for 2014 Deluxe
- Hard Bag Latches
- How do I get the pins out of my turn signal connector?
- How to Tell if ECM Calibration has been Done
- Any companies make a bike cover that works with apes?
- screaming eagle 211 cams question
- Russ Wernimont Designs Low-Profile Dash
- solenoid push button end cap for 89' softtail
- suggestions for swingarm bag. Viking?
- My Breakout After A Little More Black
- 2013 FLSTC Handle Bars
- Alarm siren installation on a Breakout?
- Best place to buy for UK Buyer
- Flush Mounted Fuel Gauge and Gas Cap Questions (fitment question)
- Softail lovers - see Jim G's posting under "engine mechanical"
- Powder coating Deuce rear signals - how to take apart?
- Help/Advice 21'' front wheel
- Rocker C passenger options
- Thoughts on Pirelli Night Dragon tires?
- Vance and hines big shots front head shield for softail
- FuelPak Rocks!!!
- Softtail vs. Fat Bob
- What oil do you use?
- rear tire change question
- Harley color shop tanks full if bondo WTF?
- floorboards on an fxst???????
- "No RSP" error code on Engine Diagnostic
- 2000 twin cam, mikuni pilot&main
- fxstc fork tins???
- HD Night Train - Black wrinkle finish.........
- Softail Slim passenger pillion
- Heritage Rear Crash Bars On A Deluxe
- Just checkin in....
- Anyone Ever Heard of These Guys?
- Softail slim fender conversion - 2up problem
- 6 speed
- What's underneath my timer cover?
- auxillary light adjusting
- Brake Pads
- Mammoth Gold Spokes on 08 Anniversary Coppertop
- Mustang Seat Fitment issue
