View Full Version : Softail Models
- 2003 fatboy handle bars
- Heritage Stage 1 Thoughts
- Just checking in with my new scoot..
- Looking to buy 06 Night Train - need advice.
- 99 Fatboy Brake Caliper Concerns?
- Best place to buy spoked wheels
- New guy, need help with fuel issue
- seat fitment
- It's over guys
- EBC brake rotors
- Kickstand Curiosity
- Rocker C compensator change out
- Replace OEM Handlebar Risers for 2010 Cross Bones Springer FLSTSB
- Backrest for Heritage Softail
- Engine Oil usage
- Cost to paint a Fatboy
- Swapping out fender arms on 94 heritage
- I'm thinkn bout Wheels but what fits?
- Engine and drivetrain life expectancy
- Help required to source or make extensions for foot controls on 1996 fatboy
- 18" Rear Wheels
- Primary oil leak! Help!!!!!
- Difference in factory Fatboy wheels before/after 2003
- Saddle bag problems, looking for a solo bag
- what wheel is this?
- Weird Front Turn Signal Issue
- Mystery of transmission fluid
- Let's see your turn/brake/tag/license plate light mods
- Washing leather bags
- turn signal module/control box
- First HD 99 softail or 02 rd king
- Mean City Cycles Seat Mods
- 2016 SOFTAIL Deluxe Switch Module-Sporadic non start..HELP?
- O2 Sensor Adapters
- 2016 HD Deluxe overheating
- 08 Rocker air filter
- Windshield Bag Options
- Toolbox Bracket
- HD Crossbones Bags
- 2001 heritage softail wheel change
- 96 heritage oil light stays on
- Progressive or single rate front springs
- 2003 fatboy
- OEM FXSTS front end technical drawing.
- First oil change on old fatboy
- Clear Film for rear fender
- Solved: Sears Pro Jack fast-drop
- 17 Deluxe...
- Stalling problem
- Pipes for my new Fat boy
- Accutronix risers for springers issues
- check valve
- My 09 Softai
- Best fuel gauge and fuel cap?
- Breakout headlight trouble
- help needed for docking kit install
- DK LED bulbs installed
- smoked lenses for (european) rear amber LED?!
- Lowering the front end of a Blackline
- 2007 Fatboy stalling
- 2017 Heritage - Aircleaner Question
- Another Springer Retrofit Thread
- Stock Deluxe seat is a literal pain in the arse.
- Samson fishtails VH head
- 2005 Fatboy handle bar advise
- Value of new stock pipes
- Starting Problems- 2011 Heritage Softail Classic
- Anniversay Color Shift Paint
- finding a rear brake line!?
- Exhaust Pipe issues
- DNA Monster Apes
- '07 Night Train FXSTB need new front wheel, which years of Wide Glide are compatible?
- fishtail exhaust on a fatboy lo
- 2007 Deuce Rear Fender
- 48 Bars on a Heritage
- If you didnt have a Softail
- Exhaust and air cleaner install
- 2004 fxsti engine/tranny questions
- Tag Mount change up
- 2007 FLSTF Passenger Grab Rail
- Looking for V&H 2 into 2 black exhaust for 2016 Breakout CVO
- Any market for a 96ci motor
- Cylinder Swap - Mechanic Input Please
- Hardbags, Grasshopper, Amer Custom pipes mounted
- Need advice on a new Seat for Softail Deluxe
- Loose Battery Leads - Why?
- 2008 FLSTC Anniversary Edition Backrest
- Security fob
- Leak from houseing of oil plug 2008 Deluxe softtail
- 2008 Softtail Deluxe transmission fluid leak
- Breakout rear tail light 1157 or 1156?
- Could you please recommend a seat?
- 06 heritage acc voltage good, Ign bad won't start
- Should have bought engine guards
- I have a dilemma: Stage 1 my Slim or not?
- At a crossroad with Cam Chain Tensioners
- Wax and Chrome
- 2005 FXSTS Floorboard Conversion...what do I need to know?
- Shifting CVO Springer
- Throw over saddle bags suggestions
- Fatboy got some mods over the weekend!
- Nano Technology Oil Additives
- Want to upgrade wheels on 2003 fatboy
- ID this softail dash
- Nephews 04 fat boy got hit and run?? Body fitment?
- 2007 Deluxe Dead
- Lock Tabs? Nutz!
- How do i install strobe lights?
- remove wires from connector
- 1998 Heritage Softail Classic wheel
- Why my brakeout pulling to one side While im riding
- 1999 Nightrain rear end specs
- 97 Heritage starting issue
- Springer with slight wobble on deceleration
- 2001 softail standard fxst engine oil check
- Arnott suspension systems
- Rear Wheel Size for my 2009 FLSTC
- fairing for softtail deluxe
- softail deuce 2005 is making a sound like popcorn popping.
- 07 FXSTB High Idle
- made of changes
- Drop the shocks, (Softail/Night Train)
- Thoughts on highspeed wobble?
- S&S cam for a 2006 softail
- Softail???
- Girl from Kentucky needs help
- Melted battery post
- Installing LED Brake light
- 07 fxstc and fairing questions (burly)
- 93 FXSTS Speedometer Odometer Knob
- Need a remedy
- exhaust question
- how to install wind deflectors on an 06 heritage
- Just installed TTIs on my Fatboy
- 2005 Harley Davidson softail deluxe
- Do you regret lowering your bike
- FXST billet brake lever wanted
- Breakout race tech front end
- Cleaning bullet holes on Fatboy wheels
- free parts from dealer!!
- 200mm Stretched Fender
- Pressing horn blows fuses
- 27 Tooth Engine Sprocket (00 Heritage)
- new from new york
- Short Rear Fender
- '05 Deluxe-check trans oil on jiffy stand or straight up?
- Welcome me back to the team
- Hi glad to join
- Colors...can't decide on a new Heritage!!
- My 2000 fxst dies while driving.
- Softail Slim with 200mm crossbones wheel/tire
- Road King Classic bags on '07 deluxe
- Oil Cap Milky Like Substances
- Softail Not So Soft. Help!
- Memphis Shades Lowers
- 16" apes on slim S clutch and brake line
- Putting a Fatboy front end on a Night Train?
- thoughts on my new heritage
- Fatboy BSS or BR 2 in 1?
- Different spark plugs after FuelMoto tuner and a/c upgrade?
- Vance and Hines from 95 custom fit 01 FLSTF?
- Vibration or buzz
- Oil level check
- Wheel options
- Softail Slim S - Clutch
- No more "mods"!
- What Brand Seat is This?
- New wheels for the bike
- 2006 Softail Night Train fxstbi ?????
- 2006 Softail Standard seat opinions
- Shotgun shock revisited??
- My fxstc
- Softail slim handlebars?
- Black Bike Wheels
- Dealership left dipstick loose on a 2007 elcetric glyde H-D
- "Wiggle" under acceleration
- What year did HDStart the B engine on softails?
- EFI swap to carb and ignition process..
- Fuel level sender wiring
- Transplanting newer organs?
- 2015 48-running lights/blinker problem
- Bolt in the middle of the inner primary cover
- 2003 Anniversary Fatboy
- Night train. 2005
- Over sized self threading gearbox plug?
- Brand New Bike - Dead Battery
- 1992 FLSTC - left turn signal is frozen on
- Another discussion on stripped gearbox plug?
- cross bones project
- Am I just dumb or do I have a problem
- Installed Cobra 3" Slash Cut Slip-ons on my Slim and...
- Side mount tool box.
- Carb change?
- Added slip ons, now i have problems..
- 06 fxsti bagger kit
- '15 Heritage tank bib with pouch?
- do i
- Dead 1985 softail
- bench testing solenoid
- Bike pulls to right
- aluminum handlebars
- lower mounting point hardware for detach kit
- O2 sensors
- New member from CLE!
- 2010 fatboy lo, abs light on after bleeding front brake
- 2002 Softail Deuce rear wheel bearings
- 93 FXSTS New Ignition Wiring Question
- Bar/Riser Combo opinions wanted
- Holy sh!t
- New apes
- Hello new member from the Bay in Michigan
- need help with handlebar
- Leather LID Inserts for Heritage Bags
- need more leg room on my 02 fatboy
- New lookin for help
- mike
- Where to find EFI custom tanks for Softail
- Hard bags on your Fat Boy Lo/Fat boy
- Oil suggestions
- looking for help
- Odometer reset Knob 1993 HD FXSTS
- V&H Longshots For Heritage Deluxe
- 2016 Slim-s Denim green tank graphics
- Wishing a safe riding season to everyone
- Front Tire Size Comparison
- 93 Softail FXSTS Ignition Console Removal Question
- Roland Sands vintage tank with EFI & backbone cover kit
- Tire issue, need some advice
- Trading my Harley
- Traditional Floor Pans On a Slim?
- Check Engine Light
- Maxi fuse on 03 Road King
- Complete B swap?
- why does my bike start slipping at 70Mph
- '15 FLSTC Auxiliary lamp bracket
- Stock Heads S&S CNC Service (Non SuperSport)
- fork oil 2012 fatboy lo
- Fatboy wont start
- 2013 hard candy green deluxe tins.
- Gangster rear fender
- Finished the 95" yesterday
- "Rocker" rear supension - does it work ?
- 18" rear wheel for Backline
- saddlebags for fatboy without turnsignal relocation.
- 1993 softail springer ignition wiring NEED HELP!!
- Kuryakyn Curved License plate relocation (9255) on Heritage?
- TC 96B upshifting?
- Whining noise on new Fatboy.
- 1st Night Train Fluid change and I have a question
