View Full Version : Softail Models
- Bolt size?
- 2004 fat Boy EFI Motor swap questions
- want to ditch the BCM
- Hogworkz bag fillers?
- ISO bottom end for 103B motor
- Duece riser bushing kit
- FLSTC Running light issue....should have bought a Honda...
- Need advice
- A real head scratcher on a 2007 Fatboy
- 2017 Heritage Engine Vibration
- 2013 FLS won't turn on any electric (run & accessories)
- What rpm for city riding 107 m8?
- 2011 Fatboy shutting down, then comes back to life
- will a Crossbone's seat fit a Deuce?
- Steering dampener for 2003 Heritage softail
- More Open Intake; More Sound?
- Two plugs under seat - INFO PLS!
- LO RNG code
- How would you reply? Why the hell would you put a Spring Saddle on a Softail, how much cushion do you need?
- 2002 Softail Standard 240 seat
- Quieter Baffles need retune?
- Laf pipes on 2013 breakout
- spacer
- Best suspension upgrade for Softail Deluxe?
- Heritage Springer Handlebar PICS Pleases
- 2007 deluxe tank and fender on 2008 heritage
- I building new custom exhaust tube and i need help
- 2010 fatboy lo
- 21" tire on Fatboy
- Fork Fluid
- tc88 compensator problems?
- 2016 Fatboy special
- Awesome deal on swingarm leather bag
- Tube or tubeless
- Accessory Bags for 2018 and Newer Heritage
- 05 night train efi map sensor circuit
- 2007 Deluxe rear fender
- Thunder bike air suspension
- 2004 fat Boy EFI SE upgrade help
- '16 Fatboy won't start
- Front tire not centered with fender
- 06 Duece handlebar help
- 2016 Softail Slim Rear Axle Torque/ Rear Plate Mount
- 91 Fatboy with aftermarket springers questions
- 2013 top end rebuild, efi issues
- ‘03 Heritage Softail tombstone taillight and Bullet turn signal swap?
- Loss of power after long idle in traffic.
- 98 fatboy
- Fatboy Wheels/Rims
- breakout thread closed? i got tire pics in here
- Sputtering followed by bad vibration
- stage 1 exaust
- Chrome handlebar controls, Where to get them?
- I Guess I'm going to have to change forums
- 2003 Heritage softail wobble on corners. HELP
- Riding two up.
- Tour Pak top box variants - What's the difference?
- 2002 FLSTFi Fatboy
- Early CVO breakout riser set alternatives
- Twin cam chain tensioner pad- good or bad!?
- Whistle in exhaust?
- Blackline Handlebars
- Fatboy front end difference
- 2016 softail slim "s"AAT sensor locaation
- Viking hardbags
- 2013 Deluxe sputtering
- Softail shock compatibility/part number
- 03 Fatboy Gas tank question
- Handlebar Clamp
- Best solo seat for 200mm rear wheel softails?
- 06 softail running rough, dies maybe due to engine change..
- CCW air ride
- My first Harley after 40 years of riding
- Is my Softail rear suspension adjustable?
- Smoking
- Noise/Thump
- Weird gouging on back of drive belt
- Road Glide Fairing on Softail.
- My husband has mislaid his spare fob
- softail side mount license plate with sadllebags? Pics?
- Issues after Stage 2 Upgrade
- 2012 Softail Deluxe
- 2003 FXSTD-SE Deuce will not start
- 16 Heritage Neutral Problem
- my big fat beach bars suck!!!!
- Are the Crossbones FORK ROCKERS interchangable with other springer models
- Front wheel spacer question fb -99
- Odometer verification
- New Harley owner HELP! Will not crank
- Here we go again
- clutch cable replacement..how long are the trans cover bolts?
- Belt rubbing front wheel well
- bouncing tac
- Question regarding Screamin' Eagle kits
- Rocker C with 255 cams?
- Need some inspiration. Need pics of custom fatboys
- 30T compenator eliminator
- i bought some big fat beach bars!!
- Brake light wire color 04 Duece.
- Almost here
- swapping ignition switch on 1999 fat boy
- 2007 FXST rear lights
- Reset alarm
- 2015 FLS cruise control
- Bought Not Built 2007 Harley Night Train
- Looking to upgrade my front rim
- Weave on highway
- Is this normal?????
- question
- 2016 Softail Slim not starting
- Saddle (seat) for Fat Bob FXFBS
- whats the widest beach bars out there for a springer?
- Knocking
- Where to purchased your Harley Davidson parts
- Reach Handlebars for 2022 Softail Standard
- Fishtails on a stage 4
- wide swingarm
- Rocker C 2008
- Vicla springer build
- looking for a seat for my 2005 FLSTS
- Fuelpak 4
- Mikuni carb 03 fatboy
- Dragging foot boards
- Clutch will not engage! Please help!
- 1990 FLH Front end to a FXSTC help
- Lowering Softail questions
- Magnum Ape Hanger kit
- softail heritage question
- Tune for Slip On?
- Crossbones Fender Mod
- Alarm & changing battery
- FXSB 20215 Battery replacement
- Annoying noise.
- Opinion on front wheel size
- Softail Deluxe Clutch Cable Adjustment
- Thinking '11 Fat Boy After all Baggers Past
- Sweet Gift
- Speedometer face replacement
- Cam Plate Identification
- 1995 FLSTN - Loud tapping noise from right hand side
- Retro Fitting F/I
- 10" Todd's cycle strip bars
- Anyone have the SE Street Cannons?
- '16 + Cruise Control Switch
- Fat boy questions
- Primary drive cover bolt lengths, please?
- Please Help! I need to convert stock speedo to a Mini
- Night Train Bag mounts
- Heritage Softail tank plate cap nut won’t come off
- Slip ons
- FLSTC rear shock bolts breaking
- West Coast Style Heritage ?
- Deuce ,Vance and Hines big radius,wide band 02
- Hogworkz bag kit
- Tune up questions
- Windshield for 2006 Fatboy
- First post…
- People checking out the ride
- 2004 heritage classic
- Installing Mini Apes
- New wheel bearings?
- Route 66
- Finished the winter projects
- New to HD, Pulsating Noise At Speed
- Winter projects completed - first ride report
- Rocker lighting issue
- CV carb issues! Help Please!
- 2014 softail slim. License relocation kits
- Confusion on bars/risers
- Difference in 18+ seats
- 2002 Heritage tins compatibility
- Softail Deluxe ABS question
- 200mm tire on an older Fat Boy?
- Softtail Slim Engine Guard
- 48306-88 Harley-Davidson steering adjustment tool
- 2008 Rocker C Fxcwc P0661 error code
- Thanks Everyone!! 2007 Heritage Softail Classic
- Touring on a softail . Who’s done it
- Trouble code 1651?
- 2005 FXSTS sissy bar question
- 05 softail headlight swap
- 2013 blackline
- Sarge Fatboy
- My Breakout journey
- 07 Fatboy seat upgrade
- Progressive 422 shocks
- Value opinion
- Here we go again
- At wits end!!!
- 2014 FLSTNSE CVO taillight
- Removing 3" Ness Forward Control Extensions and Keeping Longer Brake Line
- Breakout Pro Street (FXSE) Tires
- Oberon Levers for Clutch and Brake?!?!
- Anyone running Burleigh Bars?
- Gas tank swap and fuel pump diferences
- M8 to 96?
- Fatboy basic question
- 2002 Softtail (EFI) starter switch failure. When it starts, dies within 12 seconds no matter what I try
- 05 Fat boy 88B motor
- 2017 Softail Deluxe oil cap blowing off
- Trouble Code Help
- Low Rider S Risers List
- Recommended air pressure for a Breakout
- Windshield Options For Fatboy S With Nacelle
- Couple questions-2010 Softail Deluxe
- floorboards
- 1992 fat boy petcock issue
- 05 Softail cam tensioner
- 2007 Harley Davidson Softail Heritage Classic Missing and running like garbage
- I need a taller seat
- Fishtail True Duals for Fat Boy Lo
- Stretched Custom Rear Fenders 07 Fatboy
- 14 Heritage breather question
- Adjustable brake/ clutch levers.
- 95 Heritage leaking fuel when petcock left on
- LED turn signals
- ape hangers
- Closeup of Headlight Housing for models with fork cover tins
- Seat Fitment
- Cleaning minor rust from storage in gas tank
- gas gauge
- ABS light flashing for no reason
- Springer 2006 - original parts? help me ID please
- Rear Wheel Question
- 2007 Heritage Softail Classic Intake
- Softail Rear Wheel Questions
- New Bikers Choice round Fuel Petcock
- New Seat for my 1st Sturgis trip
- Breakout cvo riser
- Looking for Shorty 1-Inch Risers (do they exist)?
- 02 Fatboy front fender mount bolts
- Oil changes.
- Fatboy risers
- First Post, First Harley
- Sort of a strange question
- 2014 Breakout does m8 2018+ rims fit
- King & Queen Seat - 2005 FXST Softail Standard
- Fuel system question
- Crank Case Breather Question
- Rich Flathead carb
- Fueling 525 cams.
- Speedometer gauge size
- 04 Springer Softail front fender- need help!
- Strange sound on start
- Ape Question
- Softail Slim Thrashin Supply Bags
- 2008 Heritage Compensator
- 2006 front wheel torque values
