View Full Version : Panhead
- Starting Tips
- What year are these frame's???
- Shinko = Stinko?
- Panhead Build Started by Accident
- My new 54 Panhead chopper
- Looky what I found!
- Where to start with my dad's '65 Electraglide?
- My Panhead Build
- My 61 Police build
- 1957 Panhead Thoughts
- Stem nut thread pitch different by year?
- A History Buff's 1955 Panhead Chopper
- Hey you pan experts.
- 1948 Harley-Davidson Panhead For Only Ten Dollars
- Pandhead Big Bore Cylinders?
- Cool Teacher is a Panhead Chopper Rider
- 1960 Duo Glide
- Help with finding replacement Regulator
- 1956 Panhead Gets Thunderous German Makeover
- 1965 rear turn signal mount question
- Custom Panhead is Ready for Show or Go
- Captain America Auction
- Formal Dress for this S&S Panhead
- Resource List for Parts, Repairs, Services, Tech Info
- Attention classic fans
- 59 flh
- My First Pan head !!!
- 1959 Sidecar-Equipped Duo-Glide Has Room For One More
- Weber DCOE 40
- Pan/Shovel Whats it worth?
- 62 panhead electronic ignition and coil wiring
- Only a Pan can be a Pan Shovel
- Pan Shovel rebuild 3
- current fluids for panhead
- The Boogie-Woogie FLH That Elvis Did Not Get
- Brake Light Switch.
- Oem 1965flh auto advance
- torque spec for damper rod
- Gorgeous Garage-Built 1962 FL Panhead
- Kicker issue
- Matching Cases 1950 Panhead Gets New Lease on Life
- 52 Case Repairs
- 1956 FLH Panhead
- Generator model 61
- good machine shop in MA
- Garage find, on fence to purchase
- fuel tank sealer/rust cleaner
- Closer Look: Media Choice Award Winning 1963 Panhead
- 48 fl
- Jockey Shift 4 Speed
- Lost Compression
- Identify / Valuation of this bike?
- Meticulous as a Swiss Watch: 1948 Panhead Bobber Build
- 54 FLE blown head gasket?
- Is this head slavageable?
- Friend has an issue with his pan head. Needs help
- Palmer 3rd Edition
- 1958 FLH Duo-Glide is Simple and Easy
- 1948 EL basket case resto
- 1949 el
- Mint Panhead, 1965, Fresh Restoration
- Value of Pan head 1949?
- 96" Clone Pan Done ...
- Rear Wheel Lifts
- 1950s Sting with the Tennessee Highway Patrol Yellow Jackets
- Adjusting the Mousetrap
- John Parham's Dream 1955 FL Hydra-Glide
- 65 Electraglide
- 64 Duo Glide
- Barn Find Kinda
- Frame identification
- Father and Son Build 1949 Panhead Land Speed Racer
- Ewan McGregor Parts Ways with Indian Larry Panhead
- Before Captain America, There Was the Dragon
- Seacoast Choppers Creates Wicked Panhead Bobber
- One Clean and Raw Stainless Steel Panhead
- Control lamp 65 eglide
- 55 Panhead
- Fork Oil - What are you using?
- 65 FLH Build Thread
- late oil pump on panhead
- Tattoo
- 1965 Panhead 5 Gallon Tanks
- 1960 panhead ran dry on oil
- Re: my 65FLH
- Starting Issue
- 62 panhead VIN question
- Search is over
- Does anyone know idles speed of 1960's panhead?
- Worlds worst question
- 58 FL exhaust question
- Brendan Mier's 1949 FL Panhead
- 58 Duo Glide
- lead additive ?
- 1948 EL Pan/Shovel
- My new 62 Duo Glide
- Euro-Trashed 1948 EL Panhead Gets Bobbed
- 1948 PanHead Throttle Issue
- 4 speed kicker wont kick!
- 49 charging.
- 49 Speedo
- 1958 Panhead
- Clutch Tool
- 1964 FLH Duo-Glide: Once the Undisputed King of the Road
- Bolt Finishes
- Bolt Finishes
- Jamesville Motorcycle's 1964 Panhead Custom is a Tasty Danish
- 49 Panhead Major Oil Leak
- Parts diagrams for 1948 FL
- Need some advice on a vintage Panhead
- Old Panhead Tank Emblem?
- 1957 FL Pics
- Fair price for 58 pan police bike from Mexico
- Siksika: 1956 Panhead Trophy Winner
- Fair price for 1950 Panhead chopper.?
- 70 years of panheads
- “65” flh
- would not want to change a rear tire on it
- 1965 FLH throttle cable removal
- Panhead oil?
- 49 Panhead Battery
- panhead model
- 65 pan/shovel
- Value hit for not being stock? Chopper value?
- New Member Lake Elsinore CA
- Enjoying my Pan
- 48FL will springer stock mech. brake parts fit into drum that now has the newer aluminium brake plate?
- First pan (1960 flh hydro glide)
- 65 Pan misfiring when headlight is on
- 1978 FXE Exhaust and Muffler
- Anyone Have a Guess at what a 1964 Harley Swing- Arm Frame would be worth
- fork tube length for 66 flh, and 49 fl
- Japanese Shop Takes Minimalist Approach to Panhead
- '50 Panhead gearing guidance please
- Panhead head question....
- Questions regarding Rivera Pro Clutch on a 48 Panhead 4-speed
- Pan compensator question
- 55 project
- Duo-Glide Tach Bracket
- my dad is thinking about selling his panhead
- '54 Pan
- 58 Pan at auction-was the highest bidder!
- Selling a Panhead
- New to me....
- Panhead question
- From Arizona to West Oz
- Paint scheme on 62 Duo-Glide
- Shovelhead 3 1/2 Cylinders
- Panhead Oil everywhere
- Seat search for 54 rigid frame
- Panhead 49, oil pump check valve spring
- Oil Pump Lines
- What is this 52 Pan worth?
- Upgrade from 6 to 12
- Bent Fork Tube
- removal & replace distributor
- Finally found one I like...
- My 1960 pan & 1959 sidecar
- My 61 pan is looks good
- Ignition coil wiring
- 56 gets maintenance
- Restoration Project
- My first Harley
- 57 flh
- Axle differences question
- New member From New England
- Spark Advance Tab
- 65 pan elec. first year elec. start problem
- Pan Head
- 1963 panhead
- 63 Pan rebuild
- 65 pan,oil pumping out road draft port
- Dad's '51 Panhead - Clutch
- Dad's '51 Panhead
- stock internal cable bars to S&S
- Panhead VIN Number with stars on each end
- Getting Scarce
- Panhead valves
- 54-55 FL Spring Specials
- S&S P series engines?
- Triple Tree Question
- 48 Wide glide
- 65 pan question
- Belt drive problem
- Buying a panhead
- Voltage regulator woes
- OEM vs. Repro frames and other hard parts
- Heavily leaking pushrod...
- Oil pouring from Crankcase breather
- std panhead push rod question broke
- Backfire through carb
- Sweet mystery Panhead
- 48 Panhead
- stupid question probably but need help
- does anyone know about std panheads
- PanShovel Oil Light when hot
- BitsaPan Update
- Duo Glide
- Panhead manual
- Solid State Regulator
- HELP 64 duoglide
- trading evo for a pan
- Panhead mechanical brake linkage
- Transmission Sprocket
- New Panhead Advice Needed
- Heres a 55 Panhead Raffle for the guys near Texas
- Timer advance
- New 50's-ish Bitsa Panhead to me...
- accel 2.3 ohm coil w mallory ign
- thanx all
- Linkert main jet
- Pinkerton main jet
- Are there any vintage HD mechanics in the massachusetts area?
- nother engine question!
- 56 pan
- 12v 64 killing battery
- head gaskets vs. compression ratio
- electronic ign. ?'s
- 64 FLH 12v conversion
- stroker plates for pan / shovel
- std panhead problem plz help
- new 6 volt battery not charging completely
- excessive oil level in cases
- Help Identify - Chopper - Panhead?
- 55 panhead bought it from my pop
- My Latest Rebuild
- 64 duo hot start
- 6 volt battery & bulbs?
- Oil filter help
- Anybody here? I need help.
- J.C. Liang
- Speedometer authentication?
- Misses and pops in carb while riding
- pain to start if its been sitting a few days
- oil discharge mystery
- Replace sprockets?
- Internal Throttle mechanism
- bearing support for 58 pan?
- Help with motor ID?
- Where to buy wheel cylinder
- Trying to reg a 1950 fl and not a 0000 spcns!!!
- Tank Sludge
- 12 Volt battery for 62 pan conversion
- ok now what?
- got a question
- Getting Close been 3 months
- pan/knuckle hotrods
- 62 Panhead
