PDA
View Full Version : Panhead
Pages : 1 2 [3] 4
  1. Panhead
  2. 62 Pan
  3. Panhead rear brake, hydraulic
  4. my '51 fl Australia
  5. new baby
  6. dyna 2000i
  7. first pan, needing abit of help.
  8. 49EL intake repair
  9. new old girl/ my hot rod
  10. Does anyone have a parts manual for a 65 Pan?
  11. 65 inner primary bearing removal
  12. D ring width
  13. new rear chain-unable to adjust-something very wrong!
  14. 64 panhead oil problems
  15. 65 inner primary bolts
  16. Need a mustang style seat made in white for FL
  17. Panhead hard to kick
  18. quick VIN question
  19. Primary oil breather questions.
  20. Carl's Cycle Supply Fuel Valve Install
  21. 1961-1964 Panhead 12 Volt Coil Upgrade
  22. primary
  23. 64 Panhead oil problem
  24. Pictures of your OLD Panhead
  25. Looking for Aluminum rocker covers for a '57 panhead
  26. Hunt mag
  27. Selling A Pan
  28. Choice to get old pan or flat head, whats a better bet?
  29. How much does my Panhead weigh?
  30. 1950 Panhead
  31. looking
  32. Hunting
  33. Best Carburetor for Panhead
  34. Panhead electronic ignition
  35. 51 Panhead
  36. 1948
  37. Brake Master Cylinder, 59 Pan.
  38. Gas tank
  39. 1965 Panhead project
  40. frame id
  41. 63 flh
  42. Nothing but trouble!
  43. '50 Pan rear disc brake
  44. 1951 electrical question
  45. 1966 Panhead clutch removal and disassembly
  46. Question about Panhead Cylinders
  47. Munched valve
  48. 64 panhead blowing oil
  49. 1ST Place Vitage and 2ND Place Overall
  50. Need some help!!!
  51. 1951 pan head horn
  52. new here. i have some questions about my dads 1950 rigid panhead
  53. 55 Panhead on EBay
  54. 1965 Pan speedo question
  55. converting Shovelpan back to a pan
  56. 62 Pan
  57. More Panheads pleeease
  58. Mallory Distributor
  59. 59 blowing condesors
  60. 1948 FL Pan
  61. 1962 Speedo ratio?
  62. linkert carb leaking gas
  63. 53 pan clutch hub nut
  64. is it HYDRA GLIDE OR DUO GLIDE
  65. 50 Generator Shovel
  66. Another Panhead starting question.
  67. Any suggestions for brake pedal?
  68. 51 pan starting
  69. '64 Panhead FL
  70. Pan for sale
  71. 1962 FLH pan
  72. Need a Wiring diagram Panhead
  73. shovelhead flywheel
  74. Stroker Panhead new cylinders question
  75. Pan head pipes
  76. ignition upgrade on panhead
  77. What Year is my Pops bike
  78. Old Pan
  79. Build a 74 panhead chopper
  80. Does this '65 motor/tranny look stock?
  81. Frame ID and what's this?
  82. '65 FL - Stripped inner primary threads
  83. Classic panhead ok for novice rider?
  84. Air cleaner for S&S E on a '51
  85. A little Vin help!
  86. Gasket Sealer for New Pipes
  87. Rear mechanical break on 56
  88. A little advice, looking at stock '61 Pan
  89. Starting my Pan
  90. 52 pan
  91. Oil Stains
  92. 1957 Help (and Story)
  93. Panhead clutch misery
  94. Pans running great!
  95. 53 pan shifter
  96. 1951 FL questions
  97. Frame Info
  98. Help identify cases pls?
  99. 3 brush 6v
  100. Can anyone stop these bikes
  101. Electrical
  102. chain
  103. Definitive Panhead ID
  104. 58 Pan tank shift inner primary
  105. Saddlebag bracket
  106. Dumping Oil
  107. Hand shift conversion
  108. Tires
  109. Rear Axle Issue
  110. Starting issue
  111. Grinding noise
  112. 64 Panhead in baskets
  113. 6-Volt headlight on '57 Pan.
  114. pan head got no spark..any help?
  115. Neck bearings
  116. 59-66 front hub, can I update the wheel bearings?
  117. Rear wheel sprocket - which one?
  118. 50 Panhead
  119. Can’t make it up the driveway – high speed mixture tricks or other thoughts?
  120. The Correct Cam for No-Ping Operation?
  121. Linkert M-74 B Question
  122. unsure
  123. 1948 Panhead original wow!
  124. New guy from Iowa
  125. Side Rails for a '63 FLHF Super Sport Pan
  126. Help! My pans smoking
  127. Early Pans
  128. Install of LED run/brake/turn signal tail light
  129. help I.D. this frame
  130. Best Carb?
  131. External oil filter
  132. question on pan head
  133. 1948 Generator electrics
  134. oil pressure drop
  135. ironhead guy looking at a pan
  136. 1958 FL Panhead Duo Glide
  137. Looking for a Panhead to restore
  138. my first panhead
  139. Need a little help 1954 KH (unknown Part)
  140. 53 Pan no oil to top end
  141. high speed backfire
  142. Tattoo
  143. softail frame
  144. Potential Purchase
  145. Wiring a 12 volt coil
  146. Panhead Clutch Whining
  147. cluch sliping on 1963 pan
  148. broken bolt
  149. Slipping clutch
  150. Spark Plugs
  151. Odd picture request
  152. Looking to buy a Pan----?? Newbie
  153. Original pictures
  154. 63 Pan Wiring Schematic
  155. license plate
  156. Wiring schematic
  157. Looking for Pictures ?
  158. 58 Pan wiring diagram needed
  159. Oil/Oil Filter
  160. Replacement Headlamp
  161. sifton 468 s cam
  162. In need of a front fender 1961 duo glide
  163. Primary Chain over oiling
  164. 1956 panhead
  165. blowing white smoke
  166. 1964 Engine leaking oil at engine sprocket
  167. Idles Great, Backfires Under Throttle
  168. 1948 Panhead Kit
  169. Color Schemes
  170. Where to find a barn fresh panhead
  171. Crush washer
  172. Repair guides
  173. Adjusting 50fl Solid Pushrods
  174. cheap sell **** dunk,**** shox,**** air max,******1-23cheap
  175. Need help finding folding license plate bracket
  176. Screamin Eagle ignition coil compatibility
  177. oil leak at vent
  178. 1950 HD 3000 mi all original. What's it worth?
  179. oil pressure problems
  180. Rear Brake light switch mount?
  181. Valve Problem?
  182. tranny
  183. Where to buy Pan"heads"?????
  184. How to measure for front end
  185. panhead gen help!!
  186. Wanted '61 Duo Handle bars
  187. 1960 Stock pan S&S Main jet
  188. pan pushrods
  189. Neutral switch 1965
  190. 1955 pan head
  191. Wishbone frame
  192. Side case
  193. Pans forever
  194. Jockey shift
  195. Coker tires
  196. 1951 police special
  197. Early 50's lower legs ?
  198. advice-ironhead guy buying a panhead
  199. Old Panhead Wallpaper Question
  200. S&S Panhead 93" Anyone got one?
  201. stock carb or other
  202. Rust in gas tank
  203. restoring '63-'69 pan saddlebags
  204. pan sprocket shaft
  205. Changing Oil
  206. Oil pumps, new vs old
  207. Just got this project
  208. Pogo Seat Question
  209. 49 panhead vin#
  210. 1960 vin
  211. 49 pan ?
  212. 55 Panhead
  213. My Duo
  214. vin numbers
  215. timing problems
  216. saddlebag Locks 63-69
  217. gas tank problems
  218. 48 panhead
  219. 1963 Panhead Camshaft
  220. This bike just changed my world!
  221. Panhead distributor
  222. Value of 58 Duo Glide
  223. 1964 Period Chopper,kewl
  224. Synthetic oil
  225. Excessive chain oiling
  226. Help with timer & oil pump
  227. 64 pan vin
  228. Generator or Regulator?
  229. pan questions
  230. NO Pics
  231. 52 Pahead in 70s chopper trim FS
  232. Pan cylinder, need info
  233. 61 FL help
  234. Ballpark figure?
  235. 53 pan assembly
  236. need help wiring
  237. Valve cover removal
  238. 50 Panhead & 77 FLH
  239. 49-53 Type 2 Handlebar Pull Spiral
  240. what year is this trann???
  241. 53 oem uncut rigid frame.
  242. 1949 paint code needed
  243. 1960 12volt conversion
  244. S&S pan kick starting problem
  245. Electric Frank wiring
  246. blown head gasket
  247. head gasket leak
  248. Idea on value of a '57 pan?
  249. Do any of you still ride your Pans regularly?
  250. crasha51pan
