View Full Version : Softail Models
- 2011 Fatboy Lo Turn Signal Switches
- Fatboy 88 knocking low rpm
- Joined the Softail family
- Stripped Steering Stem Nut, won't come off...
- no 5th gear? 1995 Softail custom
- Rear wheel removal and installation Fatboy Lo
- Headlight and Passing Lamp Trim Ring ???
- Which pullback risers fit with 02' fatboy stock wires and cables?
- Fuel Moto LED Headlight Install
- 2016 Softail Slim S / Magnaflow LEGACY GEN-X Exhaust
- Pain to my tail bone during long ride (More than 1 hour)
- Need help solving problem
- Grinding Noise
- Shifter/clutch/transmission problem - 16 Breakout
- Fatboy 06 leak from Peacock vaccum Plate
- Where did you ride your Softail today?
- 21 from fx to FL fork, .250 offset
- How do I read codes on Softail ?
- Think I know the answer already
- Chrome inner primary
- Electrical issue fatboy Lo
- speedo cup hit blackline console!?!?!?!
- how do you calculate cable length for new bars?
- Heritage front brake fail!
- Do I really need to replace screws?
- Transmission Swap
- Shinko 777 tires
- 160 Tire Softail Slim S
- Need FXSB Derby Cover suggestions
- Springer seats
- Stripped Breakout little help needed
- Where can I get those Turn Signals in the USA
- New soft tail deluxe
- 2011 Heritage Classic
- My 2016 Breakout Before and After
- gonna make the switch to floor boards on BO
- Lo's First Shoot.
- Shovelhead in a softail frame.
- Is it possible to do an OEM HD Stage 1
- Boom Audio stage II on softail ? anyone has one ?
- other ppls outrageous claims are credible to me
- Dark blue denim?
- 05 night train larger rim/tire question
- Finally Got My Lo
- New 2016 Heritage Softail Classic = Result of Indian Chief?
- Getting There...
- 2016 softail electrical question (turn signal relocate)
- Fatboy Wheel ?
- 2016 Heritage Softail classic
- 06 night train HD LED mirrors
- Shift indicator problem
- 05 N.T. Front wheel wobble
- What is it and where can I buy it ?
- custom rear fender with stock struts?
- Need to move foot controls on Breakout
- rear fenders the same?
- Windshield, yea or nay
- rear whitewall tire size options? 18"? 17"?
- Brake pad recommendations
- 2006 Harley Davidson street glide wheels
- Running older style 16" spoke wheels with new 25mm axels???
- Changing tranny fluid w/ SotgunShock question!!!
- Vibration at 3200 rpm
- Breakout question
- Problems Installing HD King-Size Detachable Windshield #57688-10 on 2016 FLSS
- Rear stoplight swith
- Garmin car cable hack
- 2006 Heritage stuttering
- detachable sissybar sideplates for slim
- Danny Green seat for Breakout
- 2002 Fatboy shut down while riding
- New member
- 2004 Heritage Classic
- Slima and a Mustang Tripper?
- Clear Transmission Fluid
- Bad voltage reg.
- MPG question
- Winter Mods/Spring Cleaning Done!
- Retune needed?!
- 16 Heritage seats
- Slim backrest question?
- Used Breakout motor concerns
- Softail Slim.....here is some 150 rear tire info
- 2016 Softail Slim S cable extensions???
- Garage door mod on 07 deuce
- Looks like AWESOME weather for Laconia!
- Gas Tank Reserve Question
- Bike not starting when hot
- Nash Gimp Hangers
- Low Profile dash and aftermarket speedo
- 02 night train wheels
- Boarzilla Exhaust
- Lifter stuck in bore
- Front brake issue
- Low Range light, full tank of gas....
- '06 Night Train Brake Master Cylinder Part #?
- Todds 14' Strip bars 1.5 I.D. risers/ clamps?
- Fuelpak not compatable with tts master tune
- Picked up a second bike today
- Breakout as second bike???
- Can someone with a Breakout look at their rear ABS Sensor
- 1991 heritage seat options
- Adding Classic Horn to CrossBones
- Early Style handlebar on Fatboy Lo 2016 ?
- Did I Mess Up? Moved Bike and Now Out of Time
- Rocker with drjekillandhyde exhausts?
- Arnott SoftailŽ Height Adjustable Fox Air Suspension System
- Mini tach for Evo softail
- breakout hauling ability?
- total loss?
- New to me '08 Softail Custom
- Help identify rear fender.. please
- Thoughts on the red brake calipers?
- V&H Big Radius 2-1 baffle removal
- Blackline owner needs help
- 18" whitewall
- motherwell luggage rack & mustang seat
- SE 204 swap 2013 blackline
- Screeching when hot
- Elictricle Problems
- Bikes in the shop.....stalling issue
- Waiting...Patience...grrr..Softail Slim
- mustache bar with highway pegs?
- electrical panel on 03 duece.
- Electrical problem, charging related
- Dyna to a softy
- Weird Electrical Issue
- charging question?
- Removing Tank Badges
- oh chit
- 05' standard fender options for 16" front wheel
- Remove Fishtails from Samson True duals
- error codes
- HD Garage Door Transmitter Wiring
- Softtail at altitude?
- A few thoughts on break-in of my 2015 Fat Boy
- 2-up seat for long trips.
- Should i lower my bike?
- changing front wheel on a deuce
- michael ogle...error codes
- New to me Heritage
- re-map on Slim S?
- 2012 Fatboy Lo Yellow Engine light came on
- Softail Slim Ground Clearance
- Deuce undesirable?
- Fat Boy Lo Seat
- Bottom caliper bolt keeps spinning
- Is this seat fixable
- Your thoughts on the Sundowner
- Fatboy Lo windshield on an Evo Fatboy?
- exhaust header nuts keep coming loose?!?!
- Breakout license plate bracket
- Electrical Gremlins Fat Boy S
- Spark plugs look alright?
- Lowering my 07 Heritage
- Arlen Ness retro Floorboards
- First mods to the new 2016 FLSS
- Need Help on Clutch Adjustment
- how to remove catalytic converters
- Muffler clamp size?
- Rear wheel
- Nighttrain RSD Rear Fender
- Low idle/stall HELP!
- Wheels Question
- It is time to replace my Metzler 880 and doing
- White Walls ?
- S&S 509C in STD
- Deluxe 2007 oem wheels specs
- Why does it take so long to swap bars?
- '09 heritage softail classic handlebar risers
- Saddlebag liners for 2016 heritage
- My New to Me 2013 Deluxe
- 'Touring models' fender - will it fit my Slim?
- 2014 touring pack and hard bags
- 2016 Slim reduce reach seat?
- First time Harley Owner 2003 Fatboy
- Fat Boy seat
- 2013 Blackline rear rotor dragging on caliper bracket
- Apes, your height and riding postion
- Kuryakyn LED tail light
- New rears on the breakout
- 2005 Heritage Springer... ECM dead?
- DK Stealth LED Driving lights
- Compansator
- 2003 Softail Deuce 95in Reliable
- Oil on the oil tank
- The Road King is growing on me
- Front End Clunk Fix
- 2012 Fatboy gear change issue
- TC 88 Cam Chane Tensioner Fix
- Stage 1 download needed twice?
- LA Chopper cables.
- Sporster tank for EFI softails
- new tail lights wiring 05 softail
- Bouncing slow speed braking 92 FLSTC
- New forum member 16' Heritage
- Muffler Bracket
- 42mpg today
- Rough Idle
- Deluxe seat /passenger and sissy bar
- CVO pro street Breakout?!?!?!
- Satin finish scratch repair
- New Bar / Heavy Clutch Pull
- Need your opinion on Fat Bob Bar for Breakout?
- Brake caliper question
- Front fork lowering kit need some advise.
- elie 3 www tires
- 96 Heritage Classic rear caliper removal
- Front wheel inspection question
- Handle bar wire connection, repon solder or connector?
- Front End Clunk
- Screw that holds seat on options..
- What are you using to make your chrome shine?
- Open Primary Removal Help
- Stock bar wire length.
- Tall guy on softail deuce problems
- Bassani FireFlight Exhaust on a Slim
- Coming over from the Sportster Forum
- aftermarket triple trees for Breakout?
- 08 Deluxe hard bag question
- Changing from D402 to American Elite
- Luggage options 2014 Breakout
- 2003 heritage softail classic
- 08' softail deluxe break light not working, while running light still works....HELP!
- A Heritage pillion question
- Fried my clutch...
- Battery ? (Sorry!!!)
- aftermarket bars 15 slim
- Inverted Mirrors For '16 Breakout
- Part # for Harley Davidson turn signal extension caps
- Is it just my 110?
- Torque loss on a flow thru slip-on (Heritage)
- Risers on a Night Train
- Are there any Breakous running VH Big Radius 2-1
- Batwing Fairings for Heritage
- tsukayu fairing
- '02 FatBoy won't start after hitting a sunken manhole cover.
- Super Radius installed on Softail Slim S
- Engine light and battery light on at same time
- Brakes, Is this normal?
- Heritage handlebars to T-Bars
- Handle bar speaker worth it?
- Rigid sideplate question
- badlands illuminator / turn signal problems!
- 05 night train rear tire help
- Screamin eagle 103heads
- Do 2014 and 2015 softails use the same ECM
- Todd Cycle 12" Stripper or Wild 1, 12" Outlaws?
- rear fender seat mount holes heritage
