PDA
View Full Version : EVO
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 [44] 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79
  1. LED`s on 1986 FLHTC
  2. Hard ride
  3. plugs... iridum?
  4. Starter install question on 1986 flhtc
  5. Road trip prep: Primary adjustment
  6. evo slight squik when shutting down
  7. Rear shock absorber lengths for 2002 - 2007 swing arm conversion on an Evo
  8. More Fork Oil for More Dampening???
  9. Fork seals
  10. Vance & Hines Propipe HS
  11. Dang it - wheel bearings
  12. floor boards on a 95 fxsts
  13. 3/4 to 1 inch axle verification
  14. broken bracket question
  15. Wild vs Avalanche
  16. rejetting tips
  17. Rebuilding front caliper
  18. Beginner guide top end blog post- work in progress
  19. the beast is alive
  20. a big thanks to d1gger and Dr. Hess for the click write up
  21. Timing calrification
  22. Setting the timing.........
  23. Tire wear?????
  24. Idle squeek (penny fix?)
  25. Ultima 6 speed trans mods for Fxr frame
  26. Question for the oversea rider
  27. The Evolution of my 92 FLHTC...pun intended of course
  28. Guess who I got to talk to........
  29. Dyna 2000p tach
  30. staring issues, more info provided 1986 flhtc
  31. New to me Custom 90 FXSTS
  32. Turned 60,000 on the odometer today
  33. Need opinions
  34. Winter snowball
  35. need evo mod suggestions
  36. Primary Adjustment question
  37. Found one! 96' ultra
  38. spacer between rotor and stator
  39. 93 Fxr trouble starting
  40. didn't really expect that.
  41. HEy texas hill country
  42. paint question
  43. Engine year ID
  44. Does anyone know what could be causing...
  45. Turn signal question
  46. Hangs up in 3rd
  47. She ran really well today but............
  48. liftr replacement
  49. 92 ultra classic...
  50. Running on one cylinder-EFI coil ???
  51. Got my FXR / Rode from IN to CA / All is Well
  52. Missouri to Scotland with Gas.!!!!
  53. Help with my 91 ultra classic wiring 50amp circuit breaker
  54. Engine number mystery
  55. Fairing / Instrument upgrade
  56. How does this plug look?
  57. Would intake leak on rear cylinder cause the side of spark plug facing intake to show
  58. Rpm shift question
  59. New idle problem
  60. Primary chain adjustment how do you do it?
  61. 98 Heritage Springer
  62. Front base gasket leaking 4k miles into rebuild.
  63. Inner Primary starter shaft seal
  64. changing back wheel
  65. Is the Voes a wear item?
  66. Why buy a new engine?
  67. 85 Electra Glide Problem
  68. CV performance
  69. Tapping noise between 2700-3000 rpm
  70. Starting question (very odd) 1986 flhtc, also swap to 32A system?
  71. Pully seal question.
  72. tail light delete
  73. I can't flippin believe it........
  74. Late model swingarm ?
  75. Best Deka/Big Crank/East Penn battery
  76. Hey Mikuni guys
  77. Thunder Beach MC Rally Panama City Beach
  78. Earth Day
  79. Parts question
  80. Morning ride after it rained
  81. White spark plugs
  82. 89 FLHTP butterfly carb float adjustment
  83. I think I got lucky!
  84. dyna 2000i-P help
  85. Not that you would, but don't do this....a PSA for Evos
  86. Another Idle Speed Adjustment Question...
  87. installed lollipops rough running
  88. Wet sumping and very high oil pressure
  89. First ride of the year.
  90. Oil Hoses Evo Bagger
  91. charging with a new voltage reg. question for flhtc owners
  92. Nice 100 mile ride... then sprung a leak HELP
  93. 1998 ultra classic injected dies when put in gear
  94. Pulled the trigger on the Cobras
  95. Bought Crane 3000 starter boost relay
  96. Broken Fuel Gauge Wires
  97. Lollipops tuning & shift lever change trans not moving
  98. Thunder Header slip ons
  99. Blinking blinkers
  100. 1986 flhtc S&S Super E Jet help, and a volt reg. question
  101. 3 Batterys in 3 years what would you do?
  102. New FXR project
  103. New one 4 Me, any thoughts
  104. Ever tried JB Weld "putty?"
  105. 86-99 softail fxstc fender strut covers w/o turn signal holes?
  106. 98 Dyna Alignment
  107. Ultima starter 1.75 what are you using?
  108. Is there only one grease fitting...
  109. A friend might need a favour from the Florida crew.
  110. I'm assuming the transmission fluid should not be...
  111. A couple final clutch questions...if you have the patience!
  112. What's the symptoms??
  113. Evo cams?
  114. 2 Into 1 Exhaust vs. 2 into 2
  115. What to do if your clutch cable is too long???
  116. Clutch Adjustment.?.?
  117. cam cover part number
  118. Service manuals clymer vs harley
  119. 98evo(need more power)
  120. Cast Wheel Bearing Race Removal
  121. I can't believe this
  122. Tall way method for neck bearings
  123. Time for new rubber
  124. Road-side repair
  125. I love this forum
  126. primary 1996 electra glide.
  127. Dieseling ???
  128. getting the shine back on aluminum.
  129. First Ride of Season - Have S&S Carb?
  130. 10,000 miles with an Evo- Rider impressions
  131. installing fork bearing races
  132. Evo cam cover seepage
  133. Just an informationl thing
  134. Accelerator Pump or the Fuel Mixture Adjustment???
  135. Open belt drive help
  136. Would these slip-ons be better than my stock exhaust
  137. Stud trouble ... hope I ain't totally F-ed.
  138. 1991 Indicator Lights
  139. EVO Spring Start Up Help !!!!!
  140. Thanks Kees
  141. What's this Evo worth?
  142. Noticed a leak??
  143. Front brakes and Fluid
  144. Better compression releases.
  145. Stator is it Servicable?
  146. Having trouble removing the fork caps
  147. is this damaged stator still servicable
  148. dash lights keep blowing 1986 flhtc
  149. is this damaged stator still servicable
  150. happy birthday evo 30 year old this year
  151. cam and lifters 1984 evo.
  152. Spring, time to wash the bike
  153. I just got a 1991 to 1992 parts book
  154. 1988 Tour Glide "w/sc" What is w/sc?
  155. OEM Air Shocks
  156. 1998 Dyna front isolator mount repair
  157. Starter Kickback.
  158. Brake Upgrade with pics
  159. new to me 97 springer
  160. speed bleeder
  161. EV27, I'm a believer now.
  162. Wanna install a digital ignition, got ?'s
  163. Traded my hardtail for a Heritage
  164. I fixed my stripped oil drain plug today
  165. oil light on after cam install
  166. Help with rear brake
  167. Thunderheader
  168. forwards and stirrups question
  169. Air Filter
  170. Tax refund!
  171. "No Gas for 60 Miles"
  172. Detonation wierdness
  173. Issue #3...
  174. Issue #2...
  175. Hoping to draw on ya'lls expertise...gonna start a couple new threads
  176. Another timing question
  177. Need help identifying this exhaust
  178. Ultima Big growls are growling!
  179. Oil seal replacement
  180. Do we do too much (sometimes)
  181. Speed bleeders
  182. How to set radio presets on 97 FLHTC radio?
  183. Stator/voltage regulator question
  184. Here it is !
  185. Redline Heavy Shockproof?
  186. S&S ProTune II and Magneti Marrelli questions
  187. 23" front wheel question
  188. Intermittent Starting Problem
  189. Wood's 41.5 CV Carb
  190. electrical issue
  191. 80 inches of whoop ass build
  192. Oil discharge through the breather tube
  193. 97 FLHTC-I Cold Idle Speed Adjustment
  194. Cant keep oil in open primary
  195. Where do you guys buy your aftermarket Gaskets...
  196. 98 dyna low rider vibration issues
  197. Stranded....
  198. 1998 FXDL chaincase drain plug?
  199. Need A Crimp tool.
  200. TC vs. evo
  201. Got some Klockwerks Mentele bars.
  202. Killer Motorcycle CV carbs
  203. This seems awefully expensive...
  204. 4500 RPM Dead Spot
  205. New Ultima Ignition up grade
  206. Silly girl
  207. Efi?
  208. Just wanna introduce myself
  209. Noob issues
  210. 95 soft tail evo newbie
  211. 95 soft tail evo newbie
  212. 1995 Nostalgia "Charlotte"
  213. Oil drain plug for s&s evo crankcase
  214. Post your Evo dyno charts
  215. exhaust help
  216. Should I pull the trigger?
  217. Should I be using HD lubricants?
  218. GA MTN house revisited.
  219. S&S Super G Jet Issue
  220. I gotta get me some too.
  221. Fake Primary Leaks
  222. 2,000 mile road trip in mid May
  223. Big growls.....l grrrrrr
  224. Parts are-a-comin.....
  225. Charging system sucks.
  226. Where are HD engines made (in 2014).
  227. Side-cover Molding
  228. Extended S&S throttle cables
  229. Base gasket rebuild, thoughts?
  230. Doggone little hardware!
  231. break in
  232. i think its time......ì
  233. New volt meter
  234. Bike stumbling, missing, backfiring until warmed up... HELP
  235. Got scared!
  236. A heads up for TD
  237. LED brake light issue (low voltage)
  238. What the secret trick
  239. Ummmm...... Is my bike an "Evo Classic"
  240. sunday april 6th great time U should come
  241. Best ever Wolf T Shirt!!
  242. Newbie
  243. Wheel bearing questions
  244. Pic of Wheel Bearing
  245. Added new turn signals, no blink?
  246. new to me heritage
  247. I know what transmission.
  248. Ignition switch housing
  249. Spring ridin' in CO today pics
  250. Donnie Smith Motorcycle & Car Show
