View Full Version : EVO
- Breather blow by fix?
- BDay again
- Speedometer cable lube?
- Oil change every 2500?
- frame
- Primary/Derby/Inspection Seals
- ? about EV27
- Pictures of your EVO Road Kings!
- 1999 Night Train production number
- Took a ride on a Dyna… am I a Bro now?
- My latest evo problem
- oil level in tappet screen hole
- Uncle Tony discusses Amazon Chinese carbs
- What do you think of buying an engine from eBay? good or bad
- How do the older Moo Glide style saddlebags mount? Do they pop off?
- EVO 80 oil sumping
- rev tek
- BIG GREAT NEWS! ULTIMA PARTS ARE BACK!
- Sifton 112 CS
- Another Easy One for the Crowd
- A Non-Controversial thread for a Change
- 96 EVO 80 using oil
- 1995 Bad Boy Springer
- Comp sprocket
- Refresh my memory please
- Later 4-piston Rear Caliper Swap?
- FLSTC harness routing
- To Voes or Not to Voes…. That is the question.
- New Seat...
- burnin up plugs
- VOES question
- 95 flhtp evo noises valves ideas
- New to me 1997 road king!!!
- Evo Ignition Coil
- Carb fuel inlet leak
- Turn Signals Don't Auto Cancel
- Front Exh. Pushrod Cover
- Amsoil Severe Gear
- 1997 fatboy with 19” front wheel
- Picked up '98 Fat Boy w/ 124 S&S +++ Where to find exprtise?
- Wondering about EVO 80 bore sizes
- How difficult to swap head gaskets?
- Wheel bearing damage. New rear hub needed?
- Inner Primary Bearing
- 96 FLSTC ~ replacement windshield
- Evo motor issues ( 1990 in particular )
- Break in oil
- Cam shimming
- 1989 Starter Jackshaft Clip- Not Sure Where...
- Oil line ferrule
- Cam upgrade Andrew's 23
- Valve springs
- Lithium/LiFePO4 for the Dyna
- Charging system mystery
- Throttle cables time!
- New to me 1992 Electra glide!!!
- Spark plug question....
- Evo Softail gas tank capacities
- 1998 Road King FI EVO No spark
- Wierd
- Shifter pawl adjustment.....
- S&S Adjustable pushrod question
- Evo timing.
- 1998 ultra classic radio switches.
- which QD tour pack style is preferred?
- EVO being evil
- Plugs & Wires with DC3-1 coils?
- Horn Switch Spring
- 1997 FXSTC rear wheel off-center to the left
- Trans main seal
- The real mofo.
- New blinkers don't blink.
- 1997 fatboy Carburator issues
- 1998 Road King Handling & Suspension.
- Gear box oil change.
- Put a fork in her, she done
- Delay starting
- Another CV40 question
- Klock Werks windshield on Softail Evo
- '99 FXSTC in the garage! Advice, recommendations and opinions welcome!
- Relocating Battery
- D&D fatcat pipe question
- 95 Road King Handling Issues
- 1994 Fat Boy - where are my starter relay and solenoid located?
- Bikes we miss
- Which base gasket?
- Ignition timing on my Evo ( Replacing ignition sensor)
- replace oil lines 89 FLHS - remove starter?
- Oil Pressure
- Primary/Chain Tension Question
- ‘99 Evo cutting out…where to start looking..?
- Trying to get a value for a 1988 FLH
- M&M carb conversion
- Rain, Tach, Cruise Problem
- S&S manifold seals
- Big Twin Evo Head quandry...
- Softail evo flstf
- Oil tank fittings ?
- Mag wheels 95/92 FLST
- LED headlights and heat in a tour glide
- thoughts on lower fairings and heat
- Oil filter relocation
- 1995 Softail doesn’t idle right
- New Super E = New Cables?
- Got another V-twin! I am now a four bike guy!
- Throw out bearing
- Trans main shaft seal
- Hylomar
- BigMike's Grey Ghost Restoration
- 1985 Police Trike
- Leaking Inspection gasket
- dyna 2000i ignition tach issue
- 93 FXDWG...
- 96 heritage engine issue
- i keep blowing the ignition system fuse why ??
- My 86 fxrs Evo starter just has a run on it doesn't disengage!!!!!
- 1998 FLSTC - project bike?
- 1990 Fatboy Restoration - Engine reseal
- Silver EVO Engines
- Correct oil level for Baker 6 Speed/Oil Leak
- 98 Road King not charging: strong stator, new regulator, new battery
- A new issue has raised it’s head…
- No Start
- 85 FLHT occasionally dies after starting or won’t start at all
- 1997 Fatboy Turn signal help!!
- Clutch Lever Asisstance
- Docking hardware
- Bad lifter?
- Does a Twin Cam Fatboy front fender fit on an Evo Fatboy
- Red tank liner??
- Confused about oil seals.
- My Shovel, Evo and TC 3-day road trip
- 1993 FLHTC - sending unit 74406-87
- indigo blue metallic and peach from 93!!!
- Easy clutch?
- Fuel injected Evo's
- 1999 FXST Jiffy Stand and Controls Bolt Size
- oil route
- Studs and Conchos on touring packs?
- oil
- Stock Softail RPM Question
- New here , hope someone can help
- 1998 Evo Wiseco Piston Ring Dilema
- New Bar Hopper Hobber Issues...
- keihin accelerator pump adjustment?
- Troubleshooting air leak near the head with bonus: cylinder stud pulled out
- EV23 Cam buyer's remorse?
- My latest EVO - 1990 Fatboy
- I need help regarding exhaust system fitment.
- '98 Softail Dash
- Handlebar air reservoir
- After market gas gauge for EVO Softail?
- Some advice please.
- My 90s Softail EVO
- Maybe, Might, Could Be, Evo Owner Again.
- FXSTS Riser Stock Height
- My '99 was rearended :(
- 1998 FL leather saddlebags cross reference
- 1989 FLHS, Stuff to Do Etc ...
- Finally got some sun in Scotland
- 1988 FXST not charging
- EVO Throttle Control Housing or Cables for custom lower profile?
- Help to identify a clutch year.
- Coil life?
- Early Evo flhs engine replacement
- S&S 585V vs Reaper 574
- Piston orientation?
- Thinking about a ‘99 FXSTC - School me!
- '87 Softail, kickonly, small battery vs stock charging system
- *sigh*..... Primary (maybe) banging noise
- LED lights upgrade for front and rear
- What's the Evo market like these days?
- Cam spacer washer
- Fatboy Oil Leak - Rocker Box Suspected
- Gaskets - Top End Etc.
- Who has used the Dynatek Dipk-1 programming cable?
- oil in air filter even with catch can
- Primary mainshaft bearing and seal
- Two rear caliper styles for a 1998 Electra Glide Classic???
- Copper Battery Adapters
- Headlight and running lights 94 heritage
- M&M fuelie re-map Question
- Help out my Nephew with his Starter
- Base gasket time..?
- installed an LED taillight...
- Cam bearings
- ‘99 Evo Fatboy finished
- 91' Pinion Gear adventure
- My journey begins...
- "custom colors" paint codes? 1992?
- MM to Carb Conversion Video
- 2025 Bike Week Picture Thread !!!!!!
- Shout out to Twisted Choppers
- Big Thanks to 98hotrodfatboy
- Winter warm ups without fouling the plugs
- Transmssion Interchange?
- Aquatic AV Replacement Radio. Easy
- Can starter be jumped?
- Gas mileage has "tanked."
- cleaned the garage enough to unload the new project
- touring seat options
- gas tank question
- new member with a few questions
- Things to wacth out for buying a 1991 Sturgis ?
- Open Primary Options for pre1990 evo?
- Chinese module program
- 1998 Fatboy Clutch Upgrade/ Maintenance
- Springer rocker nut
- Another EVO?
- Floorboard CtC needed
- Battery cover for a Softail?
- Looking for Trans oil leak
- Bought a garage queen
- 1995 FXSTSB Fork Rocker Washers PN# 6040B and 6042
- Interesting observation about petcock
- 1999 Heritage Softail
- Fairing for 1996 Road King
- New here and looking for help
- ‘96 superglide convertible motor
- 1995 FXSTSB Help with front wheel removal.
- Fork oil Quantity
- High Quality Oil/Fuel Lines
- 1989 Springer Softail
- 1988 shocks
- Starter Motor Removal
- CVP accelerator pump nozzle
- Oil system prime/filling lines
- '95 flstn rebuild restyle / engine crack or seam question
- rear wheel bearing end play
- Tinkerman’s ride
- MM EfI to Carb Old Supertrapps and EV13-OK?
- Paint set interchanges?
- New to me 94 heritage nostalgia
- Speaking of EVO parts
- Ya'll think I can squeeze this in a softail frame? 😁
- Chinese D2K.
- Derby cover Gaskets…
- Fork question
- Transmission identification '87
- Namz Efi to Carb Harness?
- Which Pingel for EFI to Carb Conversion
- 1996 EVO EFI To Carburetor Kit
- EVOs expected to live longer than new high tech bikes
- 96 Road King to 99 Carburetor
- '92 Dyna Mid Gear Shifter
- Gas Leaked From Tank
- 1993 Ultra Classic
- SE Head part numbers..found?
- 85 Lowglide, Springer
- Time for some Upgrades
