PDA
View Full Version : EVO
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79
  1. 1984.5 FXSB kickstart won't move
  2. custom paint or from factory???
  3. 2004 and up Sportster rocker covers on Evo Big Twins?
  4. Wont start after sitting in the sun all day
  5. 1998 Ultra wont start
  6. EVO's
  7. 94 dyna exhaust bracket
  8. TD needs an EVO...
  9. got my V Thunder 3010...what jets?
  10. Already planning the Winter projects-cracked inner and outer fairing
  11. Brake Rotor question
  12. Kennedale Drag Strip
  13. are these the bulbs for the gauges on a fltc?
  14. Handlebars adjust, maybe replacement
  15. Brake squeal
  16. 1989 Electra Classic (pics). Headlight Issue
  17. 1999 bone stock EVO
  18. Batwing 85 FLTC
  19. I think I bent my hub?
  20. The chick did it
  21. Single disk single piston front brake upgrades?
  22. Anyone know if these shocks are adjustable?
  23. V&h propipe on 98 ultra classic
  24. 89 FXSTC misfires and stalls w/ lights on
  25. Front exhaust pipe
  26. FXR inner primary question
  27. RaceTech upgrade on the way.
  28. 1986 FLHTC fairing parts
  29. 1996 EVO Engine Tempreture
  30. Speaking of fluctuations / Why I hate gauges
  31. Flucuation in brightness of lights.
  32. V thunder 3010 cam noisy?
  33. 91 MORE PICS of ULTRA REBUILD.
  34. Tour Pack
  35. Evo engine vibration.......ugh..again!!
  36. Advice on new ride
  37. Winter Upgrade Suggestions.
  38. Double oilfilter?
  39. Upgrading 1994 Road King Speedometer to plug and play?
  40. 1989 FLHS purchase opinions
  41. picked up a cheap windshield
  42. Titan Sissor Jack
  43. Stock cam ?
  44. OEM 18245-02 Twin Cam Beehive Springs on Evo?
  45. 91 ultra rebuild pics. At last
  46. Oil Filter Mount Loose
  47. Upgrade to 2000+ Brakes
  48. How far, how long..
  49. Anyone install 944 shocks on evo touring?
  50. Props to Harley-Davidson LaCrosse, WI
  51. cam info needed
  52. Run-Stop-Turn rear lights conversion?
  53. re-fitting rockers...
  54. What size Philips for primary chain adjuster?
  55. Duals ehaust on Hertiage EVO
  56. FXR Tranny gear whine
  57. EVO top end rebuild
  58. 1990 FLTCU Windshield
  59. Chain Drive Secondary?
  60. Whio was looking for Cruise parts?
  61. '91 flhp
  62. Some more Electra Glide odds and ends
  63. the 88 EVO needs a few things?
  64. Help
  65. More than an in-town bike
  66. Crankcase breater options
  67. Crankcase breater options
  68. 98' Ultra Classic Voulume Control Question.
  69. Bolts vibrating loose
  70. Quick ride to northern NH
  71. gas mileage with windshield
  72. Lifting 99 FLSTC, weight on shocks
  73. Starter problems
  74. Name TDs new ride
  75. Carb Issue
  76. Swingarm on 94 FLHTC
  77. stroker evo timing
  78. bolts size
  79. wrong voltage regulator
  80. 1989 flhs
  81. CV carb on 89 FLHT enrichener question
  82. Thinking about lowering my 89 FLHS
  83. Plz help! What transmission do I have!
  84. Starter left me stranded
  85. Cruise Control Problem
  86. Powercommander V with Auto Tune
  87. Evo Mods
  88. 98 Ultra Classic
  89. Help. 94 fxds is leaking oil from clutch cable.
  90. Oil Level Very Low in Primary, 99 FLSTC Heritage Classic
  91. it's official I am back
  92. Just a simple Thanks
  93. 1998 ultra exhaust question
  94. backfiring from pipes and loss of power when cold
  95. Best bang for the buck brakes -96 FLHR
  96. been away a few years, may come back
  97. V&H hanger brackets
  98. windshield dyna
  99. 91 ultra. Intermittent fault.!
  100. 1999 or 2000 FXR's Ok For Bigger Guys??
  101. wanted to share this
  102. 32448-95B cam position sensor and VAS
  103. Primary leak?
  104. Singing the praises of the EVO!
  105. S&S Super G or MIKUNI HSR 45?
  106. Why Is There No Evo's?
  107. Picking up my Evo next week ..
  108. Help with electrical please 98 Fatboy click but not the dreaded click
  109. Score :)
  110. Evo lower case cracked
  111. SuperTrapp Supermegs vs Mean Mothers II
  112. First Impression: 1997 Harley Heritage Softail Classic
  113. What bike lift low enough to lift 99 FLSTC?
  114. School me on the difference of EV-13 vs EV-23 and some other questions
  115. Looking for a new seat - 1994 Ultra
  116. Ordered brake upgrades, please check me
  117. New from Ky
  118. Special Edition HD Custom Paint
  119. Rotor torque
  120. Tell Me About an 89 FL
  121. Burning a rear tire..
  122. Newbie 87' XLH883 RPM/MPH question...
  123. Front Master Cylinder
  124. Trailer Hitch for '84 FXRT
  125. '92 FXR Won't start
  126. 111" it is
  127. Has any one seen my air mixture screw?
  128. 19 Year Old Bike, Maintence
  129. Heathen Wheels on a Heritage
  130. What years seats fit the 1990 Ultras?
  131. 89 flh tach
  132. Rear rotor bolts
  133. Oil change question
  134. Clamshell bags aluminium strip
  135. a deal has presented itself...some opinions needed
  136. Canadian Pulley Sizes
  137. oil leak by primary....
  138. Just wondering
  139. Turn signal indicator light, re-locate and dim- FLSTC evo 1999
  140. Negative terminal sparks when starting
  141. Who need (or wants) another EVO?
  142. Picking her up SATURDAY!
  143. Electra Trade Question
  144. Horseshoe oil tank on electra?
  145. 91 ULTRA REBUILD. On the road again. !!!
  146. I need help
  147. Electrical?
  148. Clacking rear suspension
  149. Top collars for TC Beehive springs to fit Evo?
  150. 87 Heritage, where is my voes?
  151. Carby help on my EG
  152. New Rinehart Exhaust, should I dyno again?
  153. Ok it official Harley "Techs" are idiots!!
  154. Will a CVO exhaust fit?
  155. Close-Ratio 2.94:1st Gear Set
  156. stock exhaust compatability?
  157. 1987 FLHS Not Getting Gas
  158. 1998 flhr wheel spacers.
  159. Scoring on newly reamed cam bushing
  160. 1990 Low Rider Clutch Issue
  161. 91 ULTRA. "Badlands" Turn Signal Module
  162. 16 Spoke Mags for the King
  163. Need some Batwing help
  164. Lets argue carbs
  165. carburator
  166. Stalling @ 3200 rpm's
  167. Coughing and Sputtering EVO
  168. ???
  169. 86 FLST clutch and primary questions
  170. Removing side reflectors
  171. What do I need to know about new throttle/brake/clutch cables?
  172. Softail Slim fender on 96 King
  173. 32448-95B cam position sensor
  174. 86 heritage is leaking oil!
  175. Bought new (16-yr-old) EVO 1999 Heritage FLSTC !!
  176. Starting with an S&S...
  177. Will I like Dunlop American Elite As Much As My Elite3
  178. Broke a Clutch Basket "Finger"
  179. Speedo bleeding oil across face
  180. Help to identify these parts
  181. sundance frames kenny boyce look alike.
  182. Injectors, Red
  183. Anyone have a straight Mustang backrest tongue?
  184. 94 FXR Super Glide Petcock
  185. Clutch woes...
  186. 2300 kms (1400 Miles )- 5 daze
  187. Electra Glide Musings
  188. 1998 Roadking Purchase
  189. Bushes on inner rocker covers
  190. Starting hick-up 98 efi
  191. WP50 got FINISHED paint Pics
  192. My first Evo adventure
  193. Plugging the mid-shift hole in the inner primary?
  194. Acorn Nut - lower spring rod PN# 45567-88
  195. Stater
  196. Rare? FXRS
  197. I may have found THE one......
  198. Who has one? Le Pera Monterey Seat (2up) L-657
  199. Correct information from HD service guy?.
  200. 94 FLH front sprocket help
  201. God I hate posting this here: Another MM EFI question. SORRY ahead of time.
  202. 91 Ultra. Help!!!
  203. Ol' Betsy takes a leak
  204. Speedometer
  205. shifting issues update
  206. HD tool box
  207. Wheel base?
  208. 1999 EVO Heritage, carb, 40,000mi Buy / Not Buy
  209. EFI Fuel Injection vs carburetor on
  210. My tuner and breather showed up
  211. 94 Road king... Where is the main circuit breaker?
  212. 91 Ultra. Turn Signals question
  213. Installing a spike air cleaner on a 90 Ultra one way or another
  214. 1986 flht
  215. Knocking sound
  216. electronic speedometer stops working above 10 mph
  217. Kill Switch Working Intermittently
  218. Quick question for my evo gurus
  219. EVO five speed w/reverse
  220. warped rocker box
  221. Excessive vibration
  222. 1994 Road King headlight is like a spot light...
  223. EVO rideing too low
  224. Pour gas milage, need help.
  225. Sissy Bar , Backrest for Converted Tour Glide
  226. 91 ULTRA REBUILD. Nearly there!
  227. Gas tank ideas
  228. Followed me home
  229. Fuel moto LED H4 lights
  230. New friend for old girl
  231. Whats it worth????
  232. Fuel Gauge and Primary oil
  233. Crank Runout
  234. How HOT is it?
  235. Lucas oil
  236. Time for a bath
  237. noise on primary side after a ride
  238. upgrading 89 to 91-up tranny
  239. FXR transmission
  240. How Much to Ask 97' FXSTC?
  241. possessed 1988 883 Sportster
  242. 96 flstn
  243. Help with running problem
  244. Quick-Detach kit for '96 FLHR?
  245. Primary chain adjustment and noise
  246. 1991 Paint
  247. Rev counter on Roadking
  248. Rocker Cover Install help!
  249. Need to Change to Quiet Pipes
  250. full oil change - foamy oil from filter hole
