View Full Version : EVO
- Brakes Squealing.............
- S&S VFI and Throttle Body
- Look what I'm getting!
- opinions/options on a mild 80" build and gearing
- evo stage 3 question
- Question about cam bearings.
- Opinions on future exhaust set-up.
- 97 RK Cam project
- How to change a drive belt 101 Pt 4
- How to change a drive belt 101 Pt 3
- How to change a drive belt - 101 Pt 2
- How to change a drive belt -101
- pinion to cam timing?
- FXR adjustable forks?
- Outer primary cover on my '88 FLT
- Electrics? Maybe more...
- O ring help
- Check Engine Light
- Stretched flat sides
- 95 FXSTC front tires
- Rocker Box Oil Leak Fix
- Trade worth it?
- Trade worth it?
- anybody running a d&m cone filter
- 89 Electra Glide Fuel Sending Unit
- Windshield question
- Ignition
- Need help finding true duals for my 94 FXSTS
- roller tappetts ?
- new engine with rocker box noise
- Installing rear lights for Mass Inspection/Bobber
- Dyna Drive Belt Replacement - Tutorial Anyone?
- Sparkplugs
- '98 Dyna FXD-Conv Tach & Speedo Question
- Front Turn Signals
- 86 fxr
- fxrs flasher module
- fxrt 1989 seat interchange!
- CV Carb needle data.
- Digital speedo 1998 dyna fxd
- Starter Clunk
- Chirping?
- wider wide glide front wheel and tire
- Throttle/idle cable question
- Donny's Unauthorized Technical Guide Book: Learned what "V2" means among other stuff
- Planning Andrews EV 27 install, bearing question
- Engine removal...
- Get rid of the computer
- Love 'em Round and Firm
- oil leak,behind stator
- ring end gap for wisecos?
- Bigger motor?
- De-cold nature an evo
- Reinstalling cylinders
- Air/oil seperator mislabeled in parts book
- Ignition Choices
- CV carb problems
- Is the cam still good?
- Baker Drivetrain Plus+1 oil pan install and OIL TEMP guage
- anyone running sinister industries 2 into 1 exhaust?
- Newb to Evo's with a build question
- Cam install '94 Heritage
- Newish Member - Long Term bike & starting problems...anyone help please?
- Removing cone cam cover?
- New member new bike
- My First!!
- Ape Hanger Size Thoughts
- screamin kiwi, heavy breather???
- Dyno Jet Power Commander 3 input?
- Seeping from bottom of rear brake reservoir
- Happy Thanksgiving
- Harley lifters ?
- cleaning heads
- Ignition problem? Will not fire
- Disappointment:Trying to find my color :(
- fxdwg fuel sending unit gasket
- Random Misfire In the begining of the ride.
- Added another Bike to my Garage
- Wniter Project
- 1986 Heritage starter solenoid install
- louder pipes
- Softail,Fatboy front stock handlebar turn signal mounts question
- Pure gas stations
- '95 FSXTS Solid Wheel
- Dim Odometer Help
- Drag Specialties stainless braided oil lines for dyna?
- SCORE!!!! again
- Looking into a cam swap in my 91
- One of Those Days
- Short shocks and a miserable ride
- New air cleaner and Dynojet kit.
- Handlebars
- Introduction and '88 FXRS question
- What do you think
- 95 FLSTC Won't start
- My build: 98 FLHRCI
- 1996 Heritage Classic Brake Light
- Winter oil weight?
- 1987 flhtc
- timing question cam gear and timing under cam cover
- can someone tell me whats wrong with my bike?
- Help w/ my winter project please ('92 Ultra Classic)
- Checking Wheel Bearings
- Is this set up bad?
- Jetting a CV?
- Wide Glide fender on Super Glide?
- keep it simple stupid, battery post bad
- How to tell if my CV carb is "jetted"?
- Considering updating my old Keihin with a newer CV.
- High or low carb circuit
- New guy with a problem
- White wall tires
- afraid i did some damage
- 88 EVO starter clutch replacement, EZ fix
- Weber Dual Throat Opinions
- Thanks for all the info from newbie
- Late Saddlebag Install
- Convert to Royal Purple 75 - 140 for Tranny
- Time-Sert and head gasket repair update.
- passenger floor boards
- evo miss
- Bought an Evo ,pics
- Mechanical speedometer
- oil routing
- Replacing Both Flasher Units ... Can I
- advice needed
- Ultima Air Filters
- Cold natured starting on EVO 98 FXDL
- Compensator replacement
- thoughts on how much i should mill
- 1986 Evo rear wheel upgrade
- Softail shock preload adjustment
- New Seat Now Need Ideas
- Engine oil leak, need help asap!!
- Road king 2001 Model
- 1989 Tour Glide ignition issue?
- Hi ya'll
- EVO oil pump change
- looking for a good place to send heads
- Solo bag for Evo FXD?!
- bad petcock
- Fairing options for old FLHT
- Mid 80's FLHT Electra Glide Dash
- new member and bike pics
- Less noise
- Torque question
- Forgive me for I have sinned...
- Help with replacing shifter shaft? Expirence? Cost?
- finally got my hands on a nice clean one.
- 1986 Evo transmission side cover installation
- 90 Fatboy where to get these parts??
- Anyone done this?
- What to look for!
- Cable bracket
- Think my motor mount is shot- video....
- evo knock
- switching to hydraulic clutch
- Evo VS. New
- Is This A Good Deal On 98 Fatboy Wheels
- which cam would be better????
- What is the best brand of Wolf T Shirt?
- Lost and livid
- 97 Road King wont start?
- Wacha think?
- Anyone have a 1990 H-D Softail Parts book they can help with 3 part #s??
- Head bolt stud pulling out of case, need advice
- '96 ignition upgrades?
- EVO cam gear inspection
- Points conversion
- What are the signs of a mainshaft bearing going?
- What do you think? 98 heritage for $4500
- 1986 FLHTC front rear air suspension
- Cam recomendations
- Why are hard bags so expensive and hard to find?
- my 96 Evo 81 inch noisy at low speeds...
- '98 FLHR Build Thread
- twin cam primary swap to evo?
- Chrome to black!
- '96 primary chain change- parts list?
- Question for those who have True Track
- crank position sensor plug?
- Head bolt torque
- Too much play in chain.
- Help me get rid of my mid-controls "stub" on the primary
- New stator bolts?
- Engine Alignment on re-install
- Fxr
- What would you pay for a mid 90's ultra classic?
- 6 Speed Trans
- Help with info on rear pulley 70T1.5
- Wow!!!
- What intake do I have?
- Got me a J&S Jack......
- Replacing base gaskets????
- Can I swap a head bolt without taking engine apart?
- Wont run after loose intake
- Ester is in the Shop
- Added LED Brake Light for free
- Head gasket question
- '96 Evo needs all new fluids- help what Redline stuff to order?
- Bad stator, want to test regulator
- Primary Chain
- Wrapped my pipes!
- fairing mirrors on a 89-96 FLH
- Made in China! Help!!!
- Evo dyna for me?
- Will a weak battery cause this?
- anyone running a round oil tank on a softail
- anyone running true duals on a softail?
- 1990 fxsts nightmare
- 1986 fxrd
- dual disc cable but only single disc brake
- Trans Fluid Level Question
- Back on the road Head Gasket repair
- Twin Gear Levers on Forward Controls
- OEM vs aftermarket tank identification.
- Ultima El Bruto engines
- '93 flhs
- Today's Rural Ride Photos
- Quick kill switch question
- Anti-seize
- Looking at another bike
- Handlebar question
- Avon Venom dry rotting
- Results of CCP test not good Help what maybe wrong?
- 5th gear seal installation, 1990 FXRS
- Blow-by question
- Best Brake Pads?
- looking for a lid for one of my saddlebags
- Best engine gaskets?
- New Pistons
- Update and thanks!
- top end power loss???
- front cylinder not firing
- Upgrade Next Week
- windshield good deal or not
- I think I'm gonna have her painted.
- Ultima Air Filters-cleaning instructions
- how long ?
- What will happen now?
- Pan shovel Blues
- Need some help finding light lenses
- New Project
- Rear Pulley Questions
- Score # 2
- Evo front suspension
- rear break issues
- 2 into 1 slip-on softail mods?
- S&S VFI module install
