- 89 FLHTP solo seat mount
- crankpin ?
- Wouldnt You Know
- Traildogs 6 speed
- drunk fool
- '96 Evo Suggestions
- Electronic Ignition for Evo Engine
- Back cylinder not working
- Help id this speedo
- Was This Your Bike in Brookville, Indiana Today?
- 85FLHTC Suspension upgrade and lowering
- The indestructible evo?
- Seat Question
- Found the friken rattle......
- 87 FLHTC - Want to keep original radio but...
- Got my new oil sender
- Electra Glide in Blue (and some Birch White!)
- 86 Harley Evo 5 speed transmission question
- vibration
- 91FLHT front end on an 85 FLT?
- vibration at 4500
- Hd vin
- Won't start after car wash
- S&S carb help
- HEY! it covers the beat up fender...........
- Electra Glide handlebar wiring help..
- Color SAcheme 1991 Heritage Softail
- Replacing petcock, stock or "hi-flow"
- Lowering Kit
- oil pressure gauge for 98 flhtp
- black and round
- Misfire under load. 85 FLHTC
- Help Me PLEASE!!!
- 92 FLHTC need tech help - coil
- Big Bore Kit Questions
- FXRP Saddlebag measurements?
- Lights flickering
- Another FNG question! Fuel valve!
- Motor just stops,no spark
- starting issues
- Coffee Break...
- What's the diff between 92 & 93 FLHTC's?
- rear wheel
- Hi Guys
- time to finally tear down
- Need your opinion
- How do you know when to rebuild carb
- Run/Turn/Brake module question....
- 87 Electra Glide fairing removal
- i couldn't stand it anymore..
- Passing Lamp Issue
- motor identtification
- Head Pipe Glowing
- Higher wattage H4 ok on '96?
- How much rear suspension travel do I have/can afford to lose?
- ya dont see too many of these
- Puddle on floor
- Will 2011 headlight fit 1998 FLSTF?
- Bearings and axle gaulling
- Aftermarket carbs
- 95 Nostalgia misses intermittently
- All dolled up and no place to go.......
- Hayden crankcase relief valve
- FLSTF lowered to standard
- Polish
- Rear Brake pedal 98 Fatboy
- Jiffy or Center?
- Bertha has TAILS again.......
- a little air cleaner help please.
- Anyone with 99 evo?
- Question for you EVO gurus.
- Chain conversion
- Rejetting S&S Super E carb
- 1st RIDE REPORT
- Rear wheel bearing thread?
- Removed License plate hoop, now fill with what??
- New bike added to stable
- 91 FXDB-S Sturgis
- question about 21 inch front wheel...
- LED Headlight
- Be Thankfull
- Well I pulled her guts out last night
- Turn signal help needed
- Plastic gaskets?
- For all DIY mecanics..brakepads!!
- Its Been Fun
- How to tell difference in headpipes?
- A little help please......
- 93 FXR starting problem...help!
- Oil coming from air cleaner
- ditched the return cable... now grip is sloppy
- Oil sending unit or gauge?
- Smallest Evo air filter?
- 84 stator issues?
- Legislative Days - Ride on the Capital
- HF Tow behind trailer
- cam bearing puller
- turn signal upgrade help!
- stress lines or fractures in cam cover around cam opening
- Powerlet or other power gloves or the infa red inner gloves and heated outside glove
- 80" Evo Build
- Converting to Magneto Ignition
- Seeking Kick Start Conversion for 5spd. Evo
- No sound at starting
- FLHTC wheel question
- parts source
- Texas meet up?
- Hayden oil fix, pigtails, or James metal base gasket
- '97 FXSTC is slow to start ???
- Spring Solo seat?
- Hayden Oil Fix
- Finally "finished" my '96 dyna glide convertible
- Changed the whole look
- Crankcase Breather
- front fender badge and trim
- Any options for 1997 EFI Air cleaner swap
- Running into another problem with my 1992 Ultra
- 1994 road king seat and pillion
- 1988 FLHTC questions
- Swithc replacements...what to buy?
- adjustable pushrods
- 1996
- Time for air ride
- quick disconnect for bags 93FLHS
- Gas leak from the Carb (Help/1992 Ultra)
- CV Carb parts sources?
- S&S Jet
- top end rebuild .
- exhaust installed
- Bit of a quandary
- Shorter Softail rear fender struts
- shocks
- Been Busy
- Anybody running a magneto on an EVO?
- getting ready to "push the button"
- sparks plug wires.
- crank case blow by
- Speaking of LED conversion
- Badlands signal canceler
- pushrod adjustment
- throtttle not snapping back
- Where ya at map.
- Vee-4 Evo: Opportunity of a Lifetime?!
- Some good info
- Tappet sources?
- Oil Pressure Switch Help
- Exhaust problems on my FXR.....
- sprocket shaft oil seal leak
- Front brake master cylinder question
- Evo Party!
- Alaska For Three Years!!!
- Brake Calipers
- 98 Springer 844 miles
- fuel gauge
- Second guessing clip install
- Engine Swap for MM Efi FLHR
- Stock Handlebar Measurements
- 85 Electra Glide headers needed
- '92 Fatboy engine questions
- Crankcase Bolts?
- Bad exhaust fumes when pulling hill, etc?
- hand control upgrade question
- DAM**T Ring compressor!
- Engine painting going well.
- Can gaskets be installed upside down?
- Two relays
- Evo lifter tower
- 95 FXSTC shock upgrade question
- Black Switch Housings for 95 Road King
- Weather perfect!!
- Can anyone tell me if it's OK to powdercoat AFTER the cylinder/heads have been
- Fuel Efficiency Concerns 1997 FLHRI
- Engine won't return oil when hot????
- More cam help
- Oil filter hanging by oil lines-FYI
- 1995 Electra Glide transmission fluid change
- 1997 FLHRI Not starting
- 1983 Harley XLX 1000 - $1500 Good to Get?
- Hooker Headers
- Problems with Ev 27 install on 98 Evo
- Dual fire or single fire?
- 1998 Evo Softail idling on one cylinder
- Cold temps cause oil seepage?
- cranckcase crack
- Ultima Roller Rockers?
- Electrical Help!!!!
- Explain SA&S Super
- Moto Gadget wiring M unit
- tourglide windscreen size
- Ignition update 84' Evo?
- Evo cam bearing
- 1st year fatboy
- Pushrod adjustment
- Best Spark Plugs
- Fxrs fuel tank venting scheme
- stripped drain plug
- Clutch Cable Question
- Bolt on part recipe for max torque?
- 1997 road king spitting and sputtering
- 84 fxrs rear cylinder smoking weeping head gasket
- -83 Ignition rotor question (carb conversion)
- Evo ...Best oil for engine, primary and transmission.
- 1985 FLHTC Drive Belt Replacement
- Jumping My Jets up a little. Suggestions?
- transmission upgrade questions
- Tear down....Here we go!
- Took my primary apart...which spacers go where??
- 1986 HERITAGE WIRING LOOM question....
- Crane 8-3101 Hi 4E Ignition Module Wiring
- Fxr engine mount hardware
- Fuel tank cover for 1989 FLHTC
- Rear Turn Signals
- Getting ready for the gasket fix!
- Pre 1993 Evo Era Saddlebag Lid Tab
- I think I let her idle too long.
- passenger speakers will not shut off on 96 flhtcui
- 1982 Sturgis
- Value of 1994 1200cc Bobber?
- Ebay Andrews EV27?
- True duals
- Cam upgrade
- Reihart pipes ?
- Merry Christmas my biker friends
- Tour pack quick release help
- Clutch skip
- NEW FENDERS FOR MY 90's FATTY
- cam bearings ?
- 1987 Electra Glide seat question..
- Hooker Four-bidden 4-1
- Pinion Shaft snapped EVO
- I need help on finding year model.
- 1991 fxr 5 speed pulley change
- 1340 build
- 89 EVO Engine
- Clutch slippage
- Don't ignore that new ticking sound!
- independent wrench ct?
- Ignition module question
- Carb conversion questions?
- 1990 FLT ex. Police
- Could use new starter recommendations
- Turn signals
- Second alternator failure in ~9K miles
- 1990 FLHTC guages not working
- My Winter Project - Rebuilding the ol' Evo!
- Gray and damp December day.
- Dyna tank on RK?
- I need some starter help.
- FXSB Tranny Problems
