- Sportster carb same as road king aside from jetting
- 1998 Fat Boy electrical issue
- Now it's the charging system.
- Dash Lights
- Center stand
- 94 Police Bike Questions
- MM up for grabs Again
- FXR Front Motor Mount Torque
- 97 FLHTPI exhaust swap expectations
- Seat mod for a '96.
- 1998 Heritage Softail Classic frame
- Evo, HSR carb pressure release
- Mileage?
- Please Forgive Me As I Have Sinned
- another question for the new bike...quiet slip on?
- question on a softail windshield replacement
- Iso '93 flh/flhtp fsm
- multiple ignition module failures
- No Start Need Help !
- '96 Road King getting there
- Which pipes are these?
- Spark plug gap?
- Looking at picking up another king.
- Vance & Hines baffle rattle
- oil light on
- Volume switch cover
- Helicoil cylinder stud
- Had my 1998 ultra dyno'd
- S&S Super E Gas Leak
- Good Book on Motorcycle Wiring
- need alittle help with a tach and winshield
- New one to me
- Radio fuse?
- Fork seal replacement
- New D.I.D. Secondary Chain.......
- CV Needle Question
- 97 roadking running rough ( check engine light )
- Oil tank pressure?
- 97 road king engine light on and missing !!
- Primary oil transferring to oil tank
- Added to my stable ... '96 Road King
- Novice power question
- Found my fuel leak....
- 1990 fxrs rear rocker box gasket question
- New cv carb setup jetting
- Fuse box?
- 1995 Ultraclassic Magnetti-Marelli Fuel Injection Issue
- Changing engine crankcase seal & spacer
- Bike has a lot of vibration on idle with new motor mount.
- Distracted Drivers
- evo idle
- whoops. broke the dragula
- Carb overflowing from accelerator pump rod.
- Hillside stage 2
- How good can stock brakes be on a '91 FXDB
- 1986 Electra glide classic
- Need opinions on a exhaust for 98 Lowrider
- Dual plug head or single?
- Torque specs?
- Muffler Heat Shield confusion
- Changing oils
- 1985 FLHT Rear Brake fitment.
- 84 Harley FXRT Master Cylinder Rebuild
- Fxrs-sp forks leaking/air leaking
- piston clearance
- Choke
- Crankcase seal leaking?
- Magnet pieces in primary oil
- 1996 FLH carburetion/tuning?
- Curios about Wheel/Tyre sizes
- Highway Pegs slipping???
- Super e hard start
- Need a little help troubleshooting
- Clutch cable issues
- Modify stock air backing plate?
- Tour Pak to Backrest Conversion 93 FLHS
- What does an installed adjustable pushrod look like?
- better acceleration
- Trouble with the front brakes after rebuild
- Oil for 1992 with 50K miles
- Crazy electrical / battery problem
- Installing new bearings in old races
- Street slammer bars on Night Train
- 1999 NT base gaskets
- Oil line routing - 1997 Heritage
- Need Advice on hopping up a '92 FXR
- Primary Chain
- 97 odometer issue
- Dyno Day......
- exhaust for old evo
- Inner Primary Seal
- Help installing Pingel
- Evo advice-'97 Dyna
- Cleaning off the oil?
- Head Breather ?
- Fitment question
- Pre 97 Tour Pack
- Chirping Clutch
- Chirping Clutch
- Power left on the table?
- Intake leak back jug not running?????
- Pushrod question
- Drive belt rubbing sprocket
- Windshield swap
- Broke Shifter Shaft Lever 5-speed
- Figured out my shifting problem....
- Will 93 later bags fit 90 EG
- Can't seem to get belt tension and tire alignment right
- left side case insert
- seat options for 92 electra glide
- Heritage quick release windshield
- Got a few new things for the bike.
- Trouble with finding neutral
- What brake fluid to use? Manual says DOT 5
- Stator plug oil leak, easy fix?
- What would you buy...
- Nice FatBoy. Too Bad He's So Proud Of It
- Is the EVO Harley's Best Motor?
- no start panhead
- wheel bearing possibly bad ?
- Anyone ever mount a new tour pack on and older bike?
- Anybody have one?
- Finished the V111
- What's the best service manual and where can I buy one.
- Trans shifting problem
- Air suspension question
- Problems tuning the new RH 2 into 1
- Brake fluid capacity
- Out with the 5 and in with the 6
- won't go into neutral
- Electronic Cruise Control on 93 FLHS?
- I need some help please
- Taking my EVO on the road
- Missing dog bone bolt
- New to forum
- 1984 FXST won't roll in neutral...
- Occasionally leaking gas
- Brake Lines - Conversion to Floorboards
- Rear m/c push rod? '93 FXR Superglide
- Locks..tour pack and ignition..
- CV Carb Choke Issue/Question-99 EVO
- Another tour pack inquiry...
- Cam bearing 9058a or 9058b ??
- EV13--Loving it.
- Noticed the right muffler loose
- Primary and tranny oil recommendations.
- sissy bar
- Looking for the secret 96down 97up conversion
- White smoke at idle
- 1987 FLHS Turn signal module location
- sissy bar back rest
- discontinued part
- What exhaust systems will fit 90 fxrs?
- evo motor
- New aint always better
- Unusual tourpak and tool kit
- New evo owner here, what to expect
- Sturgis 1991 exhaust mount frame or trans?
- Need to find a gas tank gasket boot...can you help?
- Electrical
- Tank lift for '94 Low Rider
- 91 police to RK nacelle
- 92 electra glide Turn signal module
- Changing the front motor mount
- Rear master cylinder 89 fxstc inlet valve broke off can it be replaced
- Rear wheel removal
- 91 stator out. How's it look?
- Does this make my rear look
- New tank/ petcock update
- Speedometer Issues
- CV conversion
- valve springs
- Starting bike/running while on side stand
- Just when you own the perfect bike for yourself.
- Part number or measurement needed please
- Looking at a low miles 94 Heritage Nostalia
- Gas mileage ?
- Helmet question
- Harley evo fxrt throwout bearing keeps burning up
- Electrical issue
- What's up Evo land!
- ignition upgrade
- ignition upgrade
- In need of front master cylinder and possibly both front calipers.
- Help with front wheel
- Nuteral rattle
- Backfires sputters
- Evo cams
- Carb bikes
- Swapped cam and gas tank, bike won't start
- Quick detach hardware for 94 ultra classic
- Spark plug color and tank trim
- Longer gas hose for new tank
- Looking at a used S&S Super E
- Oil tank fills itself
- Dyna lowrider rear head removal
- CV carb running lean?
- 1990 electra glide classic
- Mag wheels for 1985 FXEF???
- Question about evo sportster
- cleaned up my fork sliders finally! 96 wide glide
- Starter Recommendations.......
- 98 Ultra FI and PC V question
- Inspection fail question
- S&S slasher air cleaner
- 1987 FLHS before and after.
- FXR2 - Upstate NY
- Rocker arm covers slightly uneven
- Brake bleeding help 91 EGC
- running lean???
- Super E enricher, how does it work?
- 1990 fxrs-sp won't run right...help needed!
- Question for you clean freaks
- '92 FLSTC (pic)
- Coils
- New Fuel level sending units for a good price
- Timing Cone Question
- 94 FLSTN project complete. Evo Vicla baby!
- Gas cap thread?
- 1992 flhtc oil canister
- Westward trip
- Final Evo Build
- Exhaust Broke? Can I Limp Home
- Throttle Cables S&S
- Texas Evo Meetup Itinerary
- S&S breather gear clearance
- Think I'm Done - For Now
- Softail Oil tank drain tube
- Evo pickup sensor plate
- Headlight upgrade suggeations
- 1989 electra glide what seats fit and where can I get one?
- LED Headlight question?
- Transmission Leak Question
- First ride, not all is well. 85 fxsb
- Is this a Dyna Super Glide?
- Tires?!?!?!
- Conversion to Floorboards - Brake Line? FXSTC
- Maintenance
- S&S E or G?
- Can someone with a evo softail standard or custom take a pic for me....
- 96 Ultra Cliassic ElectraGlide EFI
- Checking Coil
- Let the festivities begin
- Opinions on this 1995 Heritage Softail?
- Evo Softail ticking/clattering noise
- Evo Rocker Box Mods
- 2004 Harley Sportster 1200 c , head bolts
