- Cost of Barnett cables
- Qwik Silver II Carb help
- 1996 FLSTN Heritage Nostalgia
- Kudo's to Kirby
- 98 FXSTC Throttle cable to housing
- Ignition Modue
- Crazy A$$ blinkers?
- 2011 Pacific Northwest HDForums Rally!
- Dutch Stealers versus American Stealers...
- 1987 FLHTC Electra Glide inner fairing options?
- Starter woes....please help
- Puking oil
- get my bike back tomm
- What brand lifter to get
- Fairing switch
- Help for identifying an EVO CAM
- FXR 107 vs. 117
- LED Headlights - Harley
- Idle Question
- FLHT `88 Starter gear tooth.
- Spit and Sputtered after a 100 miles!
- Cam Bearing
- voltage reg, 1989 FLHS
- Just got a tick
- Motorcycle lifts
- Hose
- Evo Primary
- G'Day All.
- Cobra Tri oval slipons
- Oil filter part number?
- deutsch connector help please
- Charging Issue 92 FLHTC
- triple tree bearings...
- Road6customs???
- evo oil pressure
- Oil lines on Evo
- Vibration in FXR
- Got no luck with this bike :-(
- Tappet gide oil leak
- Handling Issue
- Battered Barrels
- 85 FXWG Clutch adjustment
- 99 softail under dash pic
- Advice / Best course of action
- Where does the jiffy stand spring connect on my '94?
- messed up with carb kit...now what do i do?
- Need part number for85 FXWG oil tank
- HELP Did I just ruin my inner primary?
- Forwards on a FLST
- 1980's-1990's FXR
- She's quiet now!
- 97 fatboy no spark huge problem please help
- front brake caliper problem
- Smoking Exhaust.
- 100" Fatvo is this a good idea?
- Top end question
- Turn Signal Control Module?
- Sta Bo I Installation Question
- should I remove Thunderslide & DynoJet kit?
- Best front hoses for 91 ultra.??
- Clutch not disengaging
- Seat Help
- 98 RKC...what's she worth?
- charging question on my`99 fatboy
- cam info online?
- solenoid seal 1988 FLHS HELP!
- Help with confusion on Triple Trees and Forks
- Back bleeding front forks.
- Mother Nature
- Stock 80in Dyno number help
- 91 Ultra. Front Brake Bleeding question
- 98 King Tap tap
- K&N oil filters-evo/TC
- ok, get her off my back !
- Pinion colour code?
- Aftermarket source for early nineties fairing and parts
- Primary Plug Leak After Teflon Tape
- Adding Cruise......
- Tiny-Tach tachometer or other Mechanics Tach
- early evo heads vs. late evo heads
- andrews adjustable pushrod question.
- knocking sound
- So what's the damage?
- Seat fitment
- Has anyone installed a Burly lowering kit
- 1985 fxwg, 4 speed rotary transmission.
- Rebuild evo Fatboy or buy kit bike?
- 98 Road King Classic Swing arm upgrade
- "Stumped"
- S&S oil pump & EVO
- starting problem
- 1989 primary oil
- Gass Tanks
- Re-engining an FXR
- dyno numbers
- tape on tranny plug
- lifter block screw size?
- Correct Idle RPM?
- Dodgy Ground/Earth?
- 16" bars on a 98fxd..cable size help +8?
- another product to stay away from...
- How to inspect for a worn compensator
- reuseable oil filter
- Picture Album
- bike stalls on kick stand
- Build Progress
- Help with my 1984 Electra Glide Classic
- Mystery clunk or slip from a stop
- Primary Chain Tension question
- Road King seat on 89 FLHT?
- early evo oil lines
- Softail Dash Question
- fuel problems
- evo guys:do you think my bikes cam'd by the dyno sheet?
- Replaced Fork Seals & Steer.Head Bearings
- 1995 electra glide carb jetting question
- '98 Wide Glide ad
- SE Igntion
- spring is here and bike is together
- Evo Springer Riders....
- Throttle Lock
- Barrel Gasket Leak Fix?
- Holy Crap..Happy to be back on an EVO
- adjusting clutch
- need a case for an 1990 evo
- Too many miles on a '93??
- Evo engine case sealer?
- Mustang or Saddlemen seat for an 87 FXRS?
- rev tech/ultima el bruto/reman harley???
- codes
- Head Work Questions
- Do you like this bike?
- Cabled Choke closing on it's own.
- evl 5005 ?
- Short hello to all
- Temptation dilemma
- 1997 Ultra missing and poping
- New tires for the old girl
- 1984 FLHTC -any issues to note
- progressive springs
- In search of a speedometer.
- It fired up today!
- Thunderheader ??
- Exhaust Wrap
- Best Battery for the $$
- Signals not flashing
- dyna muffler question
- fork seal leaking
- air cleaner hose
- cold exhaust
- learning to set curves
- OK so im stupid but figured it out!
- aligning back tire
- No oil in tranny or primary
- Blew up my 96
- Spark Plugs
- Primary Belt Drive Anyone?
- Intake leak, loose fitting carb
- rocker box question (first top end rebuild)
- Help...Which Charging System????
- Paint question
- Baffle Modification
- 80 in evo ign problem
- Need muffler ideas
- Help with derby cover leak
- lowering?
- Oil dripping from the air cleaner
- missfires under elc.load
- New look for my Fatboy front end!
- Fuel gauge - sending unit problem
- Thunderheader on 80"
- Dyno Jet kit
- replacing my first starter. Input
- Ultima 113" dropped a lifter.
- Passing light headache,,Ugh
- Fuel Injection Sputtering??
- Strange Rocker Box Question
- Exhaust reverberation..WTF??
- You ain't gonna believe this sh*t
- Front brake caliper. Any info.?
- another 5 speed question
- My 97 softail custom
- front end wobble
- Lifters revisited
- Need you evo owners to feed me info please.
- 91 Low Rider Inner primary removal
- cv carb overflow problem
- Valve Stem oil seal leak.
- abandoned Michter's Distillery Schaefferstown,PA
- Runaway Throttle S&S Super E Carb
- question for fanda M
- cluych problems
- 91 Ultra Fork Oil Seal replacement.
- Steering Head Bearings SIZES?
- Getting RPM . . .
- 1987 Heritage Electrical help
- Screamin Eagle Heads This info may be Useful
- New CV Carb...wow!
- Early Evo Oil Puke
- what are catalytic mufflers?
- Primary Leak Question
- 1985 Electra Glide Classic Rear Wheel Mounting ...
- Tins - can anybody tell....
- Are there any known issues with the Evo?
- New pipes and high idle?
- moving 3/4" axle up to 1" newer rim
- New to me Evo
- Connecting rod play
- Primary Chain Auto Adjuster
- Fatvo motor anyone?
- wiring a daytona twin-tec
- Idle mixture
- Okay dumb question
- Now I'm confused..............Rebuild dilemma
- 1984 Electra Glide Saddlebag Latches
- coughing carb
- Parts for older bikes
- Pulling tins on my 96 FLHR
- Stage 2 for 97 RK?
- Top end noise question
- Difference between a current softail and an Evo one
- wiring insight needed
- Steering Head Bearings Replacement.
- '95 -Pre, Standard Black Switch Housings- any leads???
- 92 Fatboy floorboards to FWD controls?
- 1994 FXDWG TopEnd rebuild
- Final Compression #'s
- To bore or not to bore? that is the question
- New bike this weekend
- 85 FXR Fuel Gauge
- Dead evo!
- switching to singl side brake?
- Footboards for a 86 eglide?
- My next "project" I need advice and suggestions, info!
- ideas & photos wanted front rims
- Teardown progress
- My 95 FXDL EVO Pics
- Anybody Riding?
- My gas mileage seems to suck?
- vibration
- battery draw
- Carb adjusting
- Your thoughts on my "hard to find neutral"
- Extended Idle Screw for Road King
- Back to an EVO! SE-3 Cam question
- top end rebuild
- Spring Fever
- MUFFLERS HARLEY FLSTS 97 to 2000 OBSOLETE
- primary drive help
- Yet another pushrod question.
