View Full Version : EVO
- An example of how to tell if your Dyna motor mount is worn
- Pennzoil 25w-50 GT
- Renewing a old Softail..and keeping it under $4,000
- Correct Base Gasket?
- Badlands Load Equalizer LE-03-A install
- Evo questions
- Intake leak symptoms?
- Touring Model Engine Guard Fitment
- 1986 FLHT Parts
- 1995 Bad boy
- Need a crimping tool
- I'm picking up bad vibrations - engine
- Front wheel conversion help.
- Bike week evos
- 85 fxwg
- Andrews EV13 cam installed: Nice
- Have ya'll manage to put a Fat Boy front fender on a Road King from the Evo years?
- 97 FLSTC Wheel Chock?
- 93 Heritage Bassani fishtail install problems
- 87 fxlr
- I'm back--with a problem
- Help with Speedometer Cable hookup
- Ticking sound!!
- Getting ready to swap shift spring...
- 89 FXSTC butterfly to CV swap
- More Upgrades.......
- 1987 FXLR headlight help, please
- 91 ULTRA REBUILD. Good news + Bad news.!
- Shootout in Waco
- New tool
- EVO dual exhaust help
- Compensator ?
- 98 evo ticking
- 1986 FXRS Electrical Help
- Road King leaking gas from fuel gauge
- Quick front end question (Clunk)
- New Member British Columbia Canada
- Great Idea,Thankyou...
- 1984 flt classic questions
- Tank Console Badge (What do you think?)
- ok this may sound dumb but,,,,,,
- Tach Bouncing
- 98 Road King Police base gasket seap
- 11/16 front mc rebuild kit question?
- Which forks?
- red hot evo pipes!
- Ignition pick up
- Puff puff puff!
- More EVO problems....
- I think i found my leak
- 1984 softail problems
- Loose fender
- NEW 2 ME 1988 Tour Glide
- 1998 Heritage taillight question
- What could it be?
- Oil reading
- Are there any problems with mixing...
- voltage regulator?
- No balls!
- First Gear went Bye-Bye
- Never Trust the Previous owner
- inner primary seals
- That was odd....
- What parts do I need to replace speedo drive?
- Shot in the dark on this one
- Brake Caliper
- 1995 30th Anniv Ultra Fluid Check Question
- Belt squeal anyone??
- Wish me luck...
- 98' Ultra Classic Oil Temp Gauge question...
- Bike runs on.....
- Myth or Truth ???
- Anyone else tried the S&S High performance heads?
- Ticking time bomb???
- 90 FXTS /EVO Questions and thoughts
- Paging Traildog - Seafoam Borescope Effectiveness Test
- Can somebody help Kees find a seat?
- Radio cuts off when I hit my brake (sometimes) 1986 FLHTC
- Front master cylinder removal 85 Electra glide
- 85 FLHTC Questions
- Drive belt squeel
- Evo Values
- Warping derby covers
- New Tires
- Front brake line
- 98 front motor mount
- Speedo stopped working
- I just scored a baker five speed shifter drum.....
- Which company made these brake rotors?
- ohm value ets 98 flhtcui
- Dielectric grease
- 90 tourglide speakers
- Ultima 6 transmission review
- Combination Speedometer and Tachometer Kit
- Handlebar grip question??
- Lowering 1996 Road King
- 90 evo weak spark
- 1st. Annual Steelhorse Rodeo, Hallsville TX.
- Help a Newbie - 94 Fat Boy
- 91 ultra classic rebuild.
- Ultima cases, anyone use them?
- THC said It's my fault
- Pull Torrington and replace with new one?
- Odd new development
- SE evo heads with andrews ev5 cam
- I think I need a new oil pump body
- Spark Plugs
- Front brake softness/no return issue resolved
- Exhaust Tick
- FLHT inner primary.
- Wheels and exhaust
- 93 FLSTC Trans leak question
- 94 Softail Need Help
- The bike upgrade ...
- Electra Glide Bars on a 98 RKC?
- A little disappointed ...
- Rinsing the oil tank
- Fairing or not to fairing
- MM tuning
- Stator Connector Issue
- Efi b gone
- Springer shock is loose...
- Basket case
- Center Stand?
- True Track Tracula install question
- Yet Another Newb Oil Question
- WOT take off!
- Changed to 3.37 Gearing
- Fork guestion
- Another oil question
- An Exhaust question please...
- Anyone seen or use this ...
- evo bagger cruise control
- Coil question
- Wrong oil
- motor allignment
- A question on Brakes...
- I did a brake upgrade (pics)
- how to remove speedometer cable? 89 fltc
- Frame measurements and specs?
- What happens if I go from a 70 to a 65 tooth pulley?
- Oil pressure
- Next project idea.
- Cleaning boot marks of chrome exhaust
- Modifying a windshield???
- Detachable Saddlebags for '96 FXDS
- 1991 FLHTC - Tour Pak Speaker Pods (Dragonfly)
- Ignition coil testing
- Getting a 97+ seat to fit on an 89 Electra Glide
- It's finished ok almost!
- This has to be a new one
- Good S&S Experience
- TL P7 Headlight night shots
- Tranny usually hard to shift from 5th down to 4th?
- Push Button ...push funny Honey
- Rear Master Cylinder Reservoir options?
- S&S tear drop on a mikuni hsr42
- All is quiet w/my hotrod eve
- clutch hub bearing
- cb fuse filter pod
- My 96 springer
- Gone but not forgotten
- Diy camgear change
- Brake help needed
- Wow! Had to share
- Evo advice
- Cam bearing question
- New battery
- Probably just another oil thread!
- Wich VOES?
- Extended Brake Lines (1991 FLHTC)
- Extended Throttle Cables (1991 FLHTC)
- Oil change questions - (Procedures)
- Best Cam for Evo?
- What is this plug thing under the seat?
- shift linkage interference/samson cholo ex
- Waking up the 97' FLSTC
- Is the
- Dial Back Timing Light
- Another EVO! 1996 FLTCUI
- 1998 Dyna......what do I need to know
- 3rd 4th chattering
- 92 FXRS carb issue
- What exhaust will fit my bike, and a recent pic of her 1986 flhtc
- Wiring vs Switch on 75 FLH
- 97 Front Wheel
- gimme a brake...
- Tappet Screen
- Evo Black Girl up FS-Nor Cal $7500
- Where does this wire go?????
- Another Jets question
- Seat options for a 1993 Heritage
- Left axle spacer - 41595-86
- What the bike sounds like ...
- Cam Bearing Puller....?
- Brake pedal
- New Tire Performance?
- Cutting In
- Clutch and shift lever replacement?
- Swap windshields
- Two more questions
- Ignition coil?
- All right I give, what it and how does it come apart?
- Removing the CB
- 87 Heritage circuit breakers under dash base
- switch covers
- Tank replacement..
- Troubles (magnets) inside my primary (Road King)
- Dry graffite spray
- EV13 cam swap.....lifter noise.
- wiring harness helpage
- Oil filler cap broke off 94 Ultra classic
- Cv carb accelerator pump
- starter issue on electra glide
- Better Brakes on the Cheap
- which exhaust gaskets would you recomend?
- Mashed Dash...
- After thoughts/opinions...
- I love my Evo
- Good drive belt for a good price?
- Early Softail Starter
- Speedo not working
- New owner to older evo
- Rev-Tech engines
- just changed my oil. level too full and i dont understand why/how
- Stock Carb- 89' fxstc
- Your Ultimate Bike Build ...
- Upgraded audio on Evo, yep stock controls work
- ultima ignition timing
- Air Ride Suspension
- Turn Signal Lights...
- Base gaskets...is it time?
- compensator shimming
- 5 speed transmission case question
- Allignment issues
- Air Filters/Systems
- transmission gearing question
- Poo happens I guess.....
- What's my stock air filter look like?
- Trouble Finding Year of S&S engine
- Biketronics BT1004 Died?
- Ignition Module Removal Trouble
- couple questions on my electra glide
- My 80 CI evo hits rev limiter when accelerated
- broken fog lamp switch 1986 flhtc
- What's your preference?
- 1984 FLHTC starter question.
- LED V's HID Lights
- I keep it clean!
- I was discriminated against
