View Full Version : EVO
- Which way is reserve on this d&mn thing?
- 1997 Road King crank bearing
- ? for Mr. Brown, Re:Travelling in Europe
- thank you
- 6 gallon touring tank on FXR ?
- Scarlett Likes Trees
- Exhaust mods already done?
- Spiffed her up a little...
- EVO Rider's (solid mount engine/Shaken, not stirred) coffee cup holder
- I didn't ride a 2014 water head today
- Thottle cables on Mikuni HSR 42
- Starter question
- Customizing a FLHS 1990
- 94 FXLR rear cylider oil leak
- Picked up my first HD - 1995 Road King, Suggestions on Maintenance & Mods?
- Changed my mind on something
- need help removing cb from 1990 flhtcu
- Woodds vs Zippers Who is running what?
- cant ride
- EVO Top End
- Clutch Release Arm Leak?
- Rode to work today.......
- Bright ideas to make putting back wheel on easier???
- Manuals?
- 86 fxr fender and fender strut swap? Mod
- wanting a license plate mount like on new style bikes
- Gas leak on my 1992 FLHS
- Scarlett Doesn't like Premium
- Battery Tender Cold Storage
- Gas Tank
- EV27 cam and..........?
- A new ride for an old bagger?
- Oh, no.....
- Crappy Coil
- 93 evo hollow knock. less than 500 on revuild?
- Voes and RPMs
- voes and RPMs
- Rear Brake Reservoir Buried?...Wide Glide
- 97 Ultra & Andrews 27 cam
- Top End Rebuild Parts & Pieces
- My gremlin is back.
- 1984 fltc fairing question
- Can't get to the check ball
- Airflitration!
- inspecting and replacing oil check valve spring/ball
- Just bought 1992 Springer FXSTS, questions.
- '95 Ultra Glide
- 91 FXRS-new Bassani road rage for fxr-DYNO SHEETS
- When did they stop making carburated bikes?
- EarthX Lithium ion battery
- 1999 stock Dyna wide glide shocks
- You mind if I hide in here?
- It is Official,
- Silly Front Fork Question
- 91 Ultra. Interchangeable Frames?
- 1994 Springer FXSTS opinions
- Where can I buy a new indicator lens for my 95 Road King?
- Put a new exhaust system on my evo today (pics)
- 97 bottom end build
- Pinion shaft bearings colors
- 1996 Electraglide basket Finally Complete
- Bad news from dealer, Clutch carrier bearing is going south, how to?
- No Rear Brake light...foot peddle
- trans oil
- So THAT'S why Scarlett was "passing gas!"
- Help w/ Front Caliper
- Can anyone confirm the winshield brackte part #?
- Fork lock not working 1992 FLHS
- Another unsuccessful attempt...
- Help, where the BLEEP is the throwout bearing?
- Ran a tank with some SeaFoam
- Rear brake sticking
- Giving up on the DIY diagnosis
- Back to the Evo family
- My First EVO/Harley
- 1994 FXD Primary Inspeection Cover Stuck!
- at the end of my rope with my charging system
- Gonna "leather" her up baby.......
- EVO Rebuild costs
- 94 fxds
- Brake Squeal is back
- '98 Ultra
- Will 7.50-16 tire fit a 90 springer ?
- Squeak-Squeal-grind in primary after stator replacement
- What to buy, what to buy.......
- Vanishing Primary Fluid Conundrum
- 85 FXRS clutch / shifter problem.
- Sying goodbye to a short term friend......
- Cables
- I don't get it...
- How do you know if the engine is idling fast enough......
- Oil light on at idle.
- 4th and 5th hesitation
- Ghostrider finally goes solo!
- Clutch help
- 1995 Ultra Classic Squirlly
- ThaNK God for my Evo!
- My new Evo
- Wet sump reduction
- Paging Dr. Hess....paging Dr. Hess...the 91 Classic is home and ready for a Dx
- newer motor in old bike?
- Fuel filter
- Sturgis Ride
- *new guy* 93 ultra classic tire problems
- 80" Evo cams
- Bring her home Wednesday
- evo help.
- God bless America...and Evo Harleys!
- 1990 Ultra Classic Ping Machine
- The lift went down and so did Charlotte............
- Heritage bags
- Softail Windshield on Road King?
- Floorboard Vibration
- 91 ULTRA Evo. Inner primary bearing removal.
- crank seal replacement
- Front end wobble…normal?
- How tight does an oil fiter have to be?
- Bike sat in rain for an hour, wouldn't idle past 1k RPM for a while.
- lowering kit?
- Oil usage in Evo
- Horn Suggestions?
- what to do?
- 98 FXDWG Wiring question
- Fuel Gauge on Wide Glide
- 1986 FLHTC Primary noise when in Neutral
- Harley Goodies Floorboard extenders
- Speedo puzzle
- Evo carb
- Upgrading evo motors?
- What the Postman Delivered Today
- lifter went south
- Vacuum petcock diaphragm leaking
- Quiet Pipes, New Problem
- Timing rev range
- What should I ask for my road king
- My new (to me) evo!!
- Tick tock tick tock
- Thanks cpbedor!
- Mid 90's Wide Glide Wheel >>>> Mid 90's Road King??
- Can't wait to ride
- Looking at another evo pt.II...
- 1996 Roadking wobble on bends with a bump...
- Comfort profile rear saddlebag kit - '93 Electra Glide?
- Rewire 1340 - delete kill switch wiring?
- Help me find a new shield!
- Anyone know of a solo seat for 1988 FLHTC?
- Turn signals
- Finally finished replacing drive belt!!! (man what a job!)
- How bad could it be...join in the speculation!
- Rusty spark plug wire.
- So much for riding Scarlett......
- Lookin' at another evo...
- 2 products worth mentioning
- Live to ride and Ride to live.
- Spyke or Compufire Coil
- Is my evo a time machine.
- Carb removal
- HELP!! 84 fxr forks n triple tree rebuild
- What are the chances?
- Oil beather at bottom of crank case problems
- Me and my 1998 Dyna Wide Glide
- Oil change!
- Fair deal on 99 Heritage?
- Will a 140 tire fit on a 97 Wide Glide?
- Heritage and Fatboy fenders interchangable?
- Torque Arm & D&D Fat Cat 2:1 - Exhaust Bracket Fit
- Tires
- Evo Bagger Price Check
- LA Choppers T Bars on Softail Custom
- T Bars on a Softail Custom?
- Scarlett's new look!
- Need a pic
- Valve Spring Advice
- Carb ID
- Let's talk plug wires
- Making Longer (ish) Rides More Comfy
- Ultima pushrod question...
- 50k mile service
- gas cap?
- Shearing motor mount bolts
- Rebuild Advice
- Found a poem today
- question about shovel FXR
- Could be the one! Wish me luck!
- Bike Died, No Spark, Now Fine - Question
- What do we think of this '94 Wide Glide?
- Couple quick maintenance questions
- 90 FLHST Running Issues (Carb questions)
- Single fire wires to coil
- Update. Rust on 91 Ultra Frame.
- '93 Electra Glide tallboy seat?
- Bad day....
- Piston concern
- FXR show in sturgis this year
- Long ride comfort seat for 1986 FXSTC, does one exist?
- Crank case over pressure
- clutch cable adjustment
- Changing from DOT 3 to DOT 5
- small vid
- Fuel system trouble shooting. Help?
- 1998 Heritage with 6k miles
- What pipes do I have?
- Tappet blocks seeping
- I don't smoke, but my 86 FLHTC does!
- Upgrading 85 clutch side cover to post 87
- 1992 evolution cylinder size
- Question
- Adjustable Push Rods
- '94 Fatboy Oil Leak
- Breather vent
- Mission of Mercy
- Mikuni hs40 or s&s E?
- How about this one?
- Throttle cables-push/pull-installed wrong, I believe?
- NOOOOOOOOO! Somebody SLAP me NOOOOOO!
- Trying Something Different
- 1996 EVO FLHTC exhaust question
- New Exhaust...Engine Run-on...?
- How about this fine fine deal!
- Re-post from touring forum, still needing help...
- Whats with the twinkies
- This one can be ridden upside down......
- Is this tire defective or am i paranoid
- Dying engine
- How do I take out throttle/idle cables (pic inside)?
- New Z-Bars and New Exhaust...pics
- Headlight wiring?
- EVO Lifter noise or soft pinging?
- 1990 fltc start up issue
- 98 FLTR Guages Not Working
- XR1200 2011 Front Brake Caliper fit Evo Road King?
- jackshaft starter....and frustration!
- Clutch Inspection cover and an oil leak
- It ain't an EVO but....
- Torque Spec
- Cam Issue?....Sound from the nose cone.
- needle bearing for starter nose?
- Partially blown head gasket?
- Ignition Control Module
- Partial Gas Tank Removal?
- New Top End for my '93 Sporty
- some help with the fuel injection
- Bike dies at idle after warm up
- Engine shutdown
- Replace headlight?
- Is this a problem?
- 400 Mile Day - pics
- Got it on the dyno
- When an evo gets wet?
- Rinehart slip ons
