- 91 Ultra. setting timing EV 27 Cam swop
- Bassani true duals
- Indoor Harley!
- Screaming Eagle CVO slip ons
- Here's what I got
- Tour Pack Quick Disconnect Brackets Options?
- Gas Caps
- E-Glide seat
- Cast Wheel on Early Springer
- 1998 Heritage
- 1-3/4" or 2" drag pipes
- Oxford Heaterz Premium Touring Heated Grips $89.99 Opinions please
- Riding today...
- The Yamakahondazuki........
- Crane Hi4E
- evo ignition with a kickstart
- EV 27 Cam swop. Lifters & Lobes.
- Opinion on which bars. Three pics. Three choices.
- Opinion on 50% off Vance & Hines "High Output" 2 into 1 Slip On Exhaust
- Coil replacement short cut
- pulling motor 1990 FLT
- Did I break my choke cable?
- Blue Ridge
- Dyno Jet Power Commander 3 usb
- Winter Project?
- Wiring an Ultima ignition??
- Help with Risers -have front air suspension
- andrews ev27 vs screamin eagle se1
- Another cam thead
- How do a I adjust the fork adjuster nut
- Cheap LED headlight upgrade
- 400 miles on the company dollar
- A word about Pressure Washers....
- Ultima 131
- Oil consumption
- Another question for you guys
- compensator nut !!!
- FXSTC Evo Tune up
- Looking for dash colored lenses
- Question about brakes please
- Took her out for a quick run and....
- Braggin Rights
- Possibly trading for an FXRS
- Removing 90 flt evo motor
- EVO cam/gear swops ???
- Turn signal placement when using Bagger Tail Softail mounts
- Fxr upgrades
- Can't get pushrod cover on. Also, new lifters- didn't need to bleed down?
- Removing 1990 evo motor.
- Tool List?
- For Traildog
- Help me read these plugs
- Spanners & Kees
- Anyone know roughly when Harley switch back to the INA cam bearings?
- Help with mid range popping
- Old guys tell me about the Evo?
- W6 cam over ev27
- 11/15/13 Foggy Mtn
- 1990 flt exhaust pipes
- cable change
- 12' over forks
- I'm back on an EVO!!!!
- Name those mufflers
- Part Number Help Please
- Adjustable pushrods
- sprocket size
- Brembo retrofit
- turn signal light are manually.
- slightly notchy front fork bearings fix
- I think it wet sumped
- Revtech AC?
- longer shift lever
- Melting Goo
- Opinions on factory remanufacturing
- Are all Evo rear brakes this useless??
- Best gasket kit for 93 fxr..
- Closing Petcock for Storage
- Flush mount pop up gas cap recommendations
- Bigbore kits ?
- hard bag tops flying off.
- Stinking Badges
- Sloppy cam- what now?
- Apparently, I have ride adjustable handle bars
- What does this part do? 1989 Electraglide Ultra
- fuel tank reserve
- 92 Heritage
- I'm taking the SAG out of my BAGS!
- Checking the lifters and cam bearing
- My Dad came by
- EV 27 Cam swop. Last call for help.!
- 1992 EVO S E air cleaner kit?
- question for carb guru's
- Hard Bag Quick-Detach Conversion?
- GA Mtns 11/6/13
- 87 flhtp trans prob
- Cant remove gas cap
- Windshield Info
- Orientation of Oil holes on Tappets.
- Wheel Bearings, 1996 Ultra Classic
- OMG! Don't try this at home folks!
- 94 FXR Clutch question...
- speedo gear help
- Couldn't find one so I made one....
- New Noise?
- Noob task #1: filling the gas tank
- Bike has a miss
- Another MM EFI vs Carb thread
- Shocks question
- Paint codes
- Crank case breather?
- High Flow Air Filter kit with stock cover for 95 Heritage
- Bikers getting it done
- Post your weekend ride pics... lovin' life on my Evo
- Silverado Harley Truck
- FXR: What years are best?
- Installed a Throttle Up Brace to solve my bagger wobble issues
- So who likes riding to country pubs...?
- I like it!
- How strong is the Jiffy stand?
- Loose Tranny lever on splined shaft.
- Belt length options
- Had My First Ride On a Non-Evo Today
- Do Easy Brackets work with Papa Bags?
- EV27 Noob Help
- The top end is out!
- Front end rebuild
- I finally fixed the noises
- Rebuilding a 1990 flt evo ex. police.
- '96 FLHTCI Front End Noise
- My wife took me to Milwaukee for my 50th Birthday!
- gas gauge fxd superglide 98
- Who Counts on Their Evo as a Daily Driver?
- Tires
- Refit Ultra Engine into Frame.
- HarDlife's official build thread
- Part number help?
- 95 fatboy frame
- When fire meets ice...
- geneb
- Just saw one of these at Walmart!
- Tappet guide alignment tool.
- 90+ hp/tq build
- Recommendations Please
- New-er bike recommendation
- Evo FXSTC - Speedo Cable Going to Rim?
- no compression
- Fuel filter craziness
- Chewed up starter gear plus some!
- Lower seat for 87 Heritage
- Need help finding an Ape setup for my 86 FLHTC
- Heritage tool box questions
- EV5 Cam ...anyone used one ?
- 85 fxr rear brake problem
- Sad day, put the bikes away for the season
- Best Manual for Evo
- My 1997 FXDL - some issues - NOOB thread #2
- 1993 Electra Glide Sport
- Softtail Vibes Evo vs TC vs S&
- Which parts needed for cam change?
- Right oil filter?
- Guess I should carry extras, DAMMIT
- New EV27 & Old Cams. pics
- starter will not disengage, 1986 flhtc
- will I like the VT 3020?
- Old people......
- Need new gauges for my 91 electra glide, please help
- Backfiring through carb
- colors
- 2000 swingarm on a '96?
- Fitting new Andrews EV27.
- Is it time for new lifters?
- Bike Building
- 1990 FLHTCU Stereo Woes
- not starting
- piston to cylinder fit
- Tire dye or paint for WW's?
- Uh oh- extra part from carb? What is it?
- 94 Ultra classic accessories circuit help
- Thought I would share what my 86 FLHTC looks like now.....
- Rain suit recommendations
- Let's see you faces....
- Upated the ol'evo.
- Front jug squeak
- fxr battery
- Just great!
- starter--battery ??
- My Formal Evo Introduction
- Dang, and I was planning on buying one.
- Floating Rotors
- tach wiring help!
- Give me a brake...
- rear wheel bearing # for an 85 flhtc
- '84 FLHTC Front End Servicing
- 94 Fatboy Evo Price
- 2013 Dyna FXDB Street Bob Tins
- My 86 FLHTC has 4 gauges in the bat wing, is that right?
- valve cover r&r
- 91 Ultra Frame rust. Frame repair complete.
- 97 Springer Pinion Gear Removal
- battery
- Electra Glide Liberty Edition?.....
- pouring oil
- New Vibration?
- compression
- Calipers
- out in the open
- help
- AIM VPC on Evo
- Extra wiring
- Seat options
- Bad Vibration... help
- Pics of My New-To-Me 1997 FXSTC
- 86 liberty classic starter problem
- Good thread Old School vs. New School -post your thoughts
- The fricking ignition saga continues...
- Sold my '91 Tour Glide
- Tight inner cam bearing. 91 Ultra
- Meaning of engine stamp?
- To ride or not to ride
- Rode today......
- Pinion shaft nut torque?
- Pulled cam out without aligning timing marks...
- Base gasket oil leak
- 97 efi evo
- Anyone here on the evo forums run one of these rear calipers?
- Stretched Tank on Evo Softail
- Removing wheels 1997 FXDL
- Wide tire help needed
- Nice looking head bolts?
- Electrical troubleshoot
- Considering a 95 Ultra Classic.....yea or nea?
- Anyone use an EV38?
- 85 Fxr hesitation - surging
- Clunking noise
- 88" FXR build @ Tatro machine
- The (re)(re)(re)rebuild begins again
- 1988 Softail starter questions.
- 94 Wide Glide front turn signal connectors
- Cam or cam and valve job/springs/milling?
- I'm an EVO owner now.
- I want it!
- The End Is Near....
- finally got her running again...
- Transmission question
- Kees and Spanners do Custom
- Last non-Harley bike pics
- Valve train noise
- valve float
- 2 months since buying Harley 7000 miles fix report
- Speedo change
