View Full Version : EVO
- Awesome Evo, great story
- Anyone have experience with one of these?
- 1998 flstf voes or not?
- S&S V111 owners- A question
- Anyone in Vegas?
- No Tach, No High beam
- Transmission vent hose puking oil
- Fork spring question(s)
- 84 Evo 1340 fxrt primary leak/ super e carb tuning questions
- 38 amp stator upgrade 1990 flhtcu
- Cam sensor price check
- 1986 FXWG Original Flame Paint
- Running lean?
- Howdy
- Mystery thrust washer
- 1987 Evo motor build up questions
- Relay for Starter Button
- Kuryakyn Forward controls 97 DL
- Can I remove this bolt?
- 2000 FLHTPI No Spark
- 87 FLTP.....the UGLY project
- Dead rear cylinder
- 93 fxdl Cracked head pipe
- 1994 FXR | Upgrade List
- New
- Dynatek 2000i ignition install
- 85 evo compensator stuck
- Starter change
- Unknown switch and plug
- 1987 Primary help needed
- 1998 fatboy 21 X3.5 tire size
- Uneven idle
- Intro
- High beam diagnosis FLTCU
- Running lean
- 84 1/2 mods/upgrade
- AMCA Event.
- 1999 fxstc
- Oil for S&S v111
- How can tighten my Jiffy?
- Need some help with first evo engine build!
- FXR question
- My 1998 Electra Glide Classic budget tourer build
- Oil out of breather holes in heads
- 1984 FXRS Belt Drive Conversion
- Twin Cam drivetrain in Evo frame
- Evo Heads
- Chrome tank trim on 95 evo superglide
- 1998 Evo Dyna wide glide transmission fluid check
- Shake down ride, 1989 FLTCU
- STIFF clutch lever
- A new motor mount will cause my vibrations, right?
- 32448-95a
- Found a puddle of oil this morning
- Oil lines removal
- Guys with v111 can you double check my oil line routing please
- Rear Pulley
- Found another one...fairing ????
- Killin time with mods.
- 92 FLHTCU cam opinions
- Has My Dyna Had The Cams Replaced?
- One is never enough .... incoming 94 FLXR
- Those 4-pot brake caliper adapters
- Headlight sanity?
- twins i got twins
- Evo #,s
- 1990 FLHS Ignition System Replacement
- my fully built, 1990 FXRS | taking care of business
- 87 FLHS.....anything bad/odd with that year?
- Seat Fitment Help
- Cool Pic In Kentucky's Hidden Secrets Magazine
- 95 FLHR fork /rotor / caliper cover kit question
- WEGO file
- Im very sorry...
- Front turn signal loose
- Any reason to update my crankcases?
- New to me FLTCU
- 1990 flu battery cable routing
- Wiring Diagram Needed - 88 - 95 FLH Radio
- Voltage drop in fairing 92 FLHTCU
- 5” Speedometer for 1998 Wide Glide?
- 99 Softail starting problems
- Extended brake pedal job
- Rocker box bolt kind of gnarly....
- Anyone running pm 6 pistons?
- User/Seller TexasHillCountry
- Fuse box
- What to make of this?
- Willy G 3 hole derby and timing cover?
- Brake fluid questions
- True duel exhaust
- Adjustable pushrods in unfired engine
- pushrod question
- Long time coming. My S&S V111 Thread!
- Will dash fit 89 FLHTCU
- Tripmeter knob screw 87 FLTC
- 1996 Road King fuel injected check valve
- Magnetti Marelli bikes- stay away??
- Are all FXR frames the same?
- Why Roller Rockers....
- Wheel bearing options
- Picture of right side turn signal terminal
- 1984 softail evolution
- I have a 95 super glide wondering if a 99 super glide 2 into 1 will fit on it
- Updating an old radio
- What do you guys do for oil lines? 1990 flhtcu
- Dyna vs Touring engine?
- Crankcase vent/breather after installing hypercharger
- Touring pack and sissy bar hardware
- Drag pipes
- Fuel sending unit and gauge
- 96 Nostalgia
- Renting bike for a day in Phoenix. Route suggestions?
- problem with performance machine calipers help
- Wheel upgrade '84 Electra glide
- Tach finally coming
- What are these extra clutch parts?
- First Harley = Lots of problems
- What do I need to use late model spoked wheels on 1990 flh
- Derby cover part number
- Screamin Eagle 2 into One Exhaust
- what was in my breather
- FXRS Shocks
- Texas EVO meet up 2019 planning thread
- Help with my harley
- Titan Clutch
- Breathers
- Tina's Dyno
- Went For Compression Releases And...
- 91 FHLS/FHLTC New owner 1st harley!
- Model/Year differences
- EFI oil vent to atmosphere
- Speedo sensor for an old Softail
- How do I know if swingarm bushings are bad?
- 89 FLHTCU carb has been swapped...
- 1987 FXR wiring issue
- Transmission rebuild
- 94 dyna wide glide front brakes.
- Front cylinder not firing
- 1998 heritage softail classic front fender
- S@S oil pump
- Illinois Newie
- 1998 EVO Fat Boy larger front rim
- Camper rental question
- Engine stabilizer links...when to replace?
- Rear Axel Lock
- Primary leak FYI
- 94 FXDS-CONV insurance ?
- Running lights mod completed
- Front motor mount
- Rocker box bolt copper washers
- Convert to LED turn singles
- Switching to running lights.
- gma rear brake kit
- EVO Kicker conversion
- Woods W6H Camshaft
- oil change on 86 FLST
- Adapting a Head-Breather Style Big Sucker To My Bottom Breather
- FXRP tank console suggestions
- got a evo
- Considering this 1990 Springer
- Kickstart kit problem
- 1999 Night Train petcock filter
- Bassani 2-1 black
- New Wheel mod
- 1985 Wide glide 4 speed tranny
- Front Brake Lines '96-'07, '08-'14 Touring Differences?
- How much mileage on an evo is too much for you to buy it??
- Road King Would Not Start!
- Petcock
- 92 fxr
- 1998 fatboy rim size
- Front Signals
- 96' Road King Cam upgrade with MM EFI
- Another Barn Find 1998 FLHRCI
- Bike running rich
- Jetting thoughts
- 1996 softtail speedo/odometer not working
- So I've getting some decell popping lately.
- Looking for Detachable Tour Pak Rack.
- 1 3/4 drag pipes
- Shifter fork shaft
- 1985 Wide Glide (FXWG) Mirrors
- I realize I don’t have my EVO yet. But.......
- 96 FLSTN Newbie
- Suspension???
- Getting up close and personal
- Rear brake light dimming
- Performance build questions! TC 88
- 1985 FXWG Tripple Tree Screws
- '95 Road King Headlight Cowling
- Barn Find 1995 Evo Classic Uncovered by HD Forums Member
- Rear fender
- Breather tube on back side of cam cover?
- Throttle cables carb upgrade
- crank oil seal - sanity check
- Harley Christmas
- Difference between inner primary?
- trike
- Merry Christmas My Biker Friends
- 99 Heritage not firing on rear cylinder
- tour pak quick release docking hardware
- New Cases....
- idleling just to listen to it...
- Help identifying cam and ignition
- 1994 Road King, Ingition Switch?
- Acr wiring questions?
- 97 dyna cylinders
- Voes
- Anything I should do with bike after sitting for a while?
- something missing
- Oil seal replacement on Main drive gear
- 95 Road King Front Air Ride
- FLTCU and a FLHTCU?
- Wide Glide
- '85 FLTC Turn Signal Operation
- 97 fxd turn signal question
- 1990 Fat Boy, BUY/SELL???
- Single disc conversion
- 86 FXRS Failure......
- New starter going in!
- 88 FXRS electrical issues
- Base gaskets leaks
- What kind of Pistons, rings and gasket set should I buy?
- Advice needed on top end rebuild
- Clutch Cable Routing
- Electrical no power
- memphis shades road warrior fairing on an FXR?
- I fixed the dreaded Evo click
- Posing another motor question?
- Regulator fried my stater?
- Inherited a 94 fatboy
- 1990 FLHTC Inner Primary Case Interchange
- rebuilt motor weeping base gaskets
- Regulator Time?
- I’m coming home.........
- Q: Saddle bags and supports ’98 FXDWG
- 52 Slow jet
- Wheel fitment
- Oh for the love of all things holy.... 89 EG
- 97 Evo RK Swingarm Upgrade
- Exhaust for Big Motor FXR
- Old question; new answer
- One more question...oil in intake, bottom breather
- Help me buy an ignition
- 18x5.5 wheel on 1987 FXR
- TourGlide wiring fun
- Starting to understand my old bike.
