- Jet Recommendation
- Shipping a bike across country
- Exhausted....
- finally getting some maintenance done
- 88 softail question
- Female footpeg options
- Starter problems on an 84 FL
- when did they stop making harleys with evo
- Fat Bob stock fork tube length?
- engine swap
- Cometic gasket differences?
- 1990 FLHTP wireing help
- Speedometer
- popping on deceleration
- 89 fxstc oil pressure gauge blew!! help!!!
- Why maintenance is important
- exhaust; whitch why or who gives a
- Any Suggestions...
- Loose Head Bolt
- New Ride
- New Evo Owner
- 1997 flhp....spend my money please!
- My '96 Fatboy (& 'what is this?' question)
- Led conversion 1998 flhr
- Little help
- Radio switches?
- Score!
- speedo conversion
- EFI to Carb Conversion-Won't Start
- Stator Plug Install Challenge
- Ignition switch decals?
- 85 FXEF what's the market like?
- Separating cases
- Tappet screen bolt
- 1990 softail oil change
- Primary noise
- 96 Fatboy caliper upgrade advice
- The clutch basket on my 1988 moves up and down about 1/4 of a inch 1988 fxrs
- Need some help from my European brethren.
- Locking down ape hangers
- Drag Pipes for 84 FXST
- How do you change turn signal sockets
- MM-Carb Gas Tank ?
- Softail Board Scrape
- Ignition Coil Wiring
- Starter sticking no start puddle of oil
- Decisions... 111 or 124" s&s
- 2002 heritage softail wont start
- Score!!!!
- 1988 fxsts
- S&s 111
- Tapered wheel bearings clearance
- Transmission oil leak
- 1992 fxrt
- Rear caliper brake line fitting
- Oil line connection questions
- 1984 Softail - Frame up build
- Throttle not snapping back
- Ignition mods
- Back in the saddle after 4 years
- redid cv swap with cv intake...now problems
- Broke the ice on 2017
- Fxr primary
- Tank Sealer
- Oil line routing question
- 4G93 GDI 1.8 NA Compression Test
- 1994 Fatboy Brake Upgrade
- From 60 to 30 in 24hrs
- How Far to Go?
- you know Eddie Van Halen is cool...rockin an evo
- Bike Dilemna ?
- slow cranking
- Bolt on performance, help spend my money
- 1985 fxrs
- Scored a Corbin riders bacrest....
- EVO top speed?
- Run out of Gas tip from my Mechanic
- 86 flht remove tour pack and add solo seat
- Day tech frame
- Coil
- Heavy Weight Shock advice
- FXR: Shovel or EVO ?
- Turn Signal Short
- Hard Cranking
- accel parts
- Mechanical speedo cable
- WEGO 3 installation
- Softail Wiring Question
- Looking for a new fuel tank?
- 1994 Ultra stereo upgrade questions
- S&S vs 2007 Harley Carb for 92 Softail
- Burly Boys EZ Clutch
- Butterfly carb choke spring
- Tire Pressure Spoke Wheels
- Instrument bezel
- Oldest Harley Rider in the USA.?
- Batwing fairing
- 1989 Flhtc- where to mount 30A main circuit Breaker?
- 1998 FXSTS Ignition Switch
- Intro your Evo
- Bike stalls at night when I put turn signal on.
- 1993 FXDL Broken Crank
- Score!!!
- Question about a batwing
- 41mm fat boy front end on a 1992 softail
- Went for a ride around the hood
- New EVO guy here need opinions
- Strange turn signal problem
- thinking of getting a EVO Roadking/Elektra. Which years to look for?
- What is this thing?
- Figured Out My Pingel Fuel Valve.....
- Figured Out My angel.......
- Seat compatability?
- What mileage do people get from their EVOs?
- size of mounting bolts for highway pegs on a 91 fxlr?
- Front suspension question
- shaving mech speedo drive??
- Primary fluid level?
- why evos
- big dog evo 117 motor in a fat boy
- New to me Softail
- eBay 5 gallon raw tanks
- Lifter noise
- EVOS For TRUMP
- A Fatboy for a Fatboy what I found
- 98 Road King EVO w/EFI
- 1998 Heritage Classic Value/Should I Buy?
- Dyno
- What size are the headlight retaining ring screws?
- Proper Factory Service Manual?
- EVO - Miles on Reserve
- 99 Electra glide radio
- Northeast EVO Meet-up 2017
- a few pics to share
- Shocks - 1984 Softail
- Soft King
- How do you remove the oil pump shaft bushing in this situation?
- Crane Hi-4 single fire ??
- So the tear down starts...
- Got it by the shifter bug
- 1984 Softail - basketcase
- How much air goes into the suspension
- Cam swap started today.
- Fork oil equivalent
- Where have the evo's gone
- 2011 Leather Bags on a 96' Road King
- Gas Cap Removal WTF!!
- warm winter
- EVO Newbie here: Looking at a 97 FXD
- Ultima 127 questions
- New Evo owner
- Replace 2003 revtech 100 Evo motor
- Ebay high torque starters
- Back up on two wheels
- Lifter block gaskets
- Anybody ever have to machine down a speedo drive?
- primary chain inspection cover ???
- Harley-Davidson faces suit in Marshall court
- Bars - Handlebars that is - what is required?
- Fork Oil
- Excited
- Evoing Again
- Another EV27 post
- Texas EVO Meet-up 2017
- Cam Gears
- Tires (Again)
- 1990 FLTCU teardown
- Is there a another part number for the nacelle trim piece?
- "B" Lifters in 1995?
- 1985 Fat Bob gear box
- Fork oil change going disastrously wrong
- EFI to Carb Harness Parts?
- 1984 Harley FXRT Primary, Enclosed Chain Questions
- Inner fairing
- Question about wheel bearings
- throttle lock from the factory?
- 11 days 3,482 few pics
- Anyone running tubes in there cast wheels?
- Evo torque and horsepower
- lights
- Looking for MM to Caeb thread
- Light Harness Grommet?
- Building My Winter To-Do List
- 2017 wishes
- Took my beating but accepted the action
- New HD Vin sticker?
- New to me flhrci
- Got to chopping
- Tsm
- ok...you guys been lots of help before....pinion bearing?
- Best seat ?
- 97-99 Fatboy rear fender cutout
- EVO Electrical - Intermittent Signal Light Always On
- Doing some winter clutter clearing
- Comfort on a Fatboy for a fatboy
- Primary Swap......
- Started the swing arm upgrade
- Christmas rides!!!!
- "o"ring
- Merry Christmas Evoland! What are you getting for your EVO?
- 94 Ultra Stock stereo replacement?
- I got twins for xmas...how 'bout you?
- !!! New Shoulders required urgently. !!!
- 3 Hole Oil Change on EVO - Tough!
- question about cam upgrade on an 1988 softail 1340 evo
- Trying to Identify Transmission Type - 1984 FXRT
- The Evolving EVO (Brakes)
- 1994 Heritage Special (Moo Glide)
- pinion bearings
- 1985 4speed kickerbox with excessive shift play
- Evo compatibility
- New seat options
- Braided oil line leak
- Ez clutch ?
- Bagger Brace - Terrible Customer Service
- Saddle bag spoiler lights
- wasted money
- Repainting my engine.. What paint to use?
- 1996 FLSTN Foward foot rest
- Dyna gas tank mod
- FXR with 113" S&S Motor
- What's everybody have in the works for winter projects?
- Fairing Speaker Mount
- brake light problem
- power cones
- Winter
- Clutch / derby cover ??
- Having trouble catching neutral
- Trans Vent
- Won't start after outer primary change
- 2 Questions one thread
- Fork spring question
- 59260-68 Lamp Kit
- 84 Harley FXR Solenoid Removal
- Weird Ass Evo cylinders!!
- Escaping from the 90's
- Swingarm Upgrade
- Evo Addiction
- Gas tank fitment.
- 1986 FLT transformation
- 1998 FXDL new or custom rear fender
- MM-EFI to Mikuni HSR Carb Conversion 96' FLHTC
- 1993 heritage soft tail
- 84 Harley FXRT Wiring Harness Question
- 1986 tourglide wiring
- Happy Thanksgiving
- Zipper performance kit?
- 86' fxr
- 99 evo timing
- 1990 FLHTC trunk removal
