View Full Version : EVO
- Shock bolt fell out
- I just changed a front tire
- Question about mikuni hr 42 carb
- 1994 fxr
- Searching for 87 fxrc speedometer
- Throttle Cable Issue
- 96 Ultra Classic - International type ignition switch
- Touring control replacement buttons
- More Evo's...
- 96 ultra classic - mufflers and other isdues
- Can sumping cause damage??
- 2023 Bike Week picture dump
- Evo 5-speed Primary Belt???
- Simple Vibration Fix
- Blub, blub, blub...
- Ultima 6 speed builders kit - is it worth it?
- Front fork rebuild
- Went from EV27 to EV13
- What is this cable/harness?
- Shocks, 1991 Ultra
- HardDrive oil pump
- How to jack up a 1998 Wide Glide
- Throttle cables
- Clutch Adjustment Issue: Ran Out Of Cable!
- Speedometer/Breakers
- Clutch Issue—cable fell off (thread)
- Some oil pressure but not enough
- Breather valve thrust washer ?
- Why is the cylinder torque sequence the way it is
- Slip-on exhaust for a stock, carbed ’95 Road King, ideas?
- Machine shop in socal?
- FLH exhaust question...
- Head gasket
- Alignment
- Buddy seat on 96 FLH
- Dropped bike on low speed u-turn…
- Differences between Cali carb and other states?
- Pretty 95 FXSTC on BaT.
- Relocating the stock oil filter mount
- 1998 EVO FXDWG Choke questions
- Where is VIN number
- Anybody try those Ebay 83" Evo kits?
- EVO with top breather making gerbiling sound
- Breather has oil pouring out on start uo
- Retrofit ‘Detachables’ ?
- Johnson Hylift Instructions ?
- Progressive shocks
- FLHS swingarm mods
- EVO engine case drip
- 95 FLHR Freshening-Up
- 89-99 softail master cylinder location
- Evo Dyna Jackshaft Problem
- Wiring Problem?
- 1999 softail evo not idling
- Cam whine noise normal (video)
- Do you see any potential structural issue?
- Rear Fender Trim Rail
- Hang on to those Evos!
- ‘I FLH fwd floorboard bracket.
- Oil tank vent
- EVO starter solenoid rebuild
- Base gasket leak suddenly much worse
- Ultima Transmission vs Stock for Performance
- Powder coating fork lowers
- Faux Pogo.
- 95 FXD Died while riding
- Starter Installation
- Discoloration on the chrome and motor after the fire.
- Evo original vs Crate
- 96 ultra classic - weight inside batwing fairing.
- S&S 76cc replacement heads and 0.045 gaskets?
- 2005 clutch basket in a 1990 softail
- 95 Road King Y header
- primary oil transferring into crankcase
- Having a tough time finding Stepped Drag Pipes
- Happy New Year
- Alma's progress report
- Identification problem
- 93 FXLR rocker box leak
- Ignition Module Woes
- Merry Christmas To the Evo Group
- heritage special nostalgia 1993
- Harley Battery vs. Rest
- 1990 Ultra Classic 14" Apes
- Exhaust Bracket Removal
- Eyeballing a 1989 FLHS
- front fork tube 1984 FLHTC early.
- Oil Dipstick Temperature Gauge
- Update on the 1999 FXSTS
- EV13 in ‘93 Dyna - looking for others with the same setup
- What's the "bad" about early EVOs vs Later
- Electra Glide Classic 1988 external rusty tank
- Restoring my lovely FXDB 1991 Sturgis
- Horn only works when running
- 1984 FLHT instrument cluster
- Need a single page from 1998 FLT Service Manual
- Springer frontends
- Need info on 1987 FXRS-SP
- 1996 Ultra Classic battery capacity
- 1996 ignition switch removal
- Found a keeper
- Evos Can Still Hack It.
- Non suspension front end
- Need EVO motor rebuilt
- MM to Carb Wiring Question
- Dynamic Timing
- 1986 compensator spacer
- Same dimensions question...
- Troy's 1985 FXSB Low Rider !
- Wheels/rims...
- Starter thrush washer catching
- 1999 fxstb
- 1990 Grey Ghost Registry
- 113 SnS rebuild..
- S&S forged Evo piston ?
- 1998 Wide Glide
- Front shifter shaft breaks
- Sudden loss of compression
- What should I list my bike for?
- Question about a '97 FLHTCUI Ultra Classic
- Road king front shock fluid
- Maiden voyage
- 1985 FXWG Wide Glide
- Evo head change
- Need some help
- trike
- Need some thoughts on an ignition problem
- 1990 flhs turn signals this time.
- Starter noise and smoke.
- Police seat conversion - plastic cover screws
- My Highly Technical Post of Highly Technical Information
- Now this is funny - they dumped the evo in with the old machines
- LED Dash Lights Source after LED Conversion
- What am I doing wrong here
- Cam Cover Bush
- 1986 rear fascia
- Are these hard to find saddlebags
- What’s this taillight from
- Replacing old keihin 40mm butterfly carb
- Leaks at every gasket
- Torque Cones can they minimize the drag pipe sag?
- Hand Brake lever switch
- 92 Flhtc Fairing conversion
- 85 wide glide
- Brake wiring on 85 FXWG
- Biketoberfest 2022 picture dump thread
- What happens if I lower my idle speed?
- Backfires on decel and dies after 3/4 mile
- Oil light is on
- Top Speed
- 1997 fatboy wheels
- Can clutch hub be saved?
- 86 is running
- Harley Top End Rebuild Flat Rate Times
- Mikuni carb too much for stock 93 Nostalgia exhaust?
- Burn run
- 1984 FXRT Transmission Question
- Front suspension
- Centre stands
- 97 wg - elecrical cut out
- Depin FXR harness
- Acceptable whine?
- The Most Powerful Reason to Own a Harley Davidson
- M8 shocks on Evo
- paint colour
- 85 Evo Case Studs
- Run off the road
- EVO Performance
- Clutch problem?
- Stock length fork tubes 89 flhtc?
- Starter stays engaged even when off the bike.
- New here
- Flhr cust out at low speeds
- Mechanic in NYC/LI near City?
- Red Reflectors
- What’s brand pistons to use
- Electrickery problem!
- Sensor pinning 1991
- can someone help me identify this cam 088628
- 1991 FXRS rear turn signal woe
- cop seat
- Shinko tires...
- Push rod adjust, warm or cold?
- Installing new pipes - will I need to adjust my carb?
- Andrews EV13 cam noise? 1340 EVO
- Brake light wiring?
- Rebuild bottom end cost . . . ?
- Turn Signal Issues on FLHTC
- 1990 electraglide sport dying at high rpm under load with low battery
- Ignition kit for 93 Softail with kicker
- 89 Electra glide clutch loss and now starter just spins
- How to Fight the Law
- Cane you name this part
- 1996 road king efi 1/4 tank bike stops
- 96 fxdl starting issues
- 1999 Softail Night Train Fork Question
- Need to replace the stock handlebars on my 92 FLHS
- 91 FLHTC Charging prob
- Oil pressure guage
- 96 flhtcui stator question
- Valve stem seals
- Stock fork tube length?
- REDUCED EFFORT CLUTCH KIT fit in an evo bike from 1993?
- 1984 FLHTC carb
- Is my ignition coil defective?
- Fork tubes
- Blowby and oil consumption
- Help me out fellas
- FLHS Electra Glide Sport How do I remove instrument cluster to adjust handlebars?
- Clutch sproket
- Primary leak
- 93 low rider electrical gremlins s
- Evo softail
- Forward controls and exhaust
- Engine Case Bearing Assembly Red?Blue?
- Front tube length?
- 883 1200 swap
- Main shaft key
- Shifting issue
- Torquing Engine Trans Bolts
- Voltage , Charging ?
- Right/Left hand threads
- Non resistor plugs
- What's your method for rear wheel alignment?
- Another cam question
- Evo dry clutch
- Evo dry clutch
- some iron filing from case breather hose
- ‘99 FXR shifter shaft sleeve replacement
- EVO MOTOR UPGRADE. Would this be considered Stage 3?
- Chirping noise...
- Easiest way to trim down a windshield?
- Any of you swapped a rear brake rotor?
- Occasional puff/pop from carb
- 17th Harley, First Evo, some questions
- Harley Davidson FXR Lights on, Clicking, Cycling, and Not Starting (Don't think it's the dreaded click)
- Side play in oil pump drive gear?
- Pistons: forged or cast?
- Wind Buffeting
- Inner primary
- Motor seized
- Screwed up my paint job
- Picked up a 96 springer, had some questions
- Rear axle break on 1994 sportster 1200
- Lifter Question
- Ignition module
- 98 superglide forward controls
- Speedo flutter
