PDA
View Full Version : EVO
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 [53] 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79
  1. Traildogs 6 speed
  2. drunk fool
  3. '96 Evo Suggestions
  4. Electronic Ignition for Evo Engine
  5. Back cylinder not working
  6. Help id this speedo
  7. Was This Your Bike in Brookville, Indiana Today?
  8. 85FLHTC Suspension upgrade and lowering
  9. The indestructible evo?
  10. Seat Question
  11. Found the friken rattle......
  12. 87 FLHTC - Want to keep original radio but...
  13. Got my new oil sender
  14. Electra Glide in Blue (and some Birch White!)
  15. 86 Harley Evo 5 speed transmission question
  16. vibration
  17. 91FLHT front end on an 85 FLT?
  18. vibration at 4500
  19. Hd vin
  20. Won't start after car wash
  21. S&S carb help
  22. HEY! it covers the beat up fender...........
  23. Electra Glide handlebar wiring help..
  24. Color SAcheme 1991 Heritage Softail
  25. Replacing petcock, stock or "hi-flow"
  26. Lowering Kit
  27. oil pressure gauge for 98 flhtp
  28. black and round
  29. Misfire under load. 85 FLHTC
  30. Help Me PLEASE!!!
  31. 92 FLHTC need tech help - coil
  32. Big Bore Kit Questions
  33. FXRP Saddlebag measurements?
  34. Lights flickering
  35. Another FNG question! Fuel valve!
  36. Motor just stops,no spark
  37. starting issues
  38. Coffee Break...
  39. What's the diff between 92 & 93 FLHTC's?
  40. rear wheel
  41. Hi Guys
  42. time to finally tear down
  43. Need your opinion
  44. How do you know when to rebuild carb
  45. Run/Turn/Brake module question....
  46. 87 Electra Glide fairing removal
  47. i couldn't stand it anymore..
  48. Passing Lamp Issue
  49. motor identtification
  50. Head Pipe Glowing
  51. Higher wattage H4 ok on '96?
  52. How much rear suspension travel do I have/can afford to lose?
  53. ya dont see too many of these
  54. Puddle on floor
  55. Will 2011 headlight fit 1998 FLSTF?
  56. Bearings and axle gaulling
  57. Aftermarket carbs
  58. 95 Nostalgia misses intermittently
  59. All dolled up and no place to go.......
  60. Hayden crankcase relief valve
  61. FLSTF lowered to standard
  62. Polish
  63. Rear Brake pedal 98 Fatboy
  64. Jiffy or Center?
  65. Bertha has TAILS again.......
  66. a little air cleaner help please.
  67. Anyone with 99 evo?
  68. Question for you EVO gurus.
  69. Chain conversion
  70. Rejetting S&S Super E carb
  71. 1st RIDE REPORT
  72. Rear wheel bearing thread?
  73. Removed License plate hoop, now fill with what??
  74. New bike added to stable
  75. 91 FXDB-S Sturgis
  76. question about 21 inch front wheel...
  77. LED Headlight
  78. Be Thankfull
  79. Well I pulled her guts out last night
  80. Turn signal help needed
  81. Plastic gaskets?
  82. For all DIY mecanics..brakepads!!
  83. Its Been Fun
  84. How to tell difference in headpipes?
  85. A little help please......
  86. 93 FXR starting problem...help!
  87. Oil coming from air cleaner
  88. ditched the return cable... now grip is sloppy
  89. Oil sending unit or gauge?
  90. Smallest Evo air filter?
  91. 84 stator issues?
  92. Legislative Days - Ride on the Capital
  93. HF Tow behind trailer
  94. cam bearing puller
  95. turn signal upgrade help!
  96. stress lines or fractures in cam cover around cam opening
  97. Powerlet or other power gloves or the infa red inner gloves and heated outside glove
  98. 80" Evo Build
  99. Converting to Magneto Ignition
  100. Seeking Kick Start Conversion for 5spd. Evo
  101. No sound at starting
  102. FLHTC wheel question
  103. parts source
  104. Texas meet up?
  105. Hayden oil fix, pigtails, or James metal base gasket
  106. '97 FXSTC is slow to start ???
  107. Spring Solo seat?
  108. Hayden Oil Fix
  109. Finally "finished" my '96 dyna glide convertible
  110. Changed the whole look
  111. Crankcase Breather
  112. front fender badge and trim
  113. Any options for 1997 EFI Air cleaner swap
  114. Running into another problem with my 1992 Ultra
  115. 1994 road king seat and pillion
  116. 1988 FLHTC questions
  117. Swithc replacements...what to buy?
  118. adjustable pushrods
  119. 1996
  120. Time for air ride
  121. quick disconnect for bags 93FLHS
  122. Gas leak from the Carb (Help/1992 Ultra)
  123. CV Carb parts sources?
  124. S&S Jet
  125. top end rebuild .
  126. exhaust installed
  127. Bit of a quandary
  128. Shorter Softail rear fender struts
  129. $$$$$$$$????????
  130. shocks
  131. Been Busy
  132. Anybody running a magneto on an EVO?
  133. getting ready to "push the button"
  134. sparks plug wires.
  135. crank case blow by
  136. Speaking of LED conversion
  137. Badlands signal canceler
  138. pushrod adjustment
  139. throtttle not snapping back
  140. Where ya at map.
  141. Vee-4 Evo: Opportunity of a Lifetime?!
  142. Some good info
  143. Tappet sources?
  144. Oil Pressure Switch Help
  145. Exhaust problems on my FXR.....
  146. sprocket shaft oil seal leak
  147. Front brake master cylinder question
  148. Evo Party!
  149. Alaska For Three Years!!!
  150. Brake Calipers
  151. 98 Springer 844 miles
  152. fuel gauge
  153. Second guessing clip install
  154. Engine Swap for MM Efi FLHR
  155. Stock Handlebar Measurements
  156. 85 Electra Glide headers needed
  157. '92 Fatboy engine questions
  158. Crankcase Bolts?
  159. Bad exhaust fumes when pulling hill, etc?
  160. hand control upgrade question
  161. DAM**T Ring compressor!
  162. Engine painting going well.
  163. Can gaskets be installed upside down?
  164. Two relays
  165. Evo lifter tower
  166. 95 FXSTC shock upgrade question
  167. Black Switch Housings for 95 Road King
  168. Weather perfect!!
  169. Can anyone tell me if it's OK to powdercoat AFTER the cylinder/heads have been
  170. Fuel Efficiency Concerns 1997 FLHRI
  171. Engine won't return oil when hot????
  172. More cam help
  173. Oil filter hanging by oil lines-FYI
  174. 1995 Electra Glide transmission fluid change
  175. 1997 FLHRI Not starting
  176. 1983 Harley XLX 1000 - $1500 Good to Get?
  177. Hooker Headers
  178. Problems with Ev 27 install on 98 Evo
  179. Dual fire or single fire?
  180. 1998 Evo Softail idling on one cylinder
  181. Cold temps cause oil seepage?
  182. cranckcase crack
  183. Ultima Roller Rockers?
  184. Electrical Help!!!!
  185. Explain SA&S Super
  186. Moto Gadget wiring M unit
  187. tourglide windscreen size
  188. Ignition update 84' Evo?
  189. Evo cam bearing
  190. 1st year fatboy
  191. Pushrod adjustment
  192. Best Spark Plugs
  193. Fxrs fuel tank venting scheme
  194. stripped drain plug
  195. Clutch Cable Question
  196. Bolt on part recipe for max torque?
  197. 1997 road king spitting and sputtering
  198. 84 fxrs rear cylinder smoking weeping head gasket
  199. -83 Ignition rotor question (carb conversion)
  200. Evo ...Best oil for engine, primary and transmission.
  201. 1985 FLHTC Drive Belt Replacement
  202. Jumping My Jets up a little. Suggestions?
  203. transmission upgrade questions
  204. Tear down....Here we go!
  205. Took my primary apart...which spacers go where??
  206. 1986 HERITAGE WIRING LOOM question....
  207. Crane 8-3101 Hi 4E Ignition Module Wiring
  208. Fxr engine mount hardware
  209. Fuel tank cover for 1989 FLHTC
  210. Rear Turn Signals
  211. Getting ready for the gasket fix!
  212. Pre 1993 Evo Era Saddlebag Lid Tab
  213. I think I let her idle too long.
  214. passenger speakers will not shut off on 96 flhtcui
  215. 1982 Sturgis
  216. Value of 1994 1200cc Bobber?
  217. Ebay Andrews EV27?
  218. True duals
  219. Cam upgrade
  220. Reihart pipes ?
  221. Merry Christmas my biker friends
  222. Tour pack quick release help
  223. Clutch skip
  224. NEW FENDERS FOR MY 90's FATTY
  225. cam bearings ?
  226. 1987 Electra Glide seat question..
  227. Hooker Four-bidden 4-1
  228. Pinion Shaft snapped EVO
  229. I need help on finding year model.
  230. 1991 fxr 5 speed pulley change
  231. 1340 build
  232. 89 EVO Engine
  233. Clutch slippage
  234. Don't ignore that new ticking sound!
  235. independent wrench ct?
  236. Ignition module question
  237. Carb conversion questions?
  238. 1990 FLT ex. Police
  239. Could use new starter recommendations
  240. Turn signals
  241. Second alternator failure in ~9K miles
  242. 1990 FLHTC guages not working
  243. My Winter Project - Rebuilding the ol' Evo!
  244. Gray and damp December day.
  245. Dyna tank on RK?
  246. I need some starter help.
  247. FXSB Tranny Problems
  248. Retro fitting signal canceling
  249. Idles great but dies when you go to take off
  250. Twin cam ign harness for MM EFI conversion?
