View Full Version : EVO
- Tach not reading right?
- Anyone know anything about Pingel petcocks?
- Just Sharing
- Sparkplug wires
- 1997 Bad Boy 262k miles
- Is this a Stage-1 Air Cleaner ?
- Denso Starters
- 90,000 Miles and still kicking
- Carbs
- Spark Plug Wires
- Gas tank swap
- Evo stumbling,spurratic fart 'n small flame
- Rookie move now what?
- Kees lied to you!!
- Please Take a Look at My Engine Build
- Great pics of New Zealand roads
- Engine starting to miss, Ignition?
- Sometimes, its the little things....
- for my own sanity
- evo power options ?
- fxd 1998 seat
- Starter Solenoid
- Self-canceling turn signal and/or cruise control an option?
- Exhaust Gaskets
- FXRC to FXRT?
- Turn Signals
- Cruise Control
- 89 FLHTP rear wheel axle free play .002 percent
- fxr thunderheader mount
- 1998 FXDL - Valvetrain Noise
- Quick wiring question
- Are fxsts and fxst rims different
- Creaking Sound in Steering Head
- Check your brake lines
- Totaly stumped on new engine issues/symptoms
- new carb and ignition.......
- 89 keihin carb to super e...throttle cables?
- Fixed electrical and the front brake lever issues ...
- '92 Parts manual
- how do u install a main drive gear seal?
- Oil cooler kit
- Any way to tighten up the passenger foot rests?
- gas smell
- Its time to give the old girl a new look.
- Exhaust Question??
- Question about suspension
- Drop seat kits for late Evo baggers
- Shovel wheel on EVO crank
- Have a Happy Thanksgiving my EVO friends
- Exhaust leak, smoke, bluepipe EVO Heritage 1999 FLSTC
- Upper front brake caliper bolt thread
- Crush gaskets in exhaust (balance?) pipe -how?
- The King has a new Buddy
- leaking transmission oil again!!!!!!!
- Is it OK to start the engine in first gear?
- What is the difference in the wiring between FLHR vs FLHT?
- EVO Crate Motor 1999
- Pretty............
- Lucky? Me....
- Setting the Timing with a Timing Light
- My '97 dyna is making a bad sound...
- Front end swap
- XR1200 rocker covers on an Evo Big Twin
- Rear Brake Rotor?
- Got bike apart need input *pics*
- Recovering the seat vs replacing
- How big is my motor
- Rocker Box Gaskets
- Bad VOEs
- showing off finished project
- What would you do? Dot 4 in a Dot 5 system
- Need schematic for late 90's softail-ish
- Whats the Top Speed of your Evo ?
- Battery and cable upgrade
- Derby Cover Gasket or "O" Ring ?
- Frame Changes on Evo Ultras
- Flying Wheel Horn Cover
- Head gaskets
- Woman Divorces Husband in Hopes of Marrying Kip Moore
- Here's a dumb tire question
- Brake fluid mess up
- COLD! knees on FLHTC Ultra
- Evos with FI
- Cleaning out can sensor crap
- Why do I need a battery?
- Adjusting Idle Mixture on a CV carb
- Evo rebuild underway...
- Brake issues continued
- Pic for TD
- broken lowering bolt on 99 softail
- The faded LCD Odometer fix thread
- footboard bracket keeps two into one from going on
- Carbon deposits inside manifold - Normal?
- FXRT Fairing Information
- Me and my 99 Softail Custom
- 1998 fxdl - Finicky on cold start
- evo vs twincam header question?
- Electronic odometer problem
- Tansmission oil leak
- Ignition question (advance)
- Hard wire ignition module or sell?
- heim joint
- HELP! cam came out with nose cone
- Experienced oldschool Shovelhead owners (Help Please)
- Putting bike away for the winter.
- Ignition timing and backfires.
- I should be taking pictures : Winter odds and ends
- UK and 27 tooth compensator
- Little help please
- Clutch issue maybe?
- HarDlife????
- Need help diagnosing
- Winter Project
- Noticed a front end rattle,could brakes be culprit?
- Fuel dribbles out of nozzle after bike sits for a few minutes
- A junker..
- Exhaust question
- Can you forgive me
- My New Ride
- I need a lift...
- Bought myself a 97 RK
- fuel sending unit
- Post Here if You Had Issues After Changing To Synthetic Oil in Your Evo
- Do I get nominated for sainthood?
- Gas Tank upgrade pix?
- oil filter
- Diagnose interior of exhaust manifold? FLSTC 99
- 85 Wide Glide Price
- cutting stock pushrods
- Total Lucky Score!!
- Is there another way to change the fork oil?
- noise behind timing cover
- Front-end Rattles on Rough Roads
- Will static-timing get me down the road?
- Figment question
- starter pinion gear stuck
- Mobil-1 V Twin is the Real Deal !
- handle bars
- Highest miles
- Where's D_Gyver?
- Rear Spark Plug Still Fouling Out.
- 94Fatboy
- Are Harley turn signals cursed?
- HELP ! Need advise on S&S Air Cleaner Install
- Seat options?
- Forward Brake Control
- Valve Tappet Oil Screen
- spacer between compensator nut and rotor??
- 94 softail custom want to build the motor
- One piece pushrod tubes for Evo Big Twins
- Oil gauge or oil pressure sending unit?
- S&S evo replacement motors
- What's your opinion of this?
- 2-Piece Gas Tank R&R
- Weird electrical gremlin
- The hazards of rural riding...
- Can someone tell me who else sells parts.
- Needing opinions on a bike I'm looking to buy
- Evo Cam Question
- 98 MM Fuel Tanks
- 98 ultra stuttering
- Hard starting problem with S&S Carb
- No fire on rear cylinder
- Which compensator assembly to use?
- Recommend a good Air Cleaner Assembly
- Torque Specs
- Added my LED's
- Evo oil leak at air cleaner and S&S
- Finding Neutral?
- My 1991 Softail
- My 1996 Dyna Convertible
- Ride photos thread
- Fall Riding West Coast Kali Style
- Which witness mark on the crank?
- Need 89 FLHTC Oil Dip Stick Length
- Crane Fireball Hi-4E Ing. Ditch the VOES ?
- Which stator, RR and rotor
- Charging problems
- I.D. this exhaust, will it a Fatboy
- Evo engine swap with TC.
- How is the crankcase vented on an Evo?
- 1994 Ultra - Rear Speaker Cover and Front Brakes
- Super low idle. Sounds cool but......
- Poly or Rubber Riser Bushings?
- Timing Cover Options 1998 EFI
- Air cleaner assembly for 1992 Dyna
- Craigslist jem
- Time for new oil hoses ?
- Wheel pondering
- Fuel Pump for 1996 Ultra Classic
- Can anyone identify this exhaust?
- Trip off to a great start, regulator problems
- Idle questions
- Twin cam
- My first break down, sorta.
- Pre-97 vs Post-97
- New to me evo softail
- Winter Project Came Early
- It's nice to have dependable turn signals again...
- What's your Harley worth?
- Electra glide
- Solo seat for Ultra?
- 92 FXR shift pawl replace list help
- Seat
- zerk fitting
- Rocker, head and base gasket swap
- Turn Signal Button Latch
- brake caliper pin grease
- Clutch chirp (when cold)
- Carb Question '98 Softail
- Need Help Identifying Coil
- Starter issues
- S&S carb on a turbo questions
- Hotop Designs Air Ramp & breather gear tweaks
- Crack near oil sending unit
- What's this 91 worth??
- Saddlebag options for pre-93 Touring
- Sportster Ignition in a Big Twin
- In nearly cleaned my bike...
- Duo glide
- 98 Evo Regulator problem?
- Dashcam on an evo?
- 1986FXWG Points Conversion
- Scored a nice '84 FXRP today
- exhaust cross reference?
- Thinking about selling my 91 evo rather than rebuliding engine
- After only 28 years, I bought another bike.
- Fuel injector question??
- Ultima 113 120 124 127
- tail light 89 FLHS
- 1986 FLHTC oil pressure sending unit packed up
- Frame Lower On 96 RK?
- exhaust question
- Shifter linkage problem
- Top dyna stabilizer link correct set up?
- Witness in a Crime
- Ol Betsy takes a leak Part II
- Burly Slammer shocks
- 1998 Evo leaking oil through rocker cover bolts
- Turn signal canceller bypass?
- EVO help please, oil in bottom end
- Speedometer
- Lighting
- lighter not working....
- Sold the old girl this morning.
- 91 Ultra Rebuild. Running Great...BUT
- Advance retard units
- I hate to ask this question (electrical)
- Clutch/Transmission gremlins.
- More winter ideas-chrome
