PDA
View Full Version : EVO
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79
  1. 1997 road king carb problem
  2. 19”front wheel for a FLSTC
  3. Acorn Nuts
  4. supertrapp on my 1994 flhtcu wont fit?
  5. Tappet Block Alignment Tool
  6. Cam for 1990 FXR
  7. 88 FXR Cam Cover Hardware???
  8. Torrington Cam Bearing
  9. EVO running ruff please help
  10. Oil leak - What Am I Looking at for Repair
  11. 4 years is long enough
  12. 95 FLHTP Exhaust Crack/Breakage Prevention?
  13. I Just Picked My First EVO!
  14. Skoppy Clutch lever
  15. Oil light stays on
  16. 1992 Fat Boy cold start after 3 weeks sitting.
  17. Lepera seat ordering?
  18. Time Sensitive Question...
  19. Pushrod adjustment
  20. Battery Info
  21. Transmission Bearings Project Halted
  22. Last Evo models.
  23. Mainshaft seal and O ring.
  24. Timer Cover
  25. 1999 Harley Davidson Fatboy CAM change
  26. Turn signals not blinking 99 Fatboy
  27. Did any 1996 to 1998 Ultra Classics or Classics come with a carb?
  28. '97 Ultra Classic - Tour Pack Delete - Brake/Signal LED Setup - Pics Pls
  29. Got a call about my engine, today..
  30. Gouged trap door advice
  31. Replacement ignition switch 99 Fatboy
  32. 93 DWG 180 back wheel
  33. Transmission dates, changes
  34. Quickie pushrod disappointment
  35. Wheel Bearings
  36. ss sidewinder exhaust
  37. Oil lines routing looks OK, but no oil pressure
  38. Father/Son weekend project...
  39. Biketronics help
  40. Someone please help me here. Radio memory fuse.
  41. Mustang Seat and Backrest
  42. Softail rear brake line
  43. Well that can't be good...
  44. Cam Bearing ID
  45. The Purple '86 FXRS
  46. 99 FLHTCI Fuel Issue.
  47. 98 superglide motor mounts
  48. New to me 1986 FXRS
  49. Trouble in Paso
  50. Scratch on the cylinders
  51. petcock bung hole question
  52. Some dumb fxr questions
  53. exhaust
  54. '97 Ultra Classic - Tour Pack Delete - Seat & Passenger Backrest Options
  55. Scars on Main Shaft 88 FXRS
  56. Springer Lowering Kit. (BURLY)
  57. Exhaust flange stud advice
  58. Shimming Trans Pully/Sprocket??
  59. Wind chill chart
  60. Picked up a ‘99 Fatboy
  61. CV carb identification.
  62. Info on FXRC paint code??
  63. NOS tank I scored online
  64. Broke clutch adjustment rod?
  65. Tappet question
  66. Oil Slinger Missing
  67. Cam cover gasket change
  68. Wideband for the Evo
  69. Custom 1986 Tour Glide build
  70. Opinions on this 89 Electra Glide on FB please. :)
  71. Button head Allen bolt removal
  72. 93 ultra speedometer drive unit issues
  73. evo electronic igition question
  74. Handlebar switch control swap 91 to 96 question
  75. FXR Shifting Problem
  76. First Evo Build
  77. carb question
  78. FRX Mids parts list
  79. FXR problems...
  80. Stock carb jets?
  81. FXR Question
  82. custom build questions
  83. Retaining Ring in Cam Chest?
  84. Looking for advice removing rear rack on 95 police bike
  85. 1991 dyna air filter cover question
  86. Question about straight Samson mufflers
  87. Merry Christmas from:
  88. Since Everyone's Talkin about the VOES ...
  89. Exhaust baffle wrap material
  90. Winter maintenance....watery gas
  91. Any benefit to keeping the VOES?
  92. Big vibration at idle
  93. Can you Identify this engine sound - '92 FXDC
  94. Mean City Cycles
  95. 1991 E,G tour box table removal and seat mount
  96. Mounted VOES
  97. Ultima 53-644 help please.
  98. Removing horn and bracket, where to put choke cable?
  99. 1998 flhtcui purchase advice
  100. Evo primary covers...
  101. 1995 Road King
  102. Finding a Mechanic
  103. Sportster luggagerack on FXDWG
  104. you can tell its winter
  105. SEH-57 Cam in my Evo
  106. Evo CV carb question
  107. 1999 Evo FXSTC wide tire conversion
  108. Ignition System Went Out.
  109. Not too impressed with copper exhaust gaskets
  110. Thunderheaders
  111. Setting Base Timing
  112. speedometer ??
  113. ‘97 flhr oil change overfill
  114. 91 electra glide
  115. Contemplating a 95 Electra Glide Police Bike Purchase
  116. Fuel gauge glass 98 superglide
  117. 98 flstc starter removal
  118. Evo camshaft inquiry? Who made it!?
  119. new tins
  120. Louvered license plate backing plate
  121. new clutch cable install - now no clutch?
  122. Starter install
  123. Evo differences?
  124. 96'flhtc-charging stator plug removal difficult
  125. evo cam
  126. Is this OEM?
  127. Quick question on Wheel size....
  128. 98 FXDWG - v111 build thread
  129. 1994 Touring stock headpipe
  130. 84-88 rear shocks
  131. 1992 FXDC question
  132. anyone ever snapped a cam?
  133. Coil wiring...
  134. Main jet needle recommendations '93FXRS
  135. 1997 fatboy bobber build
  136. 1990 flhs
  137. Idle Speed Adjustment Inaccessible-Help!
  138. Batwing fairing 91 Electra glide sport
  139. 1988 Electra Glide Classic Project
  140. Mikuni carb fuel hose fitting problem
  141. Transmission Question
  142. Ina bearing
  143. Flat spot
  144. 1991 Sturgis
  145. 91 Fatboy Backfire Issue
  146. Softail nostalgia build progress and questions
  147. New to me evo
  148. Too lean?
  149. Clutch basket with Starter ring gear EVO.
  150. Engine mounts.
  151. FXR Transmissions
  152. Tampa Mural Shot
  153. Need a set of pushrod lock nuts - 3/8" 24 TPI
  154. 1996 electraglide engine swap ?
  155. Evo or not?
  156. Fouling plugs 1995 FXD
  157. Evo no start
  158. Mikuni Help
  159. Nacelle on a Softail.
  160. Evo timing.....
  161. Spark plugs
  162. Electroline style headlight
  163. they mess up my rim seals slide right in, (not good )
  164. Low mileage 95 Fatboy questions
  165. Air Pressure in Handlebars???
  166. LED light into old style 5 3/4 headlight bucket
  167. Pushrod adjustment done? Still spin by hand?
  168. Hardened gunk on intake manifold Is it factory?
  169. Replacing Head Gasket question
  170. Need help identifying Ultima Transmission
  171. '88 FXR Transmission
  172. Engine rebuild update and pics...
  173. Fricking turnsignal question
  174. drag link
  175. Rear Wheel Bearing
  176. Rocker box ?
  177. Rear tire
  178. Help with identifying wheel.
  179. Road King problem!!
  180. Rear Wheel Bearing Spacer
  181. Weld mod original or buy a chopper frame?
  182. Liquid dripping from the wires where the electronics are in the cone
  183. FXR 14”+ shocks experience, advice, photos appreciated
  184. question on fuel tank nipple
  185. Front forks
  186. Thunder Header
  187. FXR intermittent stalling but starts right back up
  188. brown crap just need a verification on something
  189. 1996 Heritage - apparently we don't use mufflers anymore?
  190. Engine locking up...help
  191. 97 heritage
  192. Will FXST slip ons work on my Fatboy
  193. Evo's on the HD Forum list....
  194. Picked up a 95
  195. Fuel spraying from top of fuel pump
  196. Help identifying thunder header
  197. 1996 Dyna Convertible FXDS Fuel Line Diameter (1/4"?)
  198. My 1985 FXRS Better Pics...
  199. Headlight and signals went out in a flash on my FXR
  200. Where you been, Graham?
  201. Looking at a couple of Fatboys
  202. Alma's top-end.......
  203. Energy 1 extra plate kit with + 15% spring - plus "ez boy" type clutch assist kit?
  204. PicK this FXR Apart
  205. Flashback Friday: Free Kustom Cycles' 1990 Evo
  206. Gotta love CL!!
  207. Lost my Wellnuts
  208. 1989 tour glide getting upgraded.
  209. Trans leak
  210. Help Removing Full Gas Tank on 1996 FXDS
  211. Ignition Switch Help!
  212. Harley FXR2
  213. Rear Wheel Component Question
  214. Seat what year/frame
  215. Stock Cross Over Pipes
  216. Oil pump identification
  217. Rocker box gasket sets ?
  218. Burn Run
  219. Total rebuild
  220. Forward Control Extension Kit
  221. Intake issues
  222. Returned to original miles
  223. Size carb
  224. Mikuni carb
  225. new oil leak on 1994 road king
  226. Need help identifying this seat.
  227. 97 wide glide stock cables and bars
  228. Restoring a Nostalgia, need help
  229. 1997 road king won’t start.
  230. One for the parts experts.
  231. No ACC power
  232. ordered my 21 inch rim now to shop tires
  233. custom swingarm and much overdo maintenance
  234. Q: '98 Wideglide numbers?
  235. Cam to match edelbrock performer heads.
  236. Cutting out while cruising, backfiring, then die!
  237. 2 year warranty 100ci ultima
  238. Ignition switch removal on 96 Electra Glide Classic
  239. fuel cap oring
  240. 1994 Dyna FXDL
  241. Mags or spokes.
  242. Mufflers - what is it with parts starting at 1995 CANT find 1994 parts
  243. Question on replacement muffler fitment
  244. Bottom end breathing
  245. Speed sensor---dumb question
  246. Rear Axle Question
  247. lower rocker box
  248. Ultra classic Tourpac bracket broke
  249. “Click Click” Noise when engine/oil is hot
  250. 97 RK Fender lights and odometer staying on
