View Full Version : Exhaust System Topics
- None Vance & Hines FP3 users.
- is a tune / tuner required?
- Vance & Hines Big Shots
- Bub exhaust heat shield springs
- Anyone know where the cats are in a stock 2012 FLSTF?
- Pics of RCXhaust Slash Ups
- Breakouts w/ Vance and Hines Staggered Short Shots
- V&H Monster Round rattles
- can you identify these pipes???
- SOS Rush true dual on 2014 Touring
- 2001 road king
- 2005 exhaust fitment question
- Can you increase air flow without replacing stock mufflers?
- HELP! Exhaust Mod - FuelPak vs. Commander
- do i need to tune?
- 2014 fxdl
- replacement baffles for rinehart 2 into 2 for dyna?
- new 2014 fat boy
- Fuelpak interfering with FOB
- Exhaust help
- hooker tapered tuned flow baffles
- Why is cost of Rinehart 2:1 so high?
- Changing Pipes on 2014 Electra Glide Ultra Limited
- Exhaust/Header Wrap!!! Help!?
- anyone get there samson cholo orders yet?
- Cobra 4in. Slip-Ons
- Big Shot Duals or Pro Pipe
- exhaust
- exhaust question
- Advantages of Full System vs Slip Ons
- DK Thunder Torque Inserts on 2014 FXDB
- Switched from the regular to the quiet baffle
- 2 step, 5 step etc help/info
- '09 Nightster 2.75" pipes.. what baffles?
- Exhaust, air intake and tuner upgrade gone wrong
- Question About Cat Removal
- HELP ! Fuel Moto Headers for Touring HD
- 2 into 2 vs. 2 into 1
- I'm trying to understand
- opinions on slip on's
- Changing age...changing pipes
- Vance & Hines baffle lining loose
- Screamin Eagle pipes on a 2011 Softail Deluxe
- Vance and Hines Big Radius Sound
- street cannons
- Does anyone know who makes these pipes??
- low/mid power reversion.
- Cobra PowerPro HP 2-1 exhaust
- anybody have the long rush full system?
- Fatshotz or Nightsticks ?
- vance and hines twin slash slip on
- tedds cycle true duels
- V&H Chrome Peeling Off
- Chrome plating vs. high polishing: Pros and cons
- New Exhaust question for my wideglide
- Could use a little advice RE: baffles/ decel pop
- thunder header
- 2-1 on new low rider
- How do i restore blue/gold pipes after dyno tune!
- 2014 Fat Bob question
- CFR Exhaust Dealers in MI
- RB Racing exhaust
- FLHTK Exhaust
- Muffler with cat
- Using Permatex Ultra Copper High Temp gasket Maker
- Tuner Suggestions
- Exhaust torque-2013 CVO Breakout 110 inch
- Screamin Eagle Performance Slip-on Baffle Mod
- Advice on which header for 14 ultra limited
- V&H Power Dual fit on 2014 StreetGlide
- 2012 883 iron new exhaust
- Softail Bigshots Fit a Dyna
- Slip on exchange?
- Are My Rineharts junk?
- Springer dual stock headers
- New headpipe option without being louder?
- Street Cannons
- Smoke !!
- Need input on new slip ons
- Relieving heat shields
- fish tail on my ultra classic help
- Going back to Stock exhaust
- heat shield o2 port cut away location....
- 2014 slip ons
- 04 Dyna exhaust help
- Heat Reduction Package
- Exhaust install questions
- Quick Exhaust Question
- V&H PowerDuals & Monster Rounds Question
- Slip-ons, full exhaust, or baffles
- Drag Pipes
- Flange nuts required?
- 2014 Street Glide Headers on previous years?
- Exhaust temps.
- wife get hot foot on right side
- SE Nightstick-L.A. Choppers Adj. End Cap vs. Supertrapp Open End Cap
- Scraped pipe on used 2007 883 custom
- Deep tone mufflers
- engine growl between shifts?
- LSR 2 into 1 Pro Stock no Baffle
- help!
- Header gaskets
- 2009 Softail Custom Exhaust
- V&H Super radius ?
- Ready for some pipes!
- Bassani RoadRage 2-1 Short
- V&H's exhaust gaskets pretty small
- Air Cleaner/Pipes/Tuning Question
- SuperTrapp 2-Into-1 Supermeg Review
- Reuse Stock Flanges
- anyone using rbracing exhaust 2 into 1?
- DBI Chrome Fishtail Slip-Ons Reviews and Questions
- Exhaust cracked due to wrap
- LAF Drag Pipes and O2 Sensors
- Stock Exhaust - 2005 Dyna Wide Glide
- '13 FXDWG exhaust schematic need/advice on baffles
- New Pipes and Check engine light
- Smoke coming out exhaust now?
- rlnehart racing muffs
- Vance and Hines ???
- Airfilter/tuner neccessary with new exhaust?
- 02 sensor bung threads flat
- Just Changed to Rineharts
- Exhaust whistle or ping
- True Duels
- Samson Baffle & Torque Cones
- Question about new exhaust and stock Map & Air cleaner
- here's a question about softail true duals.
- Warranty implications?
- Muffler colouring
- loose muffler
- Questions on Rubber mount?
- V&H exhaust shipping carton size?
- Wide band O 2 sensors .......
- will they fit
- CFR's out....Jackpot 4" Slashcut's in
- Has anyone put a black exhaust on a 2014 SgS Mysterious Red Sunglo?
- Changed mufflers
- Need Help Identifying these slip-ons.
- 07 exhaust on an 01
- installed new exhaust, bike now has weird shake, why???
- Can anyone get the drawings of this exhaust system?
- Need some pointers on removing Fat Cat baffle
- 2-1,2-2,2-1-2 that is the question
- Exhaust advice on 95 inch motor
- Vance & Hines Power Duals Conversion
- Does anyone have experience with the Cobra PowerPro 2-1?
- NEED ADVICE Powercommander/Tuner
- Akrapovic 2 into 1
- Questions / ideas of what to do with my 88TC.. hmm?
- How to get the potato/potato sound
- Need professional guidance
- what size o2 sensor plugs for V&H power duals
- Header pipes causing check engine light
- Which exhaust for 103 with Stage 4 RACE kit?
- Screaming Eagle Pro 2 into 1
- Drago exhaust
- Header pipes for 2012 FLHRC
- Header Pipe
- Head temp vs Exhaust
- Will these pipes fit? Fatboy to Wide Glide
- S&S super G carb sputtering in 2nd
- LA Custom Adjustable End Plate for Supertrapp/Nightstick
- True duals - different sound from left side
- 94 road king headers
- 06 duce go's to full rev will noy idle
- S&S easy strat cams
- petcock posistion
- crusher mufflers
- slipons
- Unsafe Throttle Problem
- timming
- Fuel filter/lines dimensions
- Road King to Heritage header swap
- fuel petcock
- Engine upgrade
- rejet carb
- CFR back pressure question
- stock mufflers
- True Duals vs 2 into 1 into 2 head pipes
- hydraulic cam chain tensioners
- 03 carb EG
- Adding Slip-ons do i need to do anything else?
- Rc components vs Rinehart slip ons?
- true dual conversion
- map or not
- Switching From V&H 2 in 2 to Possibly Short Shots Staggered
- Samson 36" Longtail slip ons
- Sportster misfiring Sice air filter alteration/change.
- Time for a pipe change? 2-1? few questions for you guys
- Rinehart Slimline Duals??
- 2014 A/C 103 cover
- Motor and Frame ID Help, and more.
- exhaust info
- Who makes these????
- Santee Boa Exhaust
- Twin Cam - Catless Stock Header Pipe
- Break in Period
- The Slim is back
- E-Bay Rebuilt Harley Mufflers?
- V & H Drak Cover Turns 'Red-Hot' When Ran.
- 2009 Fat Bob - V&H short shots (video sound clips)
- Foreign object in cam chest, HELP!!
- TC88B tuning and longevity
- S&S 58 throttle body
- looking for a 2 into 1 pipe for a 2014 Slim...any recommendations?
- V&H Power Duals w/ Slash Round slip ons-opinions
- What is this exhaust worth used?
- Cams spin opposite direction?
- Yaffe X pipes real power??
- 06 Streetglide Fuel pump
- V&H slip on question
- 05 FLHRi True Dual Help
- oil reservoir
- 14' 48 Exhaust help
- Breakout kuryakyn ?
- V&H problem
- Rush slip-ons form y 2013 FXDF
- Pro pipe baffel removal
- Building Exhaust
- Valve question, someone help?
- Decking heads for power increase
- Slip on Exhaust Questions
- Cam/Pushrod/Lifter Upgrade for 2012 Street Glide
- drill out 12 mm exhaust sensor bung to 18 mm
- Help , fuel leak on CV carb !
- Louder the better
- S&S 116" EFI throttle body
- Need advice for loud exhaust on '14 Iron
- V&H Pipes, Fuelpak, and Mapping Question
- Got my pipes to sound better - VH Big Shot Duals
- help
- catalytic converters
- Exhaust for 98" Build
- trouble installing new slip ons
- red exhaust wrap
- Need advise on Night Rider Fuel enricher
- '13 FLHR Exhaust/fuel mods
- Any advice to a rookie?
- How loud are the Big Radius 2-1's?
- 09 VS 2010 FLHR exhaust
- Rinehart Slim Line Duals
- Cfr exhaust
- Cobra Slip-Ons
- Vance and Hines big radius 2-2 fitment?
- Heat Cycling
- 2 into 1 slipon/dual slipons -difference ??
- Hi-Volume AC and slips ons - wil I need to re-tune?
